  3. Install libopencv on Starling 2
starlingv2rosopencvdockervoxl-2
19 Posts 4 Posters 4.7k Views 2 Watching
  • wilkinsafW wilkinsaf
    @Judoor-0
    1. When you say voxl libraries do you mean the VOXL SDK? Probably not as ROS depends on specific packages to work together
    2. There is a decent walkthrough here: https://docs.modalai.com/docker-on-voxl/#voxl-2. At the end of the day you can pull in a docker image that has ROS pre-installed here: https://hub.docker.com/_/ros. Noetic is included in that. You can either pull it down straight on your voxl if there is an internet connection, or (takes longer) pull it down on your local PC using docker, save it to a tar file, adb push it to your voxl, and load it up using docker on your voxl.
    wilkinsafW Offline
    wilkinsafW Offline
    wilkinsaf
    For interfacing with docker, that is more about learning how docker works. you can start a container, attach to it, execute commands.
    For interfacing with more voxl things (MPA pipelines, network connections) you will want to share volumes of what you want to have access to (-v /run/mpa:/run/mpa -v /usr/bin/voxl-list-pipes:/usr/bin/voxl-list-pipes) and give the container priviledged and host network --privileged --net=host. This information should be contained in the walkthrough I posted above.
    To give you context as well, we usually run ROS on a docker image when running it on voxl.
    Does this answer your question?
      Just to add to this.. voxl-opencv package that is installed on voxl2 by default will conflict with standard opencv packages. This is not ideal, in future we may move to using opencv from standard packages and not have our own package, but this is how the packages are set up right now and there are a few voxl packages that depend on voxl-opencv, so uninstalling it could break some other dependencies.
      I agree that docker may be the best solution here, so you have full flexibility over the installed packages. You can still run the minimal ROS on the host OS on voxl2 (to handle mpa to ROS stuff) and all the processing inside a docker container.
      J 1 Reply Last reply
        J Offline
        J Offline
        Judoor 0
        wrote on last edited by Judoor 0
        @Alex-Kushleyev @wilkinsaf Thanks for your answers! Actually, I've done something similar with docker, but I still have a few problems with the data format that mpa_to_ros sends. To address this, I did the following:
        #!/usr/bin/env python
        import rospy
        import cv2
        import numpy as np
        from sensor_msgs.msg import Image, CameraInfo
        from cv_bridge import CvBridge, CvBridgeError
        import yaml
        class CamImageConverter:
            def __init__(self):
                self.bridge = CvBridge()
                # Subscribers
                rospy.Subscriber("/drone/tof_depth/image_raw", Image, self.depth_callback)
                rospy.Subscriber("/drone/hires/image_raw", Image, self.rgb_callback)
                rospy.Subscriber("/drone/tracking_front/image_raw", Image, self.tracking_callback)
                # Publishers
                self.depth_pub = rospy.Publisher("/drone/tof_depth/image", Image, queue_size=1000)
                self.rgb_pub = rospy.Publisher("/drone/hires/image", Image, queue_size=1000)
                self.rgb_info_pub = rospy.Publisher("/drone/hires/camera_info", CameraInfo, queue_size=1000)
                self.tracking_pub = rospy.Publisher("/drone/tracking_front/image", Image, queue_size=1000)
                self.tracking_info_pub = rospy.Publisher("/drone/tracking_front/camera_info", CameraInfo, queue_size=1000)
                self.camera_info_msg = self.load_camera_info("/root/ros_ws/src/cam_converter/calibration/ost.yaml")
                rospy.Timer(rospy.Duration(1.0 / 30), self.publish_tracking_info)
                rospy.Timer(rospy.Duration(1.0 / 30), self.publish_rgb_info)
            def load_camera_info(self, filename):
                with open(filename, "r") as file:
                    calib_data = yaml.safe_load(file)
                    camera_info_msg = CameraInfo()
                    camera_info_msg.height = calib_data["image_height"]
                    camera_info_msg.width = calib_data["image_width"]
                    camera_info_msg.distortion_model = calib_data["distortion_model"]
                    camera_info_msg.D = calib_data["distortion_coefficients"]["data"]
                    camera_info_msg.K = calib_data["camera_matrix"]["data"]
                    camera_info_msg.R = calib_data["rectification_matrix"]["data"]
