  3. ESC 2 MINI rapidly blinking after firmware update
esc
14 Posts 4 Posters 2.2k Views 3 Watching
  • astro_philA Offline
    astro_philA Offline
    astro_phil
    Tried to manual install the firmware but it loses connection after ish 30% of upload
    ./voxl-esc-upload-firmware.py --firmware-baud-rate 250000 -f firmware/modalai_esc_firmware_m0129_3_v39_20_9c6233d6.bin --id 0
    [GCC 8.4.0]
    INFO: Firmware file name : firmware/modalai_esc_firmware_m0129_3_v39_20_9c6233d6.bin
    INFO: Firmware file size : 23776 bytes
    VOXL Platform: M0054
    INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 230400
    Updated baud rate to 230400
    INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 230400
    INFO: ESC(s) detected: []
    WARNING: Specified ESC ID not detected; perform manual power cycle now
    INFO: Installing firmware to ESC ID 0 : firmware/modalai_esc_firmware_m0129_3_v39_20_9c6233d6.bin
            Progress:  36% [##################                                ]
    >>> Got an exception from send_request <<<
    >>> Send succeeded after retries <<<
    Connection error: connection reset
    ERROR: An error occured during the write process.
    • astro_philA astro_phil
      [GCC 8.4.0]
      @astro_phil Make sure that voxl-px4 is not running while you're trying to talk to the ESC.
      systemctl stop voxl-px4
      astro_philA 1 Reply Last reply
      -1
        astro_philA Offline
        astro_philA Offline
        astro_phil
        wrote on last edited by astro_phil
        That's the first thing i disabled/stopped.
        I also ensured px4 is not running in voxl-inspect-services.
        Even the voxl-esc wizard does run into the same issues.
        I also removed any uart device from the connectors. Before testing the previous steps.
        tomT Eric KatzfeyE 3 Replies Last reply
          @astro_phil What SDK version are you running? voxl-version
            @astro_phil , your ESC is currently in a state where the ESC firmware is corrupted, so it remains in bootloader mode, waiting to be flashed with firmware. It is not bricked (or maybe it is, depending on the definition of "bricked" 🙂 ), as it just needs to be flashed and you are running the correct procedure.
            I am unsure why this is happening, but it seems that it is not related to the ESC itself - the errors you are getting are coming from the DSP UART bridge (the UART that ESC connects to is actually routed to the DSP and there is a bridge application that allows to talk to the ESC from CPU via the DSP).
            We will get back to you with more things to try.
              Eric KatzfeyE Online
              @astro_phil Before trying the ESC commands can you double check that voxl-px4 is not running and then enter voxl-reset-slpi, then wait 5 seconds, and then try the ESC commands?
                @astro_phil Can you also capture the dmesg output when this happens?
                  astro_philA Offline
                  astro_philA Offline
                  astro_phil
                  #9
                  This time it got stuck in the flashing progress.
                  and i got a fatal error on slpi as seen in the dmesg log.
