  3. Install libopencv on Starling 2
starlingv2rosopencvdockervoxl-2
19 Posts 4 Posters 4.8k Views 2 Watching
  • wilkinsafW wilkinsaf
    @Judoor-0
    I do not have an suggestions for implementing this directly on voxl2. as mentioned the voxl-opencv might conflict with standard opencv. I have also seen other packages conflict and python versions conflict depending on the ROS version you are using.
    Far easier and cleaner to use a docker image, and creates less headache in the long run.
    when you say data for cameras, what do you mean? I do not believe Modal has a DIRECT model of the drone in RViz or Gazebo. But you can follow this guide to get HITL working in Gazebo with the voxl2 hardware: https://docs.modalai.com/voxl2-PX4-hitl/
    wilkinsafW Offline
    wilkinsafW Offline
    wilkinsaf
    and video: https://www.youtube.com/watch?v=ysvpJdXFWaM
      @Judoor-0
      J Offline
      J Offline
      Judoor 0
      @wilkinsaf Okay, thanks for your reply. Sorry, that was not clear. What I mean by data for cameras is data that I can send to RTAB-Map as a sensor_msgs/CameraInfo message. There is some data in the extrinsics files for tracking, but not for other sensors.
      wilkinsafW 1 Reply Last reply
      • J Judoor 0
        wilkinsafW Offline
        wilkinsafW Offline
        wilkinsaf
        @Judoor-0 Gotcha. Let me know if this doesnt answer your question.
        you can use voxl mpa to ros2: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-to-ros2
        and this will allow you to access camera frame information
        J 1 Reply Last reply
          J Offline
          J Offline
          Judoor 0
          @wilkinsaf Does mpa to ros do the same thing? Because I currently use ROS1. And for ROS1, mpa to ros only sends camera images or point cloud, not camera_infos.
          P 1 Reply Last reply
          • J Judoor 0
            P Offline
            P Offline
            Prabhav Gupta
            @Judoor-0 @wilkinsaf
            I am working on something very similar as well and am facing the same issue.
            I need to run RTAB-MAP for SLAM using the drone's sensors (Video and IMU). But RTAB-MAP expects camera_info (the camera matrix and other variables, as explained by @Judoor-0 above) along with video data.
            One way to provide this information to RTAB-MAP is by creating a seperate publisher and publish this data over a ROS topic as done in one of the posts above. But I suspect it would be better if the voxl-mpa-to-ros package could provide the exact camera matrix and other variables (as specified here - https://docs.ros.org/en/noetic/api/sensor_msgs/html/msg/CameraInfo.html) as a ROS topic directly.
            Kindly let us know if there is any way to implement this.
            @Judoor-0, were you able to run SLAM using the stereo data from the drone? Or did you use depth data from a depth camera? The RB5 flight drone that I am using does not provide depth data directly, and hence I was thinking of using the Stereo data package within RTAB-MAP.
            Alex KushleyevA J 2 Replies Last reply
            • P Prabhav Gupta
              @Prabhav-Gupta,
              The easiest way to do this, perhaps, is to create a python script that reads the camera calibration json and publishes a latched message via rospy. Similarly it could be done in C++ with a little more effort.. I don't think this currently exists.
              P 2 Replies Last reply
                @Prabhav-Gupta,
                P Offline
                P Offline
                Prabhav Gupta
                Yes, that is similar to what I had in mind. I will try this out.
                • P Prabhav Gupta
                  J Offline
                  J Offline
                  Judoor 0
                  @Prabhav-Gupta I didn't use the stereo data because I don't have one on my drone. I used the point cloud returned by the TOF. But I know that with RTAB-Map you can easily use stereo without depth. There are some examples that may help you in the rtabmap_ros website.
                  • J Judoor 0
                    P Offline
                    P Offline
                    Prabhav Gupta
                    @Judoor-0 Thanks a lot, I will look into it.
                      @Prabhav-Gupta,
                      P Offline
                      P Offline
                      Prabhav Gupta
                      wrote on last edited by Prabhav Gupta
                      #17
                      I was trying to create this script -
                      @Alex-Kushleyev said in Install libopencv on Starling 2:
                      and need some help.
