  3. Can you power VOXL2 from the ModalAI 6s ESC?
51 Posts 3 Posters 28.3k Views 1 Watching
    @Matthew-Wellner , just for a quick sanity check, can you share what motor / props you are using with M0134-6? i just want to confirm that the ESC will be able to support the motor/prop combination.
    Matthew WellnerM Offline
    Matthew Wellner
    Sorry for the delay - I am using SunnySky / TMotor 4004 @400kv with TMotor MS1101 props (11").
    • V Vin
      @Matthew-Wellner
      It probably due to voxl-px4, if you just run the voxl-esc, it will stop voxl-px4 however if you are running python scripts directly it does not.
      I would try stopping voxl-px4 as below, check and then run voxl-esc scripts and see if I still get the same issue
      You can check if px4 is running:
      systemctl is-active voxl-px4
      stop px4:
      systemctl stop voxl-px4
      Just in case if this is of any help as I had similar issue and above resolved it.
      Matthew Wellner
      @Vin
      Thanks, but voxl-px4 is running. I am getting GPS, battery voltage and the rest of the telemetry in QGC as expected. I'm just not getting anything for the receiver even though I can read it from the command line.
      Matt
        #28
        @Matthew-Wellner , you probably want to take a look at this post. I recently posted new firmware, params example and instructions how to make sure your low kv motor operates properly:
        https://forum.modalai.com/topic/2902/kde-4012xf-motors-with-16-in-props/10#
        I will tag you there
        I did an example tuning / testing of Tmotor MN4006 380kV with 15in prop which could be similar to your application, so it should definitely be relevant and going through the testing you will ensure that there will be no de-syncs
          @Vin
          Matt
          @Matthew-Wellner, if you still cannot figure out the RC receiver you should make another post in the forum regarding the receiver, so that this thread does not get too confusing 🙂
          I can't help you there, but other devs should be able to
            Matthew Wellner
            @Alex-Kushleyev Will do. Thanks!
              Matthew Wellner
              Hi Alex - I performed some testing with the ESC with the low kv esc params file referenced in the thread you pointed me to and when I go from 30% power to 40% and greater, my motor / prop reverses directions. Am I desyncing at that point?
              voxl2:/usr/share/modalai/voxl-esc-tools$ ./voxl-esc-spin.py --id 1 --power 40 --timeout 3.5 --enable-plot 1
              [GCC 8.4.0]
              VOXL Platform: M0054
              Board : version 41: ModalAi 4-in-1 ESC (M0134-6)
              UID : 0x203330385246571900480020
              Firmware : version 39, hash d4fe8e3d
              Bootloader : version 184, hash 10b1286a
              UID        : 0x2033303852465717003C002A
              UID        : 0x203330385246571500420047
              UID        : 0x20333038524657190034001D
