  3. Starling 2: TOF sensor not recognized by VOXL Portal
starling
28 Posts 3 Posters 7.3k Views 1 Watching
    @Hector-Gutierrez , since you have a standard camera configuration, you should run the following command to configure your VOXL2 for C27:
    voxl-configure-cameras 27
    This command should copy the correct sensormodule files to /usr/lib/camera and set up a default config in /etc/modalai/voxl-camera-server.conf for this camera arrangement.
    Hector GutierrezH Offline
    Hector Gutierrez
    Thanks. The output of voxl-camera-server -l is shown below, but it seems generic. Several issues remain:
    • voxl-camera-server detected 4 cameras, but my drone has 5
    • when opening voxl portal, zero cameras are detected. Also, the IMU plotter runs but gives empty plots.
    Please let me know what to try next - it does seem like a hardware problem.
    Thanks - Regards, Hector
    voxl2:/$ voxl-camera-server -l
    DEBUG: Attempting to open the hal module
    DEBUG: SUCCESS: Camera module opened on attempt 0
    DEBUG: ----------- Number of cameras: 4
    DEBUG: Cam idx: 0, Cam slot: 0, Slave Address: 0x0030, Sensor Id: 0x0356
    DEBUG: Cam idx: 1, Cam slot: 1, Slave Address: 0x0034, Sensor Id: 0x0577
    DEBUG: Cam idx: 2, Cam slot: 2, Slave Address: 0x0030, Sensor Id: 0x0356
    DEBUG: Cam idx: 3, Cam slot: 6, Slave Address: 0x0030, Sensor Id: 0x0356
    DEBUG: Note: This list comes from the HAL module and may not be indicative
    DEBUG: of configurations that have full pipelines
    DEBUG: Number of cameras: 4
    Stats for camera: 0
    1280 x 800
    1280 x 800
    1280 x 800 HAL_PIXEL_FORMAT_YCbCr_420_888
    1280 x 800 HAL_PIXEL_FORMAT_BLOB
    1280 x 768 HAL_PIXEL_FORMAT_YCbCr_420_888
    1280 x 768 HAL_PIXEL_FORMAT_BLOB
    1280 x 720 HAL_PIXEL_FORMAT_YCbCr_420_888
    1280 x 720 HAL_PIXEL_FORMAT_BLOB
    1024 x 738 HAL_PIXEL_FORMAT_YCbCr_420_888
    1024 x 738 HAL_PIXEL_FORMAT_BLOB
    1024 x 768 HAL_PIXEL_FORMAT_YCbCr_420_888
    1024 x 768 HAL_PIXEL_FORMAT_BLOB
    864 x 480 HAL_PIXEL_FORMAT_YCbCr_420_888
    864 x 480 HAL_PIXEL_FORMAT_BLOB
    800 x 600 HAL_PIXEL_FORMAT_YCbCr_420_888
    800 x 600 HAL_PIXEL_FORMAT_BLOB
    800 x 480 HAL_PIXEL_FORMAT_YCbCr_420_888
    800 x 480 HAL_PIXEL_FORMAT_BLOB
    720 x 480 HAL_PIXEL_FORMAT_YCbCr_420_888
    720 x 480 HAL_PIXEL_FORMAT_BLOB
    640 x 512 HAL_PIXEL_FORMAT_YCbCr_420_888
    640 x 512 HAL_PIXEL_FORMAT_BLOB
    640 x 480 HAL_PIXEL_FORMAT_YCbCr_420_888
    640 x 480 HAL_PIXEL_FORMAT_BLOB
    640 x 400 HAL_PIXEL_FORMAT_YCbCr_420_888
    640 x 400 HAL_PIXEL_FORMAT_BLOB
    640 x 360 HAL_PIXEL_FORMAT_YCbCr_420_888
    640 x 360 HAL_PIXEL_FORMAT_BLOB
    352 x 288 HAL_PIXEL_FORMAT_YCbCr_420_888
    352 x 288 HAL_PIXEL_FORMAT_BLOB
    320 x 240 HAL_PIXEL_FORMAT_YCbCr_420_888
    320 x 240 HAL_PIXEL_FORMAT_BLOB
    240 x 320 HAL_PIXEL_FORMAT_YCbCr_420_888
    240 x 320 HAL_PIXEL_FORMAT_BLOB
    176 x 144 HAL_PIXEL_FORMAT_YCbCr_420_888
    176 x 144 HAL_PIXEL_FORMAT_BLOB
    1280 x 800 HAL_PIXEL_FORMAT_RAW10
    1280 x 800 HAL_PIXEL_FORMAT_RAW12
    1280 x 800 HAL_PIXEL_FORMAT_RAW16
    1280 x 800 HAL_PIXEL_FORMAT_RAW_OPAQUE
    min = 54
    max = 1596
    1596
    min = 0ns
    max = 1318629735ns
