<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[USB3]]></title><description><![CDATA[<p dir="auto">I am following <a href="https://docs.modalai.com/voxl2-usb3-uart-add-on-user-guide/" rel="nofollow ugc">https://docs.modalai.com/voxl2-usb3-uart-add-on-user-guide/</a><br />
I have a samsung usb storage (<a href="https://www.samsung.com/us/computing/memory-storage/usb-flash-drives/usb-3-0-flash-drive-bar-32gb-muf-32ba-muf-32ba-am/" rel="nofollow ugc">https://www.samsung.com/us/computing/memory-storage/usb-flash-drives/usb-3-0-flash-drive-bar-32gb-muf-32ba-muf-32ba-am/</a>)</p>
<p dir="auto">formatted as <code>Ext4</code> . But no detected usb storage on VOXL2.<br />
The connection is exactly the same as the example.</p>
<pre><code>voxl2:/$ lsusb -t
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 10000M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
<p dir="auto">Version of VOXL2</p>
<pre><code>voxl2:/$ voxl-version
system-image: 1.7.8-M0054-14.1a-perf
kernel:       #1 SMP PREEMPT Fri May 17 23:29:23 UTC 2024 4.19.125
hw platform:  M0054
mach.var:     1.0.0
voxl-suite:   1.3.1
<p dir="auto">Any thought?</p>
]]></description><link>https://forum.modalai.com/topic/3704/usb3</link><generator>RSS for Node</generator><lastBuildDate>Mon, 08 Jun 2026 06:00:43 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/3704.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 06 Aug 2024 21:51:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to USB3 on Thu, 22 Aug 2024 03:57:22 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/586">@voxltester</a><br />
Are you able to post a high res photo of the USB breakout board, both top and bottom?<br />
Could save you the time and hassle of an RMA with a good high quality photo I can inspect.</p>
<p dir="auto">The board was tested and passed before shipping, but these boards do have some small parts on that that are susceptible to damage if the board is dropped or if a tool or other item hits into it.</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.modalai.com/post/18688</link><guid isPermaLink="true">https://forum.modalai.com/post/18688</guid><dc:creator><![CDATA[Vinny]]></dc:creator><pubDate>Thu, 22 Aug 2024 03:57:22 GMT</pubDate></item><item><title><![CDATA[Reply to USB3 on Thu, 22 Aug 2024 03:25:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/586">@voxltester</a> , my understanding is that the board you have originally purchased should work for this, so it might be defective, if it is not able to detect any USB devices.</p>
<p dir="auto">Maybe <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/157">@Vinny</a> can take a look?</p>
<p dir="auto">Alex</p>
]]></description><link>https://forum.modalai.com/post/18686</link><guid isPermaLink="true">https://forum.modalai.com/post/18686</guid><dc:creator><![CDATA[Alex Kushleyev]]></dc:creator><pubDate>Thu, 22 Aug 2024 03:25:50 GMT</pubDate></item><item><title><![CDATA[Reply to USB3 on Wed, 21 Aug 2024 04:03:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/7">@Alex-Kushleyev</a><br />
Thanks for the information. What kind of USB3 add-on will work for this?</p>
]]></description><link>https://forum.modalai.com/post/18666</link><guid isPermaLink="true">https://forum.modalai.com/post/18666</guid><dc:creator><![CDATA[voxltester]]></dc:creator><pubDate>Wed, 21 Aug 2024 04:03:01 GMT</pubDate></item><item><title><![CDATA[Reply to USB3 on Tue, 13 Aug 2024 20:40:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/586">@voxltester</a> , I am sorry to hear that - if you are not able to get any devices working on the USB3 port, perhaps the add-on board is not functioning correctly. You may want to submit an RMA and get a replacement. <a href="http://www.modalai.com/rma" rel="nofollow ugc">www.modalai.com/rma</a></p>
]]></description><link>https://forum.modalai.com/post/18594</link><guid isPermaLink="true">https://forum.modalai.com/post/18594</guid><dc:creator><![CDATA[Alex Kushleyev]]></dc:creator><pubDate>Tue, 13 Aug 2024 20:40:06 GMT</pubDate></item><item><title><![CDATA[Reply to USB3 on Fri, 09 Aug 2024 21:08:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/7">@Alex-Kushleyev</a> nothing detected.</p>
]]></description><link>https://forum.modalai.com/post/18578</link><guid isPermaLink="true">https://forum.modalai.com/post/18578</guid><dc:creator><![CDATA[voxltester]]></dc:creator><pubDate>Fri, 09 Aug 2024 21:08:40 GMT</pubDate></item><item><title><![CDATA[Reply to USB3 on Thu, 08 Aug 2024 18:58:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/586">@voxltester</a> , does VOXL2 detect any other devices (USB2.0, USB3.0) using the same USB3 add-on?</p>
]]></description><link>https://forum.modalai.com/post/18564</link><guid isPermaLink="true">https://forum.modalai.com/post/18564</guid><dc:creator><![CDATA[Alex Kushleyev]]></dc:creator><pubDate>Thu, 08 Aug 2024 18:58:29 GMT</pubDate></item></channel></rss>
