  3. ESC 2 MINI rapidly blinking after firmware update
esc
14 Posts 4 Posters 2.2k Views 3 Watching
  • astro_philA astro_phil
    That's the first thing i disabled/stopped.
    I also ensured px4 is not running in voxl-inspect-services.
    Even the voxl-esc wizard does run into the same issues.
    I also removed any uart device from the connectors. Before testing the previous steps.
    @astro_phil What SDK version are you running? voxl-version
      @astro_phil , your ESC is currently in a state where the ESC firmware is corrupted, so it remains in bootloader mode, waiting to be flashed with firmware. It is not bricked (or maybe it is, depending on the definition of "bricked" 🙂 ), as it just needs to be flashed and you are running the correct procedure.
      I am unsure why this is happening, but it seems that it is not related to the ESC itself - the errors you are getting are coming from the DSP UART bridge (the UART that ESC connects to is actually routed to the DSP and there is a bridge application that allows to talk to the ESC from CPU via the DSP).
      We will get back to you with more things to try.
        Eric KatzfeyE Online
        @astro_phil Before trying the ESC commands can you double check that voxl-px4 is not running and then enter voxl-reset-slpi, then wait 5 seconds, and then try the ESC commands?
          @astro_phil Can you also capture the dmesg output when this happens?
          astro_philA 1 Reply Last reply
            astro_philA Offline
            astro_philA Offline
            astro_phil
            wrote on last edited by astro_phil
            #9
            This time it got stuck in the flashing progress.
            and i got a fatal error on slpi as seen in the dmesg log.
            voxl2:~$ voxl-version
            kernel:       #1 SMP PREEMPT Mon Nov 11 22:08:01 UTC 2024 4.19.125
            hw platform:  M0054
            mach.var:     1.0.0
            voxl-suite:   1.4.3
            Packages:
            Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.4/binary-arm64/
            Last Updated: 2025-04-09 08:14:54
            List:
            libfc-sensor                              1.0.7
            libmodal-cv                               0.5.16
            libmodal-exposure                         0.1.3
            libmodal-journal                          0.2.3
            libmodal-pipe                             2.10.6
            libqrb5165-io                             0.4.9
            libvoxl-cci-direct                        0.2.5
            modalai-slpi                              1.1.19
            qrb5165-dfs-server                        0.2.0
            qrb5165-imu-server                        1.1.3
            qrb5165-rangefinder-server                0.1.5
            qrb5165-system-tweaks                     0.3.5
            voxl-bind-spektrum                        0.1.1
            voxl-camera-calibration                   0.5.9
            voxl-camera-server                        2.1.2
            voxl-configurator                         1.0.0
            voxl-cpu-monitor                          0.5.3
            voxl-docker-support                       1.3.1
            voxl-elrs                                 0.4.2
            voxl-esc                                  1.5.1
            voxl-feature-tracker                      0.5.2
            voxl-flow-server                          0.3.6
            voxl-io-server                            0.0.5
            voxl-lepton-server                        1.3.3
            voxl-lepton-tracker                       0.0.4
            voxl-logger                               0.5.0
            voxl-mavcam-manager                       0.5.8
            voxl-mavlink                              0.1.4
            voxl-mavlink-server                       1.4.5
            voxl-modem                                1.1.5
            voxl-mpa-to-ros                           0.3.9
            voxl-mpa-tools                            1.3.7
            voxl-open-vins                            0.4.17
            voxl-open-vins-server                     0.3.0
            voxl-opencv                               4.5.5-2
            voxl-osd                                  0.1.3
            voxl-portal                               0.7.9
            voxl-px4                                  1.14.0-2.0.98
            voxl-px4-params                           0.6.7
            voxl-qvio-server                          1.1.1
            voxl-remote-id                            0.0.9
            voxl-reset-slpi                           0.0.1
            voxl-ros2-foxy                            0.0.1
            voxl-state-estimator                      0.0.4
            voxl-streamer                             0.7.5
            voxl-suite                                1.4.3
            voxl-tflite-server                        0.3.9
            voxl-utils                                1.4.6
            voxl-uvc-server                           0.1.7
            voxl-vision-hub                           1.8.20
            voxl-vtx                                  1.2.2
            voxl2-io                                  0.0.3
            voxl2-system-image                        1.8.02-r0
            Running the commands
            voxl2:~/voxl-tools/voxl-esc/voxl-esc-tools(master)$ systemctl stop voxl-px4
            voxl2:~/voxl-tools/voxl-esc/voxl-esc-tools(master)$ voxl-reset-slpi
            Sending kill slpi command!
