  3. How to attach a servo motor to VOXL 2
5 Posts 3 Posters 932 Views 5 Watching
  • A Offline
    ashwin
    I am currently working on a project involving the VOXL 2 platform and would like to control a servo motor within my existing system architecture. Below is a summary of the current configuration:
    • RC, GPS, and Magnetometer are connected to the J19 port.
    • An FPV ESC is connected to the J18 port.
    • The M0151 expansion board is connected to a Doodle Labs module.
    I am considering two possible approaches for integrating servo motor control:
    • Using the IO Expansion Board via a free UART Port on the M0151 Board
      I plan to connect the IO Expansion Board to an available UART port on the M0151. I would like to confirm whether this setup would support reliable servo motor control.
    • Connecting the IO Expansion Board to J19 and connecting receiver to J2 terminal of IO Expansion Board
    Could you please advise on the feasibility and potential limitations of both configurations? I would appreciate any insights or recommendations you may have.
    Please feel free to reach out if any further clarification is needed.
    Regards,
    Ashwin
    A 1 Reply Last reply
    • A ashwin
      Regards,
      Ashwin
      ashwin
      Can someone kindly respond to this query?
      Regards,
      Ashwin
      • A ashwin
        Regards,
        Ashwin
        @ashwin Are you looking to control the servo via PX4 or with some custom software? What will the servo be doing?
          @ashwin
          Do you need to be able to control the servo from PX4 or it would be acceptable to have an API you could use on the CPU / Linux on VOXL2 ?
            @ashwin
            ashwin
            Hello @Alex-Kushleyev @Eric-Katzfey
            I am looking to control the servo via PX4.
            Essentially, it will be a command either from the RC or GCS to open / close the servo motor.
            But, if that is infeasible, I can make it work via an API on the CPU / Linux on VOXL 2 to be controlled via SSH.
            Regards,
            Ashwin
