  3. Supporting power monitor to see battery status
flight-core-v2
12 Posts 5 Posters 3.5k Views 4 Watching
  • W Will
    I've linked the power monitor to FCv2, but I'm unable to view the battery status from either GCS or voxlpm. Your assistance in resolving this matter would be greatly appreciated. Thank you.
    [boot] Rev 0x0 : Ver 0x3 V2003000
    [boot] Fault Log info File No 4 Length 3177 flags:0x01 state:1
    [boot] Fault Log is Armed
    ERROR [PX4_MTD] failed to initialize mtd driver
    ERROR [PX4_MTD] mtd fail[hardfault_log] Fault Log is Armed
    ure: -5 bus 2 address 0 class 1
    nsh: sysinit: fopen failed: No such file or directory
    HW arch: MODALAI_FC_V2
    HW type: V2003000
    HW version: 0x003
    HW revision: 0x000
    PX4 git-hash: 996e85e9360801dd9ec11b7149a524e38231dcc6
    PX4 version: 1.14.0 0 (17694720)
    Vendor version: 2.0.64 0 (33570816)
    OS: NuttX
    OS version: Release 11.0.0 (184549631)
    OS git-hash: 3f77354c0dc88793a47ff3b57595195ab45f7ba9
    Build datetime: Jan  3 2024 15:59:58
    Build uri: localhost
    Build variant: default
    Toolchain: GNU GCC, 9.3.1 20200408 (release)
    PX4GUID: 0006000000003333363031315105003a001c
    MCU: STM32H7[4|5]xxx, rev. V
    INFO  [param] selected parameter default file /fs/microsd/params
    INFO  [param] importing from '/fs/microsd/params'
    INFO  [parameters] BSON document size 1487 bytes, decoded 1487 bytes (INT32:29, FLOAT:44)
    INFO  [param] selected parameter backup file /fs/microsd/parameters_backup.bson
    Board architecture defaults: /etc/init.d/rc.board_arch_defaults
    Board defaults: /etc/init.d/rc.board_defaults
    Loading airframe: /etc/init.d/airframes/4001_quad_x
    nsh: tone_alarm: command not found
    INFO  [dataman] data manager file '/fs/microsd/dataman' size is 62560 bytes
    Board sensors: /etc/init.d/rc.board_sensors
    INFO  [voxlpm] Failed to init voxlpm type: 0 on bus: 3, but will try again periodically.
    voxlpm #0 on I2C bus 3 (external) address 0x44
    WARN  [SPI_I2C] Already running on bus 3
    WARN  [SPI_I2C] voxlpm: no instance started (no device on bus?)
    icm42688p #0 on SPI bus 1 rotation 12
    icm42688p #1 on SPI bus 2 rotation 12
    WARN  [SPI_I2C] icp201xx: no instance started (no device on bus?)
    nsh: icm20948_i2c_passthrough: command not found
    nsh: battery_status: command not found
    ekf2 [542:237]
    Starting MAVLink on /dev/ttyS6
    INFO  [mavlink] mode: Onboard, data rate: 46080 B/s on /dev/ttyS6 @ 921600B
    Addons script: /fs/microsd/etc/extras.txt
    nsh: BMP388: command not found
    INFO  [uavcan] Node ID 1, bitrate 1000000
    NuttShell (NSH) NuttX-11.0.0
    nsh> WARN  [health_and_arming_checks] Preflight Fail: barometer 0 missing
    WARN  [health_and_arming_checks] Preflight Fail: Crash dumps present on SD, vehicle needs service
    nsh> ver all
    HW type: V2003000
    HW version: 0x003
    HW revision: 0x000
    OS: NuttX
    nsh>
    nsh> voxlpm status
    voxlpm: sample: 0 events, 0us elapsed, 0.00us avg, min 0us max 0us 0.000us rms
    - type: BATT
      - voltage:    0.0000 VDC
      - current:    0.0000 ADC
      - shunt:    0.0000 mV,    0.0000 mA
      - rsense:  0.000500 ohm, cal: 0
      - meas interval:  100000 us
    nsh>
    nsh> i2cdetect -b 3
    Scanning I2C bus: 3
         0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
    00: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    70: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    W Offline
    W Offline
    Will
    @Vinny, I've conducted measurements on J13 pins, specifically p3 and p4. While p4 (I2C SDA) registers a stable 5V when the voxlpm is operational, I've observed that p3 (I2C SCL) shows no voltage at all. I suspect this discrepancy might be the root cause of my inability to retrieve battery information. Could you please assist in verifying and addressing this issue? Thank you.
    VinnyV 1 Reply Last reply
    • W Will
      Hi @Will
      Few questions then (and good sleuthing here):
      1. If you disconnect the power module from the FCv2 board, do you observe both I2C_SDA and I2C_SCL HIGH or LOW on the power module? The 5V pullups are located at the power module, and not the FCv2 side
      2. When plugged in to the FCv2, does anything change? (i..e: is SCL HIGH on the power module, but when you insert to J13 it goes low?)
      3. Can you possibly replace your MCBL-00062 and retry?
        https://docs.modalai.com/cable-datasheets/#mcbl-00062
        The Molex side is notorious for loosing connectivity at the pin contacts in high-use applications where folks pull on the wires and not the connector (We have a standing rule at HQ to replace any power cable after every few months).
      We'll take it from there pending your results.
      • S Offline
        S Offline
        skl1g14
        Hi both @Will, @Vinny,
        Tagging along here. I observed similar issue with the voxlpm driver on Flight core v2.
        Personally I have been working on a voxl1 + flight core v2 (I have 2 set of this). I am using the older v2 power module https://docs.modalai.com/power-module-v2-datasheet/ connected to a standard 4s LiPo battery.
        The version of my flight core shown below.
        cc575697-ba30-4bf6-921d-7d2bb4a70a34-Screenshot from 2024-01-17 21-54-48.png.
        I am seeing that one of the flight-core (rarely use this, mostly as backup) has output by voxlpm as shown below,
        acad3134-b2b0-407a-813d-1dd0b41922ca-Screenshot from 2024-01-17 22-01-16.png
        while my other flight core (mainly working on this) is not giving any output (shown below)
        fccd6c6e-bacd-4a9b-a28c-52567e94aff8-Screenshot from 2024-01-17 22-40-35.png
        Both flight core able to detect the i2c port at bus 3 address 44 and 45.
        9545e76d-a1de-4ff2-bdf2-9b8b983192af-Screenshot from 2024-01-17 22-01-57.png
        https://github.com/PX4/PX4-Autopilot/blob/main/src/drivers/power_monitor/voxlpm/voxlpm.hpp
        230d7f74-8378-42a5-ab2a-6ab1f29dabf0-Screenshot from 2024-01-17 22-32-17.png
        I assume the firmware on my board (1.13.2) is using the voxlpmv3 and sensing on the address 0x44 as the default voxlpm is sensing at the RSENSE_VBATT.
        Any idea what might be the case? Is there a way to observe the uORB id for battery_status or monitor the process when voxlpm start at boot?
        What i have tried.
        1. Use same power module connector.
        2. Load the same px4 parameter.
        3. Updating to the latest sdk 1.12 and px4 1.14 firmware http://voxl-packages.modalai.com/dists/fc-v2/sdk-1.1/modalai_fc-v2_1.14.0-2.0.63.px4
        VinnyV Eric KatzfeyE 3 Replies Last reply
        • S skl1g14
          What i have tried.
          Hi @skl1g14
          I've notified our team to look into this for you. Your request is beyond my support ability 🙂
          Anything HW related, feel free to tag me.
          • S skl1g14
            What i have tried.
            Eric KatzfeyE Online
            @skl1g14 You can use the listener command to monitor topic data. For example listener battery_status.
            • S skl1g14
              What i have tried.
              @skl1g14 You can also use the dmesg command to look at all of the past messages since boot
              • VinnyV Vinny
                Hi @skl1g14
                @skl1g14 , based on your voxlpm status, you actually have V3 power adapter, because it says V3 (INA231). The px4 driver should do a probe and find either V2 or V3 power adapter based on the i2c addresses : https://github.com/PX4/PX4-Autopilot/blob/main/src/drivers/power_monitor/voxlpm/voxlpm.cpp#L120
                If you can use i2cdetect to detect i2c addresses 44 and 45 this also confirms V3 power adapter.
                If your second flight core is not reading battery voltage, it seems that it failed to detect the power adapter. Is it possible that you are using old version of PX4 that did not have the support for V3 power adapter?
                You can try to add some print statements into init() and probe() functions here : https://github.com/PX4/PX4-Autopilot/blob/main/src/drivers/power_monitor/voxlpm/voxlpm.cpp#L68
                @Will , if you cannot see any I2C devices using i2c_detect -b 3 that is not very good. Maybe try again after disabling voxlpm driver, just to make sure there is no conflict between the driver and the i2c_detect test. I would also recommend using an oscilloscope (if you have one available) to check if there is i2c communication attempts when you do run i2c_detect
                S 1 Reply Last reply
                  S Offline
                  S Offline
                  skl1g14
                  Hi @Alex-Kushleyev,
                  Updated the PX4 firmware to 1.14
                  84a69116-dc0a-47f1-adb6-f8d6054691b3-Screenshot from 2024-01-18 16-42-22.png
                  Adding the following two parameters to the list and load parameter from file seems to fix it for me? I could not find these 2 parameters in QGC initally. I am using the latest version of QGC (v4.30).
                  d85a252f-485b-41b8-a667-37ad3dc1c0b8-Screenshot from 2024-01-18 16-47-18.png
                  I tried to remove these 2 parameters but I could not reproduce my issue, i can still see the voxlpm output afterwards.
                  • S skl1g14
                    Hi @Alex-Kushleyev,
                    S Offline
                    S Offline
                    skl1g14
                    Default px4 parameter list.