                  voxl2:~$ voxl-version
                  kernel:       #1 SMP PREEMPT Mon Nov 11 22:08:01 UTC 2024 4.19.125
                  hw platform:  M0054
                  mach.var:     1.0.0
                  voxl-suite:   1.4.3
                  Packages:
                  Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.4/binary-arm64/
                  Last Updated: 2025-04-09 08:14:54
                  List:
                  libfc-sensor                              1.0.7
                  libmodal-cv                               0.5.16
                  libmodal-exposure                         0.1.3
                  libmodal-journal                          0.2.3
                  libmodal-pipe                             2.10.6
                  libqrb5165-io                             0.4.9
                  libvoxl-cci-direct                        0.2.5
                  modalai-slpi                              1.1.19
                  qrb5165-dfs-server                        0.2.0
                  qrb5165-imu-server                        1.1.3
                  qrb5165-rangefinder-server                0.1.5
                  qrb5165-system-tweaks                     0.3.5
                  voxl-bind-spektrum                        0.1.1
                  voxl-camera-calibration                   0.5.9
                  voxl-camera-server                        2.1.2
                  voxl-configurator                         1.0.0
                  voxl-cpu-monitor                          0.5.3
                  voxl-docker-support                       1.3.1
                  voxl-elrs                                 0.4.2
                  voxl-esc                                  1.5.1
                  voxl-feature-tracker                      0.5.2
                  voxl-flow-server                          0.3.6
                  voxl-io-server                            0.0.5
                  voxl-lepton-server                        1.3.3
                  voxl-lepton-tracker                       0.0.4
                  voxl-logger                               0.5.0
                  voxl-mavcam-manager                       0.5.8
                  voxl-mavlink                              0.1.4
                  voxl-mavlink-server                       1.4.5
                  voxl-modem                                1.1.5
                  voxl-mpa-to-ros                           0.3.9
                  voxl-mpa-tools                            1.3.7
                  voxl-open-vins                            0.4.17
                  voxl-open-vins-server                     0.3.0
                  voxl-opencv                               4.5.5-2
                  voxl-osd                                  0.1.3
                  voxl-portal                               0.7.9
                  voxl-px4                                  1.14.0-2.0.98
                  voxl-px4-params                           0.6.7
                  voxl-qvio-server                          1.1.1
                  voxl-remote-id                            0.0.9
                  voxl-reset-slpi                           0.0.1
                  voxl-ros2-foxy                            0.0.1
                  voxl-state-estimator                      0.0.4
                  voxl-streamer                             0.7.5
                  voxl-suite                                1.4.3
                  voxl-tflite-server                        0.3.9
                  voxl-utils                                1.4.6
                  voxl-uvc-server                           0.1.7
                  voxl-vision-hub                           1.8.20
                  voxl-vtx                                  1.2.2
                  voxl2-io                                  0.0.3
                  voxl2-system-image                        1.8.02-r0
                  Running the commands
                  voxl2:~/voxl-tools/voxl-esc/voxl-esc-tools(master)$ systemctl stop voxl-px4
                  voxl2:~/voxl-tools/voxl-esc/voxl-esc-tools(master)$ voxl-reset-slpi
                  Sending kill slpi command!
                  voxl2:~/voxl-tools/voxl-esc/voxl-esc-tools(master)$ ./voxl-esc-upload-firmware.py --firmware-baud-rate 250000 -f firmware/modalai_esc_firmware_m0129_3_v39_20_9c6233d6.bin --id 0
                  [GCC 8.4.0]
                  Received standard error event SNS_STD_ERROR_NOT_SUPPORTED
                  Couldn't configure flight_controller sensor
                  and the dmsg output
                  [ +14.486977] Fatal error on slpi!
                  [  +0.000114] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:UTMR_CLNT_1:0x1078:sns_thread_manager.c:497:SNS_SEE_P_0 exceeded processing time limit for library 0xb25d9728.
                  [  +0.000073] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED.
                  [  +0.002289] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting
                  [  +0.000021] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2087]: Shutting down slpi
                  [  +0.013036] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                  [  +0.000076] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040
                  [  +0.000018] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040
                  [  +0.003508] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service
                  [  +0.000298] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service
                  [  +0.000830] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi
                  [  +0.000869] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi
                  [  +0.001171] subsys-restart: subsystem_powerup(): [kworker/u19:0:2087]: Powering up slpi
                  [  +0.000498] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
                  [  +0.071421] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
                  [  +0.063029] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
                  [  +0.000067] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received
                  [  +0.002257] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
                  [  +0.000008] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2087]: Restart sequence for slpi completed.
                  [  +0.000187] -139437848:Entered
                  [  +0.000449] -139437848:SMD QRTR driver probed
                  [  +0.010916] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
                  [  +0.002408] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
                  [  +0.001058] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
                  [  +0.001283] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
                  [ +14.493230] Fatal error on slpi!
                  [  +0.000113] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:UTMR_CLNT_1:0x1078:sns_thread_manager.c:497:SNS_SEE_P_0 exceeded processing time limit for library 0xb25d94f8.
