    VOXL Wifi Connection
    • Paola LimP
      Paola Lim
      Hello! I am having some issues trying to connect both wifi and 5G Connector.
      Either way I have issues getting any network connection.
      I tried all the documentations from the site but still have not success. I am getting kinda frustrated at this.
      I will attach a picture of both wifi and 5G Connector images + What images that I get after connecting voxl.
      Kindly asking for help. Thank you
      IMG_3999 중간.jpeg IMG_4001 중간.jpeg 스크린샷 2024-03-10 오후 5.24.08.png 스크린샷 2024-03-10 오후 5.24.55.png IMG_3988 중간.jpeg IMG_3989 중간.jpeg
      tomT VinnyV 2 Replies Last reply Reply Quote 0
        tom admin @Paola Lim
        @Paola-Lim Your SDK is quite old at this point so I would suggest flashing the latest (1.1.3).
        See here for voxl-wifi usage:
        https://docs.modalai.com/voxl-2-wifi-setup/
        Paola LimP 1 Reply Last reply Reply Quote 0
        • VinnyV
          Vinny ModalAI Team @Paola Lim
          HI @Paola-Lim
          Please also provide some physical separation between your two WWAN antennas. When they are that close to each other, they will detune.
          Also make sure they are not sitting up directly against any conductive material such as carbon frames or batteries. Some type of dielectric spacer is required to adhere them to most surfaces.
          You can easily google search the 3M antenna part number with a phrase like "guidelines" to get further input direct from 3M for those specific bands.
          • Paola LimP
            Paola Lim @tom
            @tom Is the "voxl-suite: 1.0.0" the SDK?
            https://docs.modalai.com/flash-system-image/ <- This is how you upgrade the SDK? Just would like to confirm so I can upgrade it first.
            Thank you
            • Paola LimP
              Paola Lim @Vinny
              @Vinny said in VOXL Wifi Connection:
              3M antenna
              Oh... I did not know that! Thank you for the info! 😊
                Alex Kushleyev ModalAI Team @Paola Lim
                @Paola-Lim
                You will need to follow directions from this page : https://docs.modalai.com/flash-system-image/#flashing-a-voxl-sdk-release
                Tom suggested getting the SDK 1.1.3, so per instructions you should go to https://developer.modalai.com, log in, then click on Protected Downloads -> VOXL2 Platform Releases and download VOXL2 SDK 1.1.3 and follow the rest of instructions from "flashing voxl sdk" page