                    camera_info_msg.P = calib_data["projection_matrix"]["data"]
                    return camera_info_msg
            def depth_callback(self, msg):
                try:
                    # Convertir le message ROS en une image OpenCV
                    raw_image = self.bridge.imgmsg_to_cv2(msg, desired_encoding="mono8")
                    # Normalisation de l'image pour améliorer la qualité
                    depth_image = cv2.normalize(raw_image, None, 0, 65535, cv2.NORM_MINMAX).astype(np.uint16)
                    # Publier l'image convertie
                    converted_msg = self.bridge.cv2_to_imgmsg(depth_image, encoding="16UC1")
                    converted_msg.header.frame_id = 'tof_link'
                    converted_msg.header.stamp = rospy.Time.now()
                    self.depth_pub.publish(converted_msg)
                except CvBridgeError as e:
                    rospy.logerr("CvBridge Error: {0}".format(e))
            def rgb_callback(self, msg):
                try:
                    raw_image = self.bridge.imgmsg_to_cv2(msg, desired_encoding="passthrough")
                    # Conversion YUV422 ou NV12 en RGB8
                    if msg.encoding == "yuv422":
                        rgb_image = cv2.cvtColor(raw_image, cv2.COLOR_YUV2RGB_Y422)
                    elif msg.encoding == "nv12":
                        yuv_image = np.frombuffer(msg.data, dtype=np.uint8).reshape((msg.height * 3 // 2, msg.width))
                        rgb_image = cv2.cvtColor(yuv_image, cv2.COLOR_YUV2RGB_NV12)
                    else:
                        rospy.logerr("Unsupported encoding: {}".format(msg.encoding))
                        return
                    # Redimensionner l'image RGB pour qu'elle ait la même taille que l'image ToF (240x180)
                    resized_rgb_image = cv2.resize(rgb_image, (180, 240), interpolation=cv2.INTER_LINEAR)
                    # Publier l'image convertie et redimensionnée
                    converted_msg = self.bridge.cv2_to_imgmsg(resized_rgb_image, encoding="rgb8")
                    converted_msg.header.frame_id = 'hires_link'
                    self.rgb_pub.publish(converted_msg)
            def tracking_callback(self, msg):
                try:
                    resized_image = cv2.resize(raw_image, (180, 240), interpolation=cv2.INTER_LINEAR)
                    converted_msg = self.bridge.cv2_to_imgmsg(resized_image)
                    converted_msg.header.frame_id = 'tracking_front_link'
                    self.tracking_pub.publish(converted_msg)
            def publish_rgb_info(self, event):
                self.camera_info_msg.header.stamp = rospy.Time.now()
                self.camera_info_msg.header.frame_id = 'hires_link'
                self.rgb_info_pub.publish(self.camera_info_msg)
            def publish_tracking_info(self, event):
                camera_info_msg.header.frame_id = 'tracking_front_link'
                camera_info_msg.height = 240
                camera_info_msg.width = 180
                camera_info_msg.distortion_model = 'plumb_bob'
                camera_info_msg.D = [5.0234834483837899e-02, 3.2967878240805777e-02, -1.6468916528340826e-02, 1.8155367951008903e-03]
                camera_info_msg.K = [4.6177826259848081e+02, 0., 6.1505488982380564e+02, 0., 4.6160870283061041e+02, 4.1065345867690684e+02, 0., 0., 1.]
                camera_info_msg.R = [1.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 1.0]
                camera_info_msg.P = [4.6177826259848081e+02, 0., 6.1505488982380564e+02, 0., 0., 4.6160870283061041e+02, 4.1065345867690684e+02, 0., 0., 0., 1., 0.]
                self.tracking_info_pub.publish(camera_info_msg)
        def main():
            rospy.init_node('cam_image_converter', anonymous=True)
            CamImageConverter()
            rospy.spin()
        if __name__ == '__main__':
            main()
        I don't know if this is the right way to do it, but it seems to work. Do you have any suggestions for implementing this directly on the Voxl2?
        Also, I have a few problems with camera calibrations and the drone model. Do you have any files that contain all the data for the cameras (ToF, tracking, and high-resolution) and a model of the drone that I can use in RViz and Gazebo? This could really help me.
        For more context, I'm trying to implement this project for Autonomous SLAM with ROS. Has anyone already used RTAB-Map on this drone? Do you have any advice to solve this problem?
