  3. Starling 2: TOF sensor not recognized by VOXL Portal
starling
28 Posts 3 Posters 7.3k Views 1 Watching
    Hello @hgutier ,
    Can you please provide output of voxl-camera-server -l, which will scan all the connected cameras? You can just list the top part, something like this (just an example). Please note that this command will stop the background camera server service, if it's running, which can be restarted using systemctl start voxl-camera-server or just rebooting voxl2.
    DEBUG:   ----------- Number of cameras: 3
    DEBUG:   Cam idx: 0, Cam slot: 0, Slave Address: 0x0020, Sensor Id: 0x0214
    DEBUG:   Cam idx: 1, Cam slot: 1, Slave Address: 0x0030, Sensor Id: 0x0356
    DEBUG:   Cam idx: 2, Cam slot: 2, Slave Address: 0x0034, Sensor Id: 0x0077
    Also, please list the following contents:
    ls /usr/lib/camera/*sensormodule*
    We will just double check that the software is set up correctly to use the TOF module.
    Thank you
    Hector GutierrezH Offline
    Hector Gutierrez
    Hi Alex - apologies for the long delay. Here is the output I get from voxl-camera-server -l :
    voxl2:/$ voxl-camera-server -l
    DEBUG: ----------- Number of cameras: 0
    DEBUG: Note: This list comes from the HAL module and may not be indicative
    DEBUG: of configurations that have full pipelines
    DEBUG: Number of cameras: 0
    In other words, my drone does not see any cameras at all. The same shows when running VOXL portal (zero cameras).
    I just run apt update && apt upgrade successfully in this drone.
    The other command you mentioned gives the following output:
    voxl2:/$ ls /usr/lib/camera/sensormodule
    /usr/lib/camera/com.qti.sensormodule.imx412_2.bin /usr/lib/camera/com.qti.sensormodule.imx412_3.bin
    Please advise - something is really wrong here since I cant see any of my cameras. My Starling 2 has the camera configuration C27 (triple tracking)
    Thanks, Hector
    • Hector GutierrezH Hector Gutierrez
      Thanks, Hector
      @Hector-Gutierrez , since you have a standard camera configuration, you should run the following command to configure your VOXL2 for C27:
      voxl-configure-cameras 27
      This command should copy the correct sensormodule files to /usr/lib/camera and set up a default config in /etc/modalai/voxl-camera-server.conf for this camera arrangement.
      Hector GutierrezH 1 Reply Last reply
        Hector Gutierrez
        Thanks. The output of voxl-camera-server -l is shown below, but it seems generic. Several issues remain:
        • voxl-camera-server detected 4 cameras, but my drone has 5
        • when opening voxl portal, zero cameras are detected. Also, the IMU plotter runs but gives empty plots.
        Please let me know what to try next - it does seem like a hardware problem.
