  3. Position mode works, but offboard mode don't
33 Posts 4 Posters 11.8k Views 2 Watching
    @Dawid-Mościcki ,
    Let's do a quick check of ESCs. Please follow this procedure:
    #stop px4 which will conflict with ESC tools
    systemctl stop voxl-px4
    #udpate voxl-esc tools to get the latest (if you have internet connection)
    apt-get update
    apt-get install voxl-esc
    #run ESC scan
    ./voxl-esc-scan.py
    This should detect the modalai ESCs without using PX4. Hopefully there is no issue in doing that, please let us know.
    Dawid MościckiD Offline
    Dawid Mościcki
    I tried to update voxl-esc, but its already newest version ...
    I 3d printed drone's skid and fly tested. Drone was having trouble with managing constant altitude, and when trying to land (it was on the ground) somehow flew up to 1.5m and made rapid descend to ground and crashed. Could You help me review this issue ? This is link to logs, params, and esc output on gdrive : link
    It was very strange ... I'm almost certain that we got a bug in params at this point.
    Best regards
    • Dawid MościckiD Dawid Mościcki
      Best regards
      Alex KushleyevA Online
      @Dawid-Mościcki , i took a look at the log, the ESC performance looks good. I do see the jump at the end, which you described, but it is not clear to my why this happened.
      @Zachary-Lowell-0 , any suggestions how to diagnose further? Position and offboard mode use VIO, for x-y-z control, right? (sorry if I am off, not entirely familiar). Can we log and look at VIO quality?
      Dawid MościckiD 1 Reply Last reply
        Dawid Mościcki
        @Alex-Kushleyev Any updates on reviewing this issue ? TBH i'm scared to take off this drone from ground again without finding cause of that strange behavior ...
        • Zachary Lowell 0Z Offline
          Zachary Lowell 0
          @Alex-Kushleyev said in Position mode works, but offboard mode don't:
          for
          @Dawid-Mościcki I would say it is safe for now to just fly via position mode or mannual mode and have a kill switch linked to the rC controller. Then you can try swapping over to positio mode. Then try your offboard code.
          If the esc chimes when booted then it is getting the right data to control the motors.
            for
            Dawid Mościcki
            @Zachary-Lowell-0 that crash happened in position mode .......
              Zachary Lowell 0
              Got it - if you are certain this is an issue in the parameters of PX4, you can reconfigure the MPA to match that of the m500 - just run voxl-configure-mpa and it will then ask for the drone you are using. Then it will parse through all the config files for the m500 and setup the MPA and px4. Then reboot and everything should be back to factory defaults.
                Dawid Mościcki
                @Zachary-Lowell-0
                I did it, and configured drone accordingly to https://docs.modalai.com/flying-with-vio/ so that drone could fly without GPS.
                Drone can't fly at all, doesnt respond to stick inputs, logs : https://review.px4.io/plot_app?log=f4e0abee-f370-4932-91c4-2e19aa6e66cf
                Vibration metrics is too high, what can we do ?
                Please help 😕
                Dawid MościckiD 2 Replies Last reply
                  @Zachary-Lowell-0
                  Please help 😕
                  Dawid Mościcki
                  @Dawid-Mościcki Any 3D files for this drone are available for download ? For example landing skid ?
                    @Zachary-Lowell-0
                    Please help 😕
                    Dawid Mościcki
                    @Dawid-Mościcki i don't even know how's that possible https://review.px4.io/plot_app?log=973783b8-6262-46e3-8214-602dce495131
                    look at actuator FFT
                      Zachary Lowell 0
                      @Dawid-Mościcki said in Position mode works, but offboard mode don't:
                      Please help
                      2 Replies Last reply about 24 hours ago Reply
                      Hi David - can you reflash your voxl with the most recent SDK and reconfigure the SKU - we need to start from baseline. Let me know.
                      Zach
                        Please help
                        Zach
                        Dawid Mościcki
                        @Zachary-Lowell-0 what do You mean by SDK ? Is this guide that i should follow, but without full wipe ? https://docs.modalai.com/sentinel-factory-reset/
                          @Dawid-Mościcki https://docs.modalai.com/flash-system-image/#flashing-a-voxl-sdk-release
                          Dawid MościckiD 4 Replies Last reply
                            Dawid Mościcki
                            @tom after flashing, i've got problem with calibrating IMU, btw should 2 imu be present ? because i can see only one :
                            voxl-calibrate-imu-temp
                            voxl-imu-server currently has no calibration file
                            Server has IMU0 enabled and available for temperature calibration
                            WARNING, voxl-fan utility missing, can't turn on fan
                            We're now starting the COLD stage of the calibration.