                      I am working with the RB5 drone and found this in the /data/modalai/ folder in the drone:
                      In opencv_stereo_front_extrinsics.yml:
                      rb5:/data/modalai$ cat opencv_stereo_front_extrinsics.yml
                      %YAML:1.0
                      R: !!opencv-matrix
                         rows: 3
                         cols: 3
                         dt: d
                         data: [ 9.9995382093423246e-01, -9.1903872613942166e-03,
                             -2.8094093711296423e-03, 9.2509466314868449e-03,
                             9.9970714036476482e-01, 2.2361875818584419e-02,
                             2.6030723098620125e-03, -2.2386832864208624e-02,
                             9.9974599460505953e-01 ]
                      T: !!opencv-matrix
                         rows: 3
                         cols: 1
                         dt: d
                         data: [ -7.9639069991921108e-02, -9.0666624431155548e-05,
                             -1.0799460870486485e-03 ]
                      reprojection_error: 2.7322523335815047e-01
                      calibration_time: "2022-04-08 23:15:23"
                      and in opencv_stereo_front_intrinsics.yml:
                      rb5:/data/modalai$ cat opencv_stereo_front_intrinsics.yml
                      %YAML:1.0
                      M1: !!opencv-matrix
                         rows: 3
                         cols: 3
                         dt: d
                         data: [ 5.0159907997903338e+02, 0., 2.9377341710319376e+02, 0.,
                             5.0083699409439379e+02, 2.3544444409742863e+02, 0., 0., 1. ]
                      D1: !!opencv-matrix
                         rows: 5
                         cols: 1
                         dt: d
                         data: [ -1.6571748643440132e-01, 6.3134583515870882e-02,
                             2.4908601395800438e-03, 6.9258577723375913e-04, 0. ]
                      reprojection_error1: 1.8877343672847582e-01
                      M2: !!opencv-matrix
                         rows: 3
                         cols: 3
                         dt: d
                         data: [ 5.0289492433892644e+02, 0., 3.1156572782508289e+02, 0.,
                             5.0234014337071841e+02, 2.4962793784523797e+02, 0., 0., 1. ]
                      D2: !!opencv-matrix
                         rows: 5
                         cols: 1
                         dt: d
                         data: [ -1.6640627389329365e-01, 6.4800083011513396e-02,
                             1.1988146735987267e-04, -6.3680006718804514e-04, 0. ]
                      reprojection_error2: 1.8906708149286014e-01
                      width: 640
                      height: 480
                      distortion_model: plumb_bob
                      To create the script that publishes CameraInfo, I need to figure out the information within these two files that correspond to the variables within the CameraInfo class as given here: https://docs.ros.org/en/noetic/api/sensor_msgs/html/msg/CameraInfo.html
                      sensor_msgs/CameraInfo:
                      std_msgs/Header header
                      uint32 height
                      uint32 width
                      string distortion_model
                      float64[] D
                      float64[9] K
                      float64[9] R
                      float64[12] P
                      uint32 binning_x
                      uint32 binning_y
                      sensor_msgs/RegionOfInterest roi
                      Some of the variable mappings are clear, such as height, width, distortion model, R and D.
                      How do I map K and P required by CameraInfo from the Calibration files? And anything else that I should potentially look out for while doing this mapping?
                      • P Prabhav Gupta
                        and need some help.
                        %YAML:1.0
                        R: !!opencv-matrix
                           rows: 3
                           cols: 3
                           dt: d
                        T: !!opencv-matrix
                           rows: 3
                           cols: 1
                           dt: d
                        %YAML:1.0
                        M1: !!opencv-matrix
                           rows: 3
                           cols: 3
                           dt: d
                        D1: !!opencv-matrix
                           rows: 5
                           cols: 1
                           dt: d
                        M2: !!opencv-matrix
                           rows: 3
                           cols: 3
                           dt: d
                        D2: !!opencv-matrix
                           rows: 5
                           cols: 1
                           dt: d
                        width: 640
                        height: 480
                        uint32 height
                        uint32 width
                        float64[] D
                        float64[9] K
                        float64[9] R
                        float64[12] P
                        uint32 binning_x
                        uint32 binning_y
                        @Prabhav-Gupta ,
                        K is your M1 and M2 matrices for both cameras (3x3 Intrinsic camera matrix)
                        The link you shared has information how to compute the P matrix. I am not sure if it would be used by your application though.
                          @Prabhav-Gupta ,
                          P Offline
                          P Offline
                          Prabhav Gupta
                          @Alex-Kushleyev,
                          Cool, Thanks a lot!