        Thanks - Regards, Hector
        DEBUG: ----------- Number of cameras: 4
        DEBUG: Cam idx: 0, Cam slot: 0, Slave Address: 0x0030, Sensor Id: 0x0356
        DEBUG: Cam idx: 1, Cam slot: 1, Slave Address: 0x0034, Sensor Id: 0x0577
        DEBUG: Cam idx: 2, Cam slot: 2, Slave Address: 0x0030, Sensor Id: 0x0356
        DEBUG: Cam idx: 3, Cam slot: 6, Slave Address: 0x0030, Sensor Id: 0x0356
        DEBUG: Number of cameras: 4
        Stats for camera: 0
        1280 x 800
        1280 x 800
        1280 x 800 HAL_PIXEL_FORMAT_YCbCr_420_888
        1280 x 800 HAL_PIXEL_FORMAT_BLOB
        1280 x 768 HAL_PIXEL_FORMAT_YCbCr_420_888
        1280 x 768 HAL_PIXEL_FORMAT_BLOB
        1280 x 720 HAL_PIXEL_FORMAT_YCbCr_420_888
        1280 x 720 HAL_PIXEL_FORMAT_BLOB
        1024 x 738 HAL_PIXEL_FORMAT_YCbCr_420_888
        1024 x 738 HAL_PIXEL_FORMAT_BLOB
        1024 x 768 HAL_PIXEL_FORMAT_YCbCr_420_888
        1024 x 768 HAL_PIXEL_FORMAT_BLOB
        864 x 480 HAL_PIXEL_FORMAT_YCbCr_420_888
        864 x 480 HAL_PIXEL_FORMAT_BLOB
        800 x 600 HAL_PIXEL_FORMAT_YCbCr_420_888
        800 x 600 HAL_PIXEL_FORMAT_BLOB
        800 x 480 HAL_PIXEL_FORMAT_YCbCr_420_888
        800 x 480 HAL_PIXEL_FORMAT_BLOB
        720 x 480 HAL_PIXEL_FORMAT_YCbCr_420_888
        720 x 480 HAL_PIXEL_FORMAT_BLOB
        640 x 512 HAL_PIXEL_FORMAT_YCbCr_420_888
        640 x 512 HAL_PIXEL_FORMAT_BLOB
        640 x 480 HAL_PIXEL_FORMAT_YCbCr_420_888
        640 x 480 HAL_PIXEL_FORMAT_BLOB
        640 x 400 HAL_PIXEL_FORMAT_YCbCr_420_888
        640 x 400 HAL_PIXEL_FORMAT_BLOB
        640 x 360 HAL_PIXEL_FORMAT_YCbCr_420_888
        640 x 360 HAL_PIXEL_FORMAT_BLOB
        352 x 288 HAL_PIXEL_FORMAT_YCbCr_420_888
        352 x 288 HAL_PIXEL_FORMAT_BLOB
        320 x 240 HAL_PIXEL_FORMAT_YCbCr_420_888
        320 x 240 HAL_PIXEL_FORMAT_BLOB
        240 x 320 HAL_PIXEL_FORMAT_YCbCr_420_888
        240 x 320 HAL_PIXEL_FORMAT_BLOB
        176 x 144 HAL_PIXEL_FORMAT_YCbCr_420_888
        176 x 144 HAL_PIXEL_FORMAT_BLOB
        1280 x 800 HAL_PIXEL_FORMAT_RAW10
        1280 x 800 HAL_PIXEL_FORMAT_RAW12
        1280 x 800 HAL_PIXEL_FORMAT_RAW16
        1280 x 800 HAL_PIXEL_FORMAT_RAW_OPAQUE
        min = 54
        max = 1596
        1596
        min = 0ns
        max = 1318629735ns
        Stats for camera: 1
        4056 x 3040
        3840 x 2160
        1920 x 1080
        1920 x 1080
        1920 x 1080
        1280 x 720
        1280 x 720
        1280 x 960 HAL_PIXEL_FORMAT_YCbCr_420_888
        1280 x 960 HAL_PIXEL_FORMAT_BLOB
        4056 x 3040 HAL_PIXEL_FORMAT_RAW10
        4056 x 3040 HAL_PIXEL_FORMAT_RAW12
        4056 x 3040 HAL_PIXEL_FORMAT_RAW16
        4056 x 3040 HAL_PIXEL_FORMAT_RAW_OPAQUE
        3840 x 2160 HAL_PIXEL_FORMAT_RAW10
        3840 x 2160 HAL_PIXEL_FORMAT_RAW12
        3840 x 2160 HAL_PIXEL_FORMAT_RAW16
        3840 x 2160 HAL_PIXEL_FORMAT_RAW_OPAQUE
        1920 x 1080 HAL_PIXEL_FORMAT_RAW10
        1920 x 1080 HAL_PIXEL_FORMAT_RAW12
        1920 x 1080 HAL_PIXEL_FORMAT_RAW16
        1920 x 1080 HAL_PIXEL_FORMAT_RAW_OPAQUE
        min = 100
        max = 35200
        2200
        min = 0ns
        max = 243753000ns
        Stats for camera: 2
        1280 x 800
        1280 x 800
        min = 54
        max = 1596
        1596
        min = 0ns
        max = 1318629735ns
        Stats for camera: 3
        1280 x 800
        1280 x 800
        FORMAT_BLOB
        min = 54
        max = 1596
        1596
        min = 0ns
        max = 1318629735ns
        Number of cameras detected: 4
          Stats for camera: 0
          1280 x 800
          1280 x 800
          min = 54
          max = 1596