                    # Onboard parameters for Vehicle 1
                    # Stack: PX4 Pro
                    # Vehicle: Multi-Rotor
                    # Version: 1.14.0 dev
                    # Git Revision: b02a6b4ae902003f
                    # Vehicle-Id Component-Id Name Value Type
                    1	1	ASPD_SCALE_1	1.000000000000000000	9
                    1	1	BAT1_CAPACITY	3000.000000000000000000	9
                    1	1	BAT1_N_CELLS	4	6
                    1	1	BAT1_R_INTERNAL	0.008000000379979610	9
                    1	1	BAT1_SOURCE	0	6
                    1	1	BAT1_V_CHARGED	4.150000095367431641	9
                    1	1	BAT1_V_EMPTY	3.599999904632568359	9
                    1	1	BAT1_V_LOAD_DROP	0.100000001490116119	9
                    1	1	BAT_AVRG_CURRENT	15.000000000000000000	9
                    1	1	BAT_CRIT_THR	0.250000000000000000	9
                    1	1	BAT_EMERGEN_THR	0.100000001490116119	9
                    1	1	BAT_LOW_THR	0.300000011920928955	9
                    1	1	BAT_N_CELLS	4	6
                    1	1	BAT_V_CHARGED	4.150000095367431641	9
                    1	1	BAT_V_EMPTY	3.599999904632568359	9
                    1	1	BAT_V_LOAD_DROP	0.300000011920928955	9
                    1	1	CAL_ACC0_ID	2490378	6
                    1	1	CAL_ACC0_PRIO	50	6
                    1	1	CAL_ACC0_ROT	-1	6
                    1	1	CAL_ACC0_XOFF	0.000000000000000000	9
                    1	1	CAL_ACC0_XSCALE	1.000000000000000000	9
                    1	1	CAL_ACC0_YOFF	0.000000000000000000	9
                    1	1	CAL_ACC0_YSCALE	1.000000000000000000	9
                    1	1	CAL_ACC0_ZOFF	0.000000000000000000	9
                    1	1	CAL_ACC0_ZSCALE	1.000000000000000000	9
                    1	1	CAL_ACC1_ID	2490386	6
                    1	1	CAL_ACC1_PRIO	50	6
                    1	1	CAL_ACC1_ROT	-1	6
                    1	1	CAL_ACC1_XOFF	0.000000000000000000	9
                    1	1	CAL_ACC1_XSCALE	1.000000000000000000	9
                    1	1	CAL_ACC1_YOFF	0.000000000000000000	9
                    1	1	CAL_ACC1_YSCALE	1.000000000000000000	9
                    1	1	CAL_ACC1_ZOFF	0.000000000000000000	9
                    1	1	CAL_ACC1_ZSCALE	1.000000000000000000	9
                    1	1	CAL_ACC2_ID	0	6
                    1	1	CAL_ACC3_ID	0	6
                    1	1	CAL_AIR_CMODEL	0	6
                    1	1	CAL_AIR_TUBED_MM	1.500000000000000000	9
                    1	1	CAL_AIR_TUBELEN	0.200000002980232239	9
                    1	1	CAL_BARO0_ID	0	6
                    1	1	CAL_BARO1_ID	0	6
                    1	1	CAL_BARO2_ID	0	6
                    1	1	CAL_BARO3_ID	0	6
                    1	1	CAL_GYRO0_ID	2490378	6
                    1	1	CAL_GYRO0_PRIO	50	6
                    1	1	CAL_GYRO0_ROT	-1	6
                    1	1	CAL_GYRO0_XOFF	-0.007948651909828186	9
                    1	1	CAL_GYRO0_YOFF	0.006882027722895145	9
                    1	1	CAL_GYRO0_ZOFF	0.005271935835480690	9
                    1	1	CAL_GYRO1_ID	2490386	6
                    1	1	CAL_GYRO1_PRIO	50	6
                    1	1	CAL_GYRO1_ROT	-1	6
                    1	1	CAL_GYRO1_XOFF	-0.014327573589980602	9
                    1	1	CAL_GYRO1_YOFF	0.010455547831952572	9
                    1	1	CAL_GYRO1_ZOFF	0.001255361014045775	9
                    1	1	CAL_GYRO2_ID	0	6
                    1	1	CAL_GYRO3_ID	0	6
                    1	1	CAL_MAG0_ID	396809	6
                    1	1	CAL_MAG0_PRIO	75	6
                    1	1	CAL_MAG0_ROT	10	6
                    1	1	CAL_MAG0_XCOMP	0.000000000000000000	9
                    1	1	CAL_MAG0_XODIAG	0.000000000000000000	9
                    1	1	CAL_MAG0_XOFF	0.000000000000000000	9
                    1	1	CAL_MAG0_XSCALE	1.000000000000000000	9
                    1	1	CAL_MAG0_YCOMP	0.000000000000000000	9
                    1	1	CAL_MAG0_YODIAG	0.000000000000000000	9
                    1	1	CAL_MAG0_YOFF	0.000000000000000000	9
                    1	1	CAL_MAG0_YSCALE	1.000000000000000000	9
                    1	1	CAL_MAG0_ZCOMP	0.000000000000000000	9
                    1	1	CAL_MAG0_ZODIAG	0.000000000000000000	9
                    1	1	CAL_MAG0_ZOFF	0.000000000000000000	9
                    1	1	CAL_MAG0_ZSCALE	1.000000000000000000	9
                    1	1	CAL_MAG1_ID	0	6
                    1	1	CAL_MAG1_ROT	-1	6
                    1	1	CAL_MAG2_ID	0	6
                    1	1	CAL_MAG2_ROT	-1	6
                    1	1	CAL_MAG3_ID	0	6
                    1	1	CAL_MAG3_ROT	-1	6
                    1	1	CAM_CAP_FBACK	0	6
                    1	1	CA_AIRFRAME	0	6
                    1	1	CA_FAILURE_MODE	0	6
                    1	1	CA_METHOD	2	6
                    1	1	CA_R0_SLEW	0.000000000000000000	9
                    1	1	CA_R10_SLEW	0.000000000000000000	9
                    1	1	CA_R11_SLEW	0.000000000000000000	9
                    1	1	CA_R1_SLEW	0.000000000000000000	9
                    1	1	CA_R2_SLEW	0.000000000000000000	9
                    1	1	CA_R3_SLEW	0.000000000000000000	9
                    1	1	CA_R4_SLEW	0.000000000000000000	9
                    1	1	CA_R5_SLEW	0.000000000000000000	9
                    1	1	CA_R6_SLEW	0.000000000000000000	9
                    1	1	CA_R7_SLEW	0.000000000000000000	9
                    1	1	CA_R8_SLEW	0.000000000000000000	9
                    1	1	CA_R9_SLEW	0.000000000000000000	9
                    1	1	CA_ROTOR0_AX	0.000000000000000000	9
                    1	1	CA_ROTOR0_AY	0.000000000000000000	9
                    1	1	CA_ROTOR0_AZ	-1.000000000000000000	9
                    1	1	CA_ROTOR0_CT	6.500000000000000000	9
                    1	1	CA_ROTOR0_KM	0.050000000745058060	9
                    1	1	CA_ROTOR0_PX	0.150000005960464478	9
                    1	1	CA_ROTOR0_PY	0.150000005960464478	9
                    1	1	CA_ROTOR0_PZ	0.000000000000000000	9
                    1	1	CA_ROTOR10_AX	0.000000000000000000	9
                    1	1	CA_ROTOR10_AY	0.000000000000000000	9
                    1	1	CA_ROTOR10_AZ	-1.000000000000000000	9
                    1	1	CA_ROTOR10_CT	6.500000000000000000	9
                    1	1	CA_ROTOR10_KM	0.050000000745058060	9
                    1	1	CA_ROTOR10_PX	0.000000000000000000	9
                    1	1	CA_ROTOR10_PY	0.000000000000000000	9
                    1	1	CA_ROTOR10_PZ	0.000000000000000000	9
                    1	1	CA_ROTOR11_AX	0.000000000000000000	9
                    1	1	CA_ROTOR11_AY	0.000000000000000000	9
                    1	1	CA_ROTOR11_AZ	-1.000000000000000000	9
                    1	1	CA_ROTOR11_CT	6.500000000000000000	9
                    1	1	CA_ROTOR11_KM	0.050000000745058060	9
                    1	1	CA_ROTOR11_PX	0.000000000000000000	9
                    1	1	CA_ROTOR11_PY	0.000000000000000000	9
                    1	1	CA_ROTOR11_PZ	0.000000000000000000	9
                    1	1	CA_ROTOR1_AX	0.000000000000000000	9
                    1	1	CA_ROTOR1_AY	0.000000000000000000	9
                    1	1	CA_ROTOR1_AZ	-1.000000000000000000	9
                    1	1	CA_ROTOR1_CT	6.500000000000000000	9
                    1	1	CA_ROTOR1_KM	0.050000000745058060	9
                    1	1	CA_ROTOR1_PX	-0.150000005960464478	9
                    1	1	CA_ROTOR1_PY	-0.150000005960464478	9
                    1	1	CA_ROTOR1_PZ	0.000000000000000000	9
                    1	1	CA_ROTOR2_AX	0.000000000000000000	9
                    1	1	CA_ROTOR2_AY	0.000000000000000000	9
                    1	1	CA_ROTOR2_AZ	-1.000000000000000000	9
                    1	1	CA_ROTOR2_CT	6.500000000000000000	9
                    1	1	CA_ROTOR2_KM	-0.050000000745058060	9
                    1	1	CA_ROTOR2_PX	0.150000005960464478	9
                    1	1	CA_ROTOR2_PY	-0.150000005960464478	9
                    1	1	CA_ROTOR2_PZ	0.000000000000000000	9
                    1	1	CA_ROTOR3_AX	0.000000000000000000	9
