  3. voxl-docker-mavsdk-python build issues
voxl
48 Posts 6 Posters 29.6k Views 4 Watching
    @Alex-Kushleyev Good afternoon Alex,
    I'm currently running into issues with the voxl-mavsdk-python docker image. I've been following the documentation and README: https://docs.modalai.com/mavsdk/ https://gitlab.com/voxl-public/voxl-docker-images/voxl-docker-mavsdk-python/-/tree/master?ref_type=heads
    All params that are mentioned in the documentation have been updated. When adb shell in the VOXL and after running voxl-configure-docker-support.sh, gcr.io/modalai-public/voxl-mavsdk-python:v1.1 returns:
    Error response from daemon: manifest for gcr.io/modalai-public/voxl-mavsdk-python:v1.1 not found: manifest unknown: Failed to fetch "v1.1" from request "/v2/modalai-public/voxl-mavsdk-python/manifests/v1.1".
    :latest has also been tried with no success. When searching for similar image in Docker, the only image returned is:
     jbruell94/drone-control-modalai:vectro-drone
    Within here, there are similar, but not 100% the same folders/files between the two. Has the name of the image changed or been moved to a different location?
    @Alexander-Saunders , I am not sure about this one, i asked my colleague to check it out.
    Alexander SaundersA 1 Reply Last reply
      Alexander SaundersA Offline
      Alexander Saunders
      wrote on last edited by Alexander Saunders
      @Alex-Kushleyev Good afternoon,
      I'm just following up with you to see if there an update with the process of enabling MAVSDK with the VOXL2.
      I did some research on my end and am getting conflicting information on what is necessary for the older VOXL and the VOXL2.
      In the section relating to VOXL2: https://docs.modalai.com/docker-on-voxl/#download--push-a-docker-image-to-voxl, voxl-configure-docker-support.sh is not recommended to be ran, but for the README from the link on MAVSDK on VOXL2, I'm told to run said command.
      I am aware the link above is in reference to Ubuntu, but the command is shared between VOXL and VOXL2 documentation.
      Also the location /data/docker/mavsdk does not exist that is referenced in the documentation, but /data directory does.
      Could you or someone else follow up with me on which parts of the documentation is for VOXL or VOXL2 so that I can pull down the docker image for MAVSDK. If just enabling the parameters and running the services for voxl-vision-hub and voxl-mavlink-server is all or going through the normal Docker install on VOXL2, can you share that.
      Thank you,
      Alexander
      Screenshot 2024-05-22 at 2.50.32 PM.png Screenshot 2024-05-22 at 3.20.42 PM.png Screenshot 2024-05-22 at 3.20.07 PM.png Screenshot 2024-05-22 at 3.09.43 PM.png
        Thank you,
        Alexander
        @Alexander-Saunders VOXL has Docker pre-installed but you need to run voxl-configure-docker-support.sh in order to enable it. VOXL 2 does not have Docker pre-installed, but since it is a Debian-based platform you can just install Docker the standard way. For VOXL 2 you do not use voxl-configure-docker-support.sh.
          Thank you,
          Alexander
          @Alexander-Saunders You should try building the Docker container instead of downloading it from the repo since that seems to not be functional at the moment (Looking into it).
          Alexander SaundersA 2 Replies Last reply
            Alexander Saunders
              Alexander Saunders
              @Eric-Katzfey Just to make sure I'm not misunderstanding you, you want me to the instructions below that is coming from: https://gitlab.com/voxl-public/voxl-docker-images/voxl-docker-mavsdk-python!Screenshot 2024-05-22 at 4.39.11 PM.png
                @Alexander-Saunders Yes
                  Alexander Saunders
                  @Eric-Katzfey Good morning Eric,
                  So I tried building the image for both voxl-docker-mavsdk & voxl-docker-mavsdk-python. I run into the same issue with both, adb: command not found. Additionally, with voxl-docker-mavsdk-python the common file is not found.
                  the ./build-image.sh was run on both directories in both SSH and ADB shell.
                  I am at a standstill with testing until I can get the docker image built. Any additional documentation is greatly appreciated!
                  Respectfully,
                  Alexander
                  Screenshot 2024-05-23 at 9.20.56 AM.png Screenshot 2024-05-23 at 9.05.11 AM.png Screenshot 2024-05-23 at 9.14.44 AM.png
                    Respectfully,
                    Alexander
                    @Alexander-Saunders You run build-image.sh on your host computer, not on the voxl
                      Alexander Saunders
                      @Eric-Katzfey Hey Eric, I'm running the ./build-image.sh on a laptop and am running into this error. Screenshot from 2024-05-23 13-02-42.png
                        Alexander Saunders
                          @Alexander-Saunders Oh, the repo probably has the name master changed to main. Can you change the Dockerfile to try to use main instead of master and see if that works?
                            Alexander Saunders
                            Eric KatzfeyE 4 Replies Last reply
                              @Alexander-Saunders But that's a different problem. Before it was the checkout of master. This is something else.
                                @Alexander-Saunders I'll try it and see what happens.
                                  @Alexander-Saunders Okay, yes, I see the same error. Sorry about that. Let me see if I can figure out what is going wrong.
                                    @Alexander-Saunders Can you try with the origin/ascend/docker branch of voxl-docker-mavsdk-python instead? Seems like that's where the latest updates have happened and haven't been merged back into master yet.
                                      Alexander Saunders
                                      #19
                                      @Eric-Katzfey I went ahead and tried the voxl-docker-mavsdk repo also and get the same issue. I tried docker pull docker.io/arm64v8/ubuntu:bionic and giving the user permissions for the file/folder.
                                      What is stumping me is the registry-1.docker.io. I can ping it and do a DNS lookup just fine. Also pinging google is fine. But the error is persisting in relation to it.
                                      I will try the other branches for voxl-docker-mavsdk andvoxl-docker-mavsdk-python. Will that require changing main to the branch name for the DockerFile?
                                        Alexander Saunders
                                        #20
                                        @Eric-Katzfey image (2).png This is from the ascend branch
                                          @Alexander-Saunders Not sure why that is happening. That does not happen when I try it. I'm guessing that you have a networking issue of some sort or perhaps all this messing with Docker on the target has somehow corrupted it and it needs to be reinstalled.