              WARNING:
              from all persons.
              Type "Yes" to continue: Yes
              [0.013] (1) RPM: 0, PWR: 0, VOLTAGE: 24.946V, TEMPERATURE: 46.80C, CURRENT: 0.000A
              [0.022] (1) RPM: 7, PWR: 0, VOLTAGE: 24.941V, TEMPERATURE: 46.79C, CURRENT: 0.000A
              [0.032] (1) RPM: 15, PWR: 0, VOLTAGE: 24.941V, TEMPERATURE: 46.80C, CURRENT: 0.056A
              [0.042] (1) RPM: 23, PWR: 0, VOLTAGE: 24.950V, TEMPERATURE: 46.79C, CURRENT: 0.128A
              [0.052] (1) RPM: 31, PWR: 0, VOLTAGE: 24.937V, TEMPERATURE: 46.82C, CURRENT: 0.264A
              [0.062] (1) RPM: 39, PWR: 0, VOLTAGE: 24.932V, TEMPERATURE: 46.85C, CURRENT: 0.440A
              [0.072] (1) RPM: 47, PWR: 0, VOLTAGE: 24.930V, TEMPERATURE: 46.83C, CURRENT: 0.520A
              [0.082] (1) RPM: 55, PWR: 0, VOLTAGE: 24.930V, TEMPERATURE: 46.78C, CURRENT: 0.680A
              [0.092] (1) RPM: 63, PWR: 0, VOLTAGE: 24.929V, TEMPERATURE: 46.79C, CURRENT: 0.648A
              [0.103] (1) RPM: 63, PWR: 0, VOLTAGE: 24.929V, TEMPERATURE: 46.79C, CURRENT: 0.648A
              [0.112] (1) RPM: 79, PWR: 0, VOLTAGE: 24.927V, TEMPERATURE: 46.79C, CURRENT: 0.632A
              [0.122] (1) RPM: 87, PWR: 0, VOLTAGE: 24.937V, TEMPERATURE: 46.79C, CURRENT: 0.680A
              [0.132] (1) RPM: 95, PWR: 0, VOLTAGE: 24.946V, TEMPERATURE: 46.79C, CURRENT: 0.664A
              [0.142] (1) RPM: 103, PWR: 0, VOLTAGE: 24.939V, TEMPERATURE: 46.79C, CURRENT: 0.608A
              [0.152] (1) RPM: 111, PWR: 0, VOLTAGE: 24.928V, TEMPERATURE: 46.80C, CURRENT: 0.776A
              [0.162] (1) RPM: 119, PWR: 0, VOLTAGE: 24.934V, TEMPERATURE: 46.80C, CURRENT: 0.528A
              [0.172] (1) RPM: 127, PWR: 0, VOLTAGE: 24.929V, TEMPERATURE: 46.81C, CURRENT: 0.464A
              [0.182] (1) RPM: 135, PWR: 0, VOLTAGE: 24.931V, TEMPERATURE: 46.85C, CURRENT: 0.688A
              [0.193] (1) RPM: 144, PWR: 0, VOLTAGE: 24.928V, TEMPERATURE: 46.82C, CURRENT: 0.648A
              [0.203] (1) RPM: 144, PWR: 0, VOLTAGE: 24.928V, TEMPERATURE: 46.82C, CURRENT: 0.648A
              [0.212] (1) RPM: 159, PWR: 0, VOLTAGE: 24.932V, TEMPERATURE: 46.86C, CURRENT: 0.688A
              [0.222] (1) RPM: 167, PWR: 0, VOLTAGE: 24.928V, TEMPERATURE: 46.89C, CURRENT: 0.696A
              [0.232] (1) RPM: 175, PWR: 0, VOLTAGE: 24.921V, TEMPERATURE: 46.85C, CURRENT: 0.688A
              [0.242] (1) RPM: 183, PWR: 0, VOLTAGE: 24.922V, TEMPERATURE: 46.87C, CURRENT: 0.736A
              [0.252] (1) RPM: 191, PWR: 0, VOLTAGE: 24.941V, TEMPERATURE: 46.81C, CURRENT: 0.856A
              [0.262] (1) RPM: 199, PWR: 0, VOLTAGE: 24.929V, TEMPERATURE: 46.78C, CURRENT: 0.672A
              [0.272] (1) RPM: 207, PWR: 0, VOLTAGE: 24.931V, TEMPERATURE: 46.76C, CURRENT: 0.696A
              [0.282] (1) RPM: 215, PWR: 0, VOLTAGE: 24.921V, TEMPERATURE: 46.83C, CURRENT: 0.736A
              [0.293] (1) RPM: 224, PWR: 0, VOLTAGE: 24.932V, TEMPERATURE: 46.81C, CURRENT: 0.736A