                    1	1	CA_ROTOR3_AY	0.000000000000000000	9
                    1	1	CA_ROTOR3_AZ	-1.000000000000000000	9
                    1	1	CA_ROTOR3_CT	6.500000000000000000	9
                    1	1	CA_ROTOR3_KM	-0.050000000745058060	9
                    1	1	CA_ROTOR3_PX	-0.150000005960464478	9
                    1	1	CA_ROTOR3_PY	0.150000005960464478	9
                    1	1	CA_ROTOR3_PZ	0.000000000000000000	9
                    1	1	CA_ROTOR4_AX	0.000000000000000000	9
                    1	1	CA_ROTOR4_AY	0.000000000000000000	9
                    1	1	CA_ROTOR4_AZ	-1.000000000000000000	9
                    1	1	CA_ROTOR4_CT	6.500000000000000000	9
                    1	1	CA_ROTOR4_KM	0.050000000745058060	9
                    1	1	CA_ROTOR4_PX	0.000000000000000000	9
                    1	1	CA_ROTOR4_PY	0.000000000000000000	9
                    1	1	CA_ROTOR4_PZ	0.000000000000000000	9
                    1	1	CA_ROTOR5_AX	0.000000000000000000	9
                    1	1	CA_ROTOR5_AY	0.000000000000000000	9
                    1	1	CA_ROTOR5_AZ	-1.000000000000000000	9
                    1	1	CA_ROTOR5_CT	6.500000000000000000	9
                    1	1	CA_ROTOR5_KM	0.050000000745058060	9
                    1	1	CA_ROTOR5_PX	0.000000000000000000	9
                    1	1	CA_ROTOR5_PY	0.000000000000000000	9
                    1	1	CA_ROTOR5_PZ	0.000000000000000000	9
                    1	1	CA_ROTOR6_AX	0.000000000000000000	9
                    1	1	CA_ROTOR6_AY	0.000000000000000000	9
                    1	1	CA_ROTOR6_AZ	-1.000000000000000000	9
                    1	1	CA_ROTOR6_CT	6.500000000000000000	9
                    1	1	CA_ROTOR6_KM	0.050000000745058060	9
                    1	1	CA_ROTOR6_PX	0.000000000000000000	9
                    1	1	CA_ROTOR6_PY	0.000000000000000000	9
                    1	1	CA_ROTOR6_PZ	0.000000000000000000	9
                    1	1	CA_ROTOR7_AX	0.000000000000000000	9
                    1	1	CA_ROTOR7_AY	0.000000000000000000	9
                    1	1	CA_ROTOR7_AZ	-1.000000000000000000	9
                    1	1	CA_ROTOR7_CT	6.500000000000000000	9
                    1	1	CA_ROTOR7_KM	0.050000000745058060	9
                    1	1	CA_ROTOR7_PX	0.000000000000000000	9
                    1	1	CA_ROTOR7_PY	0.000000000000000000	9
                    1	1	CA_ROTOR7_PZ	0.000000000000000000	9
                    1	1	CA_ROTOR8_AX	0.000000000000000000	9
                    1	1	CA_ROTOR8_AY	0.000000000000000000	9
                    1	1	CA_ROTOR8_AZ	-1.000000000000000000	9
                    1	1	CA_ROTOR8_CT	6.500000000000000000	9
                    1	1	CA_ROTOR8_KM	0.050000000745058060	9
                    1	1	CA_ROTOR8_PX	0.000000000000000000	9
                    1	1	CA_ROTOR8_PY	0.000000000000000000	9
                    1	1	CA_ROTOR8_PZ	0.000000000000000000	9
                    1	1	CA_ROTOR9_AX	0.000000000000000000	9
                    1	1	CA_ROTOR9_AY	0.000000000000000000	9
                    1	1	CA_ROTOR9_AZ	-1.000000000000000000	9
                    1	1	CA_ROTOR9_CT	6.500000000000000000	9
                    1	1	CA_ROTOR9_KM	0.050000000745058060	9
                    1	1	CA_ROTOR9_PX	0.000000000000000000	9
                    1	1	CA_ROTOR9_PY	0.000000000000000000	9
                    1	1	CA_ROTOR9_PZ	0.000000000000000000	9
                    1	1	CA_ROTOR_COUNT	4	6
                    1	1	CA_R_REV	0	6
                    1	1	CA_SV0_SLEW	0.000000000000000000	9
                    1	1	CA_SV1_SLEW	0.000000000000000000	9
                    1	1	CA_SV2_SLEW	0.000000000000000000	9
                    1	1	CA_SV3_SLEW	0.000000000000000000	9
                    1	1	CA_SV4_SLEW	0.000000000000000000	9
                    1	1	CA_SV5_SLEW	0.000000000000000000	9
                    1	1	CA_SV6_SLEW	0.000000000000000000	9
                    1	1	CA_SV7_SLEW	0.000000000000000000	9
                    1	1	CBRK_AIRSPD_CHK	0	6
                    1	1	CBRK_BUZZER	0	6
                    1	1	CBRK_FLIGHTTERM	121212	6
                    1	1	CBRK_IO_SAFETY	22027	6
                    1	1	CBRK_SUPPLY_CHK	0	6
                    1	1	CBRK_USB_CHK	197848	6
                    1	1	CBRK_VTOLARMING	0	6
                    1	1	COM_ACT_FAIL_ACT	0	6
                    1	1	COM_ARM_ARSP_EN	1	6
                    1	1	COM_ARM_AUTH_ID	10	6
                    1	1	COM_ARM_AUTH_MET	0	6
                    1	1	COM_ARM_AUTH_REQ	0	6
                    1	1	COM_ARM_AUTH_TO	1.000000000000000000	9
                    1	1	COM_ARM_BAD_INOV	0	6
                    1	1	COM_ARM_CHK_ESCS	0	6
                    1	1	COM_ARM_EKF_BIAS	3.000000000000000000	9
                    1	1	COM_ARM_EKF_HGT	1.000000000000000000	9
                    1	1	COM_ARM_EKF_POS	0.500000000000000000	9
                    1	1	COM_ARM_EKF_VEL	0.500000000000000000	9
                    1	1	COM_ARM_EKF_YAW	0.500000000000000000	9
                    1	1	COM_ARM_HFLT_CHK	1	6
                    1	1	COM_ARM_IMU_ACC	0.699999988079071045	9
                    1	1	COM_ARM_IMU_GYR	0.250000000000000000	9
                    1	1	COM_ARM_MAG_ANG	60	6
                    1	1	COM_ARM_MAG_STR	2	6
                    1	1	COM_ARM_MIS_REQ	0	6
                    1	1	COM_ARM_ODID	0	6
                    1	1	COM_ARM_SDCARD	1	6
                    1	1	COM_ARM_SWISBTN	0	6
                    1	1	COM_ARM_WO_GPS	1	6
                    1	1	COM_CPU_MAX	95.000000000000000000	9
                    1	1	COM_DISARM_FORCE	0	6
                    1	1	COM_DISARM_LAND	0.100000001490116119	9
                    1	1	COM_DISARM_PRFLT	20.000000000000000000	9
                    1	1	COM_DL_LOSS_T	10	6
                    1	1	COM_FAIL_ACT_T	5.000000000000000000	9
                    1	1	COM_FLIGHT_UUID	0	6
                    1	1	COM_FLTMODE1	1	6
                    1	1	COM_FLTMODE2	0	6
                    1	1	COM_FLTMODE3	0	6
                    1	1	COM_FLTMODE4	2	6
                    1	1	COM_FLTMODE5	0	6
                    1	1	COM_FLTMODE6	7	6
                    1	1	COM_FLT_PROFILE	0	6
                    1	1	COM_FLT_TIME_MAX	-1	6
                    1	1	COM_FORCE_SAFETY	0	6
                    1	1	COM_HLDL_LOSS_T	120	6
                    1	1	COM_HLDL_REG_T	0	6
                    1	1	COM_HOME_EN	1	6
                    1	1	COM_HOME_IN_AIR	0	6
                    1	1	COM_IMB_PROP_ACT	0	6
                    1	1	COM_KILL_DISARM	5.000000000000000000	9
                    1	1	COM_LKDOWN_TKO	3.000000000000000000	9
                    1	1	COM_LOW_BAT_ACT	0	6
                    1	1	COM_MOT_TEST_EN	1	6
                    1	1	COM_OBC_LOSS_T	5.000000000000000000	9
                    1	1	COM_OBL_RC_ACT	0	6
                    1	1	COM_OBS_AVOID	0	6
                    1	1	COM_OF_LOSS_T	1.000000000000000000	9
                    1	1	COM_PARACHUTE	0	6
                    1	1	COM_POSCTL_NAVL	0	6
                    1	1	COM_POS_FS_DELAY	1	6
                    1	1	COM_POS_FS_EPH	5.000000000000000000	9
                    1	1	COM_POS_LOW_EPH	-1.000000000000000000	9
                    1	1	COM_POWER_COUNT	1	6
                    1	1	COM_PREARM_MODE	0	6
                    1	1	COM_QC_ACT	0	6
                    1	1	COM_RCL_EXCEPT	0	6
                    1	1	COM_RC_ARM_HYST	1000	6
                    1	1	COM_RC_IN_MODE	3	6
                    1	1	COM_RC_LOSS_T	0.500000000000000000	9
                    1	1	COM_RC_OVERRIDE	1	6
                    1	1	COM_RC_STICK_OV	30.000000000000000000	9
                    1	1	COM_SPOOLUP_TIME	1.000000000000000000	9
                    1	1	COM_TAKEOFF_ACT	0	6
                    1	1	COM_VEL_FS_EVH	1.000000000000000000	9
                    1	1	COM_WIND_MAX	-1.000000000000000000	9
                    1	1	COM_WIND_WARN	-1.000000000000000000	9
                    1	1	CP_DELAY	0.400000005960464478	9
                    1	1	CP_DIST	1.000000000000000000	9