    Stats for camera: 1
    4056 x 3040
    3840 x 2160
    1920 x 1080
    1920 x 1080
    1920 x 1080
    1280 x 720
    1280 x 720
    1280 x 960 HAL_PIXEL_FORMAT_YCbCr_420_888
    1280 x 960 HAL_PIXEL_FORMAT_BLOB
    4056 x 3040 HAL_PIXEL_FORMAT_RAW10
    4056 x 3040 HAL_PIXEL_FORMAT_RAW12
    4056 x 3040 HAL_PIXEL_FORMAT_RAW16
    4056 x 3040 HAL_PIXEL_FORMAT_RAW_OPAQUE
    3840 x 2160 HAL_PIXEL_FORMAT_RAW10
    3840 x 2160 HAL_PIXEL_FORMAT_RAW12
    3840 x 2160 HAL_PIXEL_FORMAT_RAW16
    3840 x 2160 HAL_PIXEL_FORMAT_RAW_OPAQUE
    1920 x 1080 HAL_PIXEL_FORMAT_RAW10
    1920 x 1080 HAL_PIXEL_FORMAT_RAW12
    1920 x 1080 HAL_PIXEL_FORMAT_RAW16
    1920 x 1080 HAL_PIXEL_FORMAT_RAW_OPAQUE
    min = 100
    max = 35200
    2200
    min = 0ns
    max = 243753000ns
    Stats for camera: 2
    1280 x 800
    1280 x 800
    min = 54
    max = 1596
    1596
    min = 0ns
    max = 1318629735ns
    Stats for camera: 3
    1280 x 800
    1280 x 800
    FORMAT_BLOB
    min = 54
    max = 1596
    1596
    min = 0ns
    max = 1318629735ns
    Number of cameras detected: 4
    • Hector GutierrezH Hector Gutierrez
      Stats for camera: 0
      1280 x 800
      1280 x 800
      min = 54
      max = 1596
      1596
      min = 0ns
      max = 1318629735ns
      Stats for camera: 1
      4056 x 3040
      3840 x 2160
      1920 x 1080
      1920 x 1080
      1920 x 1080
      1280 x 720
      1280 x 720
      min = 100
      max = 35200
      2200
      min = 0ns
      max = 243753000ns
      Stats for camera: 2
      1280 x 800
      1280 x 800
      min = 54
      max = 1596
      1596
      min = 0ns
      max = 1318629735ns
      Stats for camera: 3
      1280 x 800
      1280 x 800
      FORMAT_BLOB
      min = 54
      max = 1596
      1596
      min = 0ns
      max = 1318629735ns
      Alex KushleyevA Online
      @Hector-Gutierrez ,
      When you were looking for cameras in voxl-portal - was the voxl-camera-server actually running? you need to make sure that it's running (either as a background service, which normally starts up using systemd right after boot, or manually if you are running the camera server in a terminal in the foreground).
      It does look like the 3 AR0144 and 1 IMX412 were detected, so lets first make sure you can view those corresponding streams first.
      Hector GutierrezH 1 Reply Last reply
        @Hector-Gutierrez ,
        Hector Gutierrez
        Yes, voxl-camera-server was running. In fact I stopped it and started it again to be sure it was running.
        I also checked with voxl-inspect-services and it showed the camera server was running. And yet I cannot open any of the cameras on voxl Portal - the portal starts properly but there are no cameras. And also the IMU plots look empty.
        And the ToF sensor is not being detected ...
        Please let me know what to try next.
        Thanks, Hector
          Thanks, Hector
          @Hector-Gutierrez , with the voxl-camera-server running on the foreground, please run the following and monitor the output of voxl-camera-server as well:
          voxl-inspect-cam -a
          This test should connect to ALL the camera streams generated by the voxl-camera-server and print out the stats.