          1596
          min = 0ns
          max = 1318629735ns
          Stats for camera: 1
          4056 x 3040
          3840 x 2160
          1920 x 1080
          1920 x 1080
          1920 x 1080
          1280 x 720
          1280 x 720
          min = 100
          max = 35200
          2200
          min = 0ns
          max = 243753000ns
          Stats for camera: 2
          1280 x 800
          1280 x 800
          min = 54
          max = 1596
          1596
          min = 0ns
          max = 1318629735ns
          Stats for camera: 3
          1280 x 800
          1280 x 800
          FORMAT_BLOB
          min = 54
          max = 1596
          1596
          min = 0ns
          max = 1318629735ns
          @Hector-Gutierrez ,
          When you were looking for cameras in voxl-portal - was the voxl-camera-server actually running? you need to make sure that it's running (either as a background service, which normally starts up using systemd right after boot, or manually if you are running the camera server in a terminal in the foreground).
          It does look like the 3 AR0144 and 1 IMX412 were detected, so lets first make sure you can view those corresponding streams first.
            @Hector-Gutierrez ,
            Hector Gutierrez
            Yes, voxl-camera-server was running. In fact I stopped it and started it again to be sure it was running.
            I also checked with voxl-inspect-services and it showed the camera server was running. And yet I cannot open any of the cameras on voxl Portal - the portal starts properly but there are no cameras. And also the IMU plots look empty.
            And the ToF sensor is not being detected ...
            Please let me know what to try next.
            Thanks, Hector
              Thanks, Hector
              @Hector-Gutierrez , with the voxl-camera-server running on the foreground, please run the following and monitor the output of voxl-camera-server as well:
              voxl-inspect-cam -a
              This test should connect to ALL the camera streams generated by the voxl-camera-server and print out the stats.
                voxl-inspect-cam -a
                Hector Gutierrez
                Thanks for the prompt reply. I receive the following output:
                Pipe Name | bytes | wide | hgt |exp(ms)| gain | frame id |latency(ms)| fps | mbpt
                | hires_large_color |18495360 | 4056 | 3040 | 16.67 | 747 | 1880 | 93.2 | 30.0 | 44422
                | hires_large_encoded | 2064 | 4056 | 3040 | 16.67 | 747 | 1879 | 100.0 | 30.0 | 0
                | hires_large_grey |12330240 | 4056 | 3040 | 16.67 | 747 | 1880 | 72.2 | 30.0 | 29618
                | hires_small_color | 1179648 | 1024 | 768 | 16.67 | 747 | 1880 | 50.4 | 30.0 | 2832
                | hires_small_encoded | 256 | 1024 | 768 | 16.67 | 747 | 1880 | 61.6 | 30.0 | 0
                | hires_small_grey | 786432 | 1024 | 768 | 16.67 | 747 | 1881 | 48.4 | 30.0 | 1888
                | hires_snapshot |
                | ov_overlay | 3235840 | 1280 | 2528 | 6.81 | 614 | 1640 | 84.2 | 4.7 | 1228
                | tracking_down | 1024000 | 1280 | 800 | 6.90 | 614 | 1647 | 34.1 | 30.0 | 2458
                | tracking_down_bayer | 1024000 | 1280 | 800 | 6.90 | 614 | 1647 | 33.7 | 30.0 | 2458
                | tracking_down_misp_grey | 1024000 | 1280 | 800 | 6.73 | 570 | 1648 | 33.3 | 30.0 | 2458
                | tracking_down_misp_norm | 1024000 | 1280 | 800 | 6.73 | 570 | 1648 | 36.3 | 30.0 | 2458
                | tracking_front | 1024000 | 1280 | 800 | 5.63 | 307 | 1648 | 33.5 | 30.0 | 2458
                | tracking_front_bayer | 1024000 | 1280 | 800 | 5.63 | 307 | 1648 | 33.7 | 30.0 | 2458