                    1	1	CP_GO_NO_DATA	1	6
                    1	1	CP_GUIDE_ANG	0.000000000000000000	9
                    1	1	DSHOT_3D_DEAD_H	1000	6
                    1	1	DSHOT_3D_DEAD_L	1000	6
                    1	1	DSHOT_3D_ENABLE	0	6
                    1	1	DSHOT_MIN	0.054999999701976776	9
                    1	1	DSHOT_TEL_CFG	0	6
                    1	1	EKF2_ABIAS_INIT	0.200000002980232239	9
                    1	1	EKF2_ABL_ACCLIM	25.000000000000000000	9
                    1	1	EKF2_ABL_GYRLIM	3.000000000000000000	9
                    1	1	EKF2_ABL_LIM	0.400000005960464478	9
                    1	1	EKF2_ABL_TAU	0.500000000000000000	9
                    1	1	EKF2_ACC_B_NOISE	0.003000000026077032	9
                    1	1	EKF2_ACC_NOISE	0.349999994039535522	9
                    1	1	EKF2_AID_MASK	0	6
                    1	1	EKF2_ANGERR_INIT	0.100000001490116119	9
                    1	1	EKF2_ARSP_THR	0.000000000000000000	9
                    1	1	EKF2_ASPD_MAX	20.000000000000000000	9
                    1	1	EKF2_ASP_DELAY	100.000000000000000000	9
                    1	1	EKF2_AVEL_DELAY	5.000000000000000000	9
                    1	1	EKF2_BARO_CTRL	1	6
                    1	1	EKF2_BARO_DELAY	0.000000000000000000	9
                    1	1	EKF2_BARO_GATE	5.000000000000000000	9
                    1	1	EKF2_BARO_NOISE	3.500000000000000000	9
                    1	1	EKF2_BCOEF_X	100.000000000000000000	9
                    1	1	EKF2_BCOEF_Y	100.000000000000000000	9
                    1	1	EKF2_BETA_GATE	5.000000000000000000	9
                    1	1	EKF2_BETA_NOISE	0.300000011920928955	9
                    1	1	EKF2_DECL_TYPE	7	6
                    1	1	EKF2_DRAG_CTRL	0	6
                    1	1	EKF2_DRAG_NOISE	2.500000000000000000	9
                    1	1	EKF2_EAS_NOISE	1.399999976158142090	9
                    1	1	EKF2_EVA_NOISE	0.100000001490116119	9
                    1	1	EKF2_EVP_GATE	5.000000000000000000	9
                    1	1	EKF2_EVP_NOISE	0.100000001490116119	9
                    1	1	EKF2_EVV_GATE	3.000000000000000000	9
                    1	1	EKF2_EVV_NOISE	0.100000001490116119	9
                    1	1	EKF2_EV_CTRL	15	6
                    1	1	EKF2_EV_DELAY	0.000000000000000000	9
                    1	1	EKF2_EV_HGT_TO	5000	6
                    1	1	EKF2_EV_NOISE_MD	0	6
                    1	1	EKF2_EV_POS_TO	1000	6
                    1	1	EKF2_EV_POS_X	0.000000000000000000	9
                    1	1	EKF2_EV_POS_Y	0.000000000000000000	9
                    1	1	EKF2_EV_POS_Z	0.000000000000000000	9
                    1	1	EKF2_EV_QMIN	0	6
                    1	1	EKF2_FUSE_BETA	0	6
                    1	1	EKF2_GBIAS_INIT	0.100000001490116119	9
                    1	1	EKF2_GND_EFF_DZ	4.000000000000000000	9
                    1	1	EKF2_GND_MAX_HGT	0.500000000000000000	9
                    1	1	EKF2_GPS_CHECK	245	6
                    1	1	EKF2_GPS_CTRL	7	6
                    1	1	EKF2_GPS_DELAY	110.000000000000000000	9
                    1	1	EKF2_GPS_POS_X	0.000000000000000000	9
                    1	1	EKF2_GPS_POS_Y	0.000000000000000000	9
                    1	1	EKF2_GPS_POS_Z	0.000000000000000000	9
                    1	1	EKF2_GPS_P_GATE	5.000000000000000000	9
                    1	1	EKF2_GPS_P_NOISE	0.500000000000000000	9
                    1	1	EKF2_GPS_V_GATE	5.000000000000000000	9
                    1	1	EKF2_GPS_V_NOISE	0.300000011920928955	9
                    1	1	EKF2_GRAV_NOISE	1.000000000000000000	9
                    1	1	EKF2_GSF_TAS	15.000000000000000000	9
                    1	1	EKF2_GYR_B_LIM	0.150000005960464478	9
                    1	1	EKF2_GYR_B_NOISE	0.001000000047497451	9
                    1	1	EKF2_GYR_NOISE	0.014999999664723873	9
                    1	1	EKF2_HDG_GATE	2.599999904632568359	9
                    1	1	EKF2_HEAD_NOISE	0.300000011920928955	9
                    1	1	EKF2_HGT_REF	3	6
                    1	1	EKF2_IMU_CTRL	3	6
                    1	1	EKF2_IMU_POS_X	-0.028000000864267349	9
                    1	1	EKF2_IMU_POS_Y	-0.004000000189989805	9
                    1	1	EKF2_IMU_POS_Z	-0.008000000379979610	9
                    1	1	EKF2_MAG_ACCLIM	0.500000000000000000	9
                    1	1	EKF2_MAG_B_NOISE	0.000099999997473788	9
                    1	1	EKF2_MAG_CHECK	1	6
                    1	1	EKF2_MAG_DECL	0.000000000000000000	9
                    1	1	EKF2_MAG_DELAY	0.000000000000000000	9
                    1	1	EKF2_MAG_E_NOISE	0.001000000047497451	9
                    1	1	EKF2_MAG_GATE	3.000000000000000000	9
                    1	1	EKF2_MAG_NOISE	0.050000000745058060	9
                    1	1	EKF2_MAG_TYPE	5	6
                    1	1	EKF2_MAG_YAWLIM	0.200000002980232239	9
                    1	1	EKF2_MCOEF	0.150000005960464478	9
                    1	1	EKF2_MIN_RNG	0.100000001490116119	9
                    1	1	EKF2_MULTI_IMU	3	6
                    1	1	EKF2_MULTI_MAG	3	6
                    1	1	EKF2_NOAID_NOISE	10.000000000000000000	9
                    1	1	EKF2_NOAID_TOUT	5000000	6
                    1	1	EKF2_OF_CTRL	0	6
                    1	1	EKF2_OF_DELAY	20.000000000000000000	9
                    1	1	EKF2_OF_GATE	3.000000000000000000	9
                    1	1	EKF2_OF_N_MAX	0.500000000000000000	9
                    1	1	EKF2_OF_N_MIN	0.150000005960464478	9
                    1	1	EKF2_OF_POS_X	0.000000000000000000	9
                    1	1	EKF2_OF_POS_Y	0.000000000000000000	9
                    1	1	EKF2_OF_POS_Z	0.000000000000000000	9
                    1	1	EKF2_OF_QMIN	1	6
                    1	1	EKF2_PCOEF_XN	0.000000000000000000	9
                    1	1	EKF2_PCOEF_XP	0.000000000000000000	9
                    1	1	EKF2_PCOEF_YN	0.000000000000000000	9
                    1	1	EKF2_PCOEF_YP	0.000000000000000000	9
                    1	1	EKF2_PCOEF_Z	0.000000000000000000	9
                    1	1	EKF2_PREDICT_US	10000	6
                    1	1	EKF2_REQ_EPH	3.000000000000000000	9
                    1	1	EKF2_REQ_EPV	5.000000000000000000	9
                    1	1	EKF2_REQ_GPS_H	10.000000000000000000	9
                    1	1	EKF2_REQ_HDRIFT	0.100000001490116119	9
                    1	1	EKF2_REQ_NSATS	6	6
                    1	1	EKF2_REQ_PDOP	2.500000000000000000	9
                    1	1	EKF2_REQ_SACC	1.000000000000000000	9
                    1	1	EKF2_REQ_VDRIFT	0.200000002980232239	9
                    1	1	EKF2_RNG_A_HMAX	5.000000000000000000	9
                    1	1	EKF2_RNG_A_IGATE	1.000000000000000000	9
                    1	1	EKF2_RNG_A_VMAX	1.000000000000000000	9
                    1	1	EKF2_RNG_CTRL	1	6
                    1	1	EKF2_RNG_DELAY	5.000000000000000000	9
                    1	1	EKF2_RNG_GATE	5.000000000000000000	9
                    1	1	EKF2_RNG_K_GATE	1.000000000000000000	9
                    1	1	EKF2_RNG_NOISE	0.100000001490116119	9
                    1	1	EKF2_RNG_PITCH	0.000000000000000000	9
                    1	1	EKF2_RNG_POS_X	0.000000000000000000	9
                    1	1	EKF2_RNG_POS_Y	0.000000000000000000	9
                    1	1	EKF2_RNG_POS_Z	0.000000000000000000	9
                    1	1	EKF2_RNG_QLTY_T	1.000000000000000000	9
                    1	1	EKF2_RNG_SFE	0.050000000745058060	9
                    1	1	EKF2_SEL_ERR_RED	0.200000002980232239	9
                    1	1	EKF2_SEL_IMU_ACC	1.000000000000000000	9
                    1	1	EKF2_SEL_IMU_ANG	15.000000000000000000	9
                    1	1	EKF2_SEL_IMU_RAT	7.000000000000000000	9
                    1	1	EKF2_SEL_IMU_VEL	2.000000000000000000	9
                    1	1	EKF2_SYNT_MAG_Z	0	6
                    1	1	EKF2_TAS_GATE	3.000000000000000000	9
                    1	1	EKF2_TAU_POS	0.250000000000000000	9
                    1	1	EKF2_TAU_VEL	0.250000000000000000	9
                    1	1	EKF2_TERR_GRAD	0.500000000000000000	9
                    1	1	EKF2_TERR_MASK	3	6
