  3. Can you power VOXL2 from the ModalAI 6s ESC?
51 Posts 3 Posters 27.6k Views 1 Watching
    @Matthew-Wellner
    Double check baud rate in esc params and px4 param for modalai esc baud rate - they have to match
    Matthew WellnerM Offline
    Matthew Wellner
    Both are set at 25000 I think, but I still have the same error.
      #20
      @Matthew-Wellner
      Yeah hmm.
      Please double check voxl-px4.conf should have:
      ESC=VOXL_ESC
      POWER_MANAGER=VOXLPM
      also check output of:
      px4-listener esc_status
      Is the ESC blinking blue LEDs while PX4 is running? it should.
      You can try stop / start voxl-esc driver:
      px4-qshell voxl_esc stop
      px4-qshell voxl_esc start
      P.S. the baud rate is 250000 (250K)
        @Matthew-Wellner
        Yeah hmm.
        ESC=VOXL_ESC
        Matthew Wellner
        I got it working!
        Two quick additional questions:
        • I'm not getting RC RSSI data in QGC even though I am getting it via px4-listener input_rc. Do I need to configure any parameters in QGC to enable this?
        • I tried to do an ESC calibration via the scripts in /usr/share/modalai/voxl-esc-tools/ and I just get a bunch of errors. I disabled the bridge via voxl-esc disable_bridge, but I still get errors running the python scripts directly.
        V 1 Reply Last reply
          I got it working!
          V Offline
          V Offline
          Vin
          @Matthew-Wellner
          It probably due to voxl-px4, if you just run the voxl-esc, it will stop voxl-px4 however if you are running python scripts directly it does not.
          I would try stopping voxl-px4 as below, check and then run voxl-esc scripts and see if I still get the same issue
          You can check if px4 is running:
          systemctl is-active voxl-px4
          stop px4:
          systemctl stop voxl-px4
          Just in case if this is of any help as I had similar issue and above resolved it.
          Alex KushleyevA Matthew WellnerM 2 Replies Last reply
          • V Vin
            @Matthew-Wellner
            stop px4:
            @Vin , you are correct.
            "enabling" the bridge via voxl-esc wrapper script simply stops px4, effectively doing systemctl stop voxl-px4 and "disabling" the bridge will re-enable px4. So @Matthew-Wellner got it backwards.
            However, it is sufficient to just use systemctl stop voxl-px4 before using voxl-esc python scripts directly. then re-start px4 with systemctl start voxl-px4. Note that there is a difference between systemctl disable and systemctl stop - the disable option disables auto start on boot, but does not stop it right away. stop will actually stop it right now but will not affect autostart.
            I am not sure about RC RSSI data, it's beyond my area of expertise. Perhaps open another question on the forum regarding RC, so other devs can pick it up.
              @Matthew-Wellner , just for a quick sanity check, can you share what motor / props you are using with M0134-6? i just want to confirm that the ESC will be able to support the motor/prop combination.
                #25
                Just FYI, if you are running the esc calibration on VOXL2, which does not have a display attached, you cannot view the calibration plot right away. If you run the calibration procedure on a linux pc (while attached to ESC using serial to usb adapter), the plot will show up in browser. However, I recently added automatic saving of the figure to disk, it is done here : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/dev/voxl-esc-tools/voxl-esc-calibrate.py?ref_type=heads#L275 , so after the calibration procedure is finished, you should be able to see calibration_results.html which you can pull from voxl2 and view in any browser (internet connection is needed because it will download the javascript library for plotting).
                Also, don't forget if you are using M0134-6 with 6S battery, install the additional capacitor that was provided with the ESC, without it 6S voltage may cause excessive noise in the ESC and poor performance.
                For example, I recently calibrated a motor and here is what the results should look like. I am writing up some better instructions for calibration (with examples, so here is a quick preview).
                • first plot (top left) is the commaded voltage vs RPM, that is the average voltage supplied to the motor in order to achieve each RPM. You can see that curve has a nice smooth shape with slight quadratic (non-linear) upward trend
                • plot on top right shows current draw vs time, it should be roughly quadratic because as the average voltage applied to the (loaded) motor increases, the current will increase quadratically.
                • Bottom right plot shows the rpm response vs time. The green samples are the samples that were used for calibration (as opposed to red samples showing all the data). This is showing that the samples were used were taken after the RPM has settled after a transition.
                • you can also use the plot of current and rpm vs time to check if the ESC is behaving normally (plots look similar to the examples) or there are some sudden jumps up or down
                zoomed in:
                  Matthew Wellner
                  Sorry for the delay - I am using SunnySky / TMotor 4004 @400kv with TMotor MS1101 props (11").
                  • V Vin
                    @Matthew-Wellner
                    stop px4:
                    Matthew Wellner
                    @Vin
                    Thanks, but voxl-px4 is running. I am getting GPS, battery voltage and the rest of the telemetry in QGC as expected. I'm just not getting anything for the receiver even though I can read it from the command line.
                    Matt
                      #28
                      @Matthew-Wellner , you probably want to take a look at this post. I recently posted new firmware, params example and instructions how to make sure your low kv motor operates properly:
                      https://forum.modalai.com/topic/2902/kde-4012xf-motors-with-16-in-props/10#
                      I will tag you there
                      I did an example tuning / testing of Tmotor MN4006 380kV with 15in prop which could be similar to your application, so it should definitely be relevant and going through the testing you will ensure that there will be no de-syncs
                        @Vin
                        Matt
                        @Matthew-Wellner, if you still cannot figure out the RC receiver you should make another post in the forum regarding the receiver, so that this thread does not get too confusing 🙂
                        I can't help you there, but other devs should be able to
                          Matthew Wellner
                          @Alex-Kushleyev Will do. Thanks!
                            Matthew Wellner
                            Hi Alex - I performed some testing with the ESC with the low kv esc params file referenced in the thread you pointed me to and when I go from 30% power to 40% and greater, my motor / prop reverses directions. Am I desyncing at that point?
                            voxl2:/usr/share/modalai/voxl-esc-tools$ ./voxl-esc-spin.py --id 1 --power 40 --timeout 3.5 --enable-plot 1
                            [GCC 8.4.0]
                            VOXL Platform: M0054
                            Board : version 41: ModalAi 4-in-1 ESC (M0134-6)
                            UID : 0x203330385246571900480020
                            Firmware : version 39, hash d4fe8e3d
                            Bootloader : version 184, hash 10b1286a
                            UID        : 0x2033303852465717003C002A
                            UID        : 0x203330385246571500420047
                            UID        : 0x20333038524657190034001D
                            WARNING:
                            from all persons.
