  2. VOXL SDK and Software
  3. Low Latency IMX412 Driver
camera
32 Posts 3 Posters 10.2k Views 3 Watching
    @Alex-Kushleyev One new error once I updated and reconfigured:
    voxl-camera-server
    using new imx214 defaults
    configuration for 1 cameras:
    cam #0
        sensor type:         imx214
        isEnabled:           1
        camId:               1
        camId2:              -1
        fps:                 30
        en_rotate:           0
        en_rotate2:          0
        en_preview:          0
        pre_width:           640
        pre_height:          480
        en_raw_preview:      0
        en_small_video:      1
        small_video_width:   1024
        small_video_height:  768
        en_large_video:      1
        large_video_width:   4096
        large_video_height:  2160
        en_misp:             0
        misp_width:          -1
        misp_height:         -1
        en_snapshot:         1
        snap_width:          4160
        snap_height:         3120
        exif_focal_length:   0.000000
        exif_focal_len_35mm_format:0
        exif_fnumber:        0.000000
        ae_mode:             isp
        msv_exposure_min_us: 20
        msv_exposure_max_us: 33000
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           1
        independent_exposure:0
    fsync_en:            0
    fsync_gpio:          109
    I tried with my old configuration as well, but all I am getting is the message "thread is locked to cores: 4 5 6 7". I am not sure how to fix this.
    tomT Online
    tomT Online
    wrote on last edited by tom
    @Matthew-Wellner That isn't an error message. We manually set the cores voxl-camera-server is allowed to use in order to maximize performance
      Matthew WellnerM Offline
      Matthew Wellner
      @tom - Thanks for the clarification.
      I thought it was an error because the server just dies without any other message immediately after the thread locked message. I'll go through everything again to see if I am missing something.
        Matthew Wellner
        @Alex-Kushleyev and @tom
        I am getting the output below in logcat when I try and run the camera server. Did I miss a configuration / initialization step after updating the SDK?
        04-23 15:26:17.186 16137 16137 I voxl-camera-server: /local/mnt/workspace/lnxbuild/project/trees_in_use/free_tree_dir/checkout/build-qti-distro-ubuntu-fullstack-perf/tmp-glibc/work/qrb5165_rb5-oe-linux/adsprpc/git-r1/adsprpc/src/fastrpc_apps_user.c:2329: fastrpc_apps_user_init done
        04-23 15:26:17.186 16137 16137 V HAL     : loaded HAL id=camera path=/usr/lib/hw/camera.qcom.so hmi=0x7f9653d0d0 handle=0x556a345410
        04-23 15:26:17.186 16137 16137 I CamX    : [CONFIG][HAL    ] camxhal3module.cpp:392 HAL3Module() ***************************************************
        04-23 15:26:17.186 16137 16137 I CamX    : [CONFIG][HAL    ] camxhal3module.cpp:393 HAL3Module() SHA1:     036a2d22fbaa18202ae206a6e464b9f46fcf83c9
        04-23 15:26:17.186 16137 16137 I CamX    : [CONFIG][HAL    ] camxhal3module.cpp:394 HAL3Module() COMMITID:
        04-23 15:26:17.186 16137 16137 I CamX    : [CONFIG][HAL    ] camxhal3module.cpp:395 HAL3Module() BUILD TS: 11/11/2024 22:13:22
        04-23 15:26:17.186 16137 16137 I CamX    : [CONFIG][HAL    ] camxhal3module.cpp:396 HAL3Module() ***************************************************
        04-23 15:26:17.187 16137 16137 I CamX    : [ INFO][CORE   ] camxoverridesettingsfile.cpp:390 Initialize() Opening override settings text file: /vendor/etc/camera/camxoverridesettings.txt
        04-23 15:26:17.187 16137 16137 V CamX    : [ VERB][UTILS  ] camxhashmap.cpp:210 GetInPlace() Key not found
        04-23 15:26:17.187 16137 16137 V CamX    : [ VERB][CORE   ] camxoverridesettingsfile.cpp:385 Initialize() Could not find override settings text file at: ./camxoverridesettings.txt
        04-23 15:26:17.188 16137 16137 V CamX    : [ VERB][UTILS  ] camxhashmap.cpp:210 GetInPlace() Key not found
        04-23 15:26:17.192 16137 16137 V CamX    : [ VERB][UTILS  ] camxhashmap.cpp:210 GetInPlace() Key not found
        04-23 15:26:17.232 16137 16137 W CamX    : [ WARN][CSL    ] camxcslhwinternal.cpp:3050 CSLHwInternalFDIoctl() Ioctl failed for FD:5 with error reason Invalid argument
        04-23 15:26:17.257 16137 16137 E         : ChiAWBAlgorithmEntry
        04-23 15:26:17.341 16137 16137 E CHIUSECASE: [ERROR  ] chxutils.cpp:743 LibMap() Failed to load library libqti-perfd-client.so error libqti-perfd-client.so: cannot open shared object file: No such file or directory
        04-23 15:26:17.341 16137 16137 E CHIUSECASE: [ERROR  ] chxextensionmodule.cpp:301 ExtensionModule() Failed to load perf lib
        04-23 15:26:17.345 16137 16137 I CamX    : [CONFIG][CORE   ] camxresourcemanager.cpp:61 Initialize() ResourceManager: 0x556a3b0dc0, name: CamXRealtimePipelineResourceManager
        04-23 15:26:17.347 16137 16137 E CamX    : [ERROR][NCS    ] camxncsintfqsee.cpp:513 ProbeSensor() Failed to Probe Sensor 0 error qmi_client_notifier_init() failed: qmi error (-17)
        04-23 15:26:17.347 16137 16137 E CamX    : [ERROR][NCS    ] camxncsintfqsee.cpp:582 ProbeSensor() Unable to create lookup object, out of memory !!
        04-23 15:26:17.347 16137 16137 W CamX    : [ WARN][NCS    ] camxncsintfqsee.cpp:246 GetListOfSensors() Probe sensor 0 with error 8
        04-23 15:26:17.347 16137 16137 E CamX    : [ERROR][NCS    ] camxncsintfqsee.cpp:513 ProbeSensor() Failed to Probe Sensor 1 error qmi_client_notifier_init() failed: qmi error (-17)
        04-23 15:26:17.347 16137 16137 W CamX    : [ WARN][NCS    ] camxncsintfqsee.cpp:246 GetListOfSensors() Probe sensor 1 with error 8
        04-23 15:26:17.347 16137 16137 E CamX    : [ERROR][NCS    ] camxncsintfqsee.cpp:513 ProbeSensor() Failed to Probe Sensor 2 error qmi_client_notifier_init() failed: qmi error (-17)
        04-23 15:26:17.347 16137 16137 W CamX    : [ WARN][NCS    ] camxncsintfqsee.cpp:246 GetListOfSensors() Probe sensor 2 with error 8
        04-23 15:26:17.348 16137 16137 E CamX    : [ERROR][NCS    ] camxncsintfqsee.cpp:513 ProbeSensor() Failed to Probe Sensor 3 error qmi_client_notifier_init() failed: qmi error (-17)
        04-23 15:26:17.348 16137 16137 E CamX    : [ERROR][NCS    ] camxncsintfqsee.cpp:582 ProbeSensor() Unable to create lookup object, out of memory !!
        04-23 15:26:17.348 16137 16137 W CamX    : [ WARN][NCS    ] camxncsintfqsee.cpp:246 GetListOfSensors() Probe sensor 3 with error 8
        04-23 15:26:17.348 16137 16137 E CamX    : [ERROR][NCS    ] camxncsintfqsee.cpp:513 ProbeSensor() Failed to Probe Sensor 4 error qmi_client_notifier_init() failed: qmi error (-17)
        04-23 15:26:17.348 16137 16137 W CamX    : [ WARN][NCS    ] camxncsintfqsee.cpp:246 GetListOfSensors() Probe sensor 4 with error 8
        04-23 15:26:17.348 16137 16137 E CamX    : [ERROR][NCS    ] camxncsintfqsee.cpp:513 ProbeSensor() Failed to Probe Sensor 5 error qmi_client_notifier_init() failed: qmi error (-17)
        04-23 15:26:17.348 16137 16137 W CamX    : [ WARN][NCS    ] camxncsintfqsee.cpp:246 GetListOfSensors() Probe sensor 5 with error 8
        04-23 15:26:17.349 16137 16137 E CamX    : [ERROR][NCS    ] camxncsintfqsee.cpp:513 ProbeSensor() Failed to Probe Sensor 6 error qmi_client_notifier_init() failed: qmi error (-17)
        04-23 15:26:17.349 16137 16137 E CamX    : [ERROR][NCS    ] camxncsintfqsee.cpp:582 ProbeSensor() Unable to create lookup object, out of memory !!
        04-23 15:26:17.349 16137 16137 W CamX    : [ WARN][NCS    ] camxncsintfqsee.cpp:246 GetListOfSensors() Probe sensor 6 with error 8
        04-23 15:26:17.350 16137 16137 E CamX    : [ERROR][NCS    ] camxncsintfqsee.cpp:513 ProbeSensor() Failed to Probe Sensor 7 error qmi_client_notifier_init() failed: qmi error (-17)
        04-23 15:26:17.350 16137 16137 E CamX    : [ERROR][NCS    ] camxncsintfqsee.cpp:582 ProbeSensor() Unable to create lookup object, out of memory !!
        04-23 15:26:17.350 16137 16137 W CamX    : [ WARN][NCS    ] camxncsintfqsee.cpp:246 GetListOfSensors() Probe sensor 7 with error 8
        04-23 15:26:17.350 16137 16137 E CamX    : [ERROR][NCS    ] camxncsintfqsee.cpp:513 ProbeSensor() Failed to Probe Sensor 8 error qmi_client_notifier_init() failed: qmi error (-17)
        04-23 15:26:17.350 16137 16137 W CamX    : [ WARN][NCS    ] camxncsintfqsee.cpp:246 GetListOfSensors() Probe sensor 8 with error 8
        04-23 15:26:17.350 16137 16137 E CamX    : [ERROR][NCS    ] camxncsintfqsee.cpp:513 ProbeSensor() Failed to Probe Sensor 9 error qmi_client_notifier_init() failed: qmi error (-17)
        04-23 15:26:17.351 16137 16137 W CamX    : [ WARN][NCS    ] camxncsintfqsee.cpp:246 GetListOfSensors() Probe sensor 9 with error 8
        04-23 15:26:17.351 16137 16137 W CHIUSECASE: [WARN   ] chxextensionmodule.cpp:1415 BuildLogicalCameraInfo() Please check if sensor id:0 is probed successfully!
        04-23 15:26:17.351 16137 16137 W CHIUSECASE: [WARN   ] chxextensionmodule.cpp:1415 BuildLogicalCameraInfo() Please check if sensor id:1 is probed successfully!
        04-23 15:26:17.351 16137 16137 W CHIUSECASE: [WARN   ] chxextensionmodule.cpp:1415 BuildLogicalCameraInfo() Please check if sensor id:2 is probed successfully!
        04-23 15:26:17.351 16137 16137 W CHIUSECASE: [WARN   ] chxextensionmodule.cpp:1415 BuildLogicalCameraInfo() Please check if sensor id:3 is probed successfully!
        04-23 15:26:17.351 16137 16137 W CHIUSECASE: [WARN   ] chxextensionmodule.cpp:1415 BuildLogicalCameraInfo() Please check if sensor id:4 is probed successfully!
        04-23 15:26:17.351 16137 16137 W CHIUSECASE: [WARN   ] chxextensionmodule.cpp:1415 BuildLogicalCameraInfo() Please check if sensor id:5 is probed successfully!
        04-23 15:26:17.351 16137 16137 W CHIUSECASE: [WARN   ] chxextensionmodule.cpp:1415 BuildLogicalCameraInfo() Please check if sensor id:6 is probed successfully!