                    1	1	EKF2_TERR_NOISE	5.000000000000000000	9
                    1	1	EKF2_WIND_NSD	0.009999999776482582	9
                    1	1	EV_TSK_RC_LOSS	0	6
                    1	1	EV_TSK_STAT_DIS	0	6
                    1	1	FD_ACT_EN	1	6
                    1	1	FD_ACT_MOT_C2T	2.000000000000000000	9
                    1	1	FD_ACT_MOT_THR	0.200000002980232239	9
                    1	1	FD_ACT_MOT_TOUT	100	6
                    1	1	FD_ESCS_EN	1	6
                    1	1	FD_EXT_ATS_EN	0	6
                    1	1	FD_EXT_ATS_TRIG	1900	6
                    1	1	FD_FAIL_P	60	6
                    1	1	FD_FAIL_P_TTRI	0.300000011920928955	9
                    1	1	FD_FAIL_R	60	6
                    1	1	FD_FAIL_R_TTRI	0.300000011920928955	9
                    1	1	FD_IMB_PROP_THR	30	6
                    1	1	FLW_TGT_ALT_M	0	6
                    1	1	FLW_TGT_DST	8.000000000000000000	9
                    1	1	FLW_TGT_FA	180.000000000000000000	9
                    1	1	FLW_TGT_HT	8.000000000000000000	9
                    1	1	FLW_TGT_MAX_VEL	5.000000000000000000	9
                    1	1	FLW_TGT_RS	0.100000001490116119	9
                    1	1	FW_AIRSPD_MAX	20.000000000000000000	9
                    1	1	FW_AIRSPD_TRIM	15.000000000000000000	9
                    1	1	FW_ARSP_MODE	0	6
                    1	1	FW_PSP_OFF	0.000000000000000000	9
                    1	1	FW_T_CLMB_R_SP	3.000000000000000000	9
                    1	1	FW_T_SINK_R_SP	2.000000000000000000	9
                    1	1	GF_ACTION	2	6
                    1	1	GF_ALTMODE	0	6
                    1	1	GF_COUNT	-1	6
                    1	1	GF_MAX_HOR_DIST	0.000000000000000000	9
                    1	1	GF_MAX_VER_DIST	0.000000000000000000	9
                    1	1	GF_PREDICT	0	6
                    1	1	GF_SOURCE	0	6
                    1	1	GND_SPEED_THR_SC	1.000000000000000000	9
                    1	1	GPS_1_CONFIG	201	6
                    1	1	GPS_1_GNSS	0	6
                    1	1	GPS_1_PROTOCOL	1	6
                    1	1	GPS_2_CONFIG	0	6
                    1	1	GPS_DUMP_COMM	0	6
                    1	1	GPS_PITCH_OFFSET	0.000000000000000000	9
                    1	1	GPS_SAT_INFO	0	6
                    1	1	GPS_UBX_BAUD2	230400	6
                    1	1	GPS_UBX_CFG_INTF	0	6
                    1	1	GPS_UBX_DYNMODEL	6	6
                    1	1	GPS_UBX_MODE	0	6
                    1	1	GPS_YAW_OFFSET	0.000000000000000000	9
                    1	1	HTE_ACC_GATE	3.000000000000000000	9
                    1	1	HTE_HT_ERR_INIT	0.100000001490116119	9
                    1	1	HTE_HT_NOISE	0.003599999938160181	9
                    1	1	HTE_THR_RANGE	0.200000002980232239	9
                    1	1	HTE_VXY_THR	10.000000000000000000	9
                    1	1	HTE_VZ_THR	2.000000000000000000	9
                    1	1	IMU_ACCEL_CUTOFF	30.000000000000000000	9
                    1	1	IMU_DGYRO_CUTOFF	30.000000000000000000	9
                    1	1	IMU_GYRO_CAL_EN	1	6
                    1	1	IMU_GYRO_CUTOFF	30.000000000000000000	9
                    1	1	IMU_GYRO_DNF_BW	15.000000000000000000	9
                    1	1	IMU_GYRO_DNF_EN	0	6
                    1	1	IMU_GYRO_DNF_HMC	3	6
                    1	1	IMU_GYRO_DNF_MIN	25.000000000000000000	9
                    1	1	IMU_GYRO_FFT_EN	1	6
                    1	1	IMU_GYRO_FFT_LEN	512	6
                    1	1	IMU_GYRO_FFT_MAX	150.000000000000000000	9
                    1	1	IMU_GYRO_FFT_MIN	30.000000000000000000	9
                    1	1	IMU_GYRO_FFT_SNR	10.000000000000000000	9
                    1	1	IMU_GYRO_NF0_BW	30.000000000000000000	9
                    1	1	IMU_GYRO_NF0_FRQ	85.000000000000000000	9
                    1	1	IMU_GYRO_NF1_BW	20.000000000000000000	9
                    1	1	IMU_GYRO_NF1_FRQ	0.000000000000000000	9
                    1	1	IMU_GYRO_RATEMAX	800	6
                    1	1	IMU_INTEG_RATE	200	6
                    1	1	LNDMC_ALT_GND	2.000000000000000000	9
                    1	1	LNDMC_ALT_MAX	-1.000000000000000000	9
                    1	1	LNDMC_ROT_MAX	30.000000000000000000	9
                    1	1	LNDMC_TRIG_TIME	1.000000000000000000	9
                    1	1	LNDMC_XY_VEL_MAX	1.500000000000000000	9
                    1	1	LNDMC_Z_VEL_MAX	0.250000000000000000	9
                    1	1	LND_FLIGHT_T_HI	0	6
                    1	1	LND_FLIGHT_T_LO	2075074960	6
                    1	1	MAN_ARM_GESTURE	1	6
                    1	1	MAV_0_CONFIG	0	6
                    1	1	MAV_1_CONFIG	101	6
                    1	1	MAV_1_FLOW_CTRL	2	6
                    1	1	MAV_1_FORWARD	0	6
                    1	1	MAV_1_MODE	2	6
                    1	1	MAV_1_RADIO_CTL	1	6
                    1	1	MAV_1_RATE	0	6
                    1	1	MAV_2_CONFIG	0	6
                    1	1	MAV_COMP_ID	1	6
                    1	1	MAV_FWDEXTSP	1	6
                    1	1	MAV_HASH_CHK_EN	1	6
                    1	1	MAV_HB_FORW_EN	1	6
                    1	1	MAV_PROTO_VER	0	6
                    1	1	MAV_RADIO_TOUT	5	6
                    1	1	MAV_SIK_RADIO_ID	0	6
                    1	1	MAV_SYS_ID	1	6
                    1	1	MAV_TYPE	2	6
                    1	1	MAV_USEHILGPS	0	6
                    1	1	MBE_ENABLE	1	6
                    1	1	MBE_LEARN_GAIN	18.000000000000000000	9
                    1	1	MC_ACRO_EXPO	0.689999997615814209	9
                    1	1	MC_ACRO_EXPO_Y	0.689999997615814209	9
                    1	1	MC_ACRO_P_MAX	720.000000000000000000	9
                    1	1	MC_ACRO_R_MAX	720.000000000000000000	9
                    1	1	MC_ACRO_SUPEXPO	0.699999988079071045	9
                    1	1	MC_ACRO_SUPEXPOY	0.699999988079071045	9
                    1	1	MC_ACRO_Y_MAX	540.000000000000000000	9
                    1	1	MC_AIRMODE	0	6
                    1	1	MC_AT_APPLY	1	6
                    1	1	MC_AT_AXES	3	6
                    1	1	MC_AT_EN	1	6
                    1	1	MC_AT_RISE_TIME	0.140000000596046448	9
                    1	1	MC_AT_START	0	6
                    1	1	MC_AT_SYSID_AMP	0.699999988079071045	9
                    1	1	MC_BAT_SCALE_EN	1	6
                    1	1	MC_INJECT_AMP	0.050000000745058060	9
                    1	1	MC_INJECT_CNT	0	6
                    1	1	MC_INJECT_EN	0	6
                    1	1	MC_INJECT_INC	1.000000000000000000	9
                    1	1	MC_INJECT_REST_T	1.000000000000000000	9
                    1	1	MC_INJECT_RPY	0	6
                    1	1	MC_INJECT_SINE_T	5.000000000000000000	9
                    1	1	MC_INJECT_START	3.000000000000000000	9
                    1	1	MC_MAN_TILT_TAU	0.000000000000000000	9
                    1	1	MC_ORBIT_RAD_MAX	1000.000000000000000000	9
                    1	1	MC_PITCHRATE_D	0.002640000078827143	9
                    1	1	MC_PITCHRATE_FF	0.000000000000000000	9
                    1	1	MC_PITCHRATE_I	0.229000002145767212	9
                    1	1	MC_PITCHRATE_K	1.000000000000000000	9
                    1	1	MC_PITCHRATE_MAX	220.000000000000000000	9
                    1	1	MC_PITCHRATE_P	0.130999997258186340	9
                    1	1	MC_PITCH_CUTOFF	0.000000000000000000	9
                    1	1	MC_PITCH_P	7.000000000000000000	9
                    1	1	MC_PR_INT_LIM	0.300000011920928955	9
                    1	1	MC_ROLLRATE_D	0.003349999897181988	9
                    1	1	MC_ROLLRATE_FF	0.000000000000000000	9
                    1	1	MC_ROLLRATE_I	0.259000003337860107	9
                    1	1	MC_ROLLRATE_K	1.000000000000000000	9
                    1	1	MC_ROLLRATE_MAX	220.000000000000000000	9
                    1	1	MC_ROLLRATE_P	0.144999995827674866	9
                    1	1	MC_ROLL_CUTOFF	0.000000000000000000	9
                    1	1	MC_ROLL_P	7.000000000000000000	9
                    1	1	MC_RR_INT_LIM	0.300000011920928955	9
                    1	1	MC_THR_CURVE_ACR	0	6
                    1	1	MC_YAWRATE_D	0.000000000000000000	9