                            Type "Yes" to continue: Yes
                            [0.013] (1) RPM: 0, PWR: 0, VOLTAGE: 24.946V, TEMPERATURE: 46.80C, CURRENT: 0.000A
                            [0.022] (1) RPM: 7, PWR: 0, VOLTAGE: 24.941V, TEMPERATURE: 46.79C, CURRENT: 0.000A
                            [0.032] (1) RPM: 15, PWR: 0, VOLTAGE: 24.941V, TEMPERATURE: 46.80C, CURRENT: 0.056A
                            [0.042] (1) RPM: 23, PWR: 0, VOLTAGE: 24.950V, TEMPERATURE: 46.79C, CURRENT: 0.128A
                            [0.052] (1) RPM: 31, PWR: 0, VOLTAGE: 24.937V, TEMPERATURE: 46.82C, CURRENT: 0.264A
                            [0.062] (1) RPM: 39, PWR: 0, VOLTAGE: 24.932V, TEMPERATURE: 46.85C, CURRENT: 0.440A
                            [0.072] (1) RPM: 47, PWR: 0, VOLTAGE: 24.930V, TEMPERATURE: 46.83C, CURRENT: 0.520A
                            [0.082] (1) RPM: 55, PWR: 0, VOLTAGE: 24.930V, TEMPERATURE: 46.78C, CURRENT: 0.680A
                            [0.092] (1) RPM: 63, PWR: 0, VOLTAGE: 24.929V, TEMPERATURE: 46.79C, CURRENT: 0.648A
                            [0.103] (1) RPM: 63, PWR: 0, VOLTAGE: 24.929V, TEMPERATURE: 46.79C, CURRENT: 0.648A
                            [0.112] (1) RPM: 79, PWR: 0, VOLTAGE: 24.927V, TEMPERATURE: 46.79C, CURRENT: 0.632A
                            [0.122] (1) RPM: 87, PWR: 0, VOLTAGE: 24.937V, TEMPERATURE: 46.79C, CURRENT: 0.680A
                            [0.132] (1) RPM: 95, PWR: 0, VOLTAGE: 24.946V, TEMPERATURE: 46.79C, CURRENT: 0.664A
                            [0.142] (1) RPM: 103, PWR: 0, VOLTAGE: 24.939V, TEMPERATURE: 46.79C, CURRENT: 0.608A
                            [0.152] (1) RPM: 111, PWR: 0, VOLTAGE: 24.928V, TEMPERATURE: 46.80C, CURRENT: 0.776A
                            [0.162] (1) RPM: 119, PWR: 0, VOLTAGE: 24.934V, TEMPERATURE: 46.80C, CURRENT: 0.528A
                            [0.172] (1) RPM: 127, PWR: 0, VOLTAGE: 24.929V, TEMPERATURE: 46.81C, CURRENT: 0.464A
                            [0.182] (1) RPM: 135, PWR: 0, VOLTAGE: 24.931V, TEMPERATURE: 46.85C, CURRENT: 0.688A
                            [0.193] (1) RPM: 144, PWR: 0, VOLTAGE: 24.928V, TEMPERATURE: 46.82C, CURRENT: 0.648A
                            [0.203] (1) RPM: 144, PWR: 0, VOLTAGE: 24.928V, TEMPERATURE: 46.82C, CURRENT: 0.648A
                            [0.212] (1) RPM: 159, PWR: 0, VOLTAGE: 24.932V, TEMPERATURE: 46.86C, CURRENT: 0.688A
                            [0.222] (1) RPM: 167, PWR: 0, VOLTAGE: 24.928V, TEMPERATURE: 46.89C, CURRENT: 0.696A
                            [0.232] (1) RPM: 175, PWR: 0, VOLTAGE: 24.921V, TEMPERATURE: 46.85C, CURRENT: 0.688A
                            [0.242] (1) RPM: 183, PWR: 0, VOLTAGE: 24.922V, TEMPERATURE: 46.87C, CURRENT: 0.736A
                            [0.252] (1) RPM: 191, PWR: 0, VOLTAGE: 24.941V, TEMPERATURE: 46.81C, CURRENT: 0.856A
                            [0.262] (1) RPM: 199, PWR: 0, VOLTAGE: 24.929V, TEMPERATURE: 46.78C, CURRENT: 0.672A
                            [0.272] (1) RPM: 207, PWR: 0, VOLTAGE: 24.931V, TEMPERATURE: 46.76C, CURRENT: 0.696A
                            [0.282] (1) RPM: 215, PWR: 0, VOLTAGE: 24.921V, TEMPERATURE: 46.83C, CURRENT: 0.736A
                            [0.293] (1) RPM: 224, PWR: 0, VOLTAGE: 24.932V, TEMPERATURE: 46.81C, CURRENT: 0.736A
                            [0.302] (1) RPM: 224, PWR: 0, VOLTAGE: 24.932V, TEMPERATURE: 46.81C, CURRENT: 0.736A
                            [0.312] (1) RPM: 231, PWR: 0, VOLTAGE: 24.930V, TEMPERATURE: 46.83C, CURRENT: 0.640A
                            [0.322] (1) RPM: 247, PWR: 0, VOLTAGE: 24.925V, TEMPERATURE: 46.77C, CURRENT: 0.720A
                            [0.332] (1) RPM: 255, PWR: 0, VOLTAGE: 24.930V, TEMPERATURE: 46.78C, CURRENT: 0.656A
                            [0.342] (1) RPM: 263, PWR: 0, VOLTAGE: 24.924V, TEMPERATURE: 46.83C, CURRENT: 0.784A
                            [0.352] (1) RPM: 271, PWR: 0, VOLTAGE: 24.921V, TEMPERATURE: 46.83C, CURRENT: 0.696A
                            [0.362] (1) RPM: 279, PWR: 0, VOLTAGE: 24.930V, TEMPERATURE: 46.85C, CURRENT: 0.784A
                            [0.372] (1) RPM: 287, PWR: 0, VOLTAGE: 24.923V, TEMPERATURE: 46.84C, CURRENT: 0.992A
                            [0.382] (1) RPM: 295, PWR: 0, VOLTAGE: 24.923V, TEMPERATURE: 46.89C, CURRENT: 0.920A
                            [0.392] (1) RPM: 303, PWR: 0, VOLTAGE: 24.940V, TEMPERATURE: 46.83C, CURRENT: 0.808A
                            [0.402] (1) RPM: 303, PWR: 0, VOLTAGE: 24.940V, TEMPERATURE: 46.83C, CURRENT: 0.808A
                            [0.412] (1) RPM: 311, PWR: 0, VOLTAGE: 24.926V, TEMPERATURE: 46.79C, CURRENT: 0.832A
                            [0.422] (1) RPM: 327, PWR: 0, VOLTAGE: 24.932V, TEMPERATURE: 46.81C, CURRENT: 0.752A
                            [0.432] (1) RPM: 335, PWR: 0, VOLTAGE: 24.922V, TEMPERATURE: 46.84C, CURRENT: 0.816A
                            [0.442] (1) RPM: 343, PWR: 0, VOLTAGE: 24.914V, TEMPERATURE: 46.84C, CURRENT: 0.896A
                            [0.452] (1) RPM: 351, PWR: 0, VOLTAGE: 24.934V, TEMPERATURE: 46.77C, CURRENT: 0.808A
                            [0.462] (1) RPM: 359, PWR: 0, VOLTAGE: 24.940V, TEMPERATURE: 46.79C, CURRENT: 0.744A
                            [0.472] (1) RPM: 367, PWR: 0, VOLTAGE: 24.932V, TEMPERATURE: 46.84C, CURRENT: 0.920A
                            [0.482] (1) RPM: 375, PWR: 0, VOLTAGE: 24.927V, TEMPERATURE: 46.82C, CURRENT: 0.904A
                            [0.493] (1) RPM: 384, PWR: 0, VOLTAGE: 24.921V, TEMPERATURE: 46.85C, CURRENT: 0.768A
                            [0.503] (1) RPM: 384, PWR: 0, VOLTAGE: 24.921V, TEMPERATURE: 46.85C, CURRENT: 0.768A
                            [0.512] (1) RPM: 399, PWR: 0, VOLTAGE: 24.934V, TEMPERATURE: 46.82C, CURRENT: 0.536A
                            [0.522] (1) RPM: 407, PWR: 0, VOLTAGE: 24.939V, TEMPERATURE: 46.82C, CURRENT: 0.808A
                            [0.533] (1) RPM: 416, PWR: 0, VOLTAGE: 24.931V, TEMPERATURE: 46.84C, CURRENT: 0.896A
