How to attach a servo motor to VOXL 2
I am currently working on a project involving the VOXL 2 platform and would like to control a servo motor within my existing system architecture. Below is a summary of the current configuration:
- RC, GPS, and Magnetometer are connected to the J19 port.
- An FPV ESC is connected to the J18 port.
- The M0151 expansion board is connected to a Doodle Labs module.
I am considering two possible approaches for integrating servo motor control:
Using the IO Expansion Board via a free UART Port on the M0151 Board
I plan to connect the IO Expansion Board to an available UART port on the M0151. I would like to confirm whether this setup would support reliable servo motor control. -
Connecting the IO Expansion Board to J19 and connecting receiver to J2 terminal of IO Expansion Board
Could you please advise on the feasibility and potential limitations of both configurations? I would appreciate any insights or recommendations you may have.
Please feel free to reach out if any further clarification is needed.
Regards,
Ashwin -
Regards,
Ashwin -
@ashwin Are you looking to control the servo via PX4 or with some custom software? What will the servo be doing?
Do you need to be able to control the servo from PX4 or it would be acceptable to have an API you could use on the CPU / Linux on VOXL2 ?
Hello @Alex-Kushleyev @Eric-Katzfey
I am looking to control the servo via PX4.
Essentially, it will be a command either from the RC or GCS to open / close the servo motor.But, if that is infeasible, I can make it work via an API on the CPU / Linux on VOXL 2 to be controlled via SSH.
Regards,
Ashwin