        04-23 15:26:17.363 16137 16137 I voxl-camera-server: /local/mnt/workspace/lnxbuild/project/trees_in_use/free_tree_dir/checkout/build-qti-distro-ubuntu-fullstack-perf/tmp-glibc/work/qrb5165_rb5-oe-linux/adsprpc/git-r1/adsprpc/src/fastrpc_apps_user.c:2273: fastrpc_apps_user_deinit done
          @Matthew-Wellner , did you update to sdk 1.4.1? Can you please let me know what camera(s) you have connected (and which camera port) and the contents of your /usr/lib/camera? Does voxl-camera-server -l detect any cameras?
          Alex KushleyevA Matthew WellnerM 2 Replies Last reply
            It seems that camera server gets stuck after
            Can you please run voxl-camera-server -d 0 to enable full debugging prints and see if anything prints after that ?
            Thank you
              Matthew Wellner
              @Alex-Kushleyev I updated to 1.4.1 and I have an IMX412 attached to port J7 upper.
              Contents of /usr/lib/camera:
              ls -la /usr/lib/camera/
              total 5840
              drwxr-xr-x  3 root root   4096 Apr 23 15:35 .
              drwxr-xr-x 69 root root  24576 Apr 22 17:15 ..
              -rwxr-xr-x  1 root root   9912 Nov 11 22:27 com.qti.eeprom.cmk_imx577.so
              -rwxr-xr-x  1 root root   9904 Nov 11 22:27 com.qti.sensor.ar0144.so
              -rwxr-xr-x  1 root root   5808 Nov 11 22:27 com.qti.sensor.boson.so
              -rwxr-xr-x  1 root root   5816 Nov 11 22:27 com.qti.sensor.cmk_imx577.so
              -rwxr-xr-x  1 root root   5816 Nov 11 22:27 com.qti.sensor.cmk_imx577_flip.so
              -rwxr-xr-x  1 root root   9904 Nov 11 22:27 com.qti.sensor.imx214.so
              -rwxr-xr-x  1 root root   9912 Nov 11 22:27 com.qti.sensor.imx214_flip.so
              -rwxr-xr-x  1 root root   9904 Nov 11 22:27 com.qti.sensor.imx335.so
              -rwxr-xr-x  1 root root   5808 Nov 11 22:27 com.qti.sensor.imx377.so
              -rwxr-xr-x  1 root root   8360 Apr 22 20:16 com.qti.sensor.imx412_fpv.so
              -rwxr-xr-x  1 root root   9904 Nov 11 22:27 com.qti.sensor.imx664.so
              -rwxr-xr-x  1 root root   9904 Nov 11 22:27 com.qti.sensor.imx678.so
              -rwxr-xr-x  1 root root   9912 Nov 11 22:27 com.qti.sensor.imx678_flip.so
              -rwxr-xr-x  1 root root   9912 Nov 11 22:27 com.qti.sensor.imx678_mod.so
              -rwxr-xr-x  1 root root   5808 Nov 11 22:27 com.qti.sensor.irs1645.so
              -rwxr-xr-x  1 root root   5808 Nov 11 22:27 com.qti.sensor.irs2975c.so
              -rwxr-xr-x  1 root root   9904 Nov 11 22:27 com.qti.sensor.ov64b40.so
              -rwxr-xr-x  1 root root   9904 Nov 11 22:27 com.qti.sensor.ov7251.so
              -rwxr-xr-x  1 root root   9912 Nov 11 22:27 com.qti.sensor.ov7251_front_left.so
              -rwxr-xr-x  1 root root   9920 Nov 11 22:27 com.qti.sensor.ov7251_front_left_flip.so
              -rwxr-xr-x  1 root root   9920 Nov 11 22:27 com.qti.sensor.ov7251_front_right.so
              -rwxr-xr-x  1 root root   9920 Nov 11 22:27 com.qti.sensor.ov7251_front_right_flip.so
              -rwxr-xr-x  1 root root   9912 Nov 11 22:27 com.qti.sensor.ov7251_fsin.so
              -rwxr-xr-x  1 root root   9912 Nov 11 22:27 com.qti.sensor.ov7251_fsout.so
              -rwxr-xr-x  1 root root   9912 Nov 11 22:27 com.qti.sensor.ov7251_rear_left.so
              -rwxr-xr-x  1 root root   9920 Nov 11 22:27 com.qti.sensor.ov7251_rear_left_flip.so
              -rwxr-xr-x  1 root root   9912 Nov 11 22:27 com.qti.sensor.ov7251_rear_right.so
              -rwxr-xr-x  1 root root   9920 Nov 11 22:27 com.qti.sensor.ov7251_rear_right_flip.so
              -rwxr-xr-x  1 root root   9904 Nov 11 22:27 com.qti.sensor.ov9782.so
              -rwxr-xr-x  1 root root   9912 Nov 11 22:27 com.qti.sensor.ov9782_front_left.so
              -rwxr-xr-x  1 root root   9920 Nov 11 22:27 com.qti.sensor.ov9782_front_left_flip.so
              -rwxr-xr-x  1 root root   9920 Nov 11 22:27 com.qti.sensor.ov9782_front_right.so
              -rwxr-xr-x  1 root root   9920 Nov 11 22:27 com.qti.sensor.ov9782_front_right_flip.so
              -rwxr-xr-x  1 root root   9912 Nov 11 22:27 com.qti.sensor.ov9782_rear_left.so
              -rwxr-xr-x  1 root root   9920 Nov 11 22:27 com.qti.sensor.ov9782_rear_left_flip.so
              -rwxr-xr-x  1 root root   9912 Nov 11 22:27 com.qti.sensor.ov9782_rear_right.so
              -rwxr-xr-x  1 root root   9920 Nov 11 22:27 com.qti.sensor.ov9782_rear_right_flip.so
              -rw-r--r--  1 root root 149272 Apr 23 15:35 com.qti.sensormodule.imx214_3.bin
              -rw-r--r--  1 root root 957344 Nov 11 22:27 com.qti.tuned.cmk_imx577.bin
              -rw-r--r--  1 root root 835464 Nov 11 22:27 com.qti.tuned.cmk_ov9282.bin
              -rw-r--r--  1 root root 931864 Nov 11 22:27 com.qti.tuned.default.bin
              -rw-r--r--  1 root root 957344 Nov 11 22:27 com.qti.tuned.imx412_fpv.bin
              -rw-r--r--  1 root root 793816 Nov 11 22:27 com.qti.tuned.ov9782.bin
              -rw-r--r--  1 root root 882376 Nov 11 22:27 com.qti.tuned.sony_imx335.bin
              drwxr-xr-x  2 root root   4096 Nov 11 22:41 components
              voxl-camera-server -l crashes similarly to when I try to run the server normally (it just exits and logcat has the same output as above)
              If I run "voxl-camera-server -d 0" it says that it doesn't recognize any cameras.
              fsync_en:            0
              fsync_gpio:          109
              DEBUG:   ----------- Number of cameras: 0
              VERBOSE: cci-direct: using voxl_platform_mod config 0 layout
              ERROR:   Found zero cameras connected, need at least one.
                Thank you
                Matthew Wellner
                @Alex-Kushleyev I moved the low latency .bin files into /usr/share/modalai/chi-cdk/imx412-fpv/ and the .so file into /usr/lib/camera. Was I not supposed to do that?
                  @Matthew-Wellner , both the .so and sensormodule(s) files need to go to /usr/lib/camera !
                  /usr/share/modalai/chi-cdk is used to store all the camera drivers that we ship with the SDK, but they are not used from this location. You either need to copy the correct sensormodule files from chi-cdk location into /usr/lib/camera/ or run voxl-configure-cameras script, which will do it based on a standard config.
                  Sorry for the confusion.
                    Matthew Wellner
                    @Alex-Kushleyev I fixed the drivers and got back to the issue I was having where the voxl-camera-server would just die after a short time. Here is the output from voxl-camera-server -d 0:
                    voxl2:/$ voxl-camera-server -d 0
                    detected system image 1.8.2
                    using new imx412 defaults
                    cam #0
                        sensor type:         imx412
                        isEnabled:           1
                        camId:               0
                        camId2:              -1
                        fps:                 60
                        en_rotate:           0
                        en_rotate2:          0
                        en_preview:          1
                        pre_width:           4040
                        pre_height:          3040
                        en_raw_preview:      1
                        en_small_video:      1
                        en_large_video:      0
                        large_video_width:   4208
                        large_video_height:  3120
                        en_misp:             0
                        misp_width:          -1
                        misp_height:         -1
                        en_snapshot:         0
                        snap_width:          4208
                        snap_height:         3120
                        ae_mode:             isp
                        gain_min           : 54
                        gain_max           : 8000
                        standby_enabled:     0
                        decimator:           1
                    fsync_en:            0
                    fsync_gpio:          109
                    DEBUG:   Cam idx: 0, Cam slot: 3, Slave Address: 0x0034, Sensor Id: 0x0577
                    connected to mavlink pipe
                    Connected to cpu-monitor
                    DEBUG:   ------ voxl-camera-server: Starting 1 cameras
                    Starting Camera: hires (id #0)
                    DEBUG:   Checking Gain limits for Camera: hires
                    DEBUG:   Using gain limits min: 100 max: 8000
                    DEBUG:   cam ID 0 checking for fmt:   37  w: 4040 h: 3040 o:   0
                    DEBUG:   	==> option   0: format= 34 width=4056 height=3040 is_input=0
                    DEBUG:   	==> option   4: format= 34 width=4056 height=3040 is_input=1
                    DEBUG:   	==> option   8: format= 35 width=4056 height=3040 is_input=0
                    DEBUG:   	==> option 568: format= 32 width=1996 height= 240 is_input=0
                    DEBUG:   	==> option 572: format= 36 width=1996 height= 240 is_input=0
                    VERBOSE: Successfully found configuration match for camera 0: 4040x3040
                    DEBUG:   cam ID 0 checking for fmt:   35  w: 1024 h:  768 o:   0
                    VERBOSE: Successfully found configuration match for camera 0: 1024x768
                    VERBOSE: Adding small video stream for camera: 0
                    DEBUG:   Converted gralloc flags 0x20900 to GBM flags 0x1400000
                    VERBOSE: Dumping GBM flags
                    DEBUG:   	Found flag GBM_BO_USAGE_HW_COMPOSER_QTI
                    VERBOSE: Opened GBM fd
                    VERBOSE: Created GBM device
                    DEBUG:   Allocated BO with width=4040 height=3040 stride=5056 aligned_w=5056 aligned_h=3040 size=15372288 flags=0x20900 format=GBM_FORMAT_RAW10 fd=62 vaddr=0x55941b5000
                    DEBUG:   Allocated BO with width=4040 height=3040 stride=5056 aligned_w=5056 aligned_h=3040 size=15372288 flags=0x20900 format=GBM_FORMAT_RAW10 fd=64 vaddr=0x55941b5000
                    DEBUG:   Allocated BO with width=4040 height=3040 stride=5056 aligned_w=5056 aligned_h=3040 size=15372288 flags=0x20900 format=GBM_FORMAT_RAW10 fd=66 vaddr=0x55941b5000
                    DEBUG:   Allocated BO with width=4040 height=3040 stride=5056 aligned_w=5056 aligned_h=3040 size=15372288 flags=0x20900 format=GBM_FORMAT_RAW10 fd=68 vaddr=0x55941b5000
                    DEBUG:   Allocated BO with width=4040 height=3040 stride=5056 aligned_w=5056 aligned_h=3040 size=15372288 flags=0x20900 format=GBM_FORMAT_RAW10 fd=70 vaddr=0x55941b5000
                    DEBUG:   Allocated BO with width=4040 height=3040 stride=5056 aligned_w=5056 aligned_h=3040 size=15372288 flags=0x20900 format=GBM_FORMAT_RAW10 fd=72 vaddr=0x55941b5000
                    DEBUG:   Allocated BO with width=4040 height=3040 stride=5056 aligned_w=5056 aligned_h=3040 size=15372288 flags=0x20900 format=GBM_FORMAT_RAW10 fd=74 vaddr=0x55941b5000