                | tracking_front_misp_grey | 1024000 | 1280 | 800 | 5.63 | 307 | 1648 | 30.2 | 30.0 | 2458
                | tracking_front_misp_norm | 1024000 | 1280 | 800 | 5.63 | 307 | 1648 | 35.5 | 30.0 | 2458
                | tracking_rear | 1024000 | 1280 | 800 | 5.32 | 192 | 1649 | 33.9 | 30.0 | 2458
                | tracking_rear_bayer | 1024000 | 1280 | 800 | 5.32 | 192 | 1649 | 33.1 | 30.0 | 2458
                | tracking_rear_misp_grey | 1024000 | 1280 | 800 | 5.32 | 192 | 1649 | 31.5 | 30.0 | 2458
                | tracking_rear_misp_norm | 1024000 | 1280 | 800 | 5.32 | 192 | 1649 | 35.1 | 30.0 | 2458
                Still dont see the ToF sensor ... Please advise
                Thanks, Hector
                  | hires_snapshot |
                  Thanks, Hector
                  @Hector-Gutierrez ,
                  OK, so it looks like that the 4 detected cameras are actually streaming data.
                  I am not sure why voxl-portal is not showing any cameras. When you access the voxl-portal via browser, do you see the actual portal (with green menu bar at the top), but no cameras are listed in the Cameras section?
                  How are you connected to the drone? (wifi, adb, etc).
                  Regarding the TOF sensor, since voxl-camera-server -l did not show that the TOF sensor is detected, the stream is not available.
                  Please double check that com.qti.sensormodule.irs2975c* file is in /usr/lib/camera/ directory - please provide the exact name or let me know if it's missing.
                  Also, can you please take a picture of your cameras plugged into the M0173 camera front end? I just want to make sure the TOF sensor is plugged in correctly.
                    @Hector-Gutierrez ,
                    Hector Gutierrez
                    Hi Alex, I disassembled and reassembled the camera board and now I get 4 cameras in VOXL Portal ! I did reconnect the ToF sensor as well to the camera board, it seems properly connected.
                    The cameras working well are hires_large_color, and all three tracking cameras. I still dont see the ToF sensor , and the view of the hires camera is blurry (out of focus). The hires camera was recently replaced, so how to get it into focus is another question.
                    I listed the files on /usr/lib/camera and found this file: com.qti.sensormodule.irs2975c_3.bin
                    So now we are down to the ToF sensor (and to put the hires camera in focus). Let me know what to try next !
                    thanks, Hector
                    Alex KushleyevA Hector GutierrezH 2 Replies Last reply
                      thanks, Hector
                      @Hector-Gutierrez , in order to focus the hires camera (I am assuming IMX412), you can twist the lens in the M12 lens holder. Normally we do focus the hires cameras to a norminal focus distance, but maybe you had one from earlier batch which was not focused. Also, focus of the camera depends on the application, so it is recommended for users to double check and correct the focus for their needs. If there is some sealant on the threads, it is not permanent and can be removed using tweezers - loosening it up a bit should allow you to twist the lens inside the holder.
                      Regarding the PMD TOF, not sure yet. Has it worked before?
                        thanks, Hector
                        Hector Gutierrez
                        @Hector-Gutierrez
                        Hi Alex - As you suggested, the focus issue was resolved by twisting the lens until good focus at 3 m. was achieved.