                            [0.542] (1) RPM: 423, PWR: 0, VOLTAGE: 24.940V, TEMPERATURE: 46.81C, CURRENT: 0.928A
                            [0.552] (1) RPM: 431, PWR: 0, VOLTAGE: 24.918V, TEMPERATURE: 46.83C, CURRENT: 0.760A
                            [0.562] (1) RPM: 439, PWR: 0, VOLTAGE: 24.922V, TEMPERATURE: 46.82C, CURRENT: 0.832A
                            [0.572] (1) RPM: 447, PWR: 0, VOLTAGE: 24.925V, TEMPERATURE: 46.83C, CURRENT: 0.832A
                            [0.582] (1) RPM: 455, PWR: 0, VOLTAGE: 24.924V, TEMPERATURE: 46.84C, CURRENT: 0.792A
                            [0.592] (1) RPM: 463, PWR: 0, VOLTAGE: 24.922V, TEMPERATURE: 46.87C, CURRENT: 0.888A
                            [0.602] (1) RPM: 463, PWR: 0, VOLTAGE: 24.922V, TEMPERATURE: 46.87C, CURRENT: 0.888A
                            [0.612] (1) RPM: 471, PWR: 0, VOLTAGE: 24.915V, TEMPERATURE: 46.88C, CURRENT: 0.952A
                            [0.622] (1) RPM: 487, PWR: 0, VOLTAGE: 24.919V, TEMPERATURE: 46.88C, CURRENT: 0.872A
                            [0.632] (1) RPM: 495, PWR: 0, VOLTAGE: 24.930V, TEMPERATURE: 46.86C, CURRENT: 0.856A
                            [0.642] (1) RPM: 503, PWR: 0, VOLTAGE: 24.921V, TEMPERATURE: 46.87C, CURRENT: 0.840A
                            [0.652] (1) RPM: 512, PWR: 0, VOLTAGE: 24.918V, TEMPERATURE: 46.89C, CURRENT: 0.936A
                            [0.662] (1) RPM: 519, PWR: 0, VOLTAGE: 24.927V, TEMPERATURE: 46.86C, CURRENT: 0.920A
                            [0.672] (1) RPM: 527, PWR: 0, VOLTAGE: 24.929V, TEMPERATURE: 46.86C, CURRENT: 0.920A
                            [0.682] (1) RPM: 535, PWR: 0, VOLTAGE: 24.940V, TEMPERATURE: 46.89C, CURRENT: 0.952A
                            [0.692] (1) RPM: 543, PWR: 0, VOLTAGE: 24.931V, TEMPERATURE: 46.96C, CURRENT: 0.856A
                            [0.703] (1) RPM: 543, PWR: 0, VOLTAGE: 24.931V, TEMPERATURE: 46.96C, CURRENT: 0.856A
                            [0.712] (1) RPM: 559, PWR: 0, VOLTAGE: 24.923V, TEMPERATURE: 46.93C, CURRENT: 0.944A
                            [0.722] (1) RPM: 567, PWR: 0, VOLTAGE: 24.925V, TEMPERATURE: 46.94C, CURRENT: 0.824A
                            [0.732] (1) RPM: 575, PWR: 0, VOLTAGE: 24.928V, TEMPERATURE: 46.89C, CURRENT: 0.928A
                            [0.742] (1) RPM: 583, PWR: 0, VOLTAGE: 24.926V, TEMPERATURE: 46.90C, CURRENT: 0.888A
                            [0.752] (1) RPM: 591, PWR: 0, VOLTAGE: 24.923V, TEMPERATURE: 46.92C, CURRENT: 0.848A
                            [0.762] (1) RPM: 599, PWR: 0, VOLTAGE: 24.921V, TEMPERATURE: 46.89C, CURRENT: 0.880A
                            [0.772] (1) RPM: 607, PWR: 0, VOLTAGE: 24.924V, TEMPERATURE: 46.87C, CURRENT: 0.840A
                            [0.782] (1) RPM: 615, PWR: 0, VOLTAGE: 24.920V, TEMPERATURE: 46.91C, CURRENT: 0.880A
                            [0.792] (1) RPM: 624, PWR: 0, VOLTAGE: 24.922V, TEMPERATURE: 46.91C, CURRENT: 1.056A
                            [0.802] (1) RPM: 624, PWR: 0, VOLTAGE: 24.922V, TEMPERATURE: 46.91C, CURRENT: 1.056A
                            [0.812] (1) RPM: 639, PWR: 0, VOLTAGE: 24.915V, TEMPERATURE: 46.92C, CURRENT: 0.968A
                            [0.822] (1) RPM: 647, PWR: 0, VOLTAGE: 24.916V, TEMPERATURE: 46.95C, CURRENT: 0.896A
                            [0.832] (1) RPM: 655, PWR: 0, VOLTAGE: 24.931V, TEMPERATURE: 46.95C, CURRENT: 0.912A
                            [0.842] (1) RPM: 663, PWR: 0, VOLTAGE: 24.925V, TEMPERATURE: 46.97C, CURRENT: 0.864A
                            [0.852] (1) RPM: 671, PWR: 0, VOLTAGE: 24.928V, TEMPERATURE: 46.93C, CURRENT: 0.984A
                            [0.862] (1) RPM: 679, PWR: 0, VOLTAGE: 24.936V, TEMPERATURE: 46.86C, CURRENT: 0.936A
                            [0.872] (1) RPM: 687, PWR: 0, VOLTAGE: 24.931V, TEMPERATURE: 46.86C, CURRENT: 0.856A
                            [0.882] (1) RPM: 695, PWR: 0, VOLTAGE: 24.922V, TEMPERATURE: 46.92C, CURRENT: 1.040A
                            [0.892] (1) RPM: 703, PWR: 0, VOLTAGE: 24.913V, TEMPERATURE: 46.97C, CURRENT: 0.872A
                            [0.903] (1) RPM: 703, PWR: 0, VOLTAGE: 24.913V, TEMPERATURE: 46.97C, CURRENT: 0.872A
                            [0.912] (1) RPM: 719, PWR: 0, VOLTAGE: 24.924V, TEMPERATURE: 46.98C, CURRENT: 0.952A
                            [0.922] (1) RPM: 727, PWR: 0, VOLTAGE: 24.926V, TEMPERATURE: 46.98C, CURRENT: 0.864A
                            [0.932] (1) RPM: 735, PWR: 0, VOLTAGE: 24.921V, TEMPERATURE: 46.94C, CURRENT: 1.096A
                            [0.942] (1) RPM: 743, PWR: 0, VOLTAGE: 24.929V, TEMPERATURE: 46.94C, CURRENT: 1.016A
                            [0.952] (1) RPM: 751, PWR: 0, VOLTAGE: 24.925V, TEMPERATURE: 46.94C, CURRENT: 0.936A
                            [0.962] (1) RPM: 759, PWR: 0, VOLTAGE: 24.929V, TEMPERATURE: 46.95C, CURRENT: 0.864A
                            [0.972] (1) RPM: 767, PWR: 0, VOLTAGE: 24.925V, TEMPERATURE: 46.93C, CURRENT: 0.864A
                            [0.982] (1) RPM: 775, PWR: 0, VOLTAGE: 24.917V, TEMPERATURE: 46.96C, CURRENT: 0.936A
                            [0.992] (1) RPM: 784, PWR: 0, VOLTAGE: 24.926V, TEMPERATURE: 46.97C, CURRENT: 0.888A
                            [1.003] (1) RPM: 784, PWR: 0, VOLTAGE: 24.926V, TEMPERATURE: 46.97C, CURRENT: 0.888A
                            [1.012] (1) RPM: 799, PWR: 0, VOLTAGE: 24.931V, TEMPERATURE: 46.96C, CURRENT: 1.128A
                            [1.022] (1) RPM: 799, PWR: 0, VOLTAGE: 24.932V, TEMPERATURE: 46.94C, CURRENT: 0.064A
                            [1.032] (1) RPM: 993, PWR: 10, VOLTAGE: 24.939V, TEMPERATURE: 46.92C, CURRENT: 0.112A
                            [1.042] (1) RPM: 848, PWR: 10, VOLTAGE: 24.939V, TEMPERATURE: 46.92C, CURRENT: 0.088A
                            [1.052] (1) RPM: 933, PWR: 10, VOLTAGE: 24.941V, TEMPERATURE: 46.93C, CURRENT: 0.096A
                            [1.062] (1) RPM: 949, PWR: 10, VOLTAGE: 24.935V, TEMPERATURE: 46.96C, CURRENT: 0.032A
                            [1.072] (1) RPM: 980, PWR: 10, VOLTAGE: 24.932V, TEMPERATURE: 46.96C, CURRENT: 0.032A
