    USB3
    • voxltesterV
      voxltester
      I am following https://docs.modalai.com/voxl2-usb3-uart-add-on-user-guide/
      I have a samsung usb storage (https://www.samsung.com/us/computing/memory-storage/usb-flash-drives/usb-3-0-flash-drive-bar-32gb-muf-32ba-muf-32ba-am/)
      formatted as Ext4 . But no detected usb storage on VOXL2.
      The connection is exactly the same as the example.
      voxl2:/$ lsusb -t
      /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 10000M
      /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
      Version of VOXL2
      voxl2:/$ voxl-version
      system-image: 1.7.8-M0054-14.1a-perf
      kernel:       #1 SMP PREEMPT Fri May 17 23:29:23 UTC 2024 4.19.125
      hw platform:  M0054
      mach.var:     1.0.0
      voxl-suite:   1.3.1
      Any thought?
      • voxltesterV voxltester deleted this topic on
      • voxltesterV voxltester restored this topic on
        Alex Kushleyev ModalAI Team @voxltester
        @voxltester , does VOXL2 detect any other devices (USB2.0, USB3.0) using the same USB3 add-on?
        voxltesterV 1 Reply Last reply Reply Quote 0
        • voxltesterV
          voxltester @Alex Kushleyev
          @Alex-Kushleyev nothing detected.
            @voxltester , I am sorry to hear that - if you are not able to get any devices working on the USB3 port, perhaps the add-on board is not functioning correctly. You may want to submit an RMA and get a replacement. www.modalai.com/rma
            • voxltesterV
              Thanks for the information. What kind of USB3 add-on will work for this?
              Alex KushleyevA VinnyV 2 Replies Last reply Reply Quote 0
                @voxltester , my understanding is that the board you have originally purchased should work for this, so it might be defective, if it is not able to detect any USB devices.
                Maybe @Vinny can take a look?
                • VinnyV
                  Vinny ModalAI Team @voxltester
                  Hi @voxltester
                  Are you able to post a high res photo of the USB breakout board, both top and bottom?
                  Could save you the time and hassle of an RMA with a good high quality photo I can inspect.
                  The board was tested and passed before shipping, but these boards do have some small parts on that that are susceptible to damage if the board is dropped or if a tool or other item hits into it.
