    VOXL2/ROS2 Drone Runs Figure 8 Offboard Program Instead of My Program
    6231
    • G
      GlennTee
      I recently started working with a Starling drone with VOXL2 and ROS2, and I am having a bit of trouble trying to run a sample offboard program I found from the PX4 website. I followed the steps on the website to upload and run a program that allows the drone to send setpoints, enter offboard mode, arm, fly five meters into the air, and finally wait. However, when attempting to run the program, the default Figure 8 program on the drone runs instead. This is the link to the guide I followed: https://docs.px4.io/main/en/ros2/offboard_control.html
      Additionally, I also ran the command voxl-vision-hub in the terminal with some of the outputted information shown below:
      config_file_version: 1
      MAVROS / MAVSDK
      en_localhost_mavlink_udp 0
      localhost_udp_port_number: 14551
      VIO
      en_vio: 1
      vio_pipe: qvio
      secondary_vio_pipe: ov
      vio_warmup_s: 3.000000
      send_odom_while_failed: 1
      MISC FEATURES
      horizon_cal_tolerance: 0.500000
      OFFBOARD MODE
      offboard_mode: figure_eight
      follow_tag_id: 0
      figure_eight_move_home: 1
      robot_radius: 0.300000
      collision_sampling_dt: 0.100000
      max_lookahead_distance: 1.000000
      FIXED FRAME RELOCALIZATION
      en_tag_fixed_frame: 0
      fixed_frame_filter_len: 5
      It should be noted that the drone has Ubuntu 18.04 and ROS2 foxy. The PX4 and Mavlink services are also enabled and running. I'm wondering if there is a step I'm missing or some software that I am missing. Anything helps. Thank you.
        Eric Katzfey ModalAI Team @GlennTee
        @GlennTee You will want to configure voxl-vision-hub to not send offboard commands if you are trying to use offboard commands from ROS2. Set offboard_mode: off in the configuration file /etc/modalai/voxl-vision-hub.conf.
        G 2 Replies Last reply Reply Quote 1
        • G
          GlennTee @Eric Katzfey
          @Eric-Katzfey Thank you, I will try that!
          • G
            @Eric-Katzfey Hi again. I just tried flying it again and the drone did not default to running the Figure Eight program this time, but instead it did nothing once I swapped the controller to offboard mode. It did not arm, the props did not spin, or anything like that, but did absolutely nothing. I made sure to set "offboard_mode": "off" in voxl-vision-hub. I've attached a screenshot of my terminal below.
            Eric KatzfeyE T 2 Replies Last reply Reply Quote 0
              @GlennTee Okay, then probably some issue with connectivity between ROS2 and PX4. Doesn't seem like anything from ROS2 is getting to PX4. I'll ask some team members who have some experience with ROS2 what they think.
              • T
                teddy.zaremba @GlennTee
                @GlennTee So that example requires you have the MicroDDS installed and running to communicate with PX4 (guide here).
                Alternatively, you can run offboard commands via mavsdk (example here). If you do it this way, make sure to edit that example to connect on port 14551 and set en_localhost_mavlink_udp to true in 'etc/modalai/voxl-vision-hub.conf'.
                Let me know if that helps.
                G 1 Reply Last reply Reply Quote 1
                • G
                  GlennTee @teddy.zaremba
                  @teddy-zaremba Thank you. I installed MicroDDS and am running the agent in VOXL2. I just enabled it and made sure the necessary services are running, but it looks like I got the same result as before, where nothing would happen after supposedly the Arm command was sent. Is there anything else I could be missing?
                  T 1 Reply Last reply Reply Quote 0
                  • T
                    @GlennTee What do you see when you run ros2 topic list?
                    Have you run "apt-get install voxl-ros2-foxy && apt-get install voxl-mpa-to-ros2" followed by "voxl-configure-mpa-to-ros2".