                    DEBUG:   Allocated BO with width=4040 height=3040 stride=5056 aligned_w=5056 aligned_h=3040 size=15372288 flags=0x20900 format=GBM_FORMAT_RAW10 fd=76 vaddr=0x55941b5000
                    DEBUG:   Allocated BO with width=4040 height=3040 stride=5056 aligned_w=5056 aligned_h=3040 size=15372288 flags=0x20900 format=GBM_FORMAT_RAW10 fd=78 vaddr=0x55941b5000
                    DEBUG:   Allocated BO with width=4040 height=3040 stride=5056 aligned_w=5056 aligned_h=3040 size=15372288 flags=0x20900 format=GBM_FORMAT_RAW10 fd=80 vaddr=0x55941b5000
                    DEBUG:   Allocated BO with width=4040 height=3040 stride=5056 aligned_w=5056 aligned_h=3040 size=15372288 flags=0x20900 format=GBM_FORMAT_RAW10 fd=82 vaddr=0x55941b5000
                    DEBUG:   Allocated BO with width=4040 height=3040 stride=5056 aligned_w=5056 aligned_h=3040 size=15372288 flags=0x20900 format=GBM_FORMAT_RAW10 fd=84 vaddr=0x55941b5000
                    DEBUG:   Allocated BO with width=4040 height=3040 stride=5056 aligned_w=5056 aligned_h=3040 size=15372288 flags=0x20900 format=GBM_FORMAT_RAW10 fd=86 vaddr=0x55941b5000
                    DEBUG:   Allocated BO with width=4040 height=3040 stride=5056 aligned_w=5056 aligned_h=3040 size=15372288 flags=0x20900 format=GBM_FORMAT_RAW10 fd=88 vaddr=0x55941b5000
                    DEBUG:   Allocated BO with width=4040 height=3040 stride=5056 aligned_w=5056 aligned_h=3040 size=15372288 flags=0x20900 format=GBM_FORMAT_RAW10 fd=90 vaddr=0x55941b5000
                    DEBUG:   Allocated BO with width=4040 height=3040 stride=5056 aligned_w=5056 aligned_h=3040 size=15372288 flags=0x20900 format=GBM_FORMAT_RAW10 fd=92 vaddr=0x55941b5000
                    DEBUG:   Found video encoder usage, removing camera read/write usage
                    DEBUG:   Converted gralloc flags 0x30022 to GBM flags 0x860000
                    DEBUG:   	Found flag GBM_BO_USAGE_CPU_READ_QTI
                    DEBUG:   	Found flag GBM_BO_USAGE_CPU_WRITE_QTI
                    DEBUG:   	Found flag GBM_BO_USAGE_VIDEO_ENCODER_QTI
                    DEBUG:   Allocated BO with width=1024 height=768 stride=1024 aligned_w=1024 aligned_h=1024 size=1572864 flags=0x30022 format=GBM_FORMAT_YCbCr_420_888 fd=94 vaddr=0x7fe2a813a0
                    DEBUG:   Allocated BO with width=1024 height=768 stride=1024 aligned_w=1024 aligned_h=1024 size=1572864 flags=0x30022 format=GBM_FORMAT_YCbCr_420_888 fd=96 vaddr=0x7fe2a813a0
                    DEBUG:   Allocated BO with width=1024 height=768 stride=1024 aligned_w=1024 aligned_h=1024 size=1572864 flags=0x30022 format=GBM_FORMAT_YCbCr_420_888 fd=98 vaddr=0x7fe2a813a0
                    DEBUG:   Allocated BO with width=1024 height=768 stride=1024 aligned_w=1024 aligned_h=1024 size=1572864 flags=0x30022 format=GBM_FORMAT_YCbCr_420_888 fd=100 vaddr=0x7fe2a813a0
                    DEBUG:   Allocated BO with width=1024 height=768 stride=1024 aligned_w=1024 aligned_h=1024 size=1572864 flags=0x30022 format=GBM_FORMAT_YCbCr_420_888 fd=102 vaddr=0x7fe2a813a0
                    DEBUG:   Allocated BO with width=1024 height=768 stride=1024 aligned_w=1024 aligned_h=1024 size=1572864 flags=0x30022 format=GBM_FORMAT_YCbCr_420_888 fd=104 vaddr=0x7fe2a813a0
                    DEBUG:   Allocated BO with width=1024 height=768 stride=1024 aligned_w=1024 aligned_h=1024 size=1572864 flags=0x30022 format=GBM_FORMAT_YCbCr_420_888 fd=106 vaddr=0x7fe2a813a0
                    DEBUG:   Allocated BO with width=1024 height=768 stride=1024 aligned_w=1024 aligned_h=1024 size=1572864 flags=0x30022 format=GBM_FORMAT_YCbCr_420_888 fd=108 vaddr=0x7fe2a813a0
                    DEBUG:   Allocated BO with width=1024 height=768 stride=1024 aligned_w=1024 aligned_h=1024 size=1572864 flags=0x30022 format=GBM_FORMAT_YCbCr_420_888 fd=110 vaddr=0x7fe2a813a0
                    DEBUG:   Allocated BO with width=1024 height=768 stride=1024 aligned_w=1024 aligned_h=1024 size=1572864 flags=0x30022 format=GBM_FORMAT_YCbCr_420_888 fd=112 vaddr=0x7fe2a813a0
                    DEBUG:   Allocated BO with width=1024 height=768 stride=1024 aligned_w=1024 aligned_h=1024 size=1572864 flags=0x30022 format=GBM_FORMAT_YCbCr_420_888 fd=114 vaddr=0x7fe2a813a0
                    DEBUG:   Allocated BO with width=1024 height=768 stride=1024 aligned_w=1024 aligned_h=1024 size=1572864 flags=0x30022 format=GBM_FORMAT_YCbCr_420_888 fd=116 vaddr=0x7fe2a813a0
                    DEBUG:   Allocated BO with width=1024 height=768 stride=1024 aligned_w=1024 aligned_h=1024 size=1572864 flags=0x30022 format=GBM_FORMAT_YCbCr_420_888 fd=118 vaddr=0x7fe2a813a0
                    DEBUG:   Allocated BO with width=1024 height=768 stride=1024 aligned_w=1024 aligned_h=1024 size=1572864 flags=0x30022 format=GBM_FORMAT_YCbCr_420_888 fd=120 vaddr=0x7fe2a813a0
                    DEBUG:   Allocated BO with width=1024 height=768 stride=1024 aligned_w=1024 aligned_h=1024 size=1572864 flags=0x30022 format=GBM_FORMAT_YCbCr_420_888 fd=122 vaddr=0x7fe2a813a0
                    DEBUG:   Allocated BO with width=1024 height=768 stride=1024 aligned_w=1024 aligned_h=1024 size=1572864 flags=0x30022 format=GBM_FORMAT_YCbCr_420_888 fd=124 vaddr=0x7fe2a813a0
                    DEBUG:   Available color formats for OMX:
                    DEBUG:   	Unknown (0x7fa30c06)
                    DEBUG:   	OMX_QCOM_COLOR_FormatYUV420PackedSemiPlanar32m (0x7fa30c04)
                    DEBUG:   	OMX_QCOM_COLOR_FormatYVU420SemiPlanar (0x7fa30c00)
                    DEBUG:   	Unknown (0x7fa30c09)
                    DEBUG:   	Unknown (0x7fa30c0a)
                    DEBUG:   	Unknown (0x7fa30c08)
                    DEBUG:   	Unknown (0x7fa30c07)
                    DEBUG:   	OMX_COLOR_FormatAndroidOpaque (0x7f000789)
                    DEBUG:   	OMX_COLOR_FormatYUV420SemiPlanar (0x15)
                    WARNING: OMX SetTargetBitrate: H265 CBR requires bps >= 3.0Mbit (2000000 bps provided). Using FPS hack. scale = 1.500000
                    DEBUG:   Buffer Count Expected: 16
                    DEBUG:   Buffer Count Actual: 16
                    DEBUG:   Port Def 0:
                    	Count Min: 16
                    	Count Actual: 16
                    	Buffers Contiguous: Yes
                    	Buffer Alignment: 0
                    DEBUG:   Port Def 1:
                    	Count Min: 12
                    	Count Actual: 16
                    	Buffers Contiguous: No
                    	Buffer Alignment: 0
                    DEBUG:   OMX_EventCmdComplete
                    DEBUG:   Encoder moved to Idle State
                    DEBUG:   Encoder moved to Executing State
                    DEBUG:   Successfully set up pipeline for stream: STREAM_SMALL_VID
                    VERBOSE: Entered thread: cam0-request(tid: 4083)
                    VERBOSE: Entered thread: cam0-result(tid: 4084)
                    DEBUG:   Started Camera: hires
                    ------ voxl-camera-server: Started 1 of 1 cameras
                    VERBOSE: added request for small video stream
                    VERBOSE: added request for preview stream
                    VERBOSE: Sending request for frame 0 for camera hires for 2 streams
                    VERBOSE: Received 0 buffers from camera hires, partial result:1
                    VERBOSE: finished sending request for frame 0 for camera hires
                    VERBOSE: returning from SendOneCaptureRequest for frame 1 for camera hires
                    VERBOSE: Sending request for frame 1 for camera hires for 2 streams
                    VERBOSE: finished sending request for frame 1 for camera hires
                    VERBOSE: returning from SendOneCaptureRequest for frame 2 for camera hires
                    VERBOSE: Sending request for frame 2 for camera hires for 2 streams
                    VERBOSE: finished sending request for frame 2 for camera hires
                    VERBOSE: returning from SendOneCaptureRequest for frame 3 for camera hires
                    VERBOSE: Sending request for frame 3 for camera hires for 2 streams
                    VERBOSE: finished sending request for frame 3 for camera hires
                    VERBOSE: returning from SendOneCaptureRequest for frame 4 for camera hires
                    VERBOSE: Sending request for frame 4 for camera hires for 2 streams
                    VERBOSE: finished sending request for frame 4 for camera hires
                    VERBOSE: returning from SendOneCaptureRequest for frame 5 for camera hires
                    VERBOSE: Sending request for frame 5 for camera hires for 2 streams
                    VERBOSE: finished sending request for frame 5 for camera hires
                    VERBOSE: returning from SendOneCaptureRequest for frame 6 for camera hires
                    VERBOSE: Sending request for frame 6 for camera hires for 2 streams
                    VERBOSE: Received result from HAl3 for frame number 2
                    DEBUG:   Value of standby_active is: 0
                    Aborted
                    voxl2:/$
                      cam #0
                          sensor type:         imx412
                          isEnabled:           1
                          camId:               0
                          camId2:              -1
                          fps:                 60
                          en_rotate:           0
                          en_rotate2:          0
                          en_preview:          1
                          pre_width:           4040
                          pre_height:          3040
                          en_raw_preview:      1
                          en_small_video:      1
                          en_large_video:      0
                          en_misp:             0
                          misp_width:          -1
                          misp_height:         -1
                          en_snapshot:         0
                          snap_width:          4208
                          snap_height:         3120
                          ae_mode:             isp
                          gain_min           : 54
                          gain_max           : 8000
                          standby_enabled:     0
                          decimator:           1
                      fsync_en:            0
                      fsync_gpio:          109
                      DEBUG:   Port Def 0:
                      	Count Min: 16
                      	Count Actual: 16
                      	Buffer Alignment: 0
                      DEBUG:   Port Def 1:
                      	Count Min: 12
                      	Count Actual: 16
                      	Buffer Alignment: 0
                      Aborted
                      voxl2:/$
                      @Matthew-Wellner , thanks, that is looking better.
                      Now, two questions..
                      • which version of the IMX412 drivers are you using now?
                      • does the error still happen if you change the FPS to 30? what about 50?