            voxl2:~/voxl-tools/voxl-esc/voxl-esc-tools(master)$ ./voxl-esc-upload-firmware.py --firmware-baud-rate 250000 -f firmware/modalai_esc_firmware_m0129_3_v39_20_9c6233d6.bin --id 0
            [GCC 8.4.0]
            INFO: Firmware file name : firmware/modalai_esc_firmware_m0129_3_v39_20_9c6233d6.bin
            INFO: Firmware file size : 23776 bytes
            VOXL Platform: M0054
            Received standard error event SNS_STD_ERROR_NOT_SUPPORTED
            Couldn't configure flight_controller sensor
            INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 230400
            and the dmsg output
            [ +14.486977] Fatal error on slpi!
            [  +0.000114] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:UTMR_CLNT_1:0x1078:sns_thread_manager.c:497:SNS_SEE_P_0 exceeded processing time limit for library 0xb25d9728.
            [  +0.000073] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED.
            [  +0.002289] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting
            [  +0.000021] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2087]: Shutting down slpi
            [  +0.013036] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
            [  +0.000076] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040
            [  +0.000018] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040
            [  +0.003508] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service
            [  +0.000298] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service
            [  +0.000830] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi
            [  +0.000869] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi
            [  +0.001171] subsys-restart: subsystem_powerup(): [kworker/u19:0:2087]: Powering up slpi
            [  +0.000498] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
            [  +0.071421] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
            [  +0.063029] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
            [  +0.000067] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received
            [  +0.002257] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
            [  +0.000008] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2087]: Restart sequence for slpi completed.
            [  +0.000187] -139437848:Entered
            [  +0.000449] -139437848:SMD QRTR driver probed
            [  +0.010916] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
            [  +0.002408] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
            [  +0.001058] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
            [  +0.001283] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
            [ +14.493230] Fatal error on slpi!
            [  +0.000113] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:UTMR_CLNT_1:0x1078:sns_thread_manager.c:497:SNS_SEE_P_0 exceeded processing time limit for library 0xb25d94f8.
            [  +0.000070] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED.
            [  +0.001215] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting
            [  +0.000014] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2087]: Shutting down slpi
            [  +0.013131] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
            [  +0.003115] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service
            [  +0.000243] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service
            [  +0.001668] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi
            [  +0.000832] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi
            [  +0.001114] subsys-restart: subsystem_powerup(): [kworker/u19:0:2087]: Powering up slpi
            [  +0.000403] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
            [  +0.070834] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
            [  +0.062804] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
            [  +0.000058] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received
            [  +0.008549] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
            [  +0.000007] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2087]: Restart sequence for slpi completed.
            [  +0.002205] -139437848:Entered
            [  +0.002883] -139437848:SMD QRTR driver probed
            [  +0.004222] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
            [  +0.002885] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
            [  +0.000020] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
            [  +0.004621] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
            [Apr 9 08:44] Fatal error on slpi!
            • astro_philA Offline
              astro_philA Offline
              astro_phil
              #10
              I tried flashing the ESC over my PC with a USB to UART adapter, which worked flawless.
              Trying to launch px4 now yields the same error messages.
              voxl2:~$ voxl-px4
              Found DSP signature file
              [INFO] Daemon mode enabled
              AIRFRAME=MULTICOPTER
              GPS=AUTODETECT
              RC=CRSF_RAW
              ESC=VOXL_ESC
              POWER MANAGER=VOXLPM
              AIRSPEED SENSOR=NONE
              DISTANCE SENSOR=NONE
              OSD=DISABLE
              DAEMON_MODE=ENABLE
              SENSOR_CAL=ACTUAL
              ARTIFACT_MODE=DISABLE
              EXTRA STEPS:
              INFO  [muorb] [modules__muorb__slpi] muorb aggregator thread running
              INFO  [muorb] [tasks] Creating pthread test_MUORB
              INFO  [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097656
              INFO  [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097655
              INFO  [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097654
              INFO  [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097653
              ______  __   __    ___
              | ___ \ \ \ / /   /   |
              | |_/ /  \ V /   / /| |
              |  __/   /   \  / /_| |
              | |     / /^\ \ \___  |
              \_|     \/   \/     |_/
              px4 starting.
