<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Hires IMX214 M0024-2 causing ADB to stop working]]></title><description><![CDATA[<p dir="auto">I was attempting voxl-configure-cams and it failed to detect the IMX214 hires camera. I unplugged the voxl2 and verified the ports that the hires was plugged into. It was on the wrong port, it was on J6L instead of J7U. I reinstalled the hires camera on the correct port. The next time I powered the Voxl2 on, ADB would not work and lsusb shows QUSB_BULK instead of KONA-QRD. I read on a different post that QSUB_BULK is typically an indication of a hardware issue.<br />
Did I fry the IMX214 M0024-2 by putting it on the wrong port?</p>
]]></description><link>https://forum.modalai.com/topic/3434/hires-imx214-m0024-2-causing-adb-to-stop-working</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 06:47:00 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/3434.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 14 May 2024 19:48:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Hires IMX214 M0024-2 causing ADB to stop working on Wed, 15 May 2024 15:30:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jeremy-frederick" aria-label="Profile: Jeremy-Frederick">@<bdi>Jeremy-Frederick</bdi></a>, that is great!</p>
<p dir="auto">Luckily (or by design <img src="https://forum.modalai.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=68ea69aeb78" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /> ) the camera connector reversal is typically not fatal, but <em>DO NOT</em> push your luck, please <img src="https://forum.modalai.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=68ea69aeb78" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /> . Technically, if damage occurs due to incorrect insertion of the camera connectors, this will void the warranty for the main board.</p>
<p dir="auto">Always verify connector orientation when changing camera configuration.</p>
<p dir="auto">Alex</p>
]]></description><link>https://forum.modalai.com/post/16911</link><guid isPermaLink="true">https://forum.modalai.com/post/16911</guid><dc:creator><![CDATA[Alex Kushleyev]]></dc:creator><pubDate>Wed, 15 May 2024 15:30:11 GMT</pubDate></item><item><title><![CDATA[Reply to Hires IMX214 M0024-2 causing ADB to stop working on Wed, 15 May 2024 15:22:09 GMT]]></title><description><![CDATA[<p dir="auto">It ended up being a combination of incorrect ports and pin alignment. The cameras worked great once I got the correct reference frame nailed down.</p>
]]></description><link>https://forum.modalai.com/post/16909</link><guid isPermaLink="true">https://forum.modalai.com/post/16909</guid><dc:creator><![CDATA[Jeremy Frederick]]></dc:creator><pubDate>Wed, 15 May 2024 15:22:09 GMT</pubDate></item><item><title><![CDATA[Reply to Hires IMX214 M0024-2 causing ADB to stop working on Wed, 15 May 2024 15:00:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jeremy-frederick" aria-label="Profile: Jeremy-Frederick">@<bdi>Jeremy-Frederick</bdi></a> , this can happen if you plug the camera or the camera interposer (or both) in the wrong orientation into VOXL2. please check pin 1 alignment in all camera connections.</p>
]]></description><link>https://forum.modalai.com/post/16906</link><guid isPermaLink="true">https://forum.modalai.com/post/16906</guid><dc:creator><![CDATA[Alex Kushleyev]]></dc:creator><pubDate>Wed, 15 May 2024 15:00:18 GMT</pubDate></item><item><title><![CDATA[Reply to Hires IMX214 M0024-2 causing ADB to stop working on Tue, 14 May 2024 20:36:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jeremy-frederick" aria-label="Profile: Jeremy-Frederick">@<bdi>Jeremy-Frederick</bdi></a> Can you post a picture of your camera setup and let us know what camera configuration you're attempting to use?</p>
]]></description><link>https://forum.modalai.com/post/16883</link><guid isPermaLink="true">https://forum.modalai.com/post/16883</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Tue, 14 May 2024 20:36:25 GMT</pubDate></item><item><title><![CDATA[Reply to Hires IMX214 M0024-2 causing ADB to stop working on Tue, 14 May 2024 20:25:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tom" aria-label="Profile: tom">@<bdi>tom</bdi></a> with no cameras I can ADB on</p>
]]></description><link>https://forum.modalai.com/post/16882</link><guid isPermaLink="true">https://forum.modalai.com/post/16882</guid><dc:creator><![CDATA[Jeremy Frederick]]></dc:creator><pubDate>Tue, 14 May 2024 20:25:08 GMT</pubDate></item><item><title><![CDATA[Reply to Hires IMX214 M0024-2 causing ADB to stop working on Tue, 14 May 2024 19:53:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jeremy-frederick" aria-label="Profile: Jeremy-Frederick">@<bdi>Jeremy-Frederick</bdi></a> If you power the voxl 2 with no cameras attached are you able to ADB on? Or does it still show QUSB_BULK?</p>
]]></description><link>https://forum.modalai.com/post/16880</link><guid isPermaLink="true">https://forum.modalai.com/post/16880</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Tue, 14 May 2024 19:53:43 GMT</pubDate></item></channel></rss>