                        Matthew Wellner
                        • I downloaded and installed the low latency drivers found on the low latency tutorial page -> https://docs.modalai.com/camera-video/low-latency-video-streaming/
                        • Yes it still occurs for... 30, 50, 60, & 90
                        Thanks again for the help!
                          @Matthew-Wellner,
                          Is any configuration at all working? I wonder if this is a hardware issue.
                          I will set up the exact use case and test. By the way i have recently updated the instructions you are referencing with updated imx412 drivers, so please double check the date on the driver zip file. Meanwhile, can you also post dmesg output after the camera server aborts? This can help spot a hardware issue.
                            @Matthew-Wellner,
                            Matthew Wellner
                            @Alex-Kushleyev - Thanks again!
                            Here is the output from /var/log/syslog when I run "voxl-camera-server -l":
                            Apr 24 13:55:58 m0054 kernel: [68157.917569] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.55
                            Apr 24 13:55:58 m0054 kernel: [68157.917657] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.79
                            Apr 24 13:55:58 m0054 kernel: [68157.946997] CAM_ERR: CAM-CCI: cam_cci_irq: 264 Base:        pK-error, M1_Q1 NACK ERROR: 0x40000000
                            Apr 24 13:55:58 m0054 kernel: [68157.947039] CAM_ERR: CAM-CCI: cam_cci_read: 1329 ERROR with Slave 0x20:
                            Apr 24 13:55:58 m0054 kernel: [68157.947042] CAM_ERR: CAM-CCI: cam_cci_read_bytes: 1613 failed to read rc:-22
                            Apr 24 13:55:58 m0054 kernel: [68157.947044] CAM_ERR: CAM-SENSOR: cam_cci_i2c_read: 35 rc = -22
                            Apr 24 13:55:58 m0054 kernel: [68157.947118] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.79
                            Apr 24 13:55:58 m0054 kernel: [68157.950956] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.55
                            Apr 24 13:55:58 m0054 kernel: [68157.950973] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.59
                            Apr 24 13:55:58 m0054 kernel: [68157.976036] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Linked as a consumer to regulator.58
                            Apr 24 13:55:58 m0054 kernel: [68157.976121] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Linked as a consumer to regulator.60
                            Apr 24 13:55:58 m0054 kernel: [68157.976135] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Linked as a consumer to regulator.55
                            Apr 24 13:55:58 m0054 kernel: [68157.976219] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Linked as a consumer to regulator.79
                            Apr 24 13:55:58 m0054 kernel: [68158.005077] CAM_ERR: CAM-CCI: cam_cci_irq: 238 Base:        pK-error, M0_Q1 NACK ERROR: 0x10000000
                            Apr 24 13:55:58 m0054 kernel: [68158.005148] CAM_ERR: CAM-CCI: cam_cci_read: 1329 ERROR with Slave 0x34:
                            Apr 24 13:55:58 m0054 kernel: [68158.005150] CAM_ERR: CAM-CCI: cam_cci_read_bytes: 1613 failed to read rc:-22
                            Apr 24 13:55:58 m0054 kernel: [68158.005151] CAM_ERR: CAM-SENSOR: cam_cci_i2c_read: 35 rc = -22
                            Apr 24 13:55:58 m0054 kernel: [68158.005152] CAM_WARN: CAM-SENSOR: cam_sensor_match_id: 707 read id: 0x0 expected id 0x577:
                            Apr 24 13:55:58 m0054 kernel: [68158.006941] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.55
                            Apr 24 13:55:58 m0054 kernel: [68158.006950] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.60
                            Apr 24 13:55:58 m0054 kernel: [68158.006982] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.58
                            Apr 24 13:55:58 m0054 kernel: [68158.032566] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Linked as a consumer to regulator.58
                            Apr 24 13:55:58 m0054 kernel: [68158.032721] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Linked as a consumer to regulator.60
                            Apr 24 13:55:58 m0054 kernel: [68158.032773] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Linked as a consumer to regulator.55
                            Apr 24 13:55:58 m0054 kernel: [68158.032908] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Linked as a consumer to regulator.79
                            Apr 24 13:55:58 m0054 kernel: [68158.047391] CAM_ERR: CAM-CCI: cam_cci_irq: 264 Base:        pK-error, M1_Q1 NACK ERROR: 0x40000000
                            Apr 24 13:55:58 m0054 kernel: [68158.047453] CAM_ERR: CAM-CCI: cam_cci_read: 1329 ERROR with Slave 0x34:
                            Apr 24 13:55:58 m0054 kernel: [68158.047460] CAM_ERR: CAM-CCI: cam_cci_read_bytes: 1613 failed to read rc:-22
                            Apr 24 13:55:58 m0054 kernel: [68158.047463] CAM_ERR: CAM-SENSOR: cam_cci_i2c_read: 35 rc = -22
                            Apr 24 13:55:58 m0054 kernel: [68158.047466] CAM_WARN: CAM-SENSOR: cam_sensor_match_id: 707 read id: 0x0 expected id 0x577:
                            Apr 24 13:55:58 m0054 kernel: [68158.071859] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.59
                            Apr 24 13:55:58 m0054 kernel: [68158.071964] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.60
                            Apr 24 13:55:58 m0054 kernel: [68158.072012] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.55
                            Apr 24 13:55:58 m0054 kernel: [68158.072156] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.79
                            Apr 24 13:55:58 m0054 kernel: [68158.086849] CAM_ERR: CAM-CCI: cam_cci_irq: 238 Base:        pK-error, M0_Q1 NACK ERROR: 0x10000000
                            Apr 24 13:55:58 m0054 kernel: [68158.087102] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.79
                            Apr 24 13:55:58 m0054 kernel: [68158.111682] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.59
                            Apr 24 13:55:58 m0054 kernel: [68158.111767] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.60
                            Apr 24 13:55:58 m0054 kernel: [68158.111807] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.55
                            Apr 24 13:55:58 m0054 kernel: [68158.111928] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.79
                            Apr 24 13:55:58 m0054 kernel: [68158.126905] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 918 Probe success,slot:3,slave_addr:0x34,sensor_id:0x577
                            Apr 24 13:55:58 m0054 kernel: [68158.126957] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.79
                            Apr 24 13:55:58 m0054 kernel: [68158.129028] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.55
                            Apr 24 13:55:58 m0054 kernel: [68158.129054] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.60
                            Apr 24 13:55:58 m0054 kernel: [68158.129093] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.59
                            Apr 24 13:55:58 m0054 kernel: [68158.142057] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor4: Linked as a consumer to regulator.59
                            Apr 24 13:55:58 m0054 kernel: [68158.142146] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor4: Linked as a consumer to regulator.60
                            Apr 24 13:55:58 m0054 kernel: [68158.142191] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor4: Linked as a consumer to regulator.55
                            Apr 24 13:55:58 m0054 kernel: [68158.142399] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor4: Linked as a consumer to regulator.79
                            Apr 24 13:55:59 m0054 kernel: [68158.157433] CAM_ERR: CAM-CCI: cam_cci_irq: 264 Base:        pK-error, M1_Q1 NACK ERROR: 0x40000000
                            Apr 24 13:55:59 m0054 kernel: [68158.157491] CAM_ERR: CAM-CCI: cam_cci_read: 1329 ERROR with Slave 0x34:
                            Apr 24 13:55:59 m0054 kernel: [68158.157496] CAM_ERR: CAM-CCI: cam_cci_read_bytes: 1613 failed to read rc:-22
                            Apr 24 13:55:59 m0054 kernel: [68158.157498] CAM_ERR: CAM-SENSOR: cam_cci_i2c_read: 35 rc = -22
                            Apr 24 13:55:59 m0054 kernel: [68158.157502] CAM_WARN: CAM-SENSOR: cam_sensor_match_id: 707 read id: 0x0 expected id 0x577:
                            Apr 24 13:55:59 m0054 kernel: [68158.157592] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor4: Dropping the link to regulator.79
                            Apr 24 13:55:59 m0054 kernel: [68158.159023] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor4: Dropping the link to regulator.55
                            Apr 24 13:55:59 m0054 kernel: [68158.159056] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor4: Dropping the link to regulator.60
                            Apr 24 13:55:59 m0054 kernel: [68158.183788] qcom,camera ac50000.qcom,cci:qcom,cam-sensor5: Linked as a consumer to regulator.59
                            Apr 24 13:55:59 m0054 kernel: [68158.183871] qcom,camera ac50000.qcom,cci:qcom,cam-sensor5: Linked as a consumer to regulator.60
                            Apr 24 13:55:59 m0054 kernel: [68158.183911] qcom,camera ac50000.qcom,cci:qcom,cam-sensor5: Linked as a consumer to regulator.55
                            Apr 24 13:55:59 m0054 kernel: [68158.184037] qcom,camera ac50000.qcom,cci:qcom,cam-sensor5: Linked as a consumer to regulator.79
                            Apr 24 13:55:59 m0054 kernel: [68158.198670] CAM_ERR: CAM-CCI: cam_cci_irq: 264 Base:        pK-error, M1_Q1 NACK ERROR: 0x40000000
                            Apr 24 13:55:59 m0054 kernel: [68158.198737] CAM_ERR: CAM-CCI: cam_cci_read: 1329 ERROR with Slave 0x34:
                            Apr 24 13:55:59 m0054 kernel: [68158.198740] CAM_ERR: CAM-CCI: cam_cci_read_bytes: 1613 failed to read rc:-22
                            Apr 24 13:55:59 m0054 kernel: [68158.198742] CAM_ERR: CAM-SENSOR: cam_cci_i2c_read: 35 rc = -22
                            Apr 24 13:55:59 m0054 kernel: [68158.198745] CAM_WARN: CAM-SENSOR: cam_sensor_match_id: 707 read id: 0x0 expected id 0x577:
                            Apr 24 13:55:59 m0054 kernel: [68158.198801] qcom,camera ac50000.qcom,cci:qcom,cam-sensor5: Dropping the link to regulator.79
                            Apr 24 13:55:59 m0054 kernel: [68158.239903] CAM_WARN: CAM-CRM: cam_req_mgr_close: 160 release invoked associated userspace process has died
                            I'll wait for your feedback, but I can try reinstalling the drivers from your tutorial and if that doesn't work, I can reflash the SDK as well.
                              @Matthew-Wellner , so this looks fine, what about dmesg when you don't use -l (just voxl-camera-server), so that we see the dmesg prints when camera server aborts.
