  3. voxl-docker-mavsdk-python build issues
voxl
48 Posts 6 Posters 31.0k Views 4 Watching
    @Alexander-Saunders You should try building the Docker container instead of downloading it from the repo since that seems to not be functional at the moment (Looking into it).
    Alexander SaundersA Offline
    Alexander Saunders
      Alexander Saunders
      @Eric-Katzfey Just to make sure I'm not misunderstanding you, you want me to the instructions below that is coming from: https://gitlab.com/voxl-public/voxl-docker-images/voxl-docker-mavsdk-python!Screenshot 2024-05-22 at 4.39.11 PM.png
        @Alexander-Saunders Yes
        Alexander SaundersA 1 Reply Last reply
          Alexander Saunders
          @Eric-Katzfey Good morning Eric,
          So I tried building the image for both voxl-docker-mavsdk & voxl-docker-mavsdk-python. I run into the same issue with both, adb: command not found. Additionally, with voxl-docker-mavsdk-python the common file is not found.
          the ./build-image.sh was run on both directories in both SSH and ADB shell.
          I am at a standstill with testing until I can get the docker image built. Any additional documentation is greatly appreciated!
          Respectfully,
          Alexander
          Screenshot 2024-05-23 at 9.20.56 AM.png Screenshot 2024-05-23 at 9.05.11 AM.png Screenshot 2024-05-23 at 9.14.44 AM.png
            Respectfully,
            Alexander
            @Alexander-Saunders You run build-image.sh on your host computer, not on the voxl
            Alexander SaundersA 2 Replies Last reply
              Alexander Saunders
              @Eric-Katzfey Hey Eric, I'm running the ./build-image.sh on a laptop and am running into this error. Screenshot from 2024-05-23 13-02-42.png
                Alexander Saunders
                  @Alexander-Saunders Oh, the repo probably has the name master changed to main. Can you change the Dockerfile to try to use main instead of master and see if that works?
                    Alexander Saunders
                    Eric KatzfeyE 4 Replies Last reply
                      @Alexander-Saunders But that's a different problem. Before it was the checkout of master. This is something else.
                        @Alexander-Saunders I'll try it and see what happens.
                          @Alexander-Saunders Okay, yes, I see the same error. Sorry about that. Let me see if I can figure out what is going wrong.
                            @Alexander-Saunders Can you try with the origin/ascend/docker branch of voxl-docker-mavsdk-python instead? Seems like that's where the latest updates have happened and haven't been merged back into master yet.
                              Alexander Saunders
                              wrote on last edited by Alexander Saunders
                              #19
                              @Eric-Katzfey I went ahead and tried the voxl-docker-mavsdk repo also and get the same issue. I tried docker pull docker.io/arm64v8/ubuntu:bionic and giving the user permissions for the file/folder.
                              What is stumping me is the registry-1.docker.io. I can ping it and do a DNS lookup just fine. Also pinging google is fine. But the error is persisting in relation to it.
                              I will try the other branches for voxl-docker-mavsdk andvoxl-docker-mavsdk-python. Will that require changing main to the branch name for the DockerFile?
                                Alexander Saunders
                                #20
                                @Eric-Katzfey image (2).png This is from the ascend branch
                                  @Alexander-Saunders Not sure why that is happening. That does not happen when I try it. I'm guessing that you have a networking issue of some sort or perhaps all this messing with Docker on the target has somehow corrupted it and it needs to be reinstalled.
                                    Alexander Saunders
                                    @Eric-Katzfey So I deleted and re cloned voxl-docker-mavsdk-python branch ascend/docker. The build image failed halfway in. Is there any work that needs to be done on the VOXL2 or host computer that I am not aware of? Screenshot from 2024-05-28 10-15-10.png Screenshot from 2024-05-28 10-14-45.png
                                      Alexander Saunders
                                      @Eric-Katzfey Also in the environment, the SDK is 1.2, python 3.10.12, Ubuntu 22.04.4 LTS
                                        @Alexander-Saunders Okay, we're looking into it, thanks!
                                          Alexander Saunders
                                          @Eric-Katzfey Thank you! What kind of timeline should I expect to hear back from you?
                                          B 2 Replies Last reply