              [0.302] (1) RPM: 224, PWR: 0, VOLTAGE: 24.932V, TEMPERATURE: 46.81C, CURRENT: 0.736A
              [0.312] (1) RPM: 231, PWR: 0, VOLTAGE: 24.930V, TEMPERATURE: 46.83C, CURRENT: 0.640A
              [0.322] (1) RPM: 247, PWR: 0, VOLTAGE: 24.925V, TEMPERATURE: 46.77C, CURRENT: 0.720A
              [0.332] (1) RPM: 255, PWR: 0, VOLTAGE: 24.930V, TEMPERATURE: 46.78C, CURRENT: 0.656A
              [0.342] (1) RPM: 263, PWR: 0, VOLTAGE: 24.924V, TEMPERATURE: 46.83C, CURRENT: 0.784A
              [0.352] (1) RPM: 271, PWR: 0, VOLTAGE: 24.921V, TEMPERATURE: 46.83C, CURRENT: 0.696A
              [0.362] (1) RPM: 279, PWR: 0, VOLTAGE: 24.930V, TEMPERATURE: 46.85C, CURRENT: 0.784A
              [0.372] (1) RPM: 287, PWR: 0, VOLTAGE: 24.923V, TEMPERATURE: 46.84C, CURRENT: 0.992A
              [0.382] (1) RPM: 295, PWR: 0, VOLTAGE: 24.923V, TEMPERATURE: 46.89C, CURRENT: 0.920A
              [0.392] (1) RPM: 303, PWR: 0, VOLTAGE: 24.940V, TEMPERATURE: 46.83C, CURRENT: 0.808A
              [0.402] (1) RPM: 303, PWR: 0, VOLTAGE: 24.940V, TEMPERATURE: 46.83C, CURRENT: 0.808A
              [0.412] (1) RPM: 311, PWR: 0, VOLTAGE: 24.926V, TEMPERATURE: 46.79C, CURRENT: 0.832A
              [0.422] (1) RPM: 327, PWR: 0, VOLTAGE: 24.932V, TEMPERATURE: 46.81C, CURRENT: 0.752A
              [0.432] (1) RPM: 335, PWR: 0, VOLTAGE: 24.922V, TEMPERATURE: 46.84C, CURRENT: 0.816A
              [0.442] (1) RPM: 343, PWR: 0, VOLTAGE: 24.914V, TEMPERATURE: 46.84C, CURRENT: 0.896A
              [0.452] (1) RPM: 351, PWR: 0, VOLTAGE: 24.934V, TEMPERATURE: 46.77C, CURRENT: 0.808A
              [0.462] (1) RPM: 359, PWR: 0, VOLTAGE: 24.940V, TEMPERATURE: 46.79C, CURRENT: 0.744A
              [0.472] (1) RPM: 367, PWR: 0, VOLTAGE: 24.932V, TEMPERATURE: 46.84C, CURRENT: 0.920A
              [0.482] (1) RPM: 375, PWR: 0, VOLTAGE: 24.927V, TEMPERATURE: 46.82C, CURRENT: 0.904A
              [0.493] (1) RPM: 384, PWR: 0, VOLTAGE: 24.921V, TEMPERATURE: 46.85C, CURRENT: 0.768A
              [0.503] (1) RPM: 384, PWR: 0, VOLTAGE: 24.921V, TEMPERATURE: 46.85C, CURRENT: 0.768A
              [0.512] (1) RPM: 399, PWR: 0, VOLTAGE: 24.934V, TEMPERATURE: 46.82C, CURRENT: 0.536A
              [0.522] (1) RPM: 407, PWR: 0, VOLTAGE: 24.939V, TEMPERATURE: 46.82C, CURRENT: 0.808A
              [0.533] (1) RPM: 416, PWR: 0, VOLTAGE: 24.931V, TEMPERATURE: 46.84C, CURRENT: 0.896A
              [0.542] (1) RPM: 423, PWR: 0, VOLTAGE: 24.940V, TEMPERATURE: 46.81C, CURRENT: 0.928A
              [0.552] (1) RPM: 431, PWR: 0, VOLTAGE: 24.918V, TEMPERATURE: 46.83C, CURRENT: 0.760A
              [0.562] (1) RPM: 439, PWR: 0, VOLTAGE: 24.922V, TEMPERATURE: 46.82C, CURRENT: 0.832A
              [0.572] (1) RPM: 447, PWR: 0, VOLTAGE: 24.925V, TEMPERATURE: 46.83C, CURRENT: 0.832A
              [0.582] (1) RPM: 455, PWR: 0, VOLTAGE: 24.924V, TEMPERATURE: 46.84C, CURRENT: 0.792A
              [0.592] (1) RPM: 463, PWR: 0, VOLTAGE: 24.922V, TEMPERATURE: 46.87C, CURRENT: 0.888A
