  3. USB3
USB3
7 Posts 3 Posters 1.0k Views 2 Watching
  • voxltesterV Offline
    voxltesterV Offline
    voxltester
    wrote on last edited by voxltester
    I am following https://docs.modalai.com/voxl2-usb3-uart-add-on-user-guide/
    I have a samsung usb storage (https://www.samsung.com/us/computing/memory-storage/usb-flash-drives/usb-3-0-flash-drive-bar-32gb-muf-32ba-muf-32ba-am/)
    formatted as Ext4 . But no detected usb storage on VOXL2.
    The connection is exactly the same as the example.
    voxl2:/$ lsusb -t
    /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 10000M
    /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
    Version of VOXL2
    voxl2:/$ voxl-version
    system-image: 1.7.8-M0054-14.1a-perf
    kernel:       #1 SMP PREEMPT Fri May 17 23:29:23 UTC 2024 4.19.125
    hw platform:  M0054
    mach.var:     1.0.0
    voxl-suite:   1.3.1
    Any thought?
    • voxltesterV voxltester deleted this topic on
    • voxltesterV voxltester restored this topic on
      voxl2:/$ lsusb -t
      Version of VOXL2
      hw platform:  M0054
      mach.var:     1.0.0
      voxl-suite:   1.3.1
      Any thought?
      @voxltester , does VOXL2 detect any other devices (USB2.0, USB3.0) using the same USB3 add-on?
      voxltesterV 1 Reply Last reply
        voxltesterV Offline
        voxltesterV Offline
        voxltester
        @Alex-Kushleyev nothing detected.
          @voxltester , I am sorry to hear that - if you are not able to get any devices working on the USB3 port, perhaps the add-on board is not functioning correctly. You may want to submit an RMA and get a replacement. www.modalai.com/rma
            voxltesterV Offline
            voxltesterV Offline
            voxltester
            Thanks for the information. What kind of USB3 add-on will work for this?
            Alex KushleyevA VinnyV 2 Replies Last reply
              @voxltester , my understanding is that the board you have originally purchased should work for this, so it might be defective, if it is not able to detect any USB devices.
              Maybe @Vinny can take a look?
                Hi @voxltester
                Are you able to post a high res photo of the USB breakout board, both top and bottom?
                Could save you the time and hassle of an RMA with a good high quality photo I can inspect.
                The board was tested and passed before shipping, but these boards do have some small parts on that that are susceptible to damage if the board is dropped or if a tool or other item hits into it.