                            [1.082] (1) RPM: 1144, PWR: 40, VOLTAGE: 24.881V, TEMPERATURE: 47.00C, CURRENT: 6.288A
                            [1.092] (1) RPM: 1016, PWR: 40, VOLTAGE: 24.846V, TEMPERATURE: 46.97C, CURRENT: 7.072A
                            [1.102] (1) RPM: 1016, PWR: 40, VOLTAGE: 24.846V, TEMPERATURE: 46.97C, CURRENT: 7.072A
                            [1.112] (1) RPM: 946, PWR: 40, VOLTAGE: 24.824V, TEMPERATURE: 47.01C, CURRENT: 7.552A
                            [1.122] (1) RPM: 911, PWR: 40, VOLTAGE: 24.844V, TEMPERATURE: 47.09C, CURRENT: 7.384A
                            [1.132] (1) RPM: 863, PWR: 40, VOLTAGE: 24.823V, TEMPERATURE: 47.10C, CURRENT: 7.032A
                            [1.142] (1) RPM: 808, PWR: 40, VOLTAGE: 24.825V, TEMPERATURE: 47.05C, CURRENT: 6.848A
                            [1.152] (1) RPM: 741, PWR: 40, VOLTAGE: 24.799V, TEMPERATURE: 47.08C, CURRENT: 6.824A
                            [1.162] (1) RPM: 655, PWR: 40, VOLTAGE: 24.811V, TEMPERATURE: 47.21C, CURRENT: 7.344A
                            [1.172] (1) RPM: 563, PWR: 40, VOLTAGE: 24.812V, TEMPERATURE: 47.24C, CURRENT: 7.704A
                            [1.182] (1) RPM: 449, PWR: 40, VOLTAGE: 24.795V, TEMPERATURE: 47.17C, CURRENT: 7.696A
                            [1.192] (1) RPM: 382, PWR: 40, VOLTAGE: 24.774V, TEMPERATURE: 47.13C, CURRENT: 8.416A
                            [1.202] (1) RPM: 382, PWR: 40, VOLTAGE: 24.774V, TEMPERATURE: 47.13C, CURRENT: 8.416A
                            [1.212] (1) RPM: 398, PWR: 40, VOLTAGE: 24.779V, TEMPERATURE: 47.29C, CURRENT: 8.528A
                            [1.222] (1) RPM: 439, PWR: 40, VOLTAGE: 24.768V, TEMPERATURE: 47.29C, CURRENT: 8.480A
                            [1.232] (1) RPM: 467, PWR: 40, VOLTAGE: 24.776V, TEMPERATURE: 47.29C, CURRENT: 8.304A
                            [1.242] (1) RPM: 484, PWR: 40, VOLTAGE: 24.800V, TEMPERATURE: 47.34C, CURRENT: 9.032A
                            [1.252] (1) RPM: 504, PWR: 40, VOLTAGE: 24.793V, TEMPERATURE: 47.36C, CURRENT: 8.576A
                            [1.262] (1) RPM: 519, PWR: 40, VOLTAGE: 24.805V, TEMPERATURE: 47.36C, CURRENT: 9.160A
                            [1.272] (1) RPM: 548, PWR: 40, VOLTAGE: 24.788V, TEMPERATURE: 47.24C, CURRENT: 8.640A
                            [1.282] (1) RPM: 589, PWR: 40, VOLTAGE: 24.804V, TEMPERATURE: 47.28C, CURRENT: 6.840A
                            [1.293] (1) RPM: 628, PWR: 40, VOLTAGE: 24.811V, TEMPERATURE: 47.33C, CURRENT: 6.976A
                            [1.303] (1) RPM: 628, PWR: 40, VOLTAGE: 24.811V, TEMPERATURE: 47.33C, CURRENT: 6.976A
                            [1.312] (1) RPM: 674, PWR: 40, VOLTAGE: 24.788V, TEMPERATURE: 47.24C, CURRENT: 7.192A
                            [1.322] (1) RPM: 708, PWR: 40, VOLTAGE: 24.823V, TEMPERATURE: 47.30C, CURRENT: 7.360A
                            [1.332] (1) RPM: 742, PWR: 40, VOLTAGE: 24.818V, TEMPERATURE: 47.38C, CURRENT: 6.752A
                            [1.342] (1) RPM: 742, PWR: 40, VOLTAGE: 24.797V, TEMPERATURE: 47.45C, CURRENT: 7.304A
                            [1.352] (1) RPM: 785, PWR: 40, VOLTAGE: 24.792V, TEMPERATURE: 47.36C, CURRENT: 6.816A
                            [1.362] (1) RPM: 802, PWR: 40, VOLTAGE: 24.806V, TEMPERATURE: 47.35C, CURRENT: 6.280A
                            [1.372] (1) RPM: 810, PWR: 40, VOLTAGE: 24.823V, TEMPERATURE: 47.32C, CURRENT: 6.424A
                            [1.382] (1) RPM: 1110, PWR: 40, VOLTAGE: 24.805V, TEMPERATURE: 47.33C, CURRENT: 5.832A
                            [1.393] (1) RPM: 858, PWR: 40, VOLTAGE: 24.823V, TEMPERATURE: 47.33C, CURRENT: 6.808A
                            [1.403] (1) RPM: 858, PWR: 40, VOLTAGE: 24.823V, TEMPERATURE: 47.33C, CURRENT: 6.808A
                            [1.412] (1) RPM: 899, PWR: 40, VOLTAGE: 24.830V, TEMPERATURE: 47.40C, CURRENT: 6.456A
                            [1.422] (1) RPM: 926, PWR: 40, VOLTAGE: 24.813V, TEMPERATURE: 47.39C, CURRENT: 6.008A
                            [1.432] (1) RPM: 925, PWR: 40, VOLTAGE: 24.795V, TEMPERATURE: 47.32C, CURRENT: 6.232A
                            [1.442] (1) RPM: 969, PWR: 40, VOLTAGE: 24.841V, TEMPERATURE: 47.31C, CURRENT: 6.120A
                            [1.452] (1) RPM: 970, PWR: 40, VOLTAGE: 24.812V, TEMPERATURE: 47.37C, CURRENT: 5.704A
                            [1.462] (1) RPM: 980, PWR: 40, VOLTAGE: 24.823V, TEMPERATURE: 47.43C, CURRENT: 6.352A
                            [1.472] (1) RPM: 1004, PWR: 40, VOLTAGE: 24.830V, TEMPERATURE: 47.36C, CURRENT: 6.392A
                            [1.482] (1) RPM: 1003, PWR: 40, VOLTAGE: 24.814V, TEMPERATURE: 47.36C, CURRENT: 6.384A
                            [1.493] (1) RPM: 1030, PWR: 40, VOLTAGE: 24.826V, TEMPERATURE: 47.28C, CURRENT: 6.376A
                            [1.503] (1) RPM: 1030, PWR: 40, VOLTAGE: 24.826V, TEMPERATURE: 47.28C, CURRENT: 6.376A
                            [1.512] (1) RPM: 10024, PWR: 40, VOLTAGE: 24.878V, TEMPERATURE: 47.28C, CURRENT: 1.096A
                            [1.522] (1) RPM: 9988, PWR: 40, VOLTAGE: 24.904V, TEMPERATURE: 47.30C, CURRENT: 1.480A
                            [1.532] (1) RPM: 9480, PWR: 40, VOLTAGE: 24.909V, TEMPERATURE: 47.32C, CURRENT: 1.824A
                            [1.542] (1) RPM: 9350, PWR: 40, VOLTAGE: 24.868V, TEMPERATURE: 47.37C, CURRENT: 1.496A
                            [1.552] (1) RPM: 8336, PWR: 40, VOLTAGE: 24.886V, TEMPERATURE: 47.32C, CURRENT: 2.832A
                            [1.562] (1) RPM: 3674, PWR: 40, VOLTAGE: 24.857V, TEMPERATURE: 47.40C, CURRENT: 4.008A
                            [1.572] (1) RPM: 2932, PWR: 40, VOLTAGE: 24.848V, TEMPERATURE: 47.38C, CURRENT: 4.096A
                            [1.582] (1) RPM: 2825, PWR: 40, VOLTAGE: 24.842V, TEMPERATURE: 47.52C, CURRENT: 4.416A
                            [1.592] (1) RPM: 2825, PWR: 40, VOLTAGE: 24.842V, TEMPERATURE: 47.52C, CURRENT: 4.416A
                            [1.602] (1) RPM: 2734, PWR: 40, VOLTAGE: 24.865V, TEMPERATURE: 47.52C, CURRENT: 5.152A