              INFO  [muorb] [uORB] Advertising remote topic log_message
              INFO  [muorb] [parameters] Starting param sync THREAD
              AIRFRAME: MULTICOPTER
              GPS: AUTODETECT
              RC: CRSF_RAW
              ESC: VOXL_ESC
              POWER MANAGER: VOXLPM
              AIRSPEED SENSOR: NONE
              DISTANCE SENSOR: NONE
              OSD: DISABLE
              ARTIFACT_MODE: DISABLE
              EXTRA STEPS:
              Running on M0054
              INFO  [muorb] [qshell] before starting the qshell_entry task
              INFO  [muorb] [tasks] Creating pthread qshell
              INFO  [muorb] [qshell] qshell entry.....
              INFO  [muorb] [tasks] Successfully created px4 task PX4_qshell with tid 2097652
              INFO  [muorb] [qshell] Init app map initialized
              INFO  [muorb] [qshell] after starting the qshell_entry task
              INFO  [muorb] [uORB] Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
              INFO  [muorb] [uORB] Advertising remote topic parameter_update
              INFO  [muorb] [uORB] Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_t
              INFO  [muorb] [uORB] Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_t
              >>> Got an exception from send_request <<<
              >>> Send succeeded after retries <<<
              Sending topic message
              --- msg_id: 1033
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_XY_VEL_I_ACC
              --- topic name: parameter_client_set_value_request
              --- msg_id: 1033
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_XY_VEL_MAX
              Connection error: connection reset
              --- msg_id: 1033
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_XY_VEL_P_ACC
              Got flight controller event
              Got response cb 0
              --- msg_id: 1033
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_YAW_EXPO
              Got response cb 0
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_Z_MAN_EXPO
              --- msg_id: 1033
              Got response cb 0
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_Z_P
              --- msg_id: 1033
              Got response cb 0
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_Z_VEL_MAX_DN
              --- msg_id: 1033
              Got response cb 0
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_Z_VEL_MAX_UP
              --- msg_id: 1033
              Got response cb 0
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_Z_VEL_P_ACC
              --- msg_id: 1033
              Got response cb 0
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC5_MAX
              --- msg_id: 1033
              Got response cb 0
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC5_MIN
              --- msg_id: 1033
              Got response cb 0
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC6_MAX
              --- msg_id: 1033
              Got response cb 0
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC6_MIN
              --- msg_id: 1033
              Got response cb 0
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC7_MAX
              --- msg_id: 1033
              Got response cb 0
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC7_MIN
              --- msg_id: 1033
              Got response cb 0
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC8_MAX
              --- msg_id: 1033
              Got response cb 0
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC8_MIN
              --- msg_id: 1033
              Got response cb 0
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC_CHAN_CNT
              --- msg_id: 1033
              Got response cb 0
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC_MAP_FLTMODE
              --- msg_id: 1033
              Got response cb 0
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC_MAP_KILL_SW
              --- msg_id: 1033
              Got response cb 0
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC_MAP_PITCH
              --- msg_id: 1033
              Got response cb 0
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC_MAP_ROLL
              --- msg_id: 1033
              Got response cb 0
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC_MAP_THROTTLE
              --- msg_id: 1033
              Got response cb 0
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC_MAP_YAW
              --- msg_id: 1033
              Got response cb 0
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for SDLOG_PROFILE
              --- msg_id: 1033
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for SYS_AUTOSTART
              --- msg_id: 1033
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for THR_MDL_FAC
              --- msg_id: 1033
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for VOXL_ESC_BAUD
              --- msg_id: 1033
              Got response cb 0
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for VOXL_ESC_CONFIG
              --- msg_id: 1033
              Got response cb 0
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for VOXL_ESC_FUNC1
              --- msg_id: 1033
              Got response cb 0
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for VOXL_ESC_FUNC2
              --- msg_id: 1033
              Got response cb 0
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for VOXL_ESC_FUNC3
              --- msg_id: 1033
              Got response cb 0
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for VOXL_ESC_FUNC4
              --- msg_id: 1033
              Got response cb 0
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for VOXL_ESC_RPM_MIN
              --- msg_id: 1033
              Got response cb 0
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for VOXL_ESC_VLOG
              INFO  [parameters] BSON document size 2522 bytes, decoded 2522 bytes (INT32:34, FLOAT:82)
              --- msg_id: 1030
              --- topic name: qshell_req
              --- msg_id: 1033
              Got response cb 0
              Got response cb 0
              ERROR [qshell] Command failed
              --- msg_id: 1030
              --- msg_id: 1033
              Got response cb 0
              Got response cb 0
              dmesg output
              [  +0.007947] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
              [Apr 9 13:16] Fatal error on slpi!