                                Matthew Wellner
                                @Alex-Kushleyev Here is the output from dmesg when I run the voxl-camera-server:
                                Apr 24 19:31:55 m0054 tailscaled[1610]: netcheck: DetectCaptivePortal(found=false)
                                Apr 24 19:32:14 m0054 kernel: [88334.080488] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00
                                Apr 24 19:32:24 m0054 kernel: [88344.643537] CAM_ERR: CAM-MEM: cam_mem_mgr_create_debug_fs: 126 failed to create dentry
                                Apr 24 19:32:25 m0054 kernel: [88344.720291] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.59
                                Apr 24 19:32:25 m0054 kernel: [88344.745479] CAM_ERR: CAM-CCI: cam_cci_read: 1329 ERROR with Slave 0x20:
                                Apr 24 19:32:25 m0054 kernel: [88344.745482] CAM_ERR: CAM-CCI: cam_cci_read_bytes: 1613 failed to read rc:-22
                                Apr 24 19:32:25 m0054 kernel: [88344.745488] CAM_ERR: CAM-SENSOR: cam_cci_i2c_read: 35 rc = -22
                                Apr 24 19:32:25 m0054 kernel: [88344.745494] CAM_WARN: CAM-SENSOR: cam_sensor_match_id: 707 read id: 0x0 expected id 0x214:
                                Apr 24 19:32:25 m0054 kernel: [88344.745595] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.79
                                Apr 24 19:32:25 m0054 kernel: [88344.748968] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.55
                                Apr 24 19:32:25 m0054 kernel: [88344.774119] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Linked as a consumer to regulator.58
                                Apr 24 19:32:25 m0054 kernel: [88344.774208] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Linked as a consumer to regulator.60
                                Apr 24 19:32:25 m0054 kernel: [88344.774231] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Linked as a consumer to regulator.55
                                Apr 24 19:32:25 m0054 kernel: [88344.774316] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Linked as a consumer to regulator.79
                                Apr 24 19:32:25 m0054 kernel: [88344.798756] CAM_ERR: CAM-CCI: cam_cci_irq: 238 Base:        pK-error, M0_Q1 NACK ERROR: 0x10000000
                                Apr 24 19:32:25 m0054 kernel: [88344.798828] CAM_ERR: CAM-CCI: cam_cci_read: 1329 ERROR with Slave 0x34:
                                Apr 24 19:32:25 m0054 kernel: [88344.798832] CAM_ERR: CAM-CCI: cam_cci_read_bytes: 1613 failed to read rc:-22
                                Apr 24 19:32:25 m0054 kernel: [88344.798838] CAM_ERR: CAM-SENSOR: cam_cci_i2c_read: 35 rc = -22
                                Apr 24 19:32:25 m0054 kernel: [88344.798843] CAM_WARN: CAM-SENSOR: cam_sensor_match_id: 707 read id: 0x0 expected id 0x577:
                                Apr 24 19:32:25 m0054 kernel: [88344.798949] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.79
                                Apr 24 19:32:25 m0054 kernel: [88344.801095] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.55
                                Apr 24 19:32:25 m0054 kernel: [88344.801128] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.60
                                Apr 24 19:32:25 m0054 kernel: [88344.801171] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.58
                                Apr 24 19:32:25 m0054 kernel: [88344.825623] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Linked as a consumer to regulator.58
                                Apr 24 19:32:25 m0054 kernel: [88344.825737] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Linked as a consumer to regulator.60
                                Apr 24 19:32:25 m0054 kernel: [88344.825780] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Linked as a consumer to regulator.55
                                Apr 24 19:32:25 m0054 kernel: [88344.825906] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Linked as a consumer to regulator.79
                                Apr 24 19:32:25 m0054 kernel: [88344.840658] CAM_ERR: CAM-CCI: cam_cci_irq: 264 Base:        pK-error, M1_Q1 NACK ERROR: 0x40000000
                                Apr 24 19:32:25 m0054 kernel: [88344.840730] CAM_ERR: CAM-CCI: cam_cci_read: 1329 ERROR with Slave 0x34:
                                Apr 24 19:32:25 m0054 kernel: [88344.840735] CAM_ERR: CAM-CCI: cam_cci_read_bytes: 1613 failed to read rc:-22
                                Apr 24 19:32:25 m0054 kernel: [88344.840737] CAM_ERR: CAM-SENSOR: cam_cci_i2c_read: 35 rc = -22
                                Apr 24 19:32:25 m0054 kernel: [88344.840740] CAM_WARN: CAM-SENSOR: cam_sensor_match_id: 707 read id: 0x0 expected id 0x577:
                                Apr 24 19:32:25 m0054 kernel: [88344.840800] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Dropping the link to regulator.79
                                Apr 24 19:32:25 m0054 kernel: [88344.842876] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Dropping the link to regulator.55
                                Apr 24 19:32:25 m0054 kernel: [88344.842906] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Dropping the link to regulator.60
                                Apr 24 19:32:25 m0054 kernel: [88344.842943] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Dropping the link to regulator.58
                                Apr 24 19:32:25 m0054 kernel: [88344.865869] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.59
                                Apr 24 19:32:25 m0054 kernel: [88344.866000] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.60
                                Apr 24 19:32:25 m0054 kernel: [88344.866043] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.55
                                Apr 24 19:32:25 m0054 kernel: [88344.866171] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.79
                                Apr 24 19:32:25 m0054 kernel: [88344.880067] CAM_ERR: CAM-CCI: cam_cci_irq: 238 Base:        pK-error, M0_Q1 NACK ERROR: 0x10000000
                                Apr 24 19:32:25 m0054 kernel: [88344.880100] CAM_ERR: CAM-CCI: cam_cci_read: 1329 ERROR with Slave 0x34:
                                Apr 24 19:32:25 m0054 kernel: [88344.880104] CAM_ERR: CAM-CCI: cam_cci_read_bytes: 1613 failed to read rc:-22
                                Apr 24 19:32:25 m0054 kernel: [88344.880106] CAM_ERR: CAM-SENSOR: cam_cci_i2c_read: 35 rc = -22
                                Apr 24 19:32:25 m0054 kernel: [88344.880109] CAM_WARN: CAM-SENSOR: cam_sensor_match_id: 707 read id: 0x0 expected id 0x577:
                                Apr 24 19:32:25 m0054 kernel: [88344.880163] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.79
                                Apr 24 19:32:25 m0054 kernel: [88344.881467] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.55
                                Apr 24 19:32:25 m0054 kernel: [88344.881498] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.60
                                Apr 24 19:32:25 m0054 kernel: [88344.881538] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.59
                                Apr 24 19:32:25 m0054 kernel: [88344.905689] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.59
                                Apr 24 19:32:25 m0054 kernel: [88344.905829] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.60
                                Apr 24 19:32:25 m0054 kernel: [88344.905874] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.55
                                Apr 24 19:32:25 m0054 kernel: [88344.906009] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.79
                                Apr 24 19:32:25 m0054 kernel: [88344.920664] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 918 Probe success,slot:3,slave_addr:0x34,sensor_id:0x577
                                Apr 24 19:32:25 m0054 kernel: [88344.920718] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.79
                                Apr 24 19:32:25 m0054 kernel: [88344.922792] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.55
                                Apr 24 19:32:25 m0054 kernel: [88344.922822] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.60
                                Apr 24 19:32:25 m0054 kernel: [88344.922861] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.59
                                Apr 24 19:32:25 m0054 kernel: [88344.935529] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor4: Linked as a consumer to regulator.59
                                Apr 24 19:32:25 m0054 kernel: [88344.935651] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor4: Linked as a consumer to regulator.60
                                Apr 24 19:32:25 m0054 kernel: [88344.935696] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor4: Linked as a consumer to regulator.55
                                Apr 24 19:32:25 m0054 kernel: [88344.936089] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor4: Linked as a consumer to regulator.79
                                Apr 24 19:32:25 m0054 kernel: [88344.950853] CAM_ERR: CAM-CCI: cam_cci_irq: 264 Base:        pK-error, M1_Q1 NACK ERROR: 0x40000000
                                Apr 24 19:32:25 m0054 kernel: [88344.950884] CAM_ERR: CAM-CCI: cam_cci_read: 1329 ERROR with Slave 0x34:
                                Apr 24 19:32:25 m0054 kernel: [88344.950890] CAM_ERR: CAM-CCI: cam_cci_read_bytes: 1613 failed to read rc:-22
                                Apr 24 19:32:25 m0054 kernel: [88344.950893] CAM_ERR: CAM-SENSOR: cam_cci_i2c_read: 35 rc = -22
                                Apr 24 19:32:25 m0054 kernel: [88344.950897] CAM_WARN: CAM-SENSOR: cam_sensor_match_id: 707 read id: 0x0 expected id 0x577:
                                Apr 24 19:32:25 m0054 kernel: [88344.950969] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor4: Dropping the link to regulator.79
                                Apr 24 19:32:25 m0054 kernel: [88344.953024] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor4: Dropping the link to regulator.55
                                Apr 24 19:32:25 m0054 kernel: [88344.953077] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor4: Dropping the link to regulator.60
                                Apr 24 19:32:25 m0054 kernel: [88344.977985] qcom,camera ac50000.qcom,cci:qcom,cam-sensor5: Linked as a consumer to regulator.59
                                Apr 24 19:32:25 m0054 kernel: [88344.978070] qcom,camera ac50000.qcom,cci:qcom,cam-sensor5: Linked as a consumer to regulator.60
                                Apr 24 19:32:25 m0054 kernel: [88344.978115] qcom,camera ac50000.qcom,cci:qcom,cam-sensor5: Linked as a consumer to regulator.55
                                Apr 24 19:32:25 m0054 kernel: [88344.978240] qcom,camera ac50000.qcom,cci:qcom,cam-sensor5: Linked as a consumer to regulator.79
                                Apr 24 19:32:25 m0054 kernel: [88344.992921] CAM_ERR: CAM-CCI: cam_cci_irq: 264 Base:        pK-error, M1_Q1 NACK ERROR: 0x40000000
                                Apr 24 19:32:25 m0054 kernel: [88344.993008] CAM_ERR: CAM-CCI: cam_cci_read: 1329 ERROR with Slave 0x34:
                                Apr 24 19:32:25 m0054 kernel: [88344.993045] CAM_ERR: CAM-CCI: cam_cci_read_bytes: 1613 failed to read rc:-22
                                Apr 24 19:32:25 m0054 kernel: [88344.993048] CAM_ERR: CAM-SENSOR: cam_cci_i2c_read: 35 rc = -22
                                Apr 24 19:32:25 m0054 kernel: [88344.993050] CAM_WARN: CAM-SENSOR: cam_sensor_match_id: 707 read id: 0x0 expected id 0x577:
                                Apr 24 19:32:25 m0054 kernel: [88344.993117] qcom,camera ac50000.qcom,cci:qcom,cam-sensor5: Dropping the link to regulator.79
                                Apr 24 19:32:25 m0054 kernel: [88344.995197] qcom,camera ac50000.qcom,cci:qcom,cam-sensor5: Dropping the link to regulator.55
                                Apr 24 19:32:25 m0054 kernel: [88344.995226] qcom,camera ac50000.qcom,cci:qcom,cam-sensor5: Dropping the link to regulator.60
                                Apr 24 19:32:25 m0054 kernel: [88344.995271] qcom,camera ac50000.qcom,cci:qcom,cam-sensor5: Dropping the link to regulator.59
                                Apr 24 19:32:25 m0054 kernel: [88345.040157] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.59
                                Apr 24 19:32:25 m0054 kernel: [88345.040247] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.60
                                Apr 24 19:32:25 m0054 kernel: [88345.040267] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.55
                                Apr 24 19:32:25 m0054 kernel: [88345.040362] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.79
                                Apr 24 19:32:25 m0054 kernel: [88345.054061] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 997 CAM_ACQUIRE_DEV Success, sensor_id:0x577,sensor_slave_addr:0x34
                                Apr 24 19:32:25 m0054 kernel: [88345.055287] CAM_INFO: CAM-HFI: cam_hfi_resume: 679 Resume IO1 : [0x10c00000 0xcf300000] IO2 [0xe0200000 0x1ed00000]
                                Apr 24 19:32:25 m0054 kernel: [88345.085767] msm_vidc:   high: 00000001: ....e: Opening video instance: ffffffd908ed6000, 0
                                Apr 24 19:32:25 m0054 kernel: [88345.361053] CAM_ERR: CAM-ISP: cam_ife_csid_cid_reserve: 1040 CSID:6 IPP resource not available
                                Apr 24 19:32:25 m0054 kernel: [88345.361057] CAM_ERR: CAM-ISP: cam_ife_csid_cid_reserve: 1040 CSID:5 IPP resource not available
                                Apr 24 19:32:25 m0054 kernel: [88345.361059] CAM_ERR: CAM-ISP: cam_ife_csid_cid_reserve: 1040 CSID:4 IPP resource not available
                                Apr 24 19:32:25 m0054 kernel: [88345.361061] CAM_ERR: CAM-ISP: cam_ife_csid_cid_reserve: 1040 CSID:3 IPP resource not available
                                Apr 24 19:32:25 m0054 kernel: [88345.361062] CAM_ERR: CAM-ISP: cam_ife_csid_cid_reserve: 1040 CSID:2 IPP resource not available
                                Apr 24 19:32:25 m0054 kernel: [88345.361091] CAM_ERR: CAM-ISP: cam_ife_hw_mgr_print_acquire_info: 710 Successfully acquire single IFE[1 -1] with [9 pix] [0 pd] [1 rdi] ports for ctx:9