                            [1.612] (1) RPM: 2627, PWR: 40, VOLTAGE: 24.865V, TEMPERATURE: 47.59C, CURRENT: 5.080A
                            [1.622] (1) RPM: 2619, PWR: 40, VOLTAGE: 24.853V, TEMPERATURE: 47.52C, CURRENT: 4.560A
                            [1.632] (1) RPM: 2586, PWR: 40, VOLTAGE: 24.849V, TEMPERATURE: 47.52C, CURRENT: 4.048A
                            [1.642] (1) RPM: 2532, PWR: 40, VOLTAGE: 24.845V, TEMPERATURE: 47.57C, CURRENT: 4.008A
                            [1.652] (1) RPM: 2431, PWR: 40, VOLTAGE: 24.812V, TEMPERATURE: 47.55C, CURRENT: 5.528A
                            [1.663] (1) RPM: 2411, PWR: 40, VOLTAGE: 24.830V, TEMPERATURE: 47.63C, CURRENT: 4.760A
                            [1.672] (1) RPM: 2505, PWR: 40, VOLTAGE: 24.843V, TEMPERATURE: 47.47C, CURRENT: 5.264A
                            [1.683] (1) RPM: 2485, PWR: 40, VOLTAGE: 24.827V, TEMPERATURE: 47.53C, CURRENT: 4.856A
                            [1.693] (1) RPM: 2485, PWR: 40, VOLTAGE: 24.827V, TEMPERATURE: 47.53C, CURRENT: 4.856A
                            [1.702] (1) RPM: 1949, PWR: 40, VOLTAGE: 24.843V, TEMPERATURE: 47.51C, CURRENT: 4.344A
                            [1.712] (1) RPM: 2392, PWR: 40, VOLTAGE: 24.828V, TEMPERATURE: 47.63C, CURRENT: 4.640A
                            [1.722] (1) RPM: 2457, PWR: 40, VOLTAGE: 24.850V, TEMPERATURE: 47.60C, CURRENT: 5.160A
                            [1.732] (1) RPM: 2359, PWR: 40, VOLTAGE: 24.839V, TEMPERATURE: 47.56C, CURRENT: 6.328A
                            [1.742] (1) RPM: 1800, PWR: 40, VOLTAGE: 24.821V, TEMPERATURE: 47.55C, CURRENT: 5.336A
                            [1.752] (1) RPM: 2452, PWR: 40, VOLTAGE: 24.846V, TEMPERATURE: 47.54C, CURRENT: 4.216A
                            [1.762] (1) RPM: 2370, PWR: 40, VOLTAGE: 24.840V, TEMPERATURE: 47.58C, CURRENT: 5.360A
                            [1.772] (1) RPM: 2420, PWR: 40, VOLTAGE: 24.861V, TEMPERATURE: 47.59C, CURRENT: 4.320A
                            [1.783] (1) RPM: 2365, PWR: 40, VOLTAGE: 24.846V, TEMPERATURE: 47.61C, CURRENT: 4.824A
                            [1.793] (1) RPM: 2365, PWR: 40, VOLTAGE: 24.846V, TEMPERATURE: 47.61C, CURRENT: 4.824A
                            [1.802] (1) RPM: 2361, PWR: 40, VOLTAGE: 24.837V, TEMPERATURE: 47.63C, CURRENT: 4.472A
                            [1.812] (1) RPM: 2338, PWR: 40, VOLTAGE: 24.853V, TEMPERATURE: 47.65C, CURRENT: 4.920A
                            [1.822] (1) RPM: 2360, PWR: 40, VOLTAGE: 24.852V, TEMPERATURE: 47.68C, CURRENT: 4.824A
                            [1.832] (1) RPM: 2326, PWR: 40, VOLTAGE: 24.829V, TEMPERATURE: 47.73C, CURRENT: 4.696A
                            [1.842] (1) RPM: 2276, PWR: 40, VOLTAGE: 24.818V, TEMPERATURE: 47.78C, CURRENT: 4.968A
                            [1.852] (1) RPM: 2367, PWR: 40, VOLTAGE: 24.829V, TEMPERATURE: 47.75C, CURRENT: 4.016A
                            [1.862] (1) RPM: 2333, PWR: 40, VOLTAGE: 24.864V, TEMPERATURE: 47.74C, CURRENT: 5.440A
                            [1.872] (1) RPM: 2284, PWR: 40, VOLTAGE: 24.842V, TEMPERATURE: 47.77C, CURRENT: 5.088A
                            [1.882] (1) RPM: 2373, PWR: 40, VOLTAGE: 24.850V, TEMPERATURE: 47.81C, CURRENT: 5.640A
                            [1.892] (1) RPM: 2373, PWR: 40, VOLTAGE: 24.850V, TEMPERATURE: 47.81C, CURRENT: 5.640A
                            [1.902] (1) RPM: 2299, PWR: 40, VOLTAGE: 24.839V, TEMPERATURE: 47.77C, CURRENT: 5.344A
                            [1.912] (1) RPM: 2316, PWR: 40, VOLTAGE: 24.847V, TEMPERATURE: 47.75C, CURRENT: 4.304A
                            [1.922] (1) RPM: 2352, PWR: 40, VOLTAGE: 24.847V, TEMPERATURE: 47.79C, CURRENT: 5.160A
                            [1.932] (1) RPM: 2271, PWR: 40, VOLTAGE: 24.832V, TEMPERATURE: 47.83C, CURRENT: 4.984A
                            [1.942] (1) RPM: 2346, PWR: 40, VOLTAGE: 24.856V, TEMPERATURE: 47.92C, CURRENT: 4.248A
                            [1.952] (1) RPM: 2354, PWR: 40, VOLTAGE: 24.833V, TEMPERATURE: 47.94C, CURRENT: 4.904A
                            [1.962] (1) RPM: 2262, PWR: 40, VOLTAGE: 24.843V, TEMPERATURE: 47.88C, CURRENT: 5.928A
                            [1.972] (1) RPM: 2355, PWR: 40, VOLTAGE: 24.844V, TEMPERATURE: 47.94C, CURRENT: 4.584A
                            [1.983] (1) RPM: 2241, PWR: 40, VOLTAGE: 24.820V, TEMPERATURE: 47.89C, CURRENT: 4.936A
                            [1.992] (1) RPM: 2241, PWR: 40, VOLTAGE: 24.820V, TEMPERATURE: 47.89C, CURRENT: 4.936A
                            [2.002] (1) RPM: 2316, PWR: 40, VOLTAGE: 24.834V, TEMPERATURE: 47.85C, CURRENT: 4.360A
                            [2.012] (1) RPM: 2369, PWR: 40, VOLTAGE: 24.878V, TEMPERATURE: 47.86C, CURRENT: 5.240A
                            [2.022] (1) RPM: 2254, PWR: 40, VOLTAGE: 24.840V, TEMPERATURE: 47.93C, CURRENT: 5.232A
                            [2.032] (1) RPM: 2327, PWR: 40, VOLTAGE: 24.844V, TEMPERATURE: 47.97C, CURRENT: 4.176A
                            [2.042] (1) RPM: 2331, PWR: 40, VOLTAGE: 24.835V, TEMPERATURE: 47.97C, CURRENT: 4.464A
                            [2.052] (1) RPM: 2270, PWR: 40, VOLTAGE: 24.855V, TEMPERATURE: 47.97C, CURRENT: 4.712A
                            [2.062] (1) RPM: 2360, PWR: 40, VOLTAGE: 24.853V, TEMPERATURE: 48.00C, CURRENT: 5.256A
                            [2.072] (1) RPM: 2375, PWR: 40, VOLTAGE: 24.839V, TEMPERATURE: 47.98C, CURRENT: 4.512A
                            [2.082] (1) RPM: 2274, PWR: 40, VOLTAGE: 24.833V, TEMPERATURE: 47.92C, CURRENT: 5.352A
                            [2.093] (1) RPM: 2274, PWR: 40, VOLTAGE: 24.833V, TEMPERATURE: 47.92C, CURRENT: 5.352A
                            [2.102] (1) RPM: 2320, PWR: 40, VOLTAGE: 24.816V, TEMPERATURE: 47.98C, CURRENT: 5.000A
                            [2.112] (1) RPM: 2318, PWR: 40, VOLTAGE: 24.823V, TEMPERATURE: 48.03C, CURRENT: 4.096A
                            [2.122] (1) RPM: 2385, PWR: 40, VOLTAGE: 24.832V, TEMPERATURE: 48.09C, CURRENT: 4.136A