        Thank you for your help
        wilkinsafW 1 Reply Last reply
        • J Judoor 0
          import rospy
          import cv2
          import numpy as np
          import yaml
              def __init__(self):
                  # Subscribers
                  # Publishers
                  try:
                  try:
                      else:
                          return
                  try:
          def main():
              CamImageConverter()
              rospy.spin()
              main()
          wilkinsafW Offline
          wilkinsafW Offline
          wilkinsaf
          @Judoor-0
          I do not have an suggestions for implementing this directly on voxl2. as mentioned the voxl-opencv might conflict with standard opencv. I have also seen other packages conflict and python versions conflict depending on the ROS version you are using.
          Far easier and cleaner to use a docker image, and creates less headache in the long run.
          when you say data for cameras, what do you mean? I do not believe Modal has a DIRECT model of the drone in RViz or Gazebo. But you can follow this guide to get HITL working in Gazebo with the voxl2 hardware: https://docs.modalai.com/voxl2-PX4-hitl/
          wilkinsafW J 2 Replies Last reply
            @Judoor-0
            wilkinsafW Offline
            wilkinsafW Offline
            wilkinsaf
            and video: https://www.youtube.com/watch?v=ysvpJdXFWaM
              @Judoor-0
              J Offline
              J Offline
              Judoor 0
              @wilkinsaf Okay, thanks for your reply. Sorry, that was not clear. What I mean by data for cameras is data that I can send to RTAB-Map as a sensor_msgs/CameraInfo message. There is some data in the extrinsics files for tracking, but not for other sensors.
              • J Judoor 0
                wilkinsafW Offline
                wilkinsafW Offline
                wilkinsaf
                @Judoor-0 Gotcha. Let me know if this doesnt answer your question.
                you can use voxl mpa to ros2: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-to-ros2
                and this will allow you to access camera frame information
                  J Offline
                  J Offline
                  Judoor 0
                  @wilkinsaf Does mpa to ros do the same thing? Because I currently use ROS1. And for ROS1, mpa to ros only sends camera images or point cloud, not camera_infos.
                  P 1 Reply Last reply
                  • J Judoor 0
                    P Offline
                    P Offline
                    Prabhav Gupta
                    @Judoor-0 @wilkinsaf
                    I am working on something very similar as well and am facing the same issue.
                    I need to run RTAB-MAP for SLAM using the drone's sensors (Video and IMU). But RTAB-MAP expects camera_info (the camera matrix and other variables, as explained by @Judoor-0 above) along with video data.
                    One way to provide this information to RTAB-MAP is by creating a seperate publisher and publish this data over a ROS topic as done in one of the posts above. But I suspect it would be better if the voxl-mpa-to-ros package could provide the exact camera matrix and other variables (as specified here - https://docs.ros.org/en/noetic/api/sensor_msgs/html/msg/CameraInfo.html) as a ROS topic directly.
                    Kindly let us know if there is any way to implement this.
                    @Judoor-0, were you able to run SLAM using the stereo data from the drone? Or did you use depth data from a depth camera? The RB5 flight drone that I am using does not provide depth data directly, and hence I was thinking of using the Stereo data package within RTAB-MAP.
                    Alex KushleyevA J 2 Replies Last reply
                    • P Prabhav Gupta
                      @Prabhav-Gupta,
                      The easiest way to do this, perhaps, is to create a python script that reads the camera calibration json and publishes a latched message via rospy. Similarly it could be done in C++ with a little more effort.. I don't think this currently exists.
                      P 2 Replies Last reply
                        @Prabhav-Gupta,
                        P Offline
                        P Offline
                        Prabhav Gupta
                        Yes, that is similar to what I had in mind. I will try this out.
                        • P Prabhav Gupta
                          J Offline
                          J Offline
                          Judoor 0
                          @Prabhav-Gupta I didn't use the stereo data because I don't have one on my drone. I used the point cloud returned by the TOF. But I know that with RTAB-Map you can easily use stereo without depth. There are some examples that may help you in the rtabmap_ros website.
                          • J Judoor 0
                            P Offline
                            P Offline
                            Prabhav Gupta
                            @Judoor-0 Thanks a lot, I will look into it.
                              @Prabhav-Gupta,
                              P Offline
                              P Offline
                              Prabhav Gupta
                              wrote on last edited by Prabhav Gupta
                              #17
                              I was trying to create this script -
                              @Alex-Kushleyev said in Install libopencv on Starling 2:
                              and need some help.
