  4. Missing Config File
Missing Config File
5 Posts 2 Posters 861 Views 1 Watching
  • Q Offline
    Q Offline
    QSL
    I have a Starling 2 we just started getting acquainted with and I am not 100 percent sure what I did. I was being very careful as I am green to much of this but I believe I somehow erased the
    /etc/modalai/voxl-vision-hub.conf
    file. I was using Nano to just look through it but not altering anything. I believe I accidentally closed my terminal window and restarted a new one to then ssh back into Voxl over Wifi.
    When I went back to examine the config file again it was blank....
    See screen shot attached
    I am not sure what to do now in terms of best path to restoring it or steps to reconfiguration that wikl recreate it.
    I also am wondering if I have another instance running on the Voxl that has the file open maybe? If so I power cycled a few times but it still seems to be blank.
    Any assistance would be great!
    Q 1 Reply Last reply
    • Q QSL
      Q Offline
      Q Offline
      QSL
      @Moderator any insight would be appreciated!
      TIA
      • Q QSL
        TIA
        @QSL I would run voxl-configure-mpa and it'll reset all config files to default
          @tom Or if you don't want to reset all of them, you can just run voxl-configure-vision-hub factory_enable
            Q Offline
            Q Offline
            QSL
            @tom said in Missing Config File:
            thanks. I tried the Sku Wizard then MPA but I seem to still have a blank file when I open it in nano. I will try the factory default next.