                            [2.132] (1) RPM: 2279, PWR: 40, VOLTAGE: 24.852V, TEMPERATURE: 48.11C, CURRENT: 5.520A
                            [2.142] (1) RPM: 2315, PWR: 40, VOLTAGE: 24.830V, TEMPERATURE: 48.18C, CURRENT: 4.816A
                            [2.152] (1) RPM: 2398, PWR: 40, VOLTAGE: 24.852V, TEMPERATURE: 48.13C, CURRENT: 4.944A
                            [2.162] (1) RPM: 2284, PWR: 40, VOLTAGE: 24.823V, TEMPERATURE: 48.11C, CURRENT: 5.312A
                            [2.172] (1) RPM: 2302, PWR: 40, VOLTAGE: 24.839V, TEMPERATURE: 48.16C, CURRENT: 5.216A
                            [2.183] (1) RPM: 2276, PWR: 40, VOLTAGE: 24.839V, TEMPERATURE: 48.13C, CURRENT: 5.200A
                            [2.192] (1) RPM: 2276, PWR: 40, VOLTAGE: 24.839V, TEMPERATURE: 48.13C, CURRENT: 5.200A
                            [2.202] (1) RPM: 2328, PWR: 40, VOLTAGE: 24.842V, TEMPERATURE: 48.19C, CURRENT: 4.208A
                            [2.212] (1) RPM: 2388, PWR: 40, VOLTAGE: 24.863V, TEMPERATURE: 48.15C, CURRENT: 5.048A
                            [2.222] (1) RPM: 2259, PWR: 40, VOLTAGE: 24.806V, TEMPERATURE: 48.16C, CURRENT: 5.048A
                            [2.232] (1) RPM: 2328, PWR: 40, VOLTAGE: 24.833V, TEMPERATURE: 48.19C, CURRENT: 4.544A
                            [2.242] (1) RPM: 2348, PWR: 40, VOLTAGE: 24.834V, TEMPERATURE: 48.23C, CURRENT: 4.984A
                            [2.252] (1) RPM: 2277, PWR: 40, VOLTAGE: 24.830V, TEMPERATURE: 48.21C, CURRENT: 4.984A
                            [2.262] (1) RPM: 2332, PWR: 40, VOLTAGE: 24.831V, TEMPERATURE: 48.18C, CURRENT: 5.144A
                            [2.272] (1) RPM: 2315, PWR: 40, VOLTAGE: 24.833V, TEMPERATURE: 48.20C, CURRENT: 5.000A
                            [2.283] (1) RPM: 2354, PWR: 40, VOLTAGE: 24.838V, TEMPERATURE: 48.23C, CURRENT: 5.448A
                            [2.292] (1) RPM: 2354, PWR: 40, VOLTAGE: 24.838V, TEMPERATURE: 48.23C, CURRENT: 5.448A
                            [2.302] (1) RPM: 2279, PWR: 40, VOLTAGE: 24.832V, TEMPERATURE: 48.25C, CURRENT: 5.000A
                            [2.312] (1) RPM: 2307, PWR: 40, VOLTAGE: 24.831V, TEMPERATURE: 48.33C, CURRENT: 5.096A
                            [2.322] (1) RPM: 5555, PWR: 40, VOLTAGE: 24.847V, TEMPERATURE: 48.38C, CURRENT: 3.064A
                            [2.332] (1) RPM: 5683, PWR: 40, VOLTAGE: 24.848V, TEMPERATURE: 48.40C, CURRENT: 3.456A
                            [2.342] (1) RPM: 2258, PWR: 40, VOLTAGE: 24.841V, TEMPERATURE: 48.44C, CURRENT: 5.168A
                            [2.352] (1) RPM: 2254, PWR: 40, VOLTAGE: 24.820V, TEMPERATURE: 48.43C, CURRENT: 4.016A
                            [2.362] (1) RPM: 2282, PWR: 40, VOLTAGE: 24.847V, TEMPERATURE: 48.47C, CURRENT: 5.288A
                            [2.372] (1) RPM: 2286, PWR: 40, VOLTAGE: 24.826V, TEMPERATURE: 48.44C, CURRENT: 5.368A
                            [2.382] (1) RPM: 2203, PWR: 40, VOLTAGE: 24.871V, TEMPERATURE: 48.48C, CURRENT: 4.912A
                            [2.392] (1) RPM: 2203, PWR: 40, VOLTAGE: 24.871V, TEMPERATURE: 48.48C, CURRENT: 4.912A
                            [2.402] (1) RPM: 2179, PWR: 40, VOLTAGE: 24.835V, TEMPERATURE: 48.53C, CURRENT: 5.352A
                            [2.412] (1) RPM: 2267, PWR: 40, VOLTAGE: 24.834V, TEMPERATURE: 48.54C, CURRENT: 4.256A
                            [2.422] (1) RPM: 2353, PWR: 40, VOLTAGE: 24.833V, TEMPERATURE: 48.51C, CURRENT: 4.728A
                            [2.432] (1) RPM: 2308, PWR: 40, VOLTAGE: 24.834V, TEMPERATURE: 48.53C, CURRENT: 4.592A
                            [2.443] (1) RPM: 2206, PWR: 40, VOLTAGE: 24.829V, TEMPERATURE: 48.54C, CURRENT: 4.744A
                            [2.452] (1) RPM: 2302, PWR: 40, VOLTAGE: 24.823V, TEMPERATURE: 48.57C, CURRENT: 4.256A
                            [2.462] (1) RPM: 2349, PWR: 40, VOLTAGE: 24.831V, TEMPERATURE: 48.62C, CURRENT: 5.248A
                            [2.472] (1) RPM: 2297, PWR: 40, VOLTAGE: 24.843V, TEMPERATURE: 48.60C, CURRENT: 5.008A
                            [2.482] (1) RPM: 2368, PWR: 40, VOLTAGE: 24.827V, TEMPERATURE: 48.58C, CURRENT: 4.328A
                            [2.493] (1) RPM: 2368, PWR: 40, VOLTAGE: 24.827V, TEMPERATURE: 48.58C, CURRENT: 4.328A
                            [2.502] (1) RPM: 2734, PWR: 40, VOLTAGE: 24.846V, TEMPERATURE: 48.63C, CURRENT: 5.496A
                            [2.512] (1) RPM: 2251, PWR: 40, VOLTAGE: 24.813V, TEMPERATURE: 48.62C, CURRENT: 4.440A
                            [2.522] (1) RPM: 2268, PWR: 40, VOLTAGE: 24.813V, TEMPERATURE: 48.59C, CURRENT: 4.640A
                            [2.532] (1) RPM: 2235, PWR: 40, VOLTAGE: 24.845V, TEMPERATURE: 48.56C, CURRENT: 4.376A
                            [2.542] (1) RPM: 2224, PWR: 40, VOLTAGE: 24.839V, TEMPERATURE: 48.56C, CURRENT: 4.960A
                            [2.552] (1) RPM: 2187, PWR: 40, VOLTAGE: 24.796V, TEMPERATURE: 48.65C, CURRENT: 6.192A
                            [2.562] (1) RPM: 2275, PWR: 40, VOLTAGE: 24.828V, TEMPERATURE: 48.75C, CURRENT: 4.008A
                            [2.572] (1) RPM: 2318, PWR: 40, VOLTAGE: 24.820V, TEMPERATURE: 48.76C, CURRENT: 4.240A
                            [2.583] (1) RPM: 2323, PWR: 40, VOLTAGE: 24.836V, TEMPERATURE: 48.75C, CURRENT: 4.600A
                            [2.593] (1) RPM: 2323, PWR: 40, VOLTAGE: 24.836V, TEMPERATURE: 48.75C, CURRENT: 4.600A
                            [2.602] (1) RPM: 2375, PWR: 40, VOLTAGE: 24.834V, TEMPERATURE: 48.82C, CURRENT: 5.176A
                            [2.612] (1) RPM: 2367, PWR: 40, VOLTAGE: 24.866V, TEMPERATURE: 48.79C, CURRENT: 4.864A
                            [2.622] (1) RPM: 2278, PWR: 40, VOLTAGE: 24.834V, TEMPERATURE: 48.83C, CURRENT: 4.376A
                            [2.632] (1) RPM: 2369, PWR: 40, VOLTAGE: 24.837V, TEMPERATURE: 48.80C, CURRENT: 4.312A
                            [2.642] (1) RPM: 2292, PWR: 40, VOLTAGE: 24.835V, TEMPERATURE: 48.94C, CURRENT: 5.296A
                            [2.652] (1) RPM: 2318, PWR: 40, VOLTAGE: 24.815V, TEMPERATURE: 48.92C, CURRENT: 4.992A
