  3. VOXL2/ROS2 Drone Runs Figure 8 Offboard Program Instead of My Program
25 Posts 6 Posters 7.8k Views 1 Watching
  • G GlennTee
    I recently started working with a Starling drone with VOXL2 and ROS2, and I am having a bit of trouble trying to run a sample offboard program I found from the PX4 website. I followed the steps on the website to upload and run a program that allows the drone to send setpoints, enter offboard mode, arm, fly five meters into the air, and finally wait. However, when attempting to run the program, the default Figure 8 program on the drone runs instead. This is the link to the guide I followed: https://docs.px4.io/main/en/ros2/offboard_control.html
    Additionally, I also ran the command voxl-vision-hub in the terminal with some of the outputted information shown below:
    config_file_version: 1
    MAVROS / MAVSDK
    en_localhost_mavlink_udp 0
    localhost_udp_port_number: 14551
    VIO
    en_vio: 1
    vio_pipe: qvio
    secondary_vio_pipe: ov
    vio_warmup_s: 3.000000
    send_odom_while_failed: 1
    MISC FEATURES
    horizon_cal_tolerance: 0.500000
    OFFBOARD MODE
    offboard_mode: figure_eight
    follow_tag_id: 0
    figure_eight_move_home: 1
    robot_radius: 0.300000
    collision_sampling_dt: 0.100000
    max_lookahead_distance: 1.000000
    FIXED FRAME RELOCALIZATION
    en_tag_fixed_frame: 0
    fixed_frame_filter_len: 5
    It should be noted that the drone has Ubuntu 18.04 and ROS2 foxy. The PX4 and Mavlink services are also enabled and running. I'm wondering if there is a step I'm missing or some software that I am missing. Anything helps. Thank you.
    @GlennTee You will want to configure voxl-vision-hub to not send offboard commands if you are trying to use offboard commands from ROS2. Set offboard_mode: off in the configuration file /etc/modalai/voxl-vision-hub.conf.
    G 2 Replies Last reply
      G Offline
      G Offline
      GlennTee
      @Eric-Katzfey Thank you, I will try that!
        G Offline
        G Offline
        GlennTee
        wrote on last edited by GlennTee
        @Eric-Katzfey Hi again. I just tried flying it again and the drone did not default to running the Figure Eight program this time, but instead it did nothing once I swapped the controller to offboard mode. It did not arm, the props did not spin, or anything like that, but did absolutely nothing. I made sure to set "offboard_mode": "off" in voxl-vision-hub. I've attached a screenshot of my terminal below.
        Eric KatzfeyE T 2 Replies Last reply
        • G GlennTee
          @GlennTee Okay, then probably some issue with connectivity between ROS2 and PX4. Doesn't seem like anything from ROS2 is getting to PX4. I'll ask some team members who have some experience with ROS2 what they think.
          • G GlennTee
            T Offline
            T Offline
            teddy.zaremba
            wrote on last edited by teddy.zaremba
            @GlennTee So that example requires you have the MicroDDS installed and running to communicate with PX4 (guide here).
            Alternatively, you can run offboard commands via mavsdk (example here). If you do it this way, make sure to edit that example to connect on port 14551 and set en_localhost_mavlink_udp to true in 'etc/modalai/voxl-vision-hub.conf'.
            Let me know if that helps.
            G 1 Reply Last reply
            • T teddy.zaremba
              G Offline
              G Offline
              GlennTee
              @teddy-zaremba Thank you. I installed MicroDDS and am running the agent in VOXL2. I just enabled it and made sure the necessary services are running, but it looks like I got the same result as before, where nothing would happen after supposedly the Arm command was sent. Is there anything else I could be missing?
              T 1 Reply Last reply
              • G GlennTee
                T Offline
                T Offline
                teddy.zaremba
                @GlennTee What do you see when you run ros2 topic list?
                Have you run "apt-get install voxl-ros2-foxy && apt-get install voxl-mpa-to-ros2" followed by "voxl-configure-mpa-to-ros2".
                Similar issue that might be helpful
                • T teddy.zaremba
                  G Offline
                  G Offline
                  GlennTee
                  @teddy-zaremba Sorry for the late reply, I've already run both of those commands in that order. This is what comes up when I run "ros2 topic list"
                  K 1 Reply Last reply
                  • G GlennTee
                    K Offline
                    K Offline
                    Kessie
                    @GlennTee the problem lies in a mismatch between the topics which you see using "ros2 topic list" and the publishers from the offboard_control node.