                            Please stop all unnecessary services in another terminal, and try your best
                            to cool the PCB with a fan. Alternatively, start this process on a cold PCB.
                            We will be measuring the static gyro and accel offset as the board heats up.
                            VOXL must remain completely still through this entire process!
                            The IMU temperatures will be printed here continuously.
                            Press ENTER to start the heating process when you are happy that the IMUs
                            are cold enough for the lower bound. 25-35C is a reasonable goal for this.
                            CPU: 36.3C IMU0: 30.4C ^M
                            WARNING, voxl-fan utility missing, can't turn off fan
                            We're now starting the HOT stage of the calibration. We just turned off
                            the fan, and started stressing the CPU to heat up the PCB.
                            This will run automatically for a while collecting data points until enough
                            data has been collected, something gets too hot, or the timeout is reached.
                            CPU: 57.1C IMU0: 34.9C all imus reached steady state, finishing test
                            taking sample #2
                            not enough samples, need at least 3
                              Dawid Mościcki
                              @tom i created backup from /data folder on my pc, but i don't know if this could be helpful
                                Dawid Mościcki
                                @Dawid-Mościcki after importing parameters for vio-indoor without gps from https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/blob/master/params/v1.14/EKF2_helpers/indoor_vio_missing_gps.params
                                i only armed vehicle to see vibrations : https://review.px4.io/plot_app?log=c70ab712-72c1-4abf-b954-edda6316bf05
                                What could I do next ?
                                  Dawid Mościcki
                                  @tom this is my second try https://review.px4.io/plot_app?log=cba05321-9bb5-42f2-a766-ecfa6ee01f80
                                    Dawid Mościcki
                                    @tom this is my dump from /data folder : https://drive.google.com/drive/folders/1ZJXCvCcAg81zJolngtlS-Y_re2BjY2pz?usp=sharing
                                      #29
                                      @Dawid-Mościcki , the gyro / accel noise in your logs is very high.
                                      This looks like the flight board is loose something is causing it to vibrate during flight (any wires or anything connected to VOXL2 that might be flopping around?).
                                      Actuator controls FFT shows
                                      shows noise at about 80 hz (4800rpm) whch maches the average commanded / actual rpm:
                                      This confirms that the oscillations are coming from propeller vibrations and not oscillations due to high attitude control gains (which would be much lower frequency in the range of 15-20hz).
                                        Dawid Mościcki
                                        @Alex-Kushleyev Thanks for help, after changing propellers everything seems to work normal, but somehow RC apparatus stopped working. When i'm trying to set up bind mode nothing happens. I was following this guide :
                                        https://docs.modalai.com/sentinel-user-guide-pre-flight-setup/
                                        Led is blinking always slowly on blue....
                                        What can i do about it ?
                                          Dawid Mościcki
                                          @Alex-Kushleyev for some reason CPU load on qvio-server is very high. We also have problem with Alfa wifi modem - every few minutes it's turning off and restarting ... Led isnt blinking for few seconds then network start working again . While this is happening Qgroundcontrol is crashing (as every time when drone is reconnected)
                                          Output from voxl-inspect-services
                                          modallink-relink | Disabled | Not Running |
                                          voxl-camera-server | Enabled | Running | 71.0%
                                          voxl-cpu-monitor | Enabled | Running | 0.6%
                                          voxl-feature-tracker | Disabled | Not Running |
                                          voxl-flow-server | Disabled | Not Running |
                                          voxl-imu-server | Enabled | Running | 5.4%
                                          voxl-lepton-server | Disabled | Not Running |
                                          voxl-mavcam-manager | Enabled | Running | 0.0%
                                          voxl-mavlink-server | Enabled | Running | 3.5%
                                          voxl-modem | Disabled | Not Running |
                                          voxl-neopixel-manager | Disabled | Not Running |
                                          voxl-open-vins-server | Disabled | Not Running |
                                          voxl-portal | Enabled | Running | 0.2%
                                          voxl-px4 | Enabled | Running | 57.1%
                                          voxl-qvio-server | Enabled | Not Running |
                                          voxl-rangefinder-server | Disabled | Not Running |
                                          voxl-remote-id | Disabled | Not Running |
                                          voxl-softap | Enabled | Completed |
                                          voxl-streamer | Enabled | Running | 0.0%
                                          voxl-tflite-server | Disabled | Not Running |
                                          voxl-uvc-server | Disabled | Not Running |
                                          voxl-vision-hub | Enabled | Running | 1.9%
