  3. Ethernet Dongle
Ethernet Dongle
voxl-2
20 Posts 4 Posters 4.0k Views 2 Watching
  • B bendraper
    Per the product description it seems that port is also peripheral. Is there any Voxl2 configuration where I can use the UART for external flight controllers and also have a wifi dongle plugged in?
    @bendraper said in Ethernet Dongle:
    Where do you see this as "peripheral"? We need to fix that typo if so. It is certainly a HOST port.
    B 1 Reply Last reply
    • VinnyV Vinny
      B Offline
      B Offline
      bendraper
      @Vinny At this link https://www.modalai.com/products/m0125?variant=40740708876339
      Our USB3.0 / UART Expansion Adapter installs directly onto a VOXL 2 via the legacy board to board connector (J3). Use this board to integrate USB 3 peripheral devices as well as an additional UART for communicating with an external flight controller. This product cannot be used in combination with other daughter boards or modems which are installed onto the legacy or high speed board to board connectors.
      VinnyV 1 Reply Last reply
      • B bendraper
        Hi @bendraper ,
        Sorry for the confusion, we can make that clearer.
        It's trying to say that you can connect peripheral devices to Voxl2.
        So, maybe Instead of
        "Use this board to integrate USB 3 peripheral devices..."
        we can change it to say
        "Use this board to connect USB 3 peripheral devices..."
        Would that help in your opinion?
        Thanks and apologies if that created confusion.
        • H Offline
          H Offline
          Huynh Gremsy
          wrote on last edited by Huynh Gremsy
          #11
          HI @Vinny @tom as you said, we can use ethernet via type C (J9), right? I followed this document to build and flash but my voxl2 can connect ethernet. I writed a post to ask about this, please help me check this my post Thanks a lot for your reply.
          • H Huynh Gremsy
            @Huynh-Gremsy Can you share your output of ifconfig on your voxl?
            H 1 Reply Last reply
              H Offline
              H Offline
              Huynh Gremsy
              yes, please help me check. This is ifconfig when I dont connect ethernet. Because we only an USB-C on board, can not get ifconfig when plug in ethernet (via type C hub)
              bond0: flags=5123<UP,BROADCAST,MASTER,MULTICAST>  mtu 1500
                      ether ee:4f:a8:9e:b0:bc  txqueuelen 1000  (Ethernet)
                      RX packets 0  bytes 0 (0.0 B)
                      TX packets 0  bytes 0 (0.0 B)
              dummy0: flags=195<UP,BROADCAST,RUNNING,NOARP>  mtu 1500
                      inet6 fe80::fe46:ab6d:b90f:6fc7  prefixlen 64  scopeid 0x20<link>
                      ether 72:cb:96:39:af:38  txqueuelen 1000  (Ethernet)
                      TX packets 24  bytes 7120 (7.1 KB)
                      RX packets 329822  bytes 32221264 (32.2 MB)
                      TX packets 329822  bytes 32221264 (32.2 MB)
              • H Huynh Gremsy
                H Offline
                H Offline
                Huynh Gremsy
                @tom log from kernel, I think something is wrong with 88e8000.ssphy in Device Tree. If you know the reason, please let me know. Thanks so much.
                [    1.857505] msm-usb-ssphy-qmp 88e8000.ssphy: Linked as a consumer to regulator.32
                [    1.857519] msm-usb-ssphy-qmp 88e8000.ssphy: Linked as a consumer to regulator.18
                [    1.857525] msm-usb-ssphy-qmp 88e8000.ssphy: failed to get phandle for msm_ssphy_qmp
                [    1.857551] msm-usb-ssphy-qmp 88e8000.ssphy: Dropping the link to regulator.18
                [    1.857563] msm-usb-ssphy-qmp 88e8000.ssphy: Dropping the link to regulator.32
                [    1.857651] msm-usb-ssphy-qmp 88eb000.ssphy: Linked as a consumer to regulator.32
                [    1.857661] msm-usb-ssphy-qmp 88eb000.ssphy: Linked as a consumer to regulator.18
                [    1.860277] msm-dwc3 a600000.ssusb: unable to get ssphy device
                [    1.956294] msm-usb-ssphy-qmp 88e8000.ssphy: Linked as a consumer to regulator.32
                [    1.956311] msm-usb-ssphy-qmp 88e8000.ssphy: Linked as a consumer to regulator.18
                [    1.956316] msm-usb-ssphy-qmp 88e8000.ssphy: failed to get phandle for msm_ssphy_qmp
                [    1.956338] msm-usb-ssphy-qmp 88e8000.ssphy: Dropping the link to regulator.18
                [    1.956346] msm-usb-ssphy-qmp 88e8000.ssphy: Dropping the link to regulator.32
                [    1.958436] msm-dwc3 a600000.ssusb: unable to get ssphy device
                [    2.149607] msm-usb-ssphy-qmp 88e8000.ssphy: Linked as a consumer to regulator.32
                [    2.149618] msm-usb-ssphy-qmp 88e8000.ssphy: Linked as a consumer to regulator.18
                [    2.149623] msm-usb-ssphy-qmp 88e8000.ssphy: failed to get phandle for msm_ssphy_qmp
                [    2.149638] msm-usb-ssphy-qmp 88e8000.ssphy: Dropping the link to regulator.18
                [    2.149648] msm-usb-ssphy-qmp 88e8000.ssphy: Dropping the link to regulator.32
                [    2.150729] msm-dwc3 a600000.ssusb: unable to get ssphy device
                [    2.158708] msm-usb-ssphy-qmp 88e8000.ssphy: Linked as a consumer to regulator.32
                [    2.158716] msm-usb-ssphy-qmp 88e8000.ssphy: Linked as a consumer to regulator.18
                [    2.158721] msm-usb-ssphy-qmp 88e8000.ssphy: No separate ID extcon device
                [    2.162528] msm-usb-ssphy-qmp 88e8000.ssphy: USB DP QMP PHY: Update TYPEC CTRL(2)
                • H Huynh Gremsy
                  @Huynh-Gremsy Apologies, didn't realize you were trying to use the usb-c port, see Vinny's comment here:
                  https://forum.modalai.com/post/8501
                  H 2 Replies Last reply
                    H Offline
                    H Offline
                    Huynh Gremsy
                    @tom Oh, I see Vinny's comment: "on Voxl2, we set that USB-C port as peripheral mode only, so it cannot be a host to any devices such as mass storage (thumb drives), ethernet dongles, and the like."
                    I would like to know if this limitation is from hardware or firmware (changed something in the Device Tree). Thanks for your reply.
                      H Offline
                      H Offline
                      Huynh Gremsy
                      @tom Oh I have a important question, please help me reply soon.
                      I see comment in this post: “ MCCA-M0125 USB3.0 / UART Expansion Adapter” can use to connect to Ethernet. So if it can use MCCA-M0125 USB3.0 / UART Expansion Adapter to connect HDMI. Thanks so much for your reply.
                      • H Huynh Gremsy
                        @Huynh-Gremsy There is no way to get HDMI output, are you trying to use HDMI input? If so you can use an HDMI to USB-A capture card and the HDMI device will enumerate as a UVC camera
                          H Offline
                          H Offline
                          Huynh Gremsy
                          @tom i am asking about HDMI output. I would like to push the frame to the Screen to watch. You mean no way to do that?
                          • H Huynh Gremsy
                            @Huynh-Gremsy No, there is no way to do that. There is no display output