                                Apr 24 19:32:25 m0054 kernel: [88345.365802] CAM_INFO: CAM-CSIPHY: cam_csiphy_core_cfg: 1137 START_DEV: CSIPHY_IDX: 3, Device_slot: 0, Datarate: 2500000000, Settletime: 2200000000
                                Apr 24 19:32:25 m0054 kernel: [88345.374728] CAM_INFO: CAM-ISP: cam_vfe_bus_ver3_init_hw: 3659 Overriding clock gating at bus input
                                Apr 24 19:32:25 m0054 kernel: [88345.374732] CAM_INFO: CAM-ISP: cam_vfe_top_ver3_init_hw: 246 Disable clock gating at IFE top
                                Apr 24 19:32:25 m0054 kernel: [88345.374879] CAM_ERR: CAM-ISP: cam_ife_mgr_start_hw: 4510 ->Config HW, 0000000013f5b900
                                Apr 24 19:32:25 m0054 kernel: [88345.376000] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1089 CAM_START_DEV Success, sensor_id:0x577,sensor_slave_addr:0x34
                                Apr 24 19:32:26 m0054 voxl-cpu-monitor[1757]: client "voxl-camera-server51691034" with id 0 has disconnected from channel 0
                                Apr 24 19:32:26 m0054 voxl-cpu-monitor[1757]: client "voxl-camera-server88398822" connected to channel 0  with client id 0
                                Apr 24 19:32:30 m0054 kernel: [88350.083476] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx  0 fd 130 off 0 size 884736 filled 0
                                Apr 24 19:32:30 m0054 kernel: [88350.083481] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx  1 fd 132 off 0 size 884736 filled 0
                                Apr 24 19:32:30 m0054 kernel: [88350.083482] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx  2 fd 134 off 0 size 884736 filled 0
                                Apr 24 19:32:30 m0054 kernel: [88350.083484] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx  3 fd 136 off 0 size 884736 filled 0
                                Apr 24 19:32:30 m0054 kernel: [88350.083485] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx  4 fd 138 off 0 size 884736 filled 0
                                Apr 24 19:32:30 m0054 kernel: [88350.083486] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx  5 fd 140 off 0 size 884736 filled 0
                                Apr 24 19:32:30 m0054 kernel: [88350.083487] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx  6 fd 142 off 0 size 884736 filled 0
                                Apr 24 19:32:30 m0054 kernel: [88350.083488] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx  7 fd 144 off 0 size 884736 filled 0
                                Apr 24 19:32:30 m0054 kernel: [88350.083489] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx  8 fd 146 off 0 size 884736 filled 0
                                Apr 24 19:32:30 m0054 kernel: [88350.083490] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx  9 fd 148 off 0 size 884736 filled 0
                                Apr 24 19:32:30 m0054 kernel: [88350.083491] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx 10 fd 150 off 0 size 884736 filled 0
                                Apr 24 19:32:30 m0054 kernel: [88350.083492] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx 11 fd 152 off 0 size 884736 filled 0
                                Apr 24 19:32:30 m0054 kernel: [88350.083493] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx 12 fd 154 off 0 size 884736 filled 0
                                Apr 24 19:32:30 m0054 kernel: [88350.083494] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx 13 fd 156 off 0 size 884736 filled 0
                                Apr 24 19:32:30 m0054 kernel: [88350.083495] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx 14 fd 158 off 0 size 884736 filled 0
                                Apr 24 19:32:30 m0054 kernel: [88350.083496] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx 15 fd 160 off 0 size 884736 filled 0
                                Apr 24 19:32:30 m0054 kernel: [88350.083500] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx  0 fd 130 off 0 daddr dfb00000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                Apr 24 19:32:30 m0054 kernel: [88350.083511] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx  1 fd 132 off 0 daddr dfa00000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                Apr 24 19:32:30 m0054 kernel: [88350.083515] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx  2 fd 134 off 0 daddr df900000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                Apr 24 19:32:30 m0054 kernel: [88350.083519] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx  3 fd 136 off 0 daddr df800000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                Apr 24 19:32:30 m0054 kernel: [88350.083522] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx  4 fd 138 off 0 daddr df700000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                Apr 24 19:32:30 m0054 kernel: [88350.083525] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx  5 fd 140 off 0 daddr df600000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                Apr 24 19:32:30 m0054 kernel: [88350.083528] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx  6 fd 142 off 0 daddr df500000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                Apr 24 19:32:30 m0054 kernel: [88350.083532] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx  7 fd 144 off 0 daddr df400000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                Apr 24 19:32:30 m0054 kernel: [88350.083534] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx  8 fd 146 off 0 daddr df300000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                Apr 24 19:32:30 m0054 kernel: [88350.083537] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx  9 fd 148 off 0 daddr df200000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                Apr 24 19:32:30 m0054 kernel: [88350.083540] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx 10 fd 150 off 0 daddr df100000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                Apr 24 19:32:30 m0054 kernel: [88350.083543] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx 11 fd 152 off 0 daddr df000000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                Apr 24 19:32:30 m0054 kernel: [88350.083546] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx 12 fd 154 off 0 daddr def00000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                Apr 24 19:32:30 m0054 kernel: [88350.083549] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx 13 fd 156 off 0 daddr dee00000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                Apr 24 19:32:30 m0054 kernel: [88350.083552] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx 14 fd 158 off 0 daddr ded00000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                Apr 24 19:32:30 m0054 kernel: [88350.083554] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx 15 fd 160 off 0 daddr dec00000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                Apr 24 19:32:30 m0054 voxl-portal[1760]: ERROR in pipe_client_open opening request pipe: No such device or address
                                Apr 24 19:32:30 m0054 voxl-portal[1760]: Most likely the server stopped without cleaning up
                                Apr 24 19:32:30 m0054 voxl-portal[1760]: Client is cleaning up pipes for the server
                                Apr 24 19:32:30 m0054 kernel: [88350.096208] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.79
                                Apr 24 19:32:30 m0054 kernel: [88350.098251] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.55
                                Apr 24 19:32:30 m0054 kernel: [88350.098263] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.60
                                Apr 24 19:32:30 m0054 kernel: [88350.098279] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.59
                                Apr 24 19:32:30 m0054 kernel: [88350.106121] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 1
                                Apr 24 19:32:30 m0054 kernel: [88350.106122] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 2
                                Apr 24 19:32:30 m0054 kernel: [88350.106123] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 2
                                Apr 24 19:32:30 m0054 kernel: [88350.106124] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 2
                                Apr 24 19:32:30 m0054 kernel: [88350.106125] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 3
                                Apr 24 19:32:30 m0054 kernel: [88350.106127] CAM_ERR: CAM-ISP: __cam_isp_ctx_release_dev_in_top_state: 3789 releasing hw
                                Apr 24 19:32:30 m0054 kernel: [88350.106156] CAM_WARN: CAM-CRM: cam_req_mgr_close: 160 release invoked associated userspace process has died
                                Apr 24 19:32:30 m0054 kernel: [88350.106286] CAM-REQ-MGR_UTIL cam_req_mgr_util_free_hdls:99 CAM_WARN: CAM-CRM: cam_req_mgr_util_free_hdls: 99 Dev handle = 5a0103 session_handle = 7e0200
                                Apr 24 19:32:30 m0054 kernel: [88350.119201] ion_buffer_destroy: 6 callbacks suppressed
                                Apr 24 19:32:30 m0054 kernel: [88350.119252] ION client likely missing a call to dma_buf_kunmap or dma_buf_vunmap
                                Apr 24 19:32:30 m0054 kernel: [88350.133256] ION client likely missing a call to dma_buf_kunmap or dma_buf_vunmap
                                Apr 24 19:32:30 m0054 kernel: [88350.133270] ION client likely missing a call to dma_buf_kunmap or dma_buf_vunmap
                                Apr 24 19:32:30 m0054 kernel: [88350.133287] ION client likely missing a call to dma_buf_kunmap or dma_buf_vunmap
                                Apr 24 19:32:30 m0054 kernel: [88350.133294] ION client likely missing a call to dma_buf_kunmap or dma_buf_vunmap
                                Apr 24 19:32:30 m0054 kernel: [88350.133358] ION client likely missing a call to dma_buf_kunmap or dma_buf_vunmap
                                Apr 24 19:32:30 m0054 kernel: [88350.133383] ION client likely missing a call to dma_buf_kunmap or dma_buf_vunmap
                                Apr 24 19:32:30 m0054 kernel: [88350.133392] ION client likely missing a call to dma_buf_kunmap or dma_buf_vunmap
                                Apr 24 19:32:30 m0054 kernel: [88350.133401] ION client likely missing a call to dma_buf_kunmap or dma_buf_vunmap
                                Apr 24 19:32:30 m0054 kernel: [88350.133426] ION client likely missing a call to dma_buf_kunmap or dma_buf_vunmap
                                Apr 24 19:32:31 m0054 kernel: [88351.602923] msm_vidc:   err : ffffffff: .....: DBLP Set: status 0
                                  #23
                                  @Matthew-Wellner , it looks like VOXL2 never gets any frames and after 5 seconds the camera pipeline gives up.
                                  Here is relevant part of your output:
                                  Note at 25 second mark, the camera is commanded to stream (then a few messages related to camera server pipes), but then at 30 second mark, the camera pipeline collapse starts (timeout).
                                  Here is my ouputput:
                                  [ 2075.623593] CAM_ERR: CAM-ISP: cam_ife_hw_mgr_print_acquire_info: 710 Successfully acquire single IFE[1 -1] with [9 pix] [0 pd] [1 rdi] ports for ctx:0
                                  [ 2075.632136] CAM_INFO: CAM-CSIPHY: cam_csiphy_core_cfg: 1137 START_DEV: CSIPHY_IDX: 1, Device_slot: 0, Datarate: 2500000000, Settletime: 2200000000
                                  [ 2075.642983] CAM_INFO: CAM-ISP: cam_vfe_bus_ver3_init_hw: 3659 Overriding clock gating at bus input
                                  [ 2075.642990] CAM_INFO: CAM-ISP: cam_vfe_top_ver3_init_hw: 246 Disable clock gating at IFE top
                                  [ 2075.643255] CAM_ERR: CAM-ISP: cam_ife_mgr_start_hw: 4510 ->Config HW, 00000000e4fe1a70
                                  [ 2075.647168] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1089 CAM_START_DEV Success, sensor_id:0x577,sensor_slave_addr:0x34
                                  [ 2075.655208] CAM_INFO: CAM-ISP: __cam_isp_ctx_sof_in_epoch: 1660 First SOF in EPCR ctx:2 frame_id:1 next substate EPOCH
                                  Note that there is a message that the First SOF (Start Of Frame) has been received, and streaming works fine.
                                  Can you please provide more information about your hardware:
                                  • Specific camera module used (such as M0107, M0161)
                                  • how are you connecting the camera to VOXL2 (all components between VOXL2 and Camera)
                                  • it seems the camera is connected in slot 3 (VOXL2 J7U) - please confirm
                                  • it seems you are using kernel config 0 (no M0173 camera front end) - please confirm.
                                  It is possible that if you are using an extension flex (I am guessing M0107 camera with M0036 15cm extension flex), some flexes may have high speed issues and the latest IMX412 drivers are running at the maximum MIPI rate (in this case 2.2Gbps), which may be pushing past the performance of the flex.
                                  Both versions of the IMX412 drivers that were posted on the Low Latency Streaming page were using 2.1Gbps speeds (and 2.2Gbps in one mode). However, the default drivers shipped with the SDK use 1.5Gbps (ones found in /usr/share/modalai/chi-cdk/imx412).
                                  If you want to try the slower drivers, you can make a small change in your config:
                                  • remove the existing sensormodules from /usr/lib/camera/
                                  • copy com.qti.sensormodule.imx412_3.bin from /usr/share/modalai/chi-cdk/imx412 to /usr/lib/camera
                                  • modify /etc/modalai/voxl-camera-server.conf as follows:
                                    • set en_preview to false
                                  • this should just enable one small encoded stream and the camera pipeline will choose some camera source resolution to satisfy 60fps and the resolution of your encoded stream.