              [  +0.000121] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:SNS_SEE_I_0:0x69:sns_stream_service.c:436:req_found.
              [  +0.000062] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED.
              [  +0.001457] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting
              [  +0.000014] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2079]: Shutting down slpi
              [  +0.013438] rpmh_rsc_send_data: 3 callbacks suppressed
              [  +0.000008] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
              [  +0.000020] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
              [  +0.003267] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service
              [  +0.000012] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi
              [  +0.001113] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service
              [  +0.003764] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi
              [  +0.001176] subsys-restart: subsystem_powerup(): [kworker/u19:0:2079]: Powering up slpi
              [  +0.000494] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
              [  +0.064541] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
              [  +0.062698] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
              [  +0.000048] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received
              [  +0.003001] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
              [  +0.000014] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2079]: Restart sequence for slpi completed.
              [  +0.007566] 359684328:Entered
              [  +0.000623] 359684328:SMD QRTR driver probed
              [  +0.002753] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
              [  +0.000358] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
              [  +0.007085] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
              [  +0.001658] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
              [ +14.479033] Fatal error on slpi!
              [  +0.000111] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:UTMR_CLNT_1:0x1078:sns_thread_manager.c:497:SNS_SEE_P_1 exceeded processing time limit for library 0xb25d9728.
              [  +0.000074] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED.
              [  +0.001843] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting
              [  +0.000015] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2079]: Shutting down slpi
              [  +0.013163] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
              [  +0.003133] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi
              [  +0.000080] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service
              [  +0.000157] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service
              [  +0.001062] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi
              [  +0.003001] subsys-restart: subsystem_powerup(): [kworker/u19:0:2079]: Powering up slpi
              [  +0.000382] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
              [  +0.070747] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
              [  +0.061514] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
              [  +0.000270] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received
              [  +0.006709] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
              [  +0.000016] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2079]: Restart sequence for slpi completed.
              [  +0.000103] 359684328:Entered
              [  +0.001518] 359684328:SMD QRTR driver probed
              [  +0.001876] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
              [  +0.002996] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
              [  +0.000127] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
              [  +0.009617] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
              [  +5.216763] Fatal error on slpi!
              [  +0.000116] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:SNS_SEE_I_0:0x69:sns_stream_service.c:436:req_found.
              [  +0.000061] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED.
              [  +0.001201] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting
              [  +0.000013] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2079]: Shutting down slpi
              [  +0.013377] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
              [  +0.000077] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040
              [  +0.000046] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040
              [  +0.000017] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040
              [  +0.002919] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi
              [  +0.000755] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service
              [  +0.000159] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service
              [  +0.000604] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi
              [  +0.001291] subsys-restart: subsystem_powerup(): [kworker/u19:0:2079]: Powering up slpi
              [  +0.000346] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
              [  +0.067077] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
              [  +0.061404] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
              [  +0.000263] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received
              [  +0.003080] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
              [  +0.000015] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2079]: Restart sequence for slpi completed.
              [  +0.008128] 359684328:Entered
              [  +0.002953] 359684328:SMD QRTR driver probed
              [  +0.003042] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
              [  +0.001505] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
              [  +0.000031] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
              [  +0.005837] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
                voxl2:~$ voxl-px4
                GPS=AUTODETECT
                RC=CRSF_RAW
                ESC=VOXL_ESC
                OSD=DISABLE
                DAEMON_MODE=ENABLE
                SENSOR_CAL=ACTUAL
                EXTRA STEPS:
                ______  __   __    ___
                | ___ \ \ \ / /   /   |
                | |_/ /  \ V /   / /| |
                |  __/   /   \  / /_| |
                | |     / /^\ \ \___  |
                \_|     \/   \/     |_/
                px4 starting.