                    Similar issue that might be helpful
                    • G
                      @teddy-zaremba Sorry for the late reply, I've already run both of those commands in that order. This is what comes up when I run "ros2 topic list"
                      K 1 Reply Last reply Reply Quote 0
                      • K
                        Kessie @GlennTee
                        @GlennTee the problem lies in a mismatch between the topics which you see using "ros2 topic list" and the publishers from the offboard_control node.
                        The ros2 node has publishers defined as follows:
                        	OffboardControl() : Node("offboard_control")
                        		offboard_control_mode_publisher_ = this->create_publisher<OffboardControlMode>("/fmu/in/offboard_control_mode", 10);
                        		trajectory_setpoint_publisher_ = this->create_publisher<TrajectorySetpoint>("/fmu/in/trajectory_setpoint", 10);
                        		vehicle_command_publisher_ = this->create_publisher<VehicleCommand>("/fmu/in/vehicle_command", 10);
                        Do you know where you changed the prefix uav_4?
                        I can't remember where to configure it.
                        So, you can change the ROS2 code, rebuild and it should work. Or remove the uav_4 prefix
                        • G
                          GlennTee @Kessie
                          @Kessie Thank you. I'm not sure where I changed the prefix, but I can try to find it.
                          • C
                            claw @GlennTee
                            @Kessie The good news is that removing the prefix allows the px4 to see the messages and arm. Thank you! The bad news is that we weren't sure this would work so the drone wasn't in our flying lab and we had to physically grab it and disconnect the battery.
                            We tried powering on the RC controller to push the kill switch, but even though it connected to the receiver, the drone didn't respond to any of the RC controls including the mode and motor disable switches.
                            How do we operate in offboard mode while preserving the ability to take over manually? Would it have worked if we powered on the drone in manual or position hold and then switched to offboard? Do we launch our code before or after the mode change?
                            • K
                              Kessie @claw
                              @claw You'll need to change the parameter COM_RC_OVERRIDE to also allow overriding offboard mode.
                              Reference link : https://docs.px4.io/main/en/advanced_config/parameter_reference.html#COM_RC_OVERRIDE
                              C G 2 Replies Last reply Reply Quote 1
                              • C
                                claw @Kessie
                                @Kessie Great. Thank you for your help.
                                • G
                                  GlennTee @Kessie
                                  @Kessie Hi again, we just changed COM_RC_OVERRIDE to allow for overriding offboard mode and we were able to cut the motors while the drone was operating in offboard mode. We modified the PX4 ROS 2 Offboard Control Example code to only enable offboard mode and arm the drone, but we noticed that once the drone armed, it had a lot of throttle. I'm guessing there is a setting maybe in QGroundControl to modify the throttle somehow, or is there another way to fix this?
                                  • G
                                    GlennTee @GlennTee
                                    I just ran into another problem where I believe after running "voxl-configure-microdds" again, it seems some of my changes were reset as I noticed "offboard_mode" defaulted back to "figure_eight" while looking in the vision-hub config file. However, I did notice that my changes with the node publishers were not changed.
                                    I thought I have reverted everything to how it was before, but the drone is now back to not flying at all. I also noticed that my list of ros2 topics has also shrunk down as well.
                                    T G 2 Replies Last reply Reply Quote 0
                                    • T
                                      @GlennTee said in VOXL2/ROS2 Drone Runs Figure 8 Offboard Program Instead of My Program:
                                      This likely means that those topics got populated from the offboard script not the px4-ros bridge. Could you check that voxl-microdds-agent is running when you see this happen.
                                      Check with "voxl-inspect-services"
                                      • G
                                        GlennTee @GlennTee
                                        @teddy-zaremba Hi, I just checked using that command and it appears the agent is enabled, but it is not running.
                                        • T
                                          @GlennTee Can you run the command "voxl-microdds-agent" and share your output please?
                                          • G
                                            @teddy-zaremba said in VOXL2/ROS2 Drone Runs Figure 8 Offboard Program Instead of My Program:
                                            This is what I get:
