  3. April Tag Setup Issues - Waiting for Server
3 Posts 3 Posters 766 Views 2 Watching
  • WineVirusW Offline
    WineVirusW Offline
    WineVirus
    Hi, I'm working on April Tag setup for the tracking camera (SDK 1.1.1, M0149 Camera). I've run through the voxl-configure-tag-detector wizard, set to factory default, and enabled. I haven't changed anything with the other configuration files. My issue arises when I'm trying to check output, but voxl-inspect-tags is producing the following, without proceeding (tried waiting for +5 minutes, power cycled and waited again):
    I'm able to see the live tracking camera output via Voxl Portal, but it's not giving me anything indicating that it's picking up on the tag.
    • WineVirusW WineVirus
      wrote on last edited by tom
      @WineVirus I would take a look at journalctl -u voxl-tag-detector to see the status of the server
      Since it is still waiting for the MPA pipe to be created, I'm guessing the server is crashing
        vox-tag-detector requires camera calibration, path to which which is stored here in the configuration file : /etc/modalai/voxl-tag-detector.conf . If you have not performed calibration of your tracking camera, please do that: https://docs.modalai.com/calibrate-cameras/
        After that, make sure the voxl-tag-detector.conf is set up to listen to the correct camera (input_pipe should match the name of the camera that you are looking at through voxl-portal, typically tracking for the tracking caemra). Also make sure the detector is enabled "enable": true in voxl-tag-detector.conf .
        Finally, as Tom suggested, if the tag detector encounters some error, it will display it in the log. You could just run the tag detector in the foreground by stopping the background service first and then running the detector in the terminal:
        systemctl stop voxl-tag-detector
        voxl-tag-detector