                GPS: AUTODETECT
                RC: CRSF_RAW
                ESC: VOXL_ESC
                OSD: DISABLE
                EXTRA STEPS:
                Running on M0054
                --- msg_id: 1033
                --- msg_id: 1033
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1033
                --- msg_id: 1033
                --- msg_id: 1033
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1033
                Got response cb 0
                --- msg_id: 1030
                --- msg_id: 1033
                Got response cb 0
                Got response cb 0
                --- msg_id: 1030
                --- msg_id: 1033
                Got response cb 0
                Got response cb 0
                dmesg output
                @astro_phil Yeah, the DSP just keeps resetting. Either there is a hardware issue or some piece of software has been corrupted. Can you do a complete reinstallation of the SDK? Perhaps back down to v1.4.1 and just see if that makes any difference?
                  astro_philA Offline
                  astro_philA Offline
                  astro_phil
                  I reflashed the voxl with the voxl2_SDK_1.4.1
                  unfortunately, without any changes.
                  Spinning the motors with the esc-tools does work for a couple of seconds but stops with a connection reset error aswell.
                  PX4 does not start at all and i still get the SLPI error in the dmesg log.
                  voxl2:/$ voxl-version
                  kernel:       #1 SMP PREEMPT Mon Nov 11 22:47:44 UTC 2024 4.19.125
                  hw platform:  M0054
                  mach.var:     1.0.1
                  voxl-suite:   1.4.1
                  Packages:
                  Last Updated: 2025-04-10 07:49:18
                  List:
                  libfc-sensor                              1.0.7
                  libmodal-cv                               0.5.16
                  libqrb5165-io                             0.4.9
                  modalai-slpi                              1.1.19
                  qrb5165-imu-server                        1.1.2
                  qrb5165-rangefinder-server                0.1.4
                  qrb5165-system-tweaks                     0.3.4
                  voxl-camera-server                        2.1.1
                  voxl-configurator                         0.9.7
                  voxl-elrs                                 0.4.1
                  voxl-esc                                  1.5.1
                  voxl-io-server                            0.0.4
                  voxl-logger                               0.4.9
                  voxl-mavcam-manager                       0.5.7
                  voxl-mavlink-server                       1.4.4
                  voxl-modem                                1.1.5
                  voxl-open-vins                            0.4.16
                  voxl-opencv                               4.5.5-2
                  voxl-osd                                  0.1.1
                  voxl-portal                               0.7.5
                  voxl-px4                                  1.14.0-2.0.94
                  voxl-px4-params                           0.6.3
                  voxl-streamer                             0.7.5
                  voxl-suite                                1.4.1
                  voxl-utils                                1.4.4
                  voxl-vision-hub                           1.8.17
                  voxl-vtx                                  1.1.8
                  voxl2-io                                  0.0.3
                  PX4 output
                  voxl2:~/voxl-esc/voxl-esc-tools(master)$ voxl-reset-slpi
                  voxl2:~/voxl-esc/voxl-esc-tools(master)$ voxl-px4
                  GPS=AUTODETECT
                  RC=CRSF_RAW
                  ESC=VOXL_ESC
                  OSD=DISABLE
                  DAEMON_MODE=ENABLE
                  SENSOR_CAL=ACTUAL
                  EXTRA STEPS:
                  ______  __   __    ___
                  | ___ \ \ \ / /   /   |
                  | |_/ /  \ V /   / /| |
                  |  __/   /   \  / /_| |
                  | |     / /^\ \ \___  |
                  \_|     \/   \/     |_/
                  px4 starting.
                  GPS: AUTODETECT
                  RC: CRSF_RAW
                  ESC: VOXL_ESC
                  OSD: DISABLE
                  EXTRA STEPS:
                  Running on M0054
                  INFO  [parameters] BSON document size 2517 bytes, decoded 2517 bytes (INT32:35, FLOAT:81)
                  INFO  [muorb] SLPI:
                  INFO  [muorb] SLPI: >>> ICM42688P this: b2600328
                  INFO  [qshell] qshell return value timestamp: 239538233, local time: 239543342
                  INFO  [muorb] SLPI: Register interrupt b214ec48 e61eccdc b2600328
                  INFO  [muorb] SLPI: Set up I2C bus mutex for bus 5
                  INFO  [qshell] Send cmd: 'temperature_compensation start'
                  Looking for ist8308 magnetometer
                  INFO  [qshell] Send cmd: 'ist8308 start -R 12 -X -b 1'
                  Looking for ncp5623c RGB LED
                  dmesg ouput
                  [Apr10 07:58] Fatal error on slpi!