                            [2.662] (1) RPM: 2388, PWR: 40, VOLTAGE: 24.844V, TEMPERATURE: 48.96C, CURRENT: 4.488A
                            [2.672] (1) RPM: 2276, PWR: 40, VOLTAGE: 24.834V, TEMPERATURE: 48.92C, CURRENT: 4.672A
                            [2.682] (1) RPM: 2399, PWR: 40, VOLTAGE: 24.824V, TEMPERATURE: 48.91C, CURRENT: 3.904A
                            [2.693] (1) RPM: 2341, PWR: 40, VOLTAGE: 24.831V, TEMPERATURE: 48.89C, CURRENT: 3.880A
                            [2.703] (1) RPM: 2341, PWR: 40, VOLTAGE: 24.831V, TEMPERATURE: 48.89C, CURRENT: 3.880A
                            [2.712] (1) RPM: 2322, PWR: 40, VOLTAGE: 24.829V, TEMPERATURE: 49.01C, CURRENT: 4.560A
                            [2.722] (1) RPM: 2255, PWR: 40, VOLTAGE: 24.810V, TEMPERATURE: 49.03C, CURRENT: 5.424A
                            [2.732] (1) RPM: 2299, PWR: 40, VOLTAGE: 24.828V, TEMPERATURE: 49.07C, CURRENT: 5.160A
                            [2.742] (1) RPM: 2401, PWR: 40, VOLTAGE: 24.827V, TEMPERATURE: 49.02C, CURRENT: 5.952A
                            [2.752] (1) RPM: 2311, PWR: 40, VOLTAGE: 24.832V, TEMPERATURE: 49.00C, CURRENT: 5.176A
                            [2.762] (1) RPM: 2343, PWR: 40, VOLTAGE: 24.859V, TEMPERATURE: 49.06C, CURRENT: 4.632A
                            [2.772] (1) RPM: 2409, PWR: 40, VOLTAGE: 24.841V, TEMPERATURE: 49.07C, CURRENT: 5.408A
                            [2.782] (1) RPM: 2265, PWR: 40, VOLTAGE: 24.819V, TEMPERATURE: 48.99C, CURRENT: 4.896A
                            [2.792] (1) RPM: 2265, PWR: 40, VOLTAGE: 24.819V, TEMPERATURE: 48.99C, CURRENT: 4.896A
                            [2.804] (1) RPM: 2296, PWR: 40, VOLTAGE: 24.830V, TEMPERATURE: 49.09C, CURRENT: 4.616A
                            [2.812] (1) RPM: 2274, PWR: 40, VOLTAGE: 24.806V, TEMPERATURE: 49.21C, CURRENT: 4.464A
                            [2.822] (1) RPM: 2376, PWR: 40, VOLTAGE: 24.819V, TEMPERATURE: 49.24C, CURRENT: 3.952A
                            [2.832] (1) RPM: 2269, PWR: 40, VOLTAGE: 24.824V, TEMPERATURE: 49.24C, CURRENT: 4.376A
                            [2.842] (1) RPM: 2337, PWR: 40, VOLTAGE: 24.827V, TEMPERATURE: 49.23C, CURRENT: 3.944A
                            [2.852] (1) RPM: 2392, PWR: 40, VOLTAGE: 24.846V, TEMPERATURE: 49.16C, CURRENT: 4.016A
                            [2.862] (1) RPM: 2253, PWR: 40, VOLTAGE: 24.832V, TEMPERATURE: 49.12C, CURRENT: 4.880A
                            [2.872] (1) RPM: 2383, PWR: 40, VOLTAGE: 24.844V, TEMPERATURE: 49.17C, CURRENT: 4.488A
                            [2.882] (1) RPM: 2265, PWR: 40, VOLTAGE: 24.826V, TEMPERATURE: 49.20C, CURRENT: 4.824A
                            [2.893] (1) RPM: 2265, PWR: 40, VOLTAGE: 24.826V, TEMPERATURE: 49.20C, CURRENT: 4.824A
                            [2.902] (1) RPM: 2400, PWR: 40, VOLTAGE: 24.841V, TEMPERATURE: 49.27C, CURRENT: 4.264A
                            [2.912] (1) RPM: 2325, PWR: 40, VOLTAGE: 24.836V, TEMPERATURE: 49.28C, CURRENT: 5.072A
                            [2.922] (1) RPM: 2352, PWR: 40, VOLTAGE: 24.810V, TEMPERATURE: 49.31C, CURRENT: 3.928A
                            [2.932] (1) RPM: 2393, PWR: 40, VOLTAGE: 24.838V, TEMPERATURE: 49.35C, CURRENT: 4.328A
                            [2.942] (1) RPM: 2289, PWR: 40, VOLTAGE: 24.822V, TEMPERATURE: 49.40C, CURRENT: 4.432A
                            [2.952] (1) RPM: 2345, PWR: 40, VOLTAGE: 24.832V, TEMPERATURE: 49.43C, CURRENT: 3.824A
                            [2.962] (1) RPM: 2346, PWR: 40, VOLTAGE: 24.858V, TEMPERATURE: 49.43C, CURRENT: 3.944A
                            [2.972] (1) RPM: 2259, PWR: 40, VOLTAGE: 24.833V, TEMPERATURE: 49.39C, CURRENT: 4.800A
                            [2.983] (1) RPM: 2262, PWR: 40, VOLTAGE: 24.828V, TEMPERATURE: 49.49C, CURRENT: 4.328A
                            [2.993] (1) RPM: 2262, PWR: 40, VOLTAGE: 24.828V, TEMPERATURE: 49.49C, CURRENT: 4.328A
                            [3.002] (1) RPM: 2314, PWR: 40, VOLTAGE: 24.805V, TEMPERATURE: 49.49C, CURRENT: 4.456A
                            [3.013] (1) RPM: 2325, PWR: 40, VOLTAGE: 24.822V, TEMPERATURE: 49.51C, CURRENT: 4.176A
                            [3.022] (1) RPM: 2295, PWR: 40, VOLTAGE: 24.828V, TEMPERATURE: 49.52C, CURRENT: 5.632A
                            [3.032] (1) RPM: 2343, PWR: 40, VOLTAGE: 24.829V, TEMPERATURE: 49.49C, CURRENT: 4.016A
                            [3.042] (1) RPM: 2303, PWR: 40, VOLTAGE: 24.830V, TEMPERATURE: 49.49C, CURRENT: 5.184A
                            [3.052] (1) RPM: 2287, PWR: 40, VOLTAGE: 24.826V, TEMPERATURE: 49.48C, CURRENT: 4.776A
                            [3.062] (1) RPM: 5707, PWR: 40, VOLTAGE: 24.841V, TEMPERATURE: 49.49C, CURRENT: 3.056A
                            [3.072] (1) RPM: 5671, PWR: 40, VOLTAGE: 24.847V, TEMPERATURE: 49.54C, CURRENT: 2.984A
                            [3.082] (1) RPM: 2334, PWR: 40, VOLTAGE: 24.829V, TEMPERATURE: 49.49C, CURRENT: 4.792A
                            [3.092] (1) RPM: 2334, PWR: 40, VOLTAGE: 24.829V, TEMPERATURE: 49.49C, CURRENT: 4.792A
                            [3.102] (1) RPM: 2230, PWR: 40, VOLTAGE: 24.821V, TEMPERATURE: 49.55C, CURRENT: 4.880A
                            [3.112] (1) RPM: 2282, PWR: 40, VOLTAGE: 24.823V, TEMPERATURE: 49.62C, CURRENT: 4.608A
                            [3.122] (1) RPM: 2297, PWR: 40, VOLTAGE: 24.837V, TEMPERATURE: 49.58C, CURRENT: 5.192A
                            [3.132] (1) RPM: 2213, PWR: 40, VOLTAGE: 24.814V, TEMPERATURE: 49.64C, CURRENT: 5.616A
                            [3.142] (1) RPM: 2203, PWR: 40, VOLTAGE: 24.830V, TEMPERATURE: 49.56C, CURRENT: 5.056A
                            [3.152] (1) RPM: 2228, PWR: 40, VOLTAGE: 24.815V, TEMPERATURE: 49.63C, CURRENT: 3.672A
                            [3.162] (1) RPM: 2338, PWR: 40, VOLTAGE: 24.815V, TEMPERATURE: 49.58C, CURRENT: 4.312A
                            [3.172] (1) RPM: 2361, PWR: 40, VOLTAGE: 24.843V, TEMPERATURE: 49.61C, CURRENT: 5.288A