                    1	1	MC_YAWRATE_FF	0.000000000000000000	9
                    1	1	MC_YAWRATE_I	0.100000001490116119	9
                    1	1	MC_YAWRATE_K	1.000000000000000000	9
                    1	1	MC_YAWRATE_MAX	200.000000000000000000	9
                    1	1	MC_YAWRATE_P	0.150000005960464478	9
                    1	1	MC_YAW_CUTOFF	0.000000000000000000	9
                    1	1	MC_YAW_P	2.000000000000000000	9
                    1	1	MC_YAW_WEIGHT	0.400000005960464478	9
                    1	1	MC_YR_INT_LIM	0.300000011920928955	9
                    1	1	MIS_DIST_1WP	900.000000000000000000	9
                    1	1	MIS_LND_ABRT_ALT	30	6
                    1	1	MIS_MNT_YAW_CTL	0	6
                    1	1	MIS_PD_TO	5.000000000000000000	9
                    1	1	MIS_TAKEOFF_ALT	2.500000000000000000	9
                    1	1	MIS_TKO_LAND_REQ	0	6
                    1	1	MIS_YAW_ERR	12.000000000000000000	9
                    1	1	MIS_YAW_TMT	-1.000000000000000000	9
                    1	1	MNT_MODE_IN	-1	6
                    1	1	MODALAI_CONFIG	0	6
                    1	1	MOT_POLE_COUNT	0	6
                    1	1	MOT_SLEW_MAX	0.000000000000000000	9
                    1	1	MPC_ACC_DOWN_MAX	3.000000000000000000	9
                    1	1	MPC_ACC_HOR	5.000000000000000000	9
                    1	1	MPC_ACC_HOR_MAX	6.000000000000000000	9
                    1	1	MPC_ACC_UP_MAX	3.000000000000000000	9
                    1	1	MPC_ALT_MODE	0	6
                    1	1	MPC_HOLD_DZ	0.100000001490116119	9
                    1	1	MPC_HOLD_MAX_XY	0.800000011920928955	9
                    1	1	MPC_HOLD_MAX_Z	0.600000023841857910	9
                    1	1	MPC_JERK_AUTO	4.000000000000000000	9
                    1	1	MPC_JERK_MAX	40.000000000000000000	9
                    1	1	MPC_LAND_ALT1	10.000000000000000000	9
                    1	1	MPC_LAND_ALT2	5.000000000000000000	9
                    1	1	MPC_LAND_ALT3	1.000000000000000000	9
                    1	1	MPC_LAND_CRWL	0.300000011920928955	9
                    1	1	MPC_LAND_RADIUS	1000.000000000000000000	9
                    1	1	MPC_LAND_RC_HELP	0	6
                    1	1	MPC_LAND_SPEED	1.000000000000000000	9
                    1	1	MPC_MANTHR_MIN	0.079999998211860657	9
                    1	1	MPC_MAN_TILT_MAX	35.000000000000000000	9
                    1	1	MPC_MAN_Y_MAX	150.000000000000000000	9
                    1	1	MPC_MAN_Y_TAU	0.079999998211860657	9
                    1	1	MPC_POS_MODE	0	6
                    1	1	MPC_THR_CURVE	0	6
                    1	1	MPC_THR_HOVER	0.224999994039535522	9
                    1	1	MPC_THR_MAX	0.750000000000000000	9
                    1	1	MPC_THR_MIN	0.079999998211860657	9
                    1	1	MPC_THR_XY_MARG	0.300000011920928955	9
                    1	1	MPC_TILTMAX_AIR	30.000000000000000000	9
                    1	1	MPC_TILTMAX_LND	12.000000000000000000	9
                    1	1	MPC_TKO_RAMP_T	2.000000000000000000	9
                    1	1	MPC_TKO_SPEED	1.500000000000000000	9
                    1	1	MPC_USE_HTE	0	6
                    1	1	MPC_VELD_LP	5.000000000000000000	9
                    1	1	MPC_VEL_MANUAL	10.000000000000000000	9
                    1	1	MPC_VEL_MAN_BACK	-1.000000000000000000	9
                    1	1	MPC_VEL_MAN_SIDE	-1.000000000000000000	9
                    1	1	MPC_XY_CRUISE	5.000000000000000000	9
                    1	1	MPC_XY_ERR_MAX	2.000000000000000000	9
                    1	1	MPC_XY_MAN_EXPO	0.449999988079071045	9
                    1	1	MPC_XY_P	0.949999988079071045	9
                    1	1	MPC_XY_TRAJ_P	0.500000000000000000	9
                    1	1	MPC_XY_VEL_ALL	-10.000000000000000000	9
                    1	1	MPC_XY_VEL_D_ACC	0.000000000000000000	9
                    1	1	MPC_XY_VEL_I_ACC	0.100000001490116119	9
                    1	1	MPC_XY_VEL_MAX	10.000000000000000000	9
                    1	1	MPC_XY_VEL_P_ACC	3.000000000000000000	9
                    1	1	MPC_YAWRAUTO_MAX	45.000000000000000000	9
                    1	1	MPC_YAW_EXPO	0.300000011920928955	9
                    1	1	MPC_YAW_MODE	0	6
                    1	1	MPC_Z_MAN_EXPO	0.300000011920928955	9
                    1	1	MPC_Z_P	3.000000000000000000	9
                    1	1	MPC_Z_VEL_ALL	-3.000000000000000000	9
                    1	1	MPC_Z_VEL_D_ACC	0.000000000000000000	9
                    1	1	MPC_Z_VEL_I_ACC	2.000000000000000000	9
                    1	1	MPC_Z_VEL_MAX_DN	2.000000000000000000	9
                    1	1	MPC_Z_VEL_MAX_UP	2.000000000000000000	9
                    1	1	MPC_Z_VEL_P_ACC	12.000000000000000000	9
                    1	1	MPC_Z_V_AUTO_DN	1.500000000000000000	9
                    1	1	MPC_Z_V_AUTO_UP	2.000000000000000000	9
                    1	1	MSP_OSD_CONFIG	0	6
                    1	1	NAV_ACC_RAD	2.000000000000000000	9
                    1	1	NAV_DLL_ACT	0	6
                    1	1	NAV_FORCE_VT	1	6
                    1	1	NAV_FW_ALTL_RAD	5.000000000000000000	9
                    1	1	NAV_FW_ALT_RAD	10.000000000000000000	9
                    1	1	NAV_LOITER_RAD	80.000000000000000000	9
                    1	1	NAV_MC_ALT_RAD	0.800000011920928955	9
                    1	1	NAV_MIN_LTR_ALT	-1.000000000000000000	9
                    1	1	NAV_RCL_ACT	2	6
                    1	1	NAV_TRAFF_AVOID	1	6
                    1	1	NAV_TRAFF_A_HOR	500.000000000000000000	9
                    1	1	NAV_TRAFF_A_VER	500.000000000000000000	9
                    1	1	NAV_TRAFF_COLL_T	60	6
                    1	1	PLD_BTOUT	5.000000000000000000	9
                    1	1	PLD_FAPPR_ALT	0.100000001490116119	9
                    1	1	PLD_HACC_RAD	0.200000002980232239	9
                    1	1	PLD_MAX_SRCH	3	6
                    1	1	PLD_SRCH_ALT	10.000000000000000000	9
                    1	1	PLD_SRCH_TOUT	10.000000000000000000	9
                    1	1	PWM_MAIN_DIS1	900	6
                    1	1	PWM_MAIN_DIS2	900	6
                    1	1	PWM_MAIN_DIS3	900	6
                    1	1	PWM_MAIN_DIS4	900	6
                    1	1	PWM_MAIN_DIS5	900	6
                    1	1	PWM_MAIN_DIS6	900	6
                    1	1	PWM_MAIN_DIS7	900	6
                    1	1	PWM_MAIN_DIS8	900	6
                    1	1	PWM_MAIN_FAIL1	-1	6
                    1	1	PWM_MAIN_FAIL2	-1	6
                    1	1	PWM_MAIN_FAIL3	-1	6
                    1	1	PWM_MAIN_FAIL4	-1	6
                    1	1	PWM_MAIN_FAIL5	-1	6
                    1	1	PWM_MAIN_FAIL6	-1	6
                    1	1	PWM_MAIN_FAIL7	-1	6
                    1	1	PWM_MAIN_FAIL8	-1	6
                    1	1	PWM_MAIN_FUNC1	101	6
                    1	1	PWM_MAIN_FUNC2	102	6
                    1	1	PWM_MAIN_FUNC3	103	6
                    1	1	PWM_MAIN_FUNC4	104	6
                    1	1	PWM_MAIN_FUNC5	0	6
                    1	1	PWM_MAIN_FUNC6	0	6
                    1	1	PWM_MAIN_FUNC7	0	6
                    1	1	PWM_MAIN_FUNC8	0	6
                    1	1	PWM_MAIN_MAX1	2000	6
                    1	1	PWM_MAIN_MAX2	2000	6
                    1	1	PWM_MAIN_MAX3	2000	6
                    1	1	PWM_MAIN_MAX4	2000	6
                    1	1	PWM_MAIN_MAX5	2000	6
                    1	1	PWM_MAIN_MAX6	2000	6
                    1	1	PWM_MAIN_MAX7	2000	6
                    1	1	PWM_MAIN_MAX8	2000	6
                    1	1	PWM_MAIN_MIN1	1000	6
                    1	1	PWM_MAIN_MIN2	1000	6
                    1	1	PWM_MAIN_MIN3	1000	6
                    1	1	PWM_MAIN_MIN4	1000	6
                    1	1	PWM_MAIN_MIN5	1000	6
                    1	1	PWM_MAIN_MIN6	1000	6
                    1	1	PWM_MAIN_MIN7	1000	6
                    1	1	PWM_MAIN_MIN8	1000	6
                    1	1	PWM_MAIN_REV	0	6
                    1	1	PWM_MAIN_TIM0	-2	6
                    1	1	PWM_MAIN_TIM1	400	6
                    1	1	PWM_MAIN_TIM2	400	6
                    1	1	RC10_DZ	0.000000000000000000	9
                    1	1	RC10_MAX	2000.000000000000000000	9