            voxl-inspect-cam -a
            Hector Gutierrez
            Thanks for the prompt reply. I receive the following output:
            Pipe Name | bytes | wide | hgt |exp(ms)| gain | frame id |latency(ms)| fps | mbpt
            | hires_large_color |18495360 | 4056 | 3040 | 16.67 | 747 | 1880 | 93.2 | 30.0 | 44422
            | hires_large_encoded | 2064 | 4056 | 3040 | 16.67 | 747 | 1879 | 100.0 | 30.0 | 0
            | hires_large_grey |12330240 | 4056 | 3040 | 16.67 | 747 | 1880 | 72.2 | 30.0 | 29618
            | hires_small_color | 1179648 | 1024 | 768 | 16.67 | 747 | 1880 | 50.4 | 30.0 | 2832
            | hires_small_encoded | 256 | 1024 | 768 | 16.67 | 747 | 1880 | 61.6 | 30.0 | 0
            | hires_small_grey | 786432 | 1024 | 768 | 16.67 | 747 | 1881 | 48.4 | 30.0 | 1888
            | hires_snapshot |
            | ov_overlay | 3235840 | 1280 | 2528 | 6.81 | 614 | 1640 | 84.2 | 4.7 | 1228
            | tracking_down | 1024000 | 1280 | 800 | 6.90 | 614 | 1647 | 34.1 | 30.0 | 2458
            | tracking_down_bayer | 1024000 | 1280 | 800 | 6.90 | 614 | 1647 | 33.7 | 30.0 | 2458
            | tracking_down_misp_grey | 1024000 | 1280 | 800 | 6.73 | 570 | 1648 | 33.3 | 30.0 | 2458
            | tracking_down_misp_norm | 1024000 | 1280 | 800 | 6.73 | 570 | 1648 | 36.3 | 30.0 | 2458
            | tracking_front | 1024000 | 1280 | 800 | 5.63 | 307 | 1648 | 33.5 | 30.0 | 2458
            | tracking_front_bayer | 1024000 | 1280 | 800 | 5.63 | 307 | 1648 | 33.7 | 30.0 | 2458
            | tracking_front_misp_grey | 1024000 | 1280 | 800 | 5.63 | 307 | 1648 | 30.2 | 30.0 | 2458
            | tracking_front_misp_norm | 1024000 | 1280 | 800 | 5.63 | 307 | 1648 | 35.5 | 30.0 | 2458
            | tracking_rear | 1024000 | 1280 | 800 | 5.32 | 192 | 1649 | 33.9 | 30.0 | 2458
            | tracking_rear_bayer | 1024000 | 1280 | 800 | 5.32 | 192 | 1649 | 33.1 | 30.0 | 2458
            | tracking_rear_misp_grey | 1024000 | 1280 | 800 | 5.32 | 192 | 1649 | 31.5 | 30.0 | 2458
            | tracking_rear_misp_norm | 1024000 | 1280 | 800 | 5.32 | 192 | 1649 | 35.1 | 30.0 | 2458
            Still dont see the ToF sensor ... Please advise
            Thanks, Hector
              | hires_snapshot |
              Thanks, Hector
              @Hector-Gutierrez ,
              OK, so it looks like that the 4 detected cameras are actually streaming data.
              I am not sure why voxl-portal is not showing any cameras. When you access the voxl-portal via browser, do you see the actual portal (with green menu bar at the top), but no cameras are listed in the Cameras section?
              How are you connected to the drone? (wifi, adb, etc).
              Regarding the TOF sensor, since voxl-camera-server -l did not show that the TOF sensor is detected, the stream is not available.
              Please double check that com.qti.sensormodule.irs2975c* file is in /usr/lib/camera/ directory - please provide the exact name or let me know if it's missing.
              Also, can you please take a picture of your cameras plugged into the M0173 camera front end? I just want to make sure the TOF sensor is plugged in correctly.
                @Hector-Gutierrez ,
                Hector Gutierrez
                Hi Alex, I disassembled and reassembled the camera board and now I get 4 cameras in VOXL Portal ! I did reconnect the ToF sensor as well to the camera board, it seems properly connected.
                The cameras working well are hires_large_color, and all three tracking cameras. I still dont see the ToF sensor , and the view of the hires camera is blurry (out of focus). The hires camera was recently replaced, so how to get it into focus is another question.
                I listed the files on /usr/lib/camera and found this file: com.qti.sensormodule.irs2975c_3.bin
                So now we are down to the ToF sensor (and to put the hires camera in focus). Let me know what to try next !
                thanks, Hector
                Alex KushleyevA Hector GutierrezH 2 Replies Last reply
                  thanks, Hector
                  @Hector-Gutierrez , in order to focus the hires camera (I am assuming IMX412), you can twist the lens in the M12 lens holder. Normally we do focus the hires cameras to a norminal focus distance, but maybe you had one from earlier batch which was not focused. Also, focus of the camera depends on the application, so it is recommended for users to double check and correct the focus for their needs. If there is some sealant on the threads, it is not permanent and can be removed using tweezers - loosening it up a bit should allow you to twist the lens inside the holder.