                  [  +0.000070] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED.
                  [  +0.001215] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting
                  [  +0.000014] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2087]: Shutting down slpi
                  [  +0.013131] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                  [  +0.003115] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service
                  [  +0.000243] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service
                  [  +0.001668] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi
                  [  +0.000832] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi
                  [  +0.001114] subsys-restart: subsystem_powerup(): [kworker/u19:0:2087]: Powering up slpi
                  [  +0.000403] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
                  [  +0.070834] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
                  [  +0.062804] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
                  [  +0.000058] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received
                  [  +0.008549] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
                  [  +0.000007] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2087]: Restart sequence for slpi completed.
                  [  +0.002205] -139437848:Entered
                  [  +0.002883] -139437848:SMD QRTR driver probed
                  [  +0.004222] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
                  [  +0.002885] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
                  [  +0.000020] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
                  [  +0.004621] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
                  [Apr 9 08:44] Fatal error on slpi!
                    astro_philA Offline
                    astro_phil
                    #10
                    I tried flashing the ESC over my PC with a USB to UART adapter, which worked flawless.
                    Trying to launch px4 now yields the same error messages.
                    voxl2:~$ voxl-px4
                    Found DSP signature file
                    [INFO] Daemon mode enabled
                    AIRFRAME=MULTICOPTER
                    GPS=AUTODETECT
                    RC=CRSF_RAW
                    ESC=VOXL_ESC
                    POWER MANAGER=VOXLPM
                    AIRSPEED SENSOR=NONE
                    DISTANCE SENSOR=NONE
                    OSD=DISABLE
                    DAEMON_MODE=ENABLE
                    SENSOR_CAL=ACTUAL
                    ARTIFACT_MODE=DISABLE
                    EXTRA STEPS:
                    INFO  [muorb] [modules__muorb__slpi] muorb aggregator thread running
                    INFO  [muorb] [tasks] Creating pthread test_MUORB
                    INFO  [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097656
                    INFO  [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097655
                    INFO  [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097654
                    INFO  [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097653
                    ______  __   __    ___
                    | ___ \ \ \ / /   /   |
                    | |_/ /  \ V /   / /| |
                    |  __/   /   \  / /_| |
                    | |     / /^\ \ \___  |
                    \_|     \/   \/     |_/
                    px4 starting.
                    INFO  [muorb] [uORB] Advertising remote topic log_message
                    INFO  [muorb] [parameters] Starting param sync THREAD
                    AIRFRAME: MULTICOPTER
                    GPS: AUTODETECT
                    RC: CRSF_RAW
                    ESC: VOXL_ESC
                    POWER MANAGER: VOXLPM
                    AIRSPEED SENSOR: NONE
                    DISTANCE SENSOR: NONE
                    OSD: DISABLE
                    ARTIFACT_MODE: DISABLE
                    EXTRA STEPS:
                    Running on M0054
                    INFO  [muorb] [qshell] before starting the qshell_entry task
                    INFO  [muorb] [tasks] Creating pthread qshell
                    INFO  [muorb] [qshell] qshell entry.....