                    1	1	RC10_MIN	1000.000000000000000000	9
                    1	1	RC10_REV	1.000000000000000000	9
                    1	1	RC10_TRIM	1500.000000000000000000	9
                    1	1	RC11_DZ	0.000000000000000000	9
                    1	1	RC11_MAX	2000.000000000000000000	9
                    1	1	RC11_MIN	1000.000000000000000000	9
                    1	1	RC11_REV	1.000000000000000000	9
                    1	1	RC11_TRIM	1500.000000000000000000	9
                    1	1	RC12_DZ	0.000000000000000000	9
                    1	1	RC12_MAX	2000.000000000000000000	9
                    1	1	RC12_MIN	1000.000000000000000000	9
                    1	1	RC12_REV	1.000000000000000000	9
                    1	1	RC12_TRIM	1500.000000000000000000	9
                    1	1	RC13_DZ	0.000000000000000000	9
                    1	1	RC13_MAX	2000.000000000000000000	9
                    1	1	RC13_MIN	1000.000000000000000000	9
                    1	1	RC13_REV	1.000000000000000000	9
                    1	1	RC13_TRIM	1500.000000000000000000	9
                    1	1	RC14_DZ	0.000000000000000000	9
                    1	1	RC14_MAX	2000.000000000000000000	9
                    1	1	RC14_MIN	1000.000000000000000000	9
                    1	1	RC14_REV	1.000000000000000000	9
                    1	1	RC14_TRIM	1500.000000000000000000	9
                    1	1	RC15_DZ	0.000000000000000000	9
                    1	1	RC15_MAX	2000.000000000000000000	9
                    1	1	RC15_MIN	1000.000000000000000000	9
                    1	1	RC15_REV	1.000000000000000000	9
                    1	1	RC15_TRIM	1500.000000000000000000	9
                    1	1	RC16_DZ	0.000000000000000000	9
                    1	1	RC16_MAX	2000.000000000000000000	9
                    1	1	RC16_MIN	1000.000000000000000000	9
                    1	1	RC16_REV	1.000000000000000000	9
                    1	1	RC16_TRIM	1500.000000000000000000	9
                    1	1	RC17_DZ	0.000000000000000000	9
                    1	1	RC17_MAX	2000.000000000000000000	9
                    1	1	RC17_MIN	1000.000000000000000000	9
                    1	1	RC17_REV	1.000000000000000000	9
                    1	1	RC17_TRIM	1500.000000000000000000	9
                    1	1	RC18_DZ	0.000000000000000000	9
                    1	1	RC18_MAX	2000.000000000000000000	9
                    1	1	RC18_MIN	1000.000000000000000000	9
                    1	1	RC18_REV	1.000000000000000000	9
                    1	1	RC18_TRIM	1500.000000000000000000	9
                    1	1	RC1_DZ	10.000000000000000000	9
                    1	1	RC1_MAX	1897.000000000000000000	9
                    1	1	RC1_MIN	1103.000000000000000000	9
                    1	1	RC1_REV	-1.000000000000000000	9
                    1	1	RC1_TRIM	1502.000000000000000000	9
                    1	1	RC2_DZ	10.000000000000000000	9
                    1	1	RC2_MAX	1897.000000000000000000	9
                    1	1	RC2_MIN	1103.000000000000000000	9
                    1	1	RC2_REV	1.000000000000000000	9
                    1	1	RC2_TRIM	1501.000000000000000000	9
                    1	1	RC3_DZ	10.000000000000000000	9
                    1	1	RC3_MAX	1898.000000000000000000	9
                    1	1	RC3_MIN	1102.000000000000000000	9
                    1	1	RC3_REV	1.000000000000000000	9
                    1	1	RC3_TRIM	1102.000000000000000000	9
                    1	1	RC4_DZ	10.000000000000000000	9
                    1	1	RC4_MAX	1897.000000000000000000	9
                    1	1	RC4_MIN	1103.000000000000000000	9
                    1	1	RC4_REV	-1.000000000000000000	9
                    1	1	RC4_TRIM	1499.000000000000000000	9
                    1	1	RC5_DZ	10.000000000000000000	9
                    1	1	RC5_MAX	1898.000000000000000000	9
                    1	1	RC5_MIN	1102.000000000000000000	9
                    1	1	RC5_REV	1.000000000000000000	9
                    1	1	RC5_TRIM	1500.000000000000000000	9
                    1	1	RC6_DZ	10.000000000000000000	9
                    1	1	RC6_MAX	1898.000000000000000000	9
                    1	1	RC6_MIN	1102.000000000000000000	9
                    1	1	RC6_REV	1.000000000000000000	9
                    1	1	RC6_TRIM	1500.000000000000000000	9
                    1	1	RC7_DZ	10.000000000000000000	9
                    1	1	RC7_MAX	2000.000000000000000000	9
                    1	1	RC7_MIN	1000.000000000000000000	9
                    1	1	RC7_REV	1.000000000000000000	9
                    1	1	RC7_TRIM	1500.000000000000000000	9
                    1	1	RC8_DZ	10.000000000000000000	9
                    1	1	RC8_MAX	2000.000000000000000000	9
                    1	1	RC8_MIN	1000.000000000000000000	9
                    1	1	RC8_REV	1.000000000000000000	9
                    1	1	RC8_TRIM	1500.000000000000000000	9
                    1	1	RC9_DZ	0.000000000000000000	9
                    1	1	RC9_MAX	2000.000000000000000000	9
                    1	1	RC9_MIN	1000.000000000000000000	9
                    1	1	RC9_REV	1.000000000000000000	9
                    1	1	RC9_TRIM	1500.000000000000000000	9
                    1	1	RC_ARMSWITCH_TH	0.750000000000000000	9
                    1	1	RC_CHAN_CNT	7	6
                    1	1	RC_ENG_MOT_TH	0.750000000000000000	9
                    1	1	RC_FAILS_THR	0	6
                    1	1	RC_GEAR_TH	0.750000000000000000	9
                    1	1	RC_INPUT_PROTO	3	6
                    1	1	RC_KILLSWITCH_TH	0.750000000000000000	9
                    1	1	RC_LOITER_TH	0.750000000000000000	9
                    1	1	RC_MAP_ACRO_SW	0	6
                    1	1	RC_MAP_ARM_SW	0	6
                    1	1	RC_MAP_AUX1	0	6
                    1	1	RC_MAP_AUX2	0	6
                    1	1	RC_MAP_AUX3	0	6
                    1	1	RC_MAP_AUX4	0	6
                    1	1	RC_MAP_AUX5	0	6
                    1	1	RC_MAP_AUX6	0	6
                    1	1	RC_MAP_ENG_MOT	0	6
                    1	1	RC_MAP_FAILSAFE	0	6
                    1	1	RC_MAP_FLAPS	0	6
                    1	1	RC_MAP_FLTMODE	5	6
                    1	1	RC_MAP_FLTM_BTN	0	6
                    1	1	RC_MAP_GEAR_SW	0	6
                    1	1	RC_MAP_KILL_SW	6	6
                    1	1	RC_MAP_LOITER_SW	0	6
                    1	1	RC_MAP_MAN_SW	0	6
                    1	1	RC_MAP_MODE_SW	0	6
                    1	1	RC_MAP_OFFB_SW	0	6
                    1	1	RC_MAP_PARAM1	0	6
                    1	1	RC_MAP_PARAM2	0	6
                    1	1	RC_MAP_PARAM3	0	6
                    1	1	RC_MAP_PITCH	2	6
                    1	1	RC_MAP_POSCTL_SW	0	6
                    1	1	RC_MAP_RATT_SW	0	6
                    1	1	RC_MAP_RETURN_SW	0	6
                    1	1	RC_MAP_ROLL	1	6
                    1	1	RC_MAP_STAB_SW	0	6
                    1	1	RC_MAP_THROTTLE	3	6
                    1	1	RC_MAP_TRANS_SW	0	6
                    1	1	RC_MAP_YAW	4	6
                    1	1	RC_OFFB_TH	0.750000000000000000	9
                    1	1	RC_PORT_CONFIG	0	6
                    1	1	RC_RETURN_TH	0.750000000000000000	9
                    1	1	RC_RSSI_PWM_CHAN	0	6
                    1	1	RC_RSSI_PWM_MAX	2000	6
                    1	1	RC_RSSI_PWM_MIN	1000	6
                    1	1	RC_TRANS_TH	0.750000000000000000	9
                    1	1	RTL_CONE_ANG	45	6
                    1	1	RTL_DESCEND_ALT	15.000000000000000000	9
                    1	1	RTL_HDG_MD	0	6
                    1	1	RTL_LAND_DELAY	1.000000000000000000	9
                    1	1	RTL_LOITER_RAD	80.000000000000000000	9
                    1	1	RTL_MIN_DIST	10.000000000000000000	9
                    1	1	RTL_PLD_MD	0	6
                    1	1	RTL_RETURN_ALT	15.000000000000000000	9
                    1	1	RTL_TIME_FACTOR	1.100000023841857910	9
                    1	1	RTL_TIME_MARGIN	100	6
                    1	1	RTL_TYPE	0	6
                    1	1	SDLOG_BOOT_BAT	0	6
                    1	1	SDLOG_DIRS_MAX	0	6