                                  I just tried this on my set up and was able to get small encoded stream at 60fps with pretty low latency:
                                  |                Pipe Name |  bytes  | wide |  hgt |exp(ms)| gain | frame id |latency(ms)|  fps |  mbps  | format
                                  | hires_down_small_encoded |    8976 | 1024 |  768 |  5.26 |  800 |     1000 |     23.2  | 60.0 |    4.2 | H264 (P)
                                  Lets try to get back to a configuration that works 🙂
                                    Matthew Wellner
                                    Here is what I am running:
                                    • M0107 (purchased 12/2023 just in case there were any issues with older versions)
                                    • I am using a flex cable connected to J7U directly to the camera (I haven't moved any hardware around except for adding a wifi USB adapter for some testing that I am doing)
                                    • Yes
                                    • Yes
                                    I followed the procedure to swap out the drivers and I am still seeing the voxl-camera-server die... Did I need to remove the .so file in /usr/lib/camera as well?
                                    Apr 25 15:57:00 m0054 kernel: [161821.673062] CAM_INFO: CAM-HFI: cam_hfi_init: 878 Init IO1 : [0x10c00000 0xcf300000] IO2 [0xe0200000 0x1ed00000]
                                    Apr 25 15:57:00 m0054 kernel: [161821.683296] CAM_INFO: CAM-ICP: cam_icp_mgr_hw_open: 3879 FW download done successfully
                                    Apr 25 15:57:00 m0054 kernel: [161821.683304] CAM_INFO: CAM-ICP: cam_icp_mgr_process_dbg_buf: 2572 FW_DBG:CICP_FW_E : HFI  :QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079,OEM_IMAGE_VERSION_STRING=CRM,BUILD_TIME: Oct 17 2019 05:49:19,CACHE_ENABLED at icphostinterface.c:636 QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079 OEM_IMAGE_VERSION_STRING=CRM
                                    Apr 25 15:57:00 m0054 kernel: [161821.683308] CAM_INFO: CAM-ICP: cam_icp_mgr_process_dbg_buf: 2572 FW_DBG:CICP_FW_E : HFI  :ELF variant: CACHE-ENABLED:T480:API_V2:USE_CDM_1_1: , API version: 0x2000049 at icphostinterface.c:637 QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079 OEM_IMAGE_VERSION_STRING=CRM
                                    Apr 25 15:57:00 m0054 kernel: [161821.724105] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.59
                                    Apr 25 15:57:00 m0054 kernel: [161821.724169] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.55
                                    Apr 25 15:57:00 m0054 kernel: [161821.724234] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.60
                                    Apr 25 15:57:00 m0054 kernel: [161821.724261] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.79
                                    Apr 25 15:57:00 m0054 kernel: [161821.748891] CAM_ERR: CAM-CCI: cam_cci_irq: 264 Base:        pK-error, M1_Q1 NACK ERROR: 0x40000000
                                    Apr 25 15:57:00 m0054 kernel: [161821.751009] CAM_ERR: CAM-CCI: cam_cci_read: 1329 ERROR with Slave 0x20:
                                    Apr 25 15:57:00 m0054 kernel: [161821.751011] CAM_ERR: CAM-CCI: cam_cci_read_bytes: 1613 failed to read rc:-22
                                    Apr 25 15:57:00 m0054 kernel: [161821.751013] CAM_ERR: CAM-SENSOR: cam_cci_i2c_read: 35 rc = -22
                                    Apr 25 15:57:00 m0054 kernel: [161821.751016] CAM_WARN: CAM-SENSOR: cam_sensor_match_id: 707 read id: 0x0 expected id 0x214:
                                    Apr 25 15:57:00 m0054 kernel: [161821.751091] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.79
                                    Apr 25 15:57:00 m0054 kernel: [161821.805664] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 918 Probe success,slot:3,slave_addr:0x34,sensor_id:0x577
                                    Apr 25 15:57:00 m0054 kernel: [161821.805730] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.79
                                    Apr 25 15:57:00 m0054 kernel: [161821.807790] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.55
                                    Apr 25 15:57:00 m0054 kernel: [161821.807800] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.60
                                    Apr 25 15:57:00 m0054 kernel: [161821.807820] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.59
                                    Apr 25 15:57:00 m0054 kernel: [161821.825950] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.59
                                    Apr 25 15:57:00 m0054 kernel: [161821.826027] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.60
                                    Apr 25 15:57:00 m0054 kernel: [161821.826043] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.55
                                    Apr 25 15:57:00 m0054 kernel: [161821.826121] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.79
                                    Apr 25 15:57:00 m0054 kernel: [161821.840661] CAM_INFO: CAM-HFI: cam_hfi_resume: 679 Resume IO1 : [0x10c00000 0xcf300000] IO2 [0xe0200000 0x1ed00000]
                                    Apr 25 15:57:00 m0054 kernel: [161821.840851] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 997 CAM_ACQUIRE_DEV Success, sensor_id:0x577,sensor_slave_addr:0x34
                                    Apr 25 15:57:00 m0054 kernel: [161821.870871] msm_vidc:   high: 00000001: ....e: Opening video instance: ffffffd8fc0d2000, 0
                                    Apr 25 15:57:00 m0054 voxl-cpu-monitor[1757]: client "voxl-camera-server74194795" with id 0 has disconnected from channel 0
                                    Apr 25 15:57:00 m0054 voxl-cpu-monitor[1757]: client "voxl-camera-server94269699" connected to channel 0  with client id 0
                                    Apr 25 15:57:00 m0054 kernel: [161822.302893] CAM_ERR: CAM-ISP: cam_ife_csid_cid_reserve: 1040 CSID:6 IPP resource not available
                                    Apr 25 15:57:00 m0054 kernel: [161822.302896] CAM_ERR: CAM-ISP: cam_ife_csid_cid_reserve: 1040 CSID:5 IPP resource not available
                                    Apr 25 15:57:00 m0054 kernel: [161822.302898] CAM_ERR: CAM-ISP: cam_ife_csid_cid_reserve: 1040 CSID:4 IPP resource not available
                                    Apr 25 15:57:00 m0054 kernel: [161822.302899] CAM_ERR: CAM-ISP: cam_ife_csid_cid_reserve: 1040 CSID:3 IPP resource not available
                                    Apr 25 15:57:00 m0054 kernel: [161822.302901] CAM_ERR: CAM-ISP: cam_ife_csid_cid_reserve: 1040 CSID:2 IPP resource not available
                                    Apr 25 15:57:00 m0054 kernel: [161822.302926] CAM_ERR: CAM-ISP: cam_ife_hw_mgr_print_acquire_info: 710 Successfully acquire single IFE[1 -1] with [11 pix] [0 pd] [0 rdi] ports for ctx:1
                                    Apr 25 15:57:00 m0054 kernel: [161822.325127] CAM_ERR: CAM-ISP: cam_ife_csid_irq: 4855 CSID:1 lane 1 over flow
                                    Apr 25 15:57:00 m0054 kernel: [161822.325132] CAM_INFO: CAM-ISP: cam_ife_csid_halt_csi2: 1931 CSID: 1 cnt: 1 Halt csi2 rx
                                    Apr 25 15:57:00 m0054 kernel: [161822.325141] CAM_INFO: CAM-CSIPHY: cam_csiphy_subdev_handle_message: 22 subdev index : 0 CSIPHY index: 3
                                    Apr 25 15:57:00 m0054 kernel: [161822.325144] CAM_INFO: CAM-CSIPHY: cam_csiphy_subdev_handle_message: 22 subdev index : 1 CSIPHY index: 3
                                    Apr 25 15:57:00 m0054 kernel: [161822.325146] CAM_INFO: CAM-CSIPHY: cam_csiphy_subdev_handle_message: 22 subdev index : 2 CSIPHY index: 3
                                    Apr 25 15:57:00 m0054 kernel: [161822.325149] CAM_INFO: CAM-CSIPHY: cam_csiphy_subdev_handle_message: 22 subdev index : 3 CSIPHY index: 3
                                    Apr 25 15:57:00 m0054 kernel: [161822.325154] CAM_INFO: CAM-CSIPHY: cam_csiphy_status_dmp: 103 PHY base addr=        pK-error offset=0x8b0 size=11
                                    Apr 25 15:57:00 m0054 kernel: [161822.325160] CAM_INFO: CAM-CSIPHY: cam_csiphy_status_dmp: 117 CSIPHY3_IRQ_STATUS_ADDR0 = 0x14
                                    Apr 25 15:57:00 m0054 kernel: [161822.325164] CAM_INFO: CAM-CSIPHY: cam_csiphy_status_dmp: 117 CSIPHY3_IRQ_STATUS_ADDR1 = 0x0
                                    Apr 25 15:57:00 m0054 kernel: [161822.325169] CAM_INFO: CAM-CSIPHY: cam_csiphy_status_dmp: 117 CSIPHY3_IRQ_STATUS_ADDR2 = 0x80
                                    Apr 25 15:57:00 m0054 kernel: [161822.325173] CAM_INFO: CAM-CSIPHY: cam_csiphy_status_dmp: 117 CSIPHY3_IRQ_STATUS_ADDR3 = 0x22
                                    Apr 25 15:57:00 m0054 kernel: [161822.325178] CAM_INFO: CAM-CSIPHY: cam_csiphy_status_dmp: 117 CSIPHY3_IRQ_STATUS_ADDR4 = 0x0
                                    Apr 25 15:57:00 m0054 kernel: [161822.325183] CAM_INFO: CAM-CSIPHY: cam_csiphy_status_dmp: 117 CSIPHY3_IRQ_STATUS_ADDR5 = 0x50
                                    Apr 25 15:57:00 m0054 kernel: [161822.325187] CAM_INFO: CAM-CSIPHY: cam_csiphy_status_dmp: 117 CSIPHY3_IRQ_STATUS_ADDR6 = 0x0
                                    Apr 25 15:57:00 m0054 kernel: [161822.325192] CAM_INFO: CAM-CSIPHY: cam_csiphy_status_dmp: 117 CSIPHY3_IRQ_STATUS_ADDR7 = 0x0
                                    Apr 25 15:57:00 m0054 kernel: [161822.325197] CAM_INFO: CAM-CSIPHY: cam_csiphy_status_dmp: 117 CSIPHY3_IRQ_STATUS_ADDR8 = 0xa
                                    Apr 25 15:57:00 m0054 kernel: [161822.325201] CAM_INFO: CAM-CSIPHY: cam_csiphy_status_dmp: 117 CSIPHY3_IRQ_STATUS_ADDR9 = 0x40
                                    Apr 25 15:57:00 m0054 kernel: [161822.325206] CAM_INFO: CAM-CSIPHY: cam_csiphy_status_dmp: 117 CSIPHY3_IRQ_STATUS_ADDR10 = 0x4
                                    Apr 25 15:57:00 m0054 kernel: [161822.325209] CAM_INFO: CAM-CSIPHY: cam_csiphy_subdev_handle_message: 22 subdev index : 4 CSIPHY index: 3
                                    Apr 25 15:57:00 m0054 kernel: [161822.325211] CAM_INFO: CAM-CSIPHY: cam_csiphy_subdev_handle_message: 22 subdev index : 5 CSIPHY index: 3
                                    Apr 25 15:57:00 m0054 kernel: [161822.325265] CAM_ERR: CAM-ISP: cam_csid_evt_bottom_half_handler: 4616 idx 1 err 5 phy 3  lane type:0 ln num:4 ln cfg:0x3210 cnt 1
                                    Apr 25 15:57:00 m0054 kernel: [161822.325271] cam_csid_evt_bottom_half_handler: 1 callbacks suppressed
                                    Apr 25 15:57:00 m0054 kernel: [161822.325280] CAM_ERR: CAM-ISP: cam_csid_evt_bottom_half_handler: 4621 status RDI0: 0
                                    Apr 25 15:57:00 m0054 kernel: [161822.325285] CAM_ERR: CAM-ISP: cam_csid_evt_bottom_half_handler: 4621 status RDI1: 0
                                    Apr 25 15:57:00 m0054 kernel: [161822.325294] CAM_ERR: CAM-ISP: cam_csid_evt_bottom_half_handler: 4621 status RDI2: 0
                                    Apr 25 15:57:00 m0054 kernel: [161822.325303] CAM_ERR: CAM-ISP: cam_csid_evt_bottom_half_handler: 4621 status RDI3: 0
                                    Apr 25 15:57:01 m0054 kernel: [161823.383488] msm_vidc:   err : ffffffff: .....: DBLP Set: status 0
                                    Apr 25 15:57:05 m0054 kernel: [161827.032884] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx  0 fd 96 off 0 size 884736 filled 0
                                    Apr 25 15:57:05 m0054 kernel: [161827.032888] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx  1 fd 98 off 0 size 884736 filled 0
                                    Apr 25 15:57:05 m0054 kernel: [161827.032890] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx  2 fd 100 off 0 size 884736 filled 0
                                    Apr 25 15:57:05 m0054 kernel: [161827.032891] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx  3 fd 102 off 0 size 884736 filled 0
                                    Apr 25 15:57:05 m0054 kernel: [161827.032893] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx  4 fd 104 off 0 size 884736 filled 0
                                    Apr 25 15:57:05 m0054 kernel: [161827.032894] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx  5 fd 106 off 0 size 884736 filled 0
                                    Apr 25 15:57:05 m0054 kernel: [161827.032895] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx  6 fd 108 off 0 size 884736 filled 0
                                    Apr 25 15:57:05 m0054 kernel: [161827.032897] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx  7 fd 110 off 0 size 884736 filled 0