                  Regarding the PMD TOF, not sure yet. Has it worked before?
                    thanks, Hector
                    Hector Gutierrez
                    @Hector-Gutierrez
                    Hi Alex - As you suggested, the focus issue was resolved by twisting the lens until good focus at 3 m. was achieved.
                    The TOF sensor remains a problem. I've tried detaching and reconnecting its cable (on both ends) but no luck so far.
                    Both VOXL Portal and voxl-camera-server -l only see 4 cameras.
                    We didnt use the TOF sensor before so I didnt notice if it was working previously or not.
                    Please let me know what to try next - thanks, Hector
                      @Hector-Gutierrez
                      @Hector-Gutierrez , can you please send a picture of the TOF sensor connected to M0173? Just to make sure the connections are correct.
                        Hector Gutierrez
                        Hi Alex - attached are some pictures of the connection. Something odd is happening. The connector engages its socket in two different locations relative to the hole for the screw. In the centered location (where it should be!) the TOF sensor causes a power short and the drone wont boot (see picture with red LED). In the off-center location there is no short and the drone boots, but I only get 4 cameras and the TOF is not visible.
                        ![centered.jpg](Request Entity Too Large) ![off-center1.jpg](Request Entity Too Large) ![off-center2.jpg](Request Entity Too Large) ![power-short.jpg](Request Entity Too Large)
                          Hector Gutierrez
                          @Hector-Gutierrez
                          Download link for the pictures in case they did not attach to previous message:
                          https://quickconnect.to/asapstorage/d/s/13iMi9oRZUxhkQYoW2DCHtZ7nI9HgYJx/bj3PLF8EXd5pKdKgwphVqcbD7VaaMBQX-V7WAgk58WAw
                            @Hector-Gutierrez
                            Hector Gutierrez
                            @Hector-Gutierrez
                            Update from my previous post. I install the TOF connector in the centered location and fully attach the screws (including the one that secures the TOF ribbon cable). There is no short, the drone start normally, and I get 4 cameras on VOXL portal, but no TOF. Also voxl-camera-server -l only see 4 cameras. So TOF connection is definitely Ok, but sensor not present.
                              @Hector-Gutierrez
                              @Hector-Gutierrez , I am sorry, i was not able to access the image you shared. Can you please just resize / crop the image so that it fits into the forum? Just please make sure the details are still easy to see.
                              Thank you!
                                Thank you!
                                Hector Gutierrez
                                After installing the TOF connector in the centered location and fully attach all the screws (including the one that secures the TOF ribbon cable), there is no short and the drone starts normally. I get 4 cameras on VOXL portal, but no TOF. Also voxl-camera-server -l only see 4 cameras. So TOF connection seems definitely Ok, but sensor not present. Seems to me like a bad TOF sensor - let me know your thoughts.
                                  Hector Gutierrez
                                  @Hector-Gutierrez Clarification on the pictures. The top picture is the centered position of the TOF ribbon cable. The bottom picture can be disregarded. The connection is done on the centered position (top picture). Thanks.
                                    Thank you!
                                    Hector Gutierrez
                                    @Alex-Kushleyev - Any updates on this thread ? Let me know if there is anything else I could try or if you consider this a hardware problem with the PMD sensor itself. Thanks, Hector
                                      @Hector-Gutierrez , sorry about the delay.. Before submitting RMA (i will provide instructions), can you please share the output of dmesg after you run voxl-camera-server -l ? this will let me confirm that there is an attempt to ping the TOF sensor and it fails. You could save the output of dmesg into a text file and share it or paste it here.