                  [  +0.000121] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:UTMR_CLNT_1:0x1078:sns_thread_manager.c:497:SNS_SEE_P_0 exceeded processing time limit for library 0xb25d94f8.
                  [  +0.000072] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED.
                  [  +0.001309] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting
                  [  +0.000014] subsys-restart: subsystem_shutdown(): [kworker/u19:0:1866]: Shutting down slpi
                  [  +0.017355] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi
                  [  +0.000147] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service
                  [  +0.003004] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi
                  [  +0.000777] subsys-restart: subsystem_powerup(): [kworker/u19:0:1866]: Powering up slpi
                  [  +0.001439] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
                  [  +0.069556] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
                  [  +0.062589] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
                  [  +0.000059] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received
                  [  +0.000130] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040
                  [  +0.002168] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
                  [  +0.000008] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:1866]: Restart sequence for slpi completed.
                  [  +0.001835] -1882171928:Entered
                  [  +0.000228] -1882171928:SMD QRTR driver probed
                  [  +0.001453] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
                  [  +0.000064] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
                  [  +0.002648] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
                  [  +0.012758] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
                  [  +2.208612] Fatal error on slpi!
                  [  +0.000113] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:SNS_SEE_I_0:0x65:sns_stream_service.c:436:req_found.
                  [  +0.001144] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting
                  [  +0.000016] subsys-restart: subsystem_shutdown(): [kworker/u19:0:1866]: Shutting down slpi
                  [  +0.013085] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                  [  +0.002398] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service
                  [  +0.000087] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service
                  [  +0.000944] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi
                  [  +0.001899] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi
                  [  +0.001040] subsys-restart: subsystem_powerup(): [kworker/u19:0:1866]: Powering up slpi
                  [  +0.000247] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
                  [  +0.062107] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
                  [  +0.061462] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
                  [  +0.004727] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
                  [  +0.000007] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:1866]: Restart sequence for slpi completed.
                  [  +0.004439] -1882171928:Entered
                  [  +0.001177] -1882171928:SMD QRTR driver probed
                  [  +0.003823] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
                  [  +0.001216] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
                  [  +0.000035] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
                  [  +0.008403] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
                    hw platform:  M0054
                    mach.var:     1.0.1
                    voxl-suite:   1.4.1
                    Packages:
                    List:
                    libfc-sensor                              1.0.7
                    libmodal-cv                               0.5.16
                    libqrb5165-io                             0.4.9
                    modalai-slpi                              1.1.19
                    voxl-elrs                                 0.4.1
                    voxl-esc                                  1.5.1
                    voxl-logger                               0.4.9
                    voxl-modem                                1.1.5
                    voxl-opencv                               4.5.5-2
                    voxl-osd                                  0.1.1
                    voxl-portal                               0.7.5
                    voxl-streamer                             0.7.5
                    voxl-suite                                1.4.1
                    voxl-utils                                1.4.4
                    voxl-vtx                                  1.1.8
                    voxl2-io                                  0.0.3
                    PX4 output
                    GPS=AUTODETECT
                    RC=CRSF_RAW
                    ESC=VOXL_ESC
                    OSD=DISABLE
                    DAEMON_MODE=ENABLE
                    SENSOR_CAL=ACTUAL
                    EXTRA STEPS:
                    ______  __   __    ___
                    | ___ \ \ \ / /   /   |
                    | |_/ /  \ V /   / /| |
                    |  __/   /   \  / /_| |
                    | |     / /^\ \ \___  |
                    \_|     \/   \/     |_/
                    px4 starting.
                    GPS: AUTODETECT
                    RC: CRSF_RAW
                    ESC: VOXL_ESC
                    OSD: DISABLE
                    EXTRA STEPS:
                    Running on M0054
                    INFO  [muorb] SLPI:
                    dmesg ouput
                    @astro_phil I think then that there must be some sort of hardware issue. Probably time to RMA the board. http://modalai.com/rma
                      astro_philA Offline
                      astro_philA Offline
                      astro_phil
                      Okay, then I'm gonna do that. Thanks for the assist.
