  3. Hires IMX214 M0024-2 causing ADB to stop working
image-sensor
7 Posts 3 Posters 1.2k Views 2 Watching
  • Jeremy FrederickJ Offline
    Jeremy Frederick
    I was attempting voxl-configure-cams and it failed to detect the IMX214 hires camera. I unplugged the voxl2 and verified the ports that the hires was plugged into. It was on the wrong port, it was on J6L instead of J7U. I reinstalled the hires camera on the correct port. The next time I powered the Voxl2 on, ADB would not work and lsusb shows QUSB_BULK instead of KONA-QRD. I read on a different post that QSUB_BULK is typically an indication of a hardware issue.
    Did I fry the IMX214 M0024-2 by putting it on the wrong port?
    • Jeremy FrederickJ Jeremy Frederick
      @Jeremy-Frederick If you power the voxl 2 with no cameras attached are you able to ADB on? Or does it still show QUSB_BULK?
      Jeremy FrederickJ 1 Reply Last reply
        Jeremy Frederick
        @tom with no cameras I can ADB on
          @Jeremy-Frederick Can you post a picture of your camera setup and let us know what camera configuration you're attempting to use?
            @Jeremy-Frederick , this can happen if you plug the camera or the camera interposer (or both) in the wrong orientation into VOXL2. please check pin 1 alignment in all camera connections.
              Jeremy Frederick
              It ended up being a combination of incorrect ports and pin alignment. The cameras worked great once I got the correct reference frame nailed down.
                @Jeremy-Frederick, that is great!
                Luckily (or by design 🙂 ) the camera connector reversal is typically not fatal, but DO NOT push your luck, please 🙂 . Technically, if damage occurs due to incorrect insertion of the camera connectors, this will void the warranty for the main board.
                Always verify connector orientation when changing camera configuration.