                                      A successful dmesg output should look something like this (this is from a Starling 2 Max), which has an extra IMX412 camera:
                                      [ 1712.362675] CAM_ERR: CAM-MEM: cam_mem_mgr_create_debug_fs: 126 failed to create dentry
                                      [ 1712.383711] CAM_INFO: CAM-HFI: cam_hfi_init: 878 Init IO1 : [0x10c00000 0xcf300000] IO2 [0xe0200000 0x1ed00000]
                                      [ 1712.393864] CAM_INFO: CAM-ICP: cam_icp_mgr_process_dbg_buf: 2572 FW_DBG:CICP_FW_E : HFI  :QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079,OEM_IMAGE_VERSION_STRING=CRM,BUILD_TIME: Oct 17 2019 05:49:19,CACHE_ENABLED at icphostinterface.c:636 QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079 OEM_IMAGE_VERSION_STRING=CRM
                                      [ 1712.393868] CAM_INFO: CAM-ICP: cam_icp_mgr_process_dbg_buf: 2572 FW_DBG:CICP_FW_E : HFI  :ELF variant: CACHE-ENABLED:T480:API_V2:USE_CDM_1_1: , API version: 0x2000049 at icphostinterface.c:637 QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079 OEM_IMAGE_VERSION_STRING=CRM
                                      [ 1712.393916] CAM_INFO: CAM-ICP: cam_icp_mgr_hw_open: 3879 FW download done successfully
                                      [ 1712.470777] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Linked as a consumer to regulator.58
                                      [ 1712.472096] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Linked as a consumer to regulator.56
                                      [ 1712.474369] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Linked as a consumer to regulator.60
                                      [ 1712.474408] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Linked as a consumer to regulator.79
                                      [ 1712.498846] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 918 Probe success,slot:0,slave_addr:0x30,sensor_id:0x356
                                      [ 1712.498997] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.79
                                      [ 1712.502731] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.60
                                      [ 1712.502868] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.56
                                      [ 1712.502981] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.58
                                      [ 1712.526976] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Linked as a consumer to regulator.58
                                      [ 1712.527116] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Linked as a consumer to regulator.60
                                      [ 1712.527175] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Linked as a consumer to regulator.56
                                      [ 1712.527326] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Linked as a consumer to regulator.79
                                      [ 1712.541852] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 918 Probe success,slot:1,slave_addr:0x34,sensor_id:0x577
                                      [ 1712.541967] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Dropping the link to regulator.79
                                      [ 1712.543257] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Dropping the link to regulator.56
                                      [ 1712.543316] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Dropping the link to regulator.60
                                      [ 1712.543392] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Dropping the link to regulator.58
                                      [ 1712.561608] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.60
                                      [ 1712.563718] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.59
                                      [ 1712.565875] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.55
                                      [ 1712.567770] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.79
                                      [ 1712.575483] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 918 Probe success,slot:3,slave_addr:0x7a,sensor_id:0x2975
                                      [ 1712.577616] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.79
                                      [ 1712.579717] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.55
                                      [ 1712.579758] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.60
                                      [ 1712.579812] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.59
                                      [ 1712.604128] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Linked as a consumer to regulator.58
                                      [ 1712.606318] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Linked as a consumer to regulator.56
                                      [ 1712.608394] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Linked as a consumer to regulator.60
                                      [ 1712.608473] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Linked as a consumer to regulator.79
                                      [ 1712.631999] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 918 Probe success,slot:6,slave_addr:0x30,sensor_id:0x356
                                      [ 1712.632517] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Dropping the link to regulator.79
                                      [ 1712.636492] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Dropping the link to regulator.60
                                      [ 1712.636595] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Dropping the link to regulator.56
                                      [ 1712.636686] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Dropping the link to regulator.58
                                      [ 1712.662182] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.59
                                      [ 1712.662338] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.60
                                      [ 1712.662399] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.56
                                      [ 1712.662543] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.79
                                      [ 1712.677605] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 918 Probe success,slot:2,slave_addr:0x34,sensor_id:0x577
                                      [ 1712.677728] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.79
                                      [ 1712.679699] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.56
                                      [ 1712.679736] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.60
                                      [ 1712.679789] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.59
                                      [ 1712.739998] CAM_WARN: CAM-CRM: cam_req_mgr_close: 160 release invoked associated userspace process has died
                                      Specifically, the following line says that the TOF sensor has been probed successfully:
                                      If the probe fails, you would see some CCI errors. If you do not see anything related to slave address 0x7a , the the sensor is not being probed and the issue is on the SW configuration side, which we can investigate further.
                                        Hector Gutierrez
                                        @Alex-Kushleyev said in Starling 2: TOF sensor not recognized by VOXL Portal:
                                        Can you send me the syntax to get the dmesg output from voxl-camera-server -l ? I've tried a few options but I do not get an output that looks like the one you show. Thanks.
                                          Hector Gutierrez
                                          @Alex-Kushleyev : got the output of dmesg. It is too large to cut and paste here, but you can download the text file from this link:
                                          https://quickconnect.to/asapstorage/d/s/144lSyeQPPdNEZhCoWVCOjXUTudhlakC/Yfk8uh0E8Vk96kuc_96XHvRM6svAJSIF-bLWAR1fcaQw
                                          (dont click on the link: copy and paste to a browser window).
                                          Or send me the syntax to get a filtered output as you have above. Thanks.