                    The ros2 node has publishers defined as follows:
                    	OffboardControl() : Node("offboard_control")
                    		offboard_control_mode_publisher_ = this->create_publisher<OffboardControlMode>("/fmu/in/offboard_control_mode", 10);
                    		trajectory_setpoint_publisher_ = this->create_publisher<TrajectorySetpoint>("/fmu/in/trajectory_setpoint", 10);
                    		vehicle_command_publisher_ = this->create_publisher<VehicleCommand>("/fmu/in/vehicle_command", 10);
                    Do you know where you changed the prefix uav_4?
                    I can't remember where to configure it.
                    So, you can change the ROS2 code, rebuild and it should work. Or remove the uav_4 prefix
                    • K Kessie
                      G Offline
                      G Offline
                      GlennTee
                      @Kessie Thank you. I'm not sure where I changed the prefix, but I can try to find it.
                      C 1 Reply Last reply
                      • G GlennTee
                        C Offline
                        C Offline
                        claw
                        @Kessie The good news is that removing the prefix allows the px4 to see the messages and arm. Thank you! The bad news is that we weren't sure this would work so the drone wasn't in our flying lab and we had to physically grab it and disconnect the battery.
                        We tried powering on the RC controller to push the kill switch, but even though it connected to the receiver, the drone didn't respond to any of the RC controls including the mode and motor disable switches.
                        How do we operate in offboard mode while preserving the ability to take over manually? Would it have worked if we powered on the drone in manual or position hold and then switched to offboard? Do we launch our code before or after the mode change?
                        • C claw
                          K Offline
                          K Offline
                          Kessie
                          @claw You'll need to change the parameter COM_RC_OVERRIDE to also allow overriding offboard mode.
                          Reference link : https://docs.px4.io/main/en/advanced_config/parameter_reference.html#COM_RC_OVERRIDE
                          C G 2 Replies Last reply
                          • K Kessie
                            C Offline
                            C Offline
                            claw
                            @Kessie Great. Thank you for your help.
                            • K Kessie
                              G Offline
                              G Offline
                              GlennTee
                              @Kessie Hi again, we just changed COM_RC_OVERRIDE to allow for overriding offboard mode and we were able to cut the motors while the drone was operating in offboard mode. We modified the PX4 ROS 2 Offboard Control Example code to only enable offboard mode and arm the drone, but we noticed that once the drone armed, it had a lot of throttle. I'm guessing there is a setting maybe in QGroundControl to modify the throttle somehow, or is there another way to fix this?
                              • G GlennTee
                                G Offline
                                G Offline
                                GlennTee
                                I just ran into another problem where I believe after running "voxl-configure-microdds" again, it seems some of my changes were reset as I noticed "offboard_mode" defaulted back to "figure_eight" while looking in the vision-hub config file. However, I did notice that my changes with the node publishers were not changed.
                                I thought I have reverted everything to how it was before, but the drone is now back to not flying at all. I also noticed that my list of ros2 topics has also shrunk down as well.
                                T G 2 Replies Last reply
                                • G GlennTee
                                  T Offline
                                  T Offline
                                  teddy.zaremba
                                  @GlennTee said in VOXL2/ROS2 Drone Runs Figure 8 Offboard Program Instead of My Program:
                                  This likely means that those topics got populated from the offboard script not the px4-ros bridge. Could you check that voxl-microdds-agent is running when you see this happen.
                                  Check with "voxl-inspect-services"
                                  • G GlennTee
                                    G Offline
                                    G Offline
                                    GlennTee
                                    #18
                                    @teddy-zaremba Hi, I just checked using that command and it appears the agent is enabled, but it is not running.
                                    • G GlennTee
                                      T Offline
                                      T Offline
                                      teddy.zaremba
                                      @GlennTee Can you run the command "voxl-microdds-agent" and share your output please?
                                      • T teddy.zaremba
                                        G Offline
                                        G Offline
                                        GlennTee
                                        @teddy-zaremba said in VOXL2/ROS2 Drone Runs Figure 8 Offboard Program Instead of My Program:
                                        This is what I get:
                                        • G GlennTee
                                          This is what I get:
                                          T Offline
                                          T Offline
                                          teddy.zaremba
                                          @GlennTee This looks fine to me if it's not running I'd suggest just restarting the service via "systemctl restart voxl-microdds-agent" and then double check that it's running with "voxl-inspect-services"