                    INFO  [muorb] [tasks] Successfully created px4 task PX4_qshell with tid 2097652
                    INFO  [muorb] [qshell] Init app map initialized
                    INFO  [muorb] [qshell] after starting the qshell_entry task
                    INFO  [muorb] [uORB] Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
                    INFO  [muorb] [uORB] Advertising remote topic parameter_update
                    INFO  [muorb] [uORB] Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_t
                    INFO  [muorb] [uORB] Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_t
                    Sending topic message
                    --- msg_id: 1033
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_XY_VEL_I_ACC
                    --- topic name: parameter_client_set_value_request
                    --- msg_id: 1033
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_XY_VEL_MAX
                    --- msg_id: 1033
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_XY_VEL_P_ACC
                    Got flight controller event
                    Got response cb 0
                    --- msg_id: 1033
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_YAW_EXPO
                    Got response cb 0
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_Z_MAN_EXPO
                    --- msg_id: 1033
                    Got response cb 0
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_Z_P
                    --- msg_id: 1033
                    Got response cb 0
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_Z_VEL_MAX_DN
                    --- msg_id: 1033
                    Got response cb 0
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_Z_VEL_MAX_UP
                    --- msg_id: 1033
                    Got response cb 0
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_Z_VEL_P_ACC
                    --- msg_id: 1033
                    Got response cb 0
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC5_MAX
                    --- msg_id: 1033
                    Got response cb 0
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC5_MIN
                    --- msg_id: 1033
                    Got response cb 0
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC6_MAX
                    --- msg_id: 1033
                    Got response cb 0
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC6_MIN
                    --- msg_id: 1033
                    Got response cb 0
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC7_MAX
                    --- msg_id: 1033
                    Got response cb 0
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC7_MIN
                    --- msg_id: 1033
                    Got response cb 0
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC8_MAX
                    --- msg_id: 1033
                    Got response cb 0
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC8_MIN
                    --- msg_id: 1033
                    Got response cb 0
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC_CHAN_CNT
                    --- msg_id: 1033
                    Got response cb 0
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC_MAP_FLTMODE
                    --- msg_id: 1033
                    Got response cb 0
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC_MAP_KILL_SW
                    --- msg_id: 1033
                    Got response cb 0
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC_MAP_PITCH
                    --- msg_id: 1033
                    Got response cb 0
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC_MAP_ROLL
                    --- msg_id: 1033
                    Got response cb 0
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC_MAP_THROTTLE
                    --- msg_id: 1033
                    Got response cb 0
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC_MAP_YAW
                    --- msg_id: 1033
                    Got response cb 0
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for SDLOG_PROFILE
                    --- msg_id: 1033
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for SYS_AUTOSTART
                    --- msg_id: 1033
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for THR_MDL_FAC
                    --- msg_id: 1033
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for VOXL_ESC_BAUD
                    --- msg_id: 1033
                    Got response cb 0
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for VOXL_ESC_CONFIG
                    --- msg_id: 1033
                    Got response cb 0
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for VOXL_ESC_FUNC1
                    --- msg_id: 1033
                    Got response cb 0
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for VOXL_ESC_FUNC2
                    --- msg_id: 1033
                    Got response cb 0
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for VOXL_ESC_FUNC3
                    --- msg_id: 1033
                    Got response cb 0
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for VOXL_ESC_FUNC4
                    --- msg_id: 1033
                    Got response cb 0
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for VOXL_ESC_RPM_MIN
                    --- msg_id: 1033
                    Got response cb 0
                    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for VOXL_ESC_VLOG
                    INFO  [parameters] BSON document size 2522 bytes, decoded 2522 bytes (INT32:34, FLOAT:82)
                    --- msg_id: 1030
                    --- topic name: qshell_req
                    --- msg_id: 1033
                    Got response cb 0
                    Got response cb 0
                    ERROR [qshell] Command failed
                    --- msg_id: 1030
                    --- msg_id: 1033
                    Got response cb 0
                    Got response cb 0
                    dmesg output
                    [  +0.007947] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
                    [Apr 9 13:16] Fatal error on slpi!
                    [  +0.000121] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:SNS_SEE_I_0:0x69:sns_stream_service.c:436:req_found.
                    [  +0.000062] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED.
                    [  +0.001457] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting
                    [  +0.000014] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2079]: Shutting down slpi
                    [  +0.013438] rpmh_rsc_send_data: 3 callbacks suppressed
                    [  +0.000008] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                    [  +0.000020] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                    [  +0.003267] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service
                    [  +0.000012] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi
                    [  +0.001113] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service
                    [  +0.003764] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi
                    [  +0.001176] subsys-restart: subsystem_powerup(): [kworker/u19:0:2079]: Powering up slpi
                    [  +0.000494] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
                    [  +0.064541] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
                    [  +0.062698] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
                    [  +0.000048] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received
                    [  +0.003001] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
                    [  +0.000014] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2079]: Restart sequence for slpi completed.
                    [  +0.007566] 359684328:Entered
                    [  +0.000623] 359684328:SMD QRTR driver probed
                    [  +0.002753] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
                    [  +0.000358] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
                    [  +0.007085] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
                    [  +0.001658] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
                    [ +14.479033] Fatal error on slpi!
                    [  +0.000111] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:UTMR_CLNT_1:0x1078:sns_thread_manager.c:497:SNS_SEE_P_1 exceeded processing time limit for library 0xb25d9728.
                    [  +0.000074] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED.
                    [  +0.001843] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting
                    [  +0.000015] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2079]: Shutting down slpi
                    [  +0.013163] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                    [  +0.003133] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi
                    [  +0.000080] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service
                    [  +0.000157] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service
                    [  +0.001062] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi
                    [  +0.003001] subsys-restart: subsystem_powerup(): [kworker/u19:0:2079]: Powering up slpi
                    [  +0.000382] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
                    [  +0.070747] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
                    [  +0.061514] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
                    [  +0.000270] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received
                    [  +0.006709] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
                    [  +0.000016] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2079]: Restart sequence for slpi completed.
                    [  +0.000103] 359684328:Entered
                    [  +0.001518] 359684328:SMD QRTR driver probed
                    [  +0.001876] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
                    [  +0.002996] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
                    [  +0.000127] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
                    [  +0.009617] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
                    [  +5.216763] Fatal error on slpi!
                    [  +0.000116] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:SNS_SEE_I_0:0x69:sns_stream_service.c:436:req_found.
                    [  +0.000061] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED.
                    [  +0.001201] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting
                    [  +0.000013] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2079]: Shutting down slpi
                    [  +0.013377] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                    [  +0.000077] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040
                    [  +0.000046] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040
                    [  +0.000017] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040
                    [  +0.002919] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi
                    [  +0.000755] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service
                    [  +0.000159] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service
                    [  +0.000604] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi
                    [  +0.001291] subsys-restart: subsystem_powerup(): [kworker/u19:0:2079]: Powering up slpi
                    [  +0.000346] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
                    [  +0.067077] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
                    [  +0.061404] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
                    [  +0.000263] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received
                    [  +0.003080] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
                    [  +0.000015] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2079]: Restart sequence for slpi completed.
                    [  +0.008128] 359684328:Entered
                    [  +0.002953] 359684328:SMD QRTR driver probed
                    [  +0.003042] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
                    [  +0.001505] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
                    [  +0.000031] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
                    [  +0.005837] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
                      voxl2:~$ voxl-px4
                      GPS=AUTODETECT
                      RC=CRSF_RAW
                      ESC=VOXL_ESC
                      OSD=DISABLE
                      DAEMON_MODE=ENABLE
                      SENSOR_CAL=ACTUAL
                      EXTRA STEPS:
                      ______  __   __    ___
                      | ___ \ \ \ / /   /   |
                      | |_/ /  \ V /   / /| |
                      |  __/   /   \  / /_| |
                      | |     / /^\ \ \___  |
                      \_|     \/   \/     |_/
                      px4 starting.
                      GPS: AUTODETECT
                      RC: CRSF_RAW
                      ESC: VOXL_ESC
                      OSD: DISABLE
                      EXTRA STEPS:
                      Running on M0054
                      --- msg_id: 1033
                      --- msg_id: 1033
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1033
                      --- msg_id: 1033
                      --- msg_id: 1033
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1033
                      Got response cb 0
                      --- msg_id: 1030
                      --- msg_id: 1033
                      Got response cb 0
                      Got response cb 0
                      --- msg_id: 1030
                      --- msg_id: 1033
                      Got response cb 0
                      Got response cb 0
                      dmesg output
                      @astro_phil Yeah, the DSP just keeps resetting. Either there is a hardware issue or some piece of software has been corrupted. Can you do a complete reinstallation of the SDK? Perhaps back down to v1.4.1 and just see if that makes any difference?
                        astro_philA Offline
                        astro_philA Offline
                        astro_phil
                        I reflashed the voxl with the voxl2_SDK_1.4.1
                        unfortunately, without any changes.
                        Spinning the motors with the esc-tools does work for a couple of seconds but stops with a connection reset error aswell.
                        PX4 does not start at all and i still get the SLPI error in the dmesg log.
                        voxl2:/$ voxl-version
                        kernel:       #1 SMP PREEMPT Mon Nov 11 22:47:44 UTC 2024 4.19.125
                        hw platform:  M0054
                        mach.var:     1.0.1
                        voxl-suite:   1.4.1
                        Packages:
                        Last Updated: 2025-04-10 07:49:18
                        List:
                        libfc-sensor                              1.0.7
                        libmodal-cv                               0.5.16
                        libqrb5165-io                             0.4.9
                        modalai-slpi                              1.1.19
                        qrb5165-imu-server                        1.1.2
                        qrb5165-rangefinder-server                0.1.4
                        qrb5165-system-tweaks                     0.3.4
                        voxl-camera-server                        2.1.1
                        voxl-configurator                         0.9.7
                        voxl-elrs                                 0.4.1
                        voxl-esc                                  1.5.1
                        voxl-io-server                            0.0.4
                        voxl-logger                               0.4.9
                        voxl-mavcam-manager                       0.5.7
                        voxl-mavlink-server                       1.4.4
                        voxl-modem                                1.1.5
                        voxl-open-vins                            0.4.16
                        voxl-opencv                               4.5.5-2
                        voxl-osd                                  0.1.1
                        voxl-portal                               0.7.5
                        voxl-px4                                  1.14.0-2.0.94
                        voxl-px4-params                           0.6.3
                        voxl-streamer                             0.7.5
                        voxl-suite                                1.4.1
                        voxl-utils                                1.4.4
                        voxl-vision-hub                           1.8.17
                        voxl-vtx                                  1.1.8
                        voxl2-io                                  0.0.3
                        PX4 output
                        voxl2:~/voxl-esc/voxl-esc-tools(master)$ voxl-reset-slpi
                        voxl2:~/voxl-esc/voxl-esc-tools(master)$ voxl-px4
                        GPS=AUTODETECT
                        RC=CRSF_RAW
                        ESC=VOXL_ESC
                        OSD=DISABLE
                        DAEMON_MODE=ENABLE
                        SENSOR_CAL=ACTUAL
                        EXTRA STEPS:
                        ______  __   __    ___
                        | ___ \ \ \ / /   /   |
                        | |_/ /  \ V /   / /| |
                        |  __/   /   \  / /_| |
                        | |     / /^\ \ \___  |
                        \_|     \/   \/     |_/
                        px4 starting.
                        GPS: AUTODETECT
                        RC: CRSF_RAW
                        ESC: VOXL_ESC
                        OSD: DISABLE
                        EXTRA STEPS:
                        Running on M0054
                        INFO  [parameters] BSON document size 2517 bytes, decoded 2517 bytes (INT32:35, FLOAT:81)
                        INFO  [muorb] SLPI:
                        INFO  [muorb] SLPI: >>> ICM42688P this: b2600328
                        INFO  [qshell] qshell return value timestamp: 239538233, local time: 239543342
                        INFO  [muorb] SLPI: Register interrupt b214ec48 e61eccdc b2600328
                        INFO  [muorb] SLPI: Set up I2C bus mutex for bus 5
                        INFO  [qshell] Send cmd: 'temperature_compensation start'
                        Looking for ist8308 magnetometer
                        INFO  [qshell] Send cmd: 'ist8308 start -R 12 -X -b 1'
                        Looking for ncp5623c RGB LED
                        dmesg ouput
                        [Apr10 07:58] Fatal error on slpi!