                        The TOF sensor remains a problem. I've tried detaching and reconnecting its cable (on both ends) but no luck so far.
                        Both VOXL Portal and voxl-camera-server -l only see 4 cameras.
                        We didnt use the TOF sensor before so I didnt notice if it was working previously or not.
                        Please let me know what to try next - thanks, Hector
                          @Hector-Gutierrez
                          @Hector-Gutierrez , can you please send a picture of the TOF sensor connected to M0173? Just to make sure the connections are correct.
                            Hector Gutierrez
                            Hi Alex - attached are some pictures of the connection. Something odd is happening. The connector engages its socket in two different locations relative to the hole for the screw. In the centered location (where it should be!) the TOF sensor causes a power short and the drone wont boot (see picture with red LED). In the off-center location there is no short and the drone boots, but I only get 4 cameras and the TOF is not visible.
                            ![centered.jpg](Request Entity Too Large) ![off-center1.jpg](Request Entity Too Large) ![off-center2.jpg](Request Entity Too Large) ![power-short.jpg](Request Entity Too Large)
                              Hector Gutierrez
                              @Hector-Gutierrez
                              Download link for the pictures in case they did not attach to previous message:
                              https://quickconnect.to/asapstorage/d/s/13iMi9oRZUxhkQYoW2DCHtZ7nI9HgYJx/bj3PLF8EXd5pKdKgwphVqcbD7VaaMBQX-V7WAgk58WAw
                                @Hector-Gutierrez
                                Hector Gutierrez
                                @Hector-Gutierrez
                                Update from my previous post. I install the TOF connector in the centered location and fully attach the screws (including the one that secures the TOF ribbon cable). There is no short, the drone start normally, and I get 4 cameras on VOXL portal, but no TOF. Also voxl-camera-server -l only see 4 cameras. So TOF connection is definitely Ok, but sensor not present.
                                  @Hector-Gutierrez
                                  @Hector-Gutierrez , I am sorry, i was not able to access the image you shared. Can you please just resize / crop the image so that it fits into the forum? Just please make sure the details are still easy to see.
                                  Thank you!
                                    Thank you!
                                    Hector Gutierrez
                                    After installing the TOF connector in the centered location and fully attach all the screws (including the one that secures the TOF ribbon cable), there is no short and the drone starts normally. I get 4 cameras on VOXL portal, but no TOF. Also voxl-camera-server -l only see 4 cameras. So TOF connection seems definitely Ok, but sensor not present. Seems to me like a bad TOF sensor - let me know your thoughts.
                                      Hector Gutierrez
                                      @Hector-Gutierrez Clarification on the pictures. The top picture is the centered position of the TOF ribbon cable. The bottom picture can be disregarded. The connection is done on the centered position (top picture). Thanks.
                                        Thank you!
                                        Hector Gutierrez
                                        @Alex-Kushleyev - Any updates on this thread ? Let me know if there is anything else I could try or if you consider this a hardware problem with the PMD sensor itself. Thanks, Hector
                                          @Hector-Gutierrez , sorry about the delay.. Before submitting RMA (i will provide instructions), can you please share the output of dmesg after you run voxl-camera-server -l ? this will let me confirm that there is an attempt to ping the TOF sensor and it fails. You could save the output of dmesg into a text file and share it or paste it here.
