    Missing Config File
    • Q
      QSL
      I have a Starling 2 we just started getting acquainted with and I am not 100 percent sure what I did. I was being very careful as I am green to much of this but I believe I somehow erased the
      /etc/modalai/voxl-vision-hub.conf
      file. I was using Nano to just look through it but not altering anything. I believe I accidentally closed my terminal window and restarted a new one to then ssh back into Voxl over Wifi.
      When I went back to examine the config file again it was blank....
      See screen shot attached
      I am not sure what to do now in terms of best path to restoring it or steps to reconfiguration that wikl recreate it.
      I also am wondering if I have another instance running on the Voxl that has the file open maybe? If so I power cycled a few times but it still seems to be blank.
      Any assistance would be great!
      Q 1 Reply Last reply Reply Quote 0
      • Q
        QSL @QSL
        @Moderator any insight would be appreciated!
        TIA
          tom admin @QSL
          @QSL I would run voxl-configure-mpa and it'll reset all config files to default
            tom admin @tom
            @tom Or if you don't want to reset all of them, you can just run voxl-configure-vision-hub factory_enable
            • Q
              QSL @tom
              @tom said in Missing Config File:
              thanks. I tried the Sku Wizard then MPA but I seem to still have a blank file when I open it in nano. I will try the factory default next.