                    1	1	SDLOG_MISSION	0	6
                    1	1	SDLOG_MODE	0	6
                    1	1	SDLOG_PROFILE	1	6
                    1	1	SDLOG_UTC_OFFSET	0	6
                    1	1	SDLOG_UUID	1	6
                    1	1	SENS_BARO_QNH	1013.250000000000000000	9
                    1	1	SENS_BARO_RATE	20.000000000000000000	9
                    1	1	SENS_BOARD_ROT	0	6
                    1	1	SENS_BOARD_X_OFF	0.082520216703414917	9
                    1	1	SENS_BOARD_Y_OFF	0.260665357112884521	9
                    1	1	SENS_BOARD_Z_OFF	0.000000000000000000	9
                    1	1	SENS_CM8JL65_CFG	0	6
                    1	1	SENS_DPRES_OFF	0.000000000000000000	9
                    1	1	SENS_EN_BATT	0	6
                    1	1	SENS_EN_IRLOCK	0	6
                    1	1	SENS_EN_LL40LS	0	6
                    1	1	SENS_EN_MB12XX	0	6
                    1	1	SENS_EN_MPDT	0	6
                    1	1	SENS_EN_MS4525DO	0	6
                    1	1	SENS_EN_MS5525DS	0	6
                    1	1	SENS_EN_PAA3905	0	6
                    1	1	SENS_EN_PAW3902	0	6
                    1	1	SENS_EN_PGA460	0	6
                    1	1	SENS_EN_PMW3901	0	6
                    1	1	SENS_EN_PX4FLOW	0	6
                    1	1	SENS_EN_SDP3X	0	6
                    1	1	SENS_EN_SF1XX	0	6
                    1	1	SENS_EN_TF02PRO	0	6
                    1	1	SENS_EN_THERMAL	-1	6
                    1	1	SENS_EN_TRANGER	0	6
                    1	1	SENS_EN_VL53L0X	0	6
                    1	1	SENS_EN_VL53L1X	0	6
                    1	1	SENS_EXT_I2C_PRB	1	6
                    1	1	SENS_IMU_AUTOCAL	0	6
                    1	1	SENS_IMU_MODE	0	6
                    1	1	SENS_LEDDAR1_CFG	0	6
                    1	1	SENS_MAG_MODE	0	6
                    1	1	SENS_SF0X_CFG	0	6
                    1	1	SENS_TFLOW_CFG	0	6
                    1	1	SENS_TFMINI_CFG	0	6
                    1	1	SENS_ULAND_CFG	0	6
                    1	1	SER_GPS1_BAUD	0	6
                    1	1	SER_TEL1_BAUD	921600	6
                    1	1	SYS_AUTOCONFIG	0	6
                    1	1	SYS_AUTOSTART	4001	6
                    1	1	SYS_CAL_ACCEL	0	6
                    1	1	SYS_CAL_BARO	0	6
                    1	1	SYS_CAL_GYRO	0	6
                    1	1	SYS_CAL_TDEL	24	6
                    1	1	SYS_CAL_TMAX	10	6
                    1	1	SYS_CAL_TMIN	5	6
                    1	1	SYS_DM_BACKEND	0	6
                    1	1	SYS_FAC_CAL_MODE	0	6
                    1	1	SYS_FAILURE_EN	0	6
                    1	1	SYS_HAS_BARO	1	6
                    1	1	SYS_HAS_GPS	0	6
                    1	1	SYS_HAS_MAG	0	6
                    1	1	SYS_HAS_NUM_DIST	0	6
                    1	1	SYS_HITL	0	6
                    1	1	SYS_MC_EST_GROUP	2	6
                    1	1	SYS_RGB_MAXBRT	1.000000000000000000	9
                    1	1	SYS_STCK_EN	1	6
                    1	1	SYS_VEHICLE_RESP	-0.400000005960464478	9
                    1	1	TC_A_ENABLE	0	6
                    1	1	TC_B_ENABLE	0	6
                    1	1	TC_G_ENABLE	0	6
                    1	1	TEL_BST_EN	0	6
                    1	1	TEL_FRSKY_CONFIG	0	6
                    1	1	TEL_HOTT_CONFIG	0	6
                    1	1	THR_MDL_FAC	0.730000019073486328	9
                    1	1	TRIG_MODE	0	6
                    1	1	VOXL_ESC_BAUD	250000	6
                    1	1	VOXL_ESC_CONFIG	1	6
                    1	1	VOXL_ESC_FUNC1	0	6
                    1	1	VOXL_ESC_FUNC2	0	6
                    1	1	VOXL_ESC_FUNC3	0	6
                    1	1	VOXL_ESC_FUNC4	0	6
                    1	1	VOXL_ESC_MODE	0	6
                    1	1	VOXL_ESC_PUB_BST	1	6
                    1	1	VOXL_ESC_REV	0	6
                    1	1	VOXL_ESC_RPM_MAX	15000	6
                    1	1	VOXL_ESC_RPM_MIN	5500	6
                    1	1	VOXL_ESC_SDIR1	0	6
                    1	1	VOXL_ESC_SDIR2	0	6
                    1	1	VOXL_ESC_SDIR3	0	6
                    1	1	VOXL_ESC_SDIR4	0	6
                    1	1	VOXL_ESC_T_COSP	0.990000009536743164	9
                    1	1	VOXL_ESC_T_DEAD	20	6
                    1	1	VOXL_ESC_T_EXPO	35	6
                    1	1	VOXL_ESC_T_MINF	0.150000005960464478	9
                    1	1	VOXL_ESC_T_PERC	90	6
                    1	1	VOXL_ESC_VLOG	0	6
                    1	1	VTO_LOITER_ALT	80.000000000000000000	9
                    1	1	VT_B_DEC_MSS	2.000000000000000000	9
                    1	1	WV_EN	0	6
                    1	1	WV_GAIN	1.000000000000000000	9
                    1	1	WV_ROLL_MIN	1.000000000000000000	9
                    1	1	WV_YRATE_MAX	90.000000000000000000	9
                    1	1	XRCE_DDS_CFG	0	6
                    • S skl1g14
                      # Stack: PX4 Pro
                      1	1	BAT1_SOURCE	0	6
                      1	1	BAT_N_CELLS	4	6
                      1	1	CAL_ACC2_ID	0	6
                      1	1	CAL_ACC3_ID	0	6
                      1	1	CAL_MAG1_ID	0	6
                      1	1	CAL_MAG2_ID	0	6
                      1	1	CAL_MAG3_ID	0	6
                      1	1	CA_AIRFRAME	0	6
                      1	1	CA_METHOD	2	6
                      1	1	CA_R_REV	0	6
                      1	1	CBRK_BUZZER	0	6
                      1	1	COM_HOME_EN	1	6
                      1	1	COM_QC_ACT	0	6
                      1	1	FD_ACT_EN	1	6
                      1	1	FD_ESCS_EN	1	6
                      1	1	FD_FAIL_P	60	6
                      1	1	FD_FAIL_R	60	6
                      1	1	GF_ACTION	2	6
                      1	1	GF_ALTMODE	0	6
                      1	1	GF_COUNT	-1	6
                      1	1	GF_PREDICT	0	6
                      1	1	GF_SOURCE	0	6
                      1	1	GPS_1_GNSS	0	6
                      1	1	MAV_1_MODE	2	6
                      1	1	MAV_1_RATE	0	6
                      1	1	MAV_COMP_ID	1	6
                      1	1	MAV_SYS_ID	1	6
                      1	1	MAV_TYPE	2	6
                      1	1	MBE_ENABLE	1	6
                      1	1	MC_AIRMODE	0	6
                      1	1	MC_AT_APPLY	1	6
                      1	1	MC_AT_AXES	3	6
                      1	1	MC_AT_EN	1	6
                      1	1	MC_AT_START	0	6
                      1	1	MPC_USE_HTE	0	6
                      1	1	NAV_DLL_ACT	0	6
                      1	1	NAV_RCL_ACT	2	6
                      1	1	RC_CHAN_CNT	7	6
                      1	1	RC_MAP_AUX1	0	6
                      1	1	RC_MAP_AUX2	0	6
                      1	1	RC_MAP_AUX3	0	6
                      1	1	RC_MAP_AUX4	0	6
                      1	1	RC_MAP_AUX5	0	6
                      1	1	RC_MAP_AUX6	0	6
                      1	1	RC_MAP_ROLL	1	6
                      1	1	RC_MAP_YAW	4	6
                      1	1	RTL_HDG_MD	0	6
                      1	1	RTL_PLD_MD	0	6
                      1	1	RTL_TYPE	0	6
                      1	1	SDLOG_MODE	0	6
                      1	1	SDLOG_UUID	1	6
                      1	1	SYS_HAS_GPS	0	6
                      1	1	SYS_HAS_MAG	0	6
                      1	1	SYS_HITL	0	6
                      1	1	SYS_STCK_EN	1	6
                      1	1	TC_A_ENABLE	0	6
                      1	1	TC_B_ENABLE	0	6
                      1	1	TC_G_ENABLE	0	6
                      1	1	TEL_BST_EN	0	6
                      1	1	TRIG_MODE	0	6
                      1	1	WV_EN	0	6
                      #11
                      @skl1g14 , based on the following function, the shunt parameters are not required and will default to nominal values if not present : https://github.com/PX4/PX4-Autopilot/blob/main/src/drivers/power_monitor/voxlpm/voxlpm.cpp#L163
                      So i am not sure what happened, it is possible that adding those shunt values to px4 params and issue being resolved was a coincidence - perhaps something else has triggered the change..
                        S Offline
                        S Offline
                        skl1g14
                        Yes, i believe that might be the case. There might be some other px4 firmware parameters that are causing it.