                        [  +0.000121] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:UTMR_CLNT_1:0x1078:sns_thread_manager.c:497:SNS_SEE_P_0 exceeded processing time limit for library 0xb25d94f8.
                        [  +0.000072] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED.
                        [  +0.001309] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting
                        [  +0.000014] subsys-restart: subsystem_shutdown(): [kworker/u19:0:1866]: Shutting down slpi
                        [  +0.017355] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi
                        [  +0.000147] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service
                        [  +0.003004] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi
                        [  +0.000777] subsys-restart: subsystem_powerup(): [kworker/u19:0:1866]: Powering up slpi
                        [  +0.001439] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
                        [  +0.069556] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
                        [  +0.062589] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
                        [  +0.000059] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received
                        [  +0.000130] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040
                        [  +0.002168] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
                        [  +0.000008] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:1866]: Restart sequence for slpi completed.
                        [  +0.001835] -1882171928:Entered
                        [  +0.000228] -1882171928:SMD QRTR driver probed
                        [  +0.001453] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
                        [  +0.000064] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
                        [  +0.002648] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
                        [  +0.012758] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
                        [  +2.208612] Fatal error on slpi!
                        [  +0.000113] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:SNS_SEE_I_0:0x65:sns_stream_service.c:436:req_found.
                        [  +0.001144] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting
                        [  +0.000016] subsys-restart: subsystem_shutdown(): [kworker/u19:0:1866]: Shutting down slpi
                        [  +0.013085] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                        [  +0.002398] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service
                        [  +0.000087] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service
                        [  +0.000944] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi
                        [  +0.001899] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi
                        [  +0.001040] subsys-restart: subsystem_powerup(): [kworker/u19:0:1866]: Powering up slpi
                        [  +0.000247] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
                        [  +0.062107] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
                        [  +0.061462] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
                        [  +0.004727] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
                        [  +0.000007] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:1866]: Restart sequence for slpi completed.
                        [  +0.004439] -1882171928:Entered
                        [  +0.001177] -1882171928:SMD QRTR driver probed
                        [  +0.003823] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
                        [  +0.001216] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
                        [  +0.000035] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
                        [  +0.008403] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
                          hw platform:  M0054
                          mach.var:     1.0.1
                          voxl-suite:   1.4.1
                          Packages:
                          List:
                          libfc-sensor                              1.0.7
                          libmodal-cv                               0.5.16
                          libqrb5165-io                             0.4.9
                          modalai-slpi                              1.1.19
                          voxl-elrs                                 0.4.1
                          voxl-esc                                  1.5.1
                          voxl-logger                               0.4.9
                          voxl-modem                                1.1.5
                          voxl-opencv                               4.5.5-2
                          voxl-osd                                  0.1.1
                          voxl-portal                               0.7.5
                          voxl-streamer                             0.7.5
                          voxl-suite                                1.4.1
                          voxl-utils                                1.4.4
                          voxl-vtx                                  1.1.8
                          voxl2-io                                  0.0.3
                          PX4 output
                          GPS=AUTODETECT
                          RC=CRSF_RAW
                          ESC=VOXL_ESC
                          OSD=DISABLE
                          DAEMON_MODE=ENABLE
                          SENSOR_CAL=ACTUAL
                          EXTRA STEPS:
                          ______  __   __    ___
                          | ___ \ \ \ / /   /   |
                          | |_/ /  \ V /   / /| |
                          |  __/   /   \  / /_| |
                          | |     / /^\ \ \___  |
                          \_|     \/   \/     |_/
                          px4 starting.
                          GPS: AUTODETECT
                          RC: CRSF_RAW
                          ESC: VOXL_ESC
                          OSD: DISABLE
                          EXTRA STEPS:
                          Running on M0054
                          INFO  [muorb] SLPI:
                          dmesg ouput
                          @astro_phil I think then that there must be some sort of hardware issue. Probably time to RMA the board. http://modalai.com/rma
                            astro_philA Offline
                            astro_philA Offline
                            astro_phil
                            Okay, then I'm gonna do that. Thanks for the assist.