                            [3.182] (1) RPM: 2294, PWR: 40, VOLTAGE: 24.829V, TEMPERATURE: 49.68C, CURRENT: 5.320A
                            [3.192] (1) RPM: 2294, PWR: 40, VOLTAGE: 24.829V, TEMPERATURE: 49.68C, CURRENT: 5.320A
                            [3.202] (1) RPM: 2310, PWR: 40, VOLTAGE: 24.821V, TEMPERATURE: 49.73C, CURRENT: 4.792A
                            [3.212] (1) RPM: 2279, PWR: 40, VOLTAGE: 24.823V, TEMPERATURE: 49.74C, CURRENT: 4.432A
                            [3.222] (1) RPM: 2418, PWR: 40, VOLTAGE: 24.830V, TEMPERATURE: 49.74C, CURRENT: 4.600A
                            [3.232] (1) RPM: 2275, PWR: 40, VOLTAGE: 24.815V, TEMPERATURE: 49.86C, CURRENT: 4.640A
                            [3.242] (1) RPM: 2356, PWR: 40, VOLTAGE: 24.830V, TEMPERATURE: 49.83C, CURRENT: 4.224A
                            [3.252] (1) RPM: 2325, PWR: 40, VOLTAGE: 24.831V, TEMPERATURE: 49.82C, CURRENT: 4.280A
                            [3.262] (1) RPM: 2300, PWR: 40, VOLTAGE: 24.823V, TEMPERATURE: 49.78C, CURRENT: 4.496A
                            [3.272] (1) RPM: 2418, PWR: 40, VOLTAGE: 24.817V, TEMPERATURE: 49.80C, CURRENT: 5.352A
                            [3.282] (1) RPM: 2370, PWR: 40, VOLTAGE: 24.828V, TEMPERATURE: 49.94C, CURRENT: 4.088A
                            [3.293] (1) RPM: 2370, PWR: 40, VOLTAGE: 24.828V, TEMPERATURE: 49.94C, CURRENT: 4.088A
                            [3.302] (1) RPM: 2316, PWR: 40, VOLTAGE: 24.828V, TEMPERATURE: 49.87C, CURRENT: 4.072A
                            [3.312] (1) RPM: 2344, PWR: 40, VOLTAGE: 24.839V, TEMPERATURE: 49.86C, CURRENT: 4.424A
                            [3.322] (1) RPM: 2428, PWR: 40, VOLTAGE: 24.824V, TEMPERATURE: 49.89C, CURRENT: 4.872A
                            [3.332] (1) RPM: 2271, PWR: 40, VOLTAGE: 24.847V, TEMPERATURE: 49.91C, CURRENT: 4.408A
                            [3.342] (1) RPM: 2391, PWR: 40, VOLTAGE: 24.828V, TEMPERATURE: 50.00C, CURRENT: 4.392A
                            [3.352] (1) RPM: 2283, PWR: 40, VOLTAGE: 24.829V, TEMPERATURE: 49.93C, CURRENT: 5.312A
                            [3.362] (1) RPM: 2343, PWR: 40, VOLTAGE: 24.833V, TEMPERATURE: 50.05C, CURRENT: 4.128A
                            [3.372] (1) RPM: 2295, PWR: 40, VOLTAGE: 24.820V, TEMPERATURE: 50.06C, CURRENT: 4.304A
                            [3.383] (1) RPM: 2382, PWR: 40, VOLTAGE: 24.828V, TEMPERATURE: 50.03C, CURRENT: 4.128A
                            [3.392] (1) RPM: 2382, PWR: 40, VOLTAGE: 24.828V, TEMPERATURE: 50.03C, CURRENT: 4.128A
                            [3.402] (1) RPM: 2280, PWR: 40, VOLTAGE: 24.834V, TEMPERATURE: 49.98C, CURRENT: 4.080A
                            [3.412] (1) RPM: 2393, PWR: 40, VOLTAGE: 24.822V, TEMPERATURE: 49.97C, CURRENT: 4.432A
                            [3.422] (1) RPM: 2318, PWR: 40, VOLTAGE: 24.831V, TEMPERATURE: 50.00C, CURRENT: 5.880A
                            [3.432] (1) RPM: 2337, PWR: 40, VOLTAGE: 24.839V, TEMPERATURE: 50.04C, CURRENT: 4.000A
                            [3.442] (1) RPM: 2371, PWR: 40, VOLTAGE: 24.816V, TEMPERATURE: 50.11C, CURRENT: 4.560A
                            [3.452] (1) RPM: 2323, PWR: 40, VOLTAGE: 24.835V, TEMPERATURE: 50.15C, CURRENT: 4.992A
                            [3.462] (1) RPM: 2356, PWR: 40, VOLTAGE: 24.846V, TEMPERATURE: 50.05C, CURRENT: 4.456A
                            [3.472] (1) RPM: 2286, PWR: 40, VOLTAGE: 24.837V, TEMPERATURE: 50.06C, CURRENT: 5.256A
                            [3.482] (1) RPM: 2420, PWR: 40, VOLTAGE: 24.856V, TEMPERATURE: 50.08C, CURRENT: 5.208A
                            [3.492] (1) RPM: 2420, PWR: 40, VOLTAGE: 24.856V, TEMPERATURE: 50.08C, CURRENT: 5.208A
                            Finished!
                            [1705518380.137016] TX=358, RX=356 packets, RX CRC ERRORS=0
                            Average RPMs: 0.00 2378.00 0.00 0.00
                            Average RPM deviation between ESCs : 2378.00
                            False
                            WARNING: In order to plot the results, install the Python "plotly" module: pip3 install plotly --upgrade
                            • Alex KushleyevA Offline
                              Yes, potentially. You should follow the steps to update your firmware and params specifically for low kv motors as I suggested and documented
                                Matthew Wellner
                                Just to confirm - I updated the params file (mn4006 low kv) according to the instructions and I am on this ESC firmware: version 39, hash d4fe8e3d. The firmware you list is 39 RC11, is the firmware I'm running good, or do I need to use the RC11 version? Everything else is the same as in your instructions.
                                Matthew WellnerM Alex KushleyevA 2 Replies Last reply
                                  Matthew Wellner
                                  @Alex-Kushleyev - Nevermind. I see you checked it in 2 days ago. I am updating the firmware now. Sorry!!
                                    @Matthew-Wellner you need the firmware modalai_esc_firmware_m0134_6_v0_39_RC11_17d64675.bin - there is an update specifically to address the de-sync issue. as well as the params i mentioned, most importantly timing_advance, sense_advance and demag_timing
                                      also please review params that i used for a similar motor : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/dev/voxl-esc-params/low_kv/mn4006_m0134_6_low_kv.xml
                                        Matthew Wellner
                                        The firmware update worked! Sorry again for not paying better attention 🤦
                                          Matthew Wellner
                                          @Matthew-Wellner said in Can you power VOXL2 from the ModalAI 6s ESC?:
                                          Ugh - I spoke too soon... 50%+ is still having issues, but I am going to re-run through everything again to make sure I didn't miss anything else.
                                          Thanks again!