                              I am working with the RB5 drone and found this in the /data/modalai/ folder in the drone:
                              In opencv_stereo_front_extrinsics.yml:
                              rb5:/data/modalai$ cat opencv_stereo_front_extrinsics.yml
                              %YAML:1.0
                              R: !!opencv-matrix
                                 rows: 3
                                 cols: 3
                                 dt: d
                                 data: [ 9.9995382093423246e-01, -9.1903872613942166e-03,
                                     -2.8094093711296423e-03, 9.2509466314868449e-03,
                                     9.9970714036476482e-01, 2.2361875818584419e-02,
                                     2.6030723098620125e-03, -2.2386832864208624e-02,
                                     9.9974599460505953e-01 ]
                              T: !!opencv-matrix
                                 rows: 3
                                 cols: 1
                                 dt: d
                                 data: [ -7.9639069991921108e-02, -9.0666624431155548e-05,
                                     -1.0799460870486485e-03 ]
                              reprojection_error: 2.7322523335815047e-01
                              calibration_time: "2022-04-08 23:15:23"
                              and in opencv_stereo_front_intrinsics.yml:
                              rb5:/data/modalai$ cat opencv_stereo_front_intrinsics.yml
                              %YAML:1.0
                              M1: !!opencv-matrix
                                 rows: 3
                                 cols: 3
                                 dt: d
                                 data: [ 5.0159907997903338e+02, 0., 2.9377341710319376e+02, 0.,
                                     5.0083699409439379e+02, 2.3544444409742863e+02, 0., 0., 1. ]
                              D1: !!opencv-matrix
                                 rows: 5
                                 cols: 1
                                 dt: d
                                 data: [ -1.6571748643440132e-01, 6.3134583515870882e-02,
                                     2.4908601395800438e-03, 6.9258577723375913e-04, 0. ]
                              reprojection_error1: 1.8877343672847582e-01
                              M2: !!opencv-matrix
                                 rows: 3
                                 cols: 3
                                 dt: d
                                 data: [ 5.0289492433892644e+02, 0., 3.1156572782508289e+02, 0.,
                                     5.0234014337071841e+02, 2.4962793784523797e+02, 0., 0., 1. ]
                              D2: !!opencv-matrix
                                 rows: 5
                                 cols: 1
                                 dt: d
                                 data: [ -1.6640627389329365e-01, 6.4800083011513396e-02,
                                     1.1988146735987267e-04, -6.3680006718804514e-04, 0. ]
                              reprojection_error2: 1.8906708149286014e-01
                              width: 640
                              height: 480
                              distortion_model: plumb_bob
                              To create the script that publishes CameraInfo, I need to figure out the information within these two files that correspond to the variables within the CameraInfo class as given here: https://docs.ros.org/en/noetic/api/sensor_msgs/html/msg/CameraInfo.html
                              sensor_msgs/CameraInfo:
                              std_msgs/Header header
                              uint32 height
                              uint32 width
                              string distortion_model
                              float64[] D
                              float64[9] K
                              float64[9] R
                              float64[12] P
                              uint32 binning_x
                              uint32 binning_y
                              sensor_msgs/RegionOfInterest roi
                              Some of the variable mappings are clear, such as height, width, distortion model, R and D.
                              How do I map K and P required by CameraInfo from the Calibration files? And anything else that I should potentially look out for while doing this mapping?
                              • P Prabhav Gupta
                                and need some help.
                                %YAML:1.0
                                R: !!opencv-matrix
                                   rows: 3
                                   cols: 3
                                   dt: d
                                T: !!opencv-matrix
                                   rows: 3
                                   cols: 1
                                   dt: d
                                %YAML:1.0
                                M1: !!opencv-matrix
                                   rows: 3
                                   cols: 3
                                   dt: d
                                D1: !!opencv-matrix
                                   rows: 5
                                   cols: 1
                                   dt: d
                                M2: !!opencv-matrix
                                   rows: 3
                                   cols: 3
                                   dt: d
                                D2: !!opencv-matrix
                                   rows: 5
                                   cols: 1
                                   dt: d
                                width: 640
                                height: 480
                                uint32 height
                                uint32 width
                                float64[] D
                                float64[9] K
                                float64[9] R
                                float64[12] P
                                uint32 binning_x
                                uint32 binning_y
                                @Prabhav-Gupta ,
                                K is your M1 and M2 matrices for both cameras (3x3 Intrinsic camera matrix)
                                The link you shared has information how to compute the P matrix. I am not sure if it would be used by your application though.
                                  @Prabhav-Gupta ,
                                  P Offline
                                  P Offline
                                  Prabhav Gupta
                                  @Alex-Kushleyev,
                                  Cool, Thanks a lot!