                                    Apr 25 15:57:05 m0054 kernel: [161827.032898] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx  8 fd 112 off 0 size 884736 filled 0
                                    Apr 25 15:57:05 m0054 kernel: [161827.032899] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx  9 fd 114 off 0 size 884736 filled 0
                                    Apr 25 15:57:05 m0054 kernel: [161827.032901] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx 10 fd 116 off 0 size 884736 filled 0
                                    Apr 25 15:57:05 m0054 kernel: [161827.032902] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx 11 fd 118 off 0 size 884736 filled 0
                                    Apr 25 15:57:05 m0054 kernel: [161827.032903] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx 12 fd 120 off 0 size 884736 filled 0
                                    Apr 25 15:57:05 m0054 kernel: [161827.032905] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx 13 fd 122 off 0 size 884736 filled 0
                                    Apr 25 15:57:05 m0054 kernel: [161827.032906] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx 14 fd 124 off 0 size 884736 filled 0
                                    Apr 25 15:57:05 m0054 kernel: [161827.032907] msm_vidc:   err : 00000001: h265e: undequeud vb2: CAPTURE: idx 15 fd 126 off 0 size 884736 filled 0
                                    Apr 25 15:57:05 m0054 kernel: [161827.032910] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx  0 fd 96 off 0 daddr dfb00000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                    Apr 25 15:57:05 m0054 kernel: [161827.032921] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx  1 fd 98 off 0 daddr dfa00000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                    Apr 25 15:57:05 m0054 kernel: [161827.032925] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx  2 fd 100 off 0 daddr df900000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                    Apr 25 15:57:05 m0054 kernel: [161827.032929] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx  3 fd 102 off 0 daddr df800000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                    Apr 25 15:57:05 m0054 kernel: [161827.032932] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx  4 fd 104 off 0 daddr df700000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                    Apr 25 15:57:05 m0054 kernel: [161827.032936] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx  5 fd 106 off 0 daddr df600000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                    Apr 25 15:57:05 m0054 kernel: [161827.032939] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx  6 fd 108 off 0 daddr df500000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                    Apr 25 15:57:05 m0054 kernel: [161827.032942] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx  7 fd 110 off 0 daddr df400000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                    Apr 25 15:57:05 m0054 kernel: [161827.032944] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx  8 fd 112 off 0 daddr df300000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                    Apr 25 15:57:05 m0054 kernel: [161827.032947] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx  9 fd 114 off 0 daddr df200000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                    Apr 25 15:57:05 m0054 kernel: [161827.032952] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx 10 fd 116 off 0 daddr df100000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                    Apr 25 15:57:05 m0054 kernel: [161827.032955] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx 11 fd 118 off 0 daddr df000000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                    Apr 25 15:57:05 m0054 kernel: [161827.032958] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx 12 fd 120 off 0 daddr def00000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                    Apr 25 15:57:05 m0054 kernel: [161827.032960] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx 13 fd 122 off 0 daddr dee00000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                    Apr 25 15:57:05 m0054 kernel: [161827.032963] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx 14 fd 124 off 0 daddr ded00000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                    Apr 25 15:57:05 m0054 kernel: [161827.032965] msm_vidc:   err : 00000001: h265e: undequeud buf: CAPTURE: idx 15 fd 126 off 0 daddr dec00000 size 884736 filled 0 flags 0x0 ts 0 refcnt 2 mflags 0x1
                                    Apr 25 15:57:05 m0054 voxl-portal[1760]: ERROR in pipe_client_open opening request pipe: No such device or address
                                    Apr 25 15:57:05 m0054 kernel: [161827.035402] msm_vidc:   err : 00000001: h265e: State not recognized
                                    Apr 25 15:57:05 m0054 kernel: [161827.035404] msm_vidc:   err : 00000001: h265e: Failed to move from state: 16 to 13
                                    Apr 25 15:57:05 m0054 kernel: [161827.035408] msm_vidc:   err : 00000001: h265e: msm_comm_kill_session: no session to kill for inst ffffffd8fc0d2000
                                    Apr 25 15:57:05 m0054 kernel: [161827.035409] msm_vidc:   err : 00000001: h265e: Failed to move inst: ffffffd8fc0d2000 to state 13
                                    Apr 25 15:57:05 m0054 kernel: [161827.035412] msm_vidc:   err : 00000001: h265e: Failed STOP Streaming inst = ffffffd8fc0d2000 on cap = 9
                                    Apr 25 15:57:05 m0054 kernel: [161827.035457] msm_vidc:   high: 00000001: h265e: Closed video instance: ffffffd8fc0d2000
                                    Apr 25 15:57:05 m0054 voxl-portal[1760]: Most likely the server stopped without cleaning up
                                    Apr 25 15:57:05 m0054 voxl-portal[1760]: Client is cleaning up pipes for the server
                                    Apr 25 15:57:05 m0054 kernel: [161827.044477] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.79
                                    Apr 25 15:57:05 m0054 kernel: [161827.045822] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.55
                                    Apr 25 15:57:05 m0054 kernel: [161827.045834] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.60
                                    Apr 25 15:57:05 m0054 kernel: [161827.045850] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.59
                                    Apr 25 15:57:05 m0054 kernel: [161827.053512] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 5
                                    Apr 25 15:57:05 m0054 kernel: [161827.053514] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 5
                                    Apr 25 15:57:05 m0054 kernel: [161827.053515] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 6
                                    Apr 25 15:57:05 m0054 kernel: [161827.053516] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 6
                                    Apr 25 15:57:05 m0054 kernel: [161827.053517] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 6
                                    Apr 25 15:57:05 m0054 kernel: [161827.053518] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 6
                                    Apr 25 15:57:05 m0054 kernel: [161827.053519] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 7
                                    Apr 25 15:57:05 m0054 kernel: [161827.053520] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 9
                                    Apr 25 15:57:05 m0054 kernel: [161827.053521] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 9
                                    Apr 25 15:57:05 m0054 kernel: [161827.053523] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 10
                                    Apr 25 15:57:05 m0054 kernel: [161827.053524] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 10
                                    Apr 25 15:57:05 m0054 kernel: [161827.053525] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 10
                                    Apr 25 15:57:05 m0054 kernel: [161827.053526] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 11
                                    Apr 25 15:57:05 m0054 kernel: [161827.053528] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 1
                                    Apr 25 15:57:05 m0054 kernel: [161827.053529] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 2
                                    Apr 25 15:57:05 m0054 kernel: [161827.053531] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 2
                                    Apr 25 15:57:05 m0054 kernel: [161827.053532] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 2
                                    Apr 25 15:57:05 m0054 kernel: [161827.053533] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 2
                                    Apr 25 15:57:05 m0054 kernel: [161827.053534] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 3
                                    Apr 25 15:57:05 m0054 kernel: [161827.053536] CAM_ERR: CAM-ISP: __cam_isp_ctx_release_dev_in_top_state: 3789 releasing hw
                                    Apr 25 15:57:05 m0054 kernel: [161827.053549] CAM_INFO: CAM-ISP: cam_ife_mgr_release_hw: 4755 Release HW success ctx id: 1
                                    Apr 25 15:57:05 m0054 kernel: [161827.053564] CAM_WARN: CAM-CRM: cam_req_mgr_close: 160 release invoked associated userspace process has died
                                    Apr 25 15:57:05 m0054 kernel: [161827.053591] CAM-REQ-MGR_UTIL cam_req_mgr_util_free_hdls:99 CAM_WARN: CAM-CRM: cam_req_mgr_util_free_hdls: 99 Dev handle = 1e0102 session_handle = e50200
                                    Apr 25 15:57:05 m0054 kernel: [161827.053592] CAM-REQ-MGR_UTIL cam_req_mgr_util_free_hdls:99 CAM_WARN: CAM-CRM: cam_req_mgr_util_free_hdls: 99 Dev handle = 30103 session_handle = e50200
                                    Apr 25 15:57:05 m0054 kernel: [161827.063758] ion_buffer_destroy: 6 callbacks suppressed
                                    Apr 25 15:57:05 m0054 kernel: [161827.063760] ION client likely missing a call to dma_buf_kunmap or dma_buf_vunmap
                                    Apr 25 15:57:05 m0054 kernel: [161827.063802] ION client likely missing a call to dma_buf_kunmap or dma_buf_vunmap
                                    Apr 25 15:57:05 m0054 kernel: [161827.063906] ION client likely missing a call to dma_buf_kunmap or dma_buf_vunmap
                                    Apr 25 15:57:05 m0054 kernel: [161827.063914] ION client likely missing a call to dma_buf_kunmap or dma_buf_vunmap
                                    Apr 25 15:57:05 m0054 kernel: [161827.064018] ION client likely missing a call to dma_buf_kunmap or dma_buf_vunmap
                                    Apr 25 15:57:05 m0054 kernel: [161827.064412] ION client likely missing a call to dma_buf_kunmap or dma_buf_vunmap
                                    Apr 25 15:57:05 m0054 kernel: [161827.064430] ION client likely missing a call to dma_buf_kunmap or dma_buf_vunmap
                                      • Yes
                                      • Yes
                                      @Matthew-Wellner , you should not remove the com.qti.sensor*.so file .
                                      The error looks the same as before.
                                      Do you have another flex / camera to try? what is between the M0107 and VOXL2 (as you cannot plug them in directly). What flex / adapter(s) ?
                                        Matthew WellnerM Offline
                                        Matthew Wellner
                                        The camera is connected to a smaller flex cable (camera extension flex?) that is connected to the flex cable that plugs into the VOXL2 J7U port. I don't think I have another camera here - I may, but it's definitely not the same camera.
                                        I planned to buy a micro coax cable and adapter board to use on this project, but I planned to validate the low latency setup worked before doing so 🤦
                                        I have a second VOXL2 - I might try moving the camera from this setup to the other setup and I'll go through the procedures again to verify I didn't mess up the drivers.
                                          @Matthew-Wellner , do you have a M0076 or M0135 interposer that you could plug in your short flex cable directly?
                                          Can you please check the part number that is marked on "flex cable that plugs into the VOXL2 J7U port" ? or a picture.