                                          A successful dmesg output should look something like this (this is from a Starling 2 Max), which has an extra IMX412 camera:
                                          [ 1712.362675] CAM_ERR: CAM-MEM: cam_mem_mgr_create_debug_fs: 126 failed to create dentry
                                          [ 1712.383711] CAM_INFO: CAM-HFI: cam_hfi_init: 878 Init IO1 : [0x10c00000 0xcf300000] IO2 [0xe0200000 0x1ed00000]
                                          [ 1712.393864] CAM_INFO: CAM-ICP: cam_icp_mgr_process_dbg_buf: 2572 FW_DBG:CICP_FW_E : HFI  :QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079,OEM_IMAGE_VERSION_STRING=CRM,BUILD_TIME: Oct 17 2019 05:49:19,CACHE_ENABLED at icphostinterface.c:636 QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079 OEM_IMAGE_VERSION_STRING=CRM
                                          [ 1712.393868] CAM_INFO: CAM-ICP: cam_icp_mgr_process_dbg_buf: 2572 FW_DBG:CICP_FW_E : HFI  :ELF variant: CACHE-ENABLED:T480:API_V2:USE_CDM_1_1: , API version: 0x2000049 at icphostinterface.c:637 QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079 OEM_IMAGE_VERSION_STRING=CRM
                                          [ 1712.393916] CAM_INFO: CAM-ICP: cam_icp_mgr_hw_open: 3879 FW download done successfully
                                          [ 1712.470777] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Linked as a consumer to regulator.58
                                          [ 1712.472096] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Linked as a consumer to regulator.56
                                          [ 1712.474369] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Linked as a consumer to regulator.60
                                          [ 1712.474408] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Linked as a consumer to regulator.79
                                          [ 1712.498846] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 918 Probe success,slot:0,slave_addr:0x30,sensor_id:0x356
                                          [ 1712.498997] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.79
                                          [ 1712.502731] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.60
                                          [ 1712.502868] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.56
                                          [ 1712.502981] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.58
                                          [ 1712.526976] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Linked as a consumer to regulator.58
                                          [ 1712.527116] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Linked as a consumer to regulator.60
                                          [ 1712.527175] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Linked as a consumer to regulator.56
                                          [ 1712.527326] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Linked as a consumer to regulator.79
                                          [ 1712.541852] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 918 Probe success,slot:1,slave_addr:0x34,sensor_id:0x577
                                          [ 1712.541967] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Dropping the link to regulator.79
                                          [ 1712.543257] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Dropping the link to regulator.56
                                          [ 1712.543316] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Dropping the link to regulator.60
                                          [ 1712.543392] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Dropping the link to regulator.58
                                          [ 1712.561608] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.60
                                          [ 1712.563718] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.59
                                          [ 1712.565875] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.55
                                          [ 1712.567770] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.79
                                          [ 1712.575483] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 918 Probe success,slot:3,slave_addr:0x7a,sensor_id:0x2975
                                          [ 1712.577616] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.79
                                          [ 1712.579717] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.55
                                          [ 1712.579758] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.60
                                          [ 1712.579812] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.59
                                          [ 1712.604128] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Linked as a consumer to regulator.58
                                          [ 1712.606318] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Linked as a consumer to regulator.56
                                          [ 1712.608394] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Linked as a consumer to regulator.60
                                          [ 1712.608473] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Linked as a consumer to regulator.79
                                          [ 1712.631999] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 918 Probe success,slot:6,slave_addr:0x30,sensor_id:0x356
                                          [ 1712.632517] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Dropping the link to regulator.79
                                          [ 1712.636492] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Dropping the link to regulator.60
                                          [ 1712.636595] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Dropping the link to regulator.56
                                          [ 1712.636686] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Dropping the link to regulator.58
                                          [ 1712.662182] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.59
                                          [ 1712.662338] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.60
                                          [ 1712.662399] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.56
                                          [ 1712.662543] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.79
                                          [ 1712.677605] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 918 Probe success,slot:2,slave_addr:0x34,sensor_id:0x577
                                          [ 1712.677728] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.79
                                          [ 1712.679699] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.56
                                          [ 1712.679736] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.60
                                          [ 1712.679789] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.59
                                          [ 1712.739998] CAM_WARN: CAM-CRM: cam_req_mgr_close: 160 release invoked associated userspace process has died
                                          Specifically, the following line says that the TOF sensor has been probed successfully:
                                          If the probe fails, you would see some CCI errors. If you do not see anything related to slave address 0x7a , the the sensor is not being probed and the issue is on the SW configuration side, which we can investigate further.