              [0.602] (1) RPM: 463, PWR: 0, VOLTAGE: 24.922V, TEMPERATURE: 46.87C, CURRENT: 0.888A
              [0.612] (1) RPM: 471, PWR: 0, VOLTAGE: 24.915V, TEMPERATURE: 46.88C, CURRENT: 0.952A
              [0.622] (1) RPM: 487, PWR: 0, VOLTAGE: 24.919V, TEMPERATURE: 46.88C, CURRENT: 0.872A
              [0.632] (1) RPM: 495, PWR: 0, VOLTAGE: 24.930V, TEMPERATURE: 46.86C, CURRENT: 0.856A
              [0.642] (1) RPM: 503, PWR: 0, VOLTAGE: 24.921V, TEMPERATURE: 46.87C, CURRENT: 0.840A
              [0.652] (1) RPM: 512, PWR: 0, VOLTAGE: 24.918V, TEMPERATURE: 46.89C, CURRENT: 0.936A
              [0.662] (1) RPM: 519, PWR: 0, VOLTAGE: 24.927V, TEMPERATURE: 46.86C, CURRENT: 0.920A
              [0.672] (1) RPM: 527, PWR: 0, VOLTAGE: 24.929V, TEMPERATURE: 46.86C, CURRENT: 0.920A
              [0.682] (1) RPM: 535, PWR: 0, VOLTAGE: 24.940V, TEMPERATURE: 46.89C, CURRENT: 0.952A
              [0.692] (1) RPM: 543, PWR: 0, VOLTAGE: 24.931V, TEMPERATURE: 46.96C, CURRENT: 0.856A
              [0.703] (1) RPM: 543, PWR: 0, VOLTAGE: 24.931V, TEMPERATURE: 46.96C, CURRENT: 0.856A
              [0.712] (1) RPM: 559, PWR: 0, VOLTAGE: 24.923V, TEMPERATURE: 46.93C, CURRENT: 0.944A
              [0.722] (1) RPM: 567, PWR: 0, VOLTAGE: 24.925V, TEMPERATURE: 46.94C, CURRENT: 0.824A
              [0.732] (1) RPM: 575, PWR: 0, VOLTAGE: 24.928V, TEMPERATURE: 46.89C, CURRENT: 0.928A
              [0.742] (1) RPM: 583, PWR: 0, VOLTAGE: 24.926V, TEMPERATURE: 46.90C, CURRENT: 0.888A
              [0.752] (1) RPM: 591, PWR: 0, VOLTAGE: 24.923V, TEMPERATURE: 46.92C, CURRENT: 0.848A
              [0.762] (1) RPM: 599, PWR: 0, VOLTAGE: 24.921V, TEMPERATURE: 46.89C, CURRENT: 0.880A
              [0.772] (1) RPM: 607, PWR: 0, VOLTAGE: 24.924V, TEMPERATURE: 46.87C, CURRENT: 0.840A
              [0.782] (1) RPM: 615, PWR: 0, VOLTAGE: 24.920V, TEMPERATURE: 46.91C, CURRENT: 0.880A
              [0.792] (1) RPM: 624, PWR: 0, VOLTAGE: 24.922V, TEMPERATURE: 46.91C, CURRENT: 1.056A
              [0.802] (1) RPM: 624, PWR: 0, VOLTAGE: 24.922V, TEMPERATURE: 46.91C, CURRENT: 1.056A
              [0.812] (1) RPM: 639, PWR: 0, VOLTAGE: 24.915V, TEMPERATURE: 46.92C, CURRENT: 0.968A
              [0.822] (1) RPM: 647, PWR: 0, VOLTAGE: 24.916V, TEMPERATURE: 46.95C, CURRENT: 0.896A
              [0.832] (1) RPM: 655, PWR: 0, VOLTAGE: 24.931V, TEMPERATURE: 46.95C, CURRENT: 0.912A
              [0.842] (1) RPM: 663, PWR: 0, VOLTAGE: 24.925V, TEMPERATURE: 46.97C, CURRENT: 0.864A
              [0.852] (1) RPM: 671, PWR: 0, VOLTAGE: 24.928V, TEMPERATURE: 46.93C, CURRENT: 0.984A
              [0.862] (1) RPM: 679, PWR: 0, VOLTAGE: 24.936V, TEMPERATURE: 46.86C, CURRENT: 0.936A
              [0.872] (1) RPM: 687, PWR: 0, VOLTAGE: 24.931V, TEMPERATURE: 46.86C, CURRENT: 0.856A
              [0.882] (1) RPM: 695, PWR: 0, VOLTAGE: 24.922V, TEMPERATURE: 46.92C, CURRENT: 1.040A
              [0.892] (1) RPM: 703, PWR: 0, VOLTAGE: 24.913V, TEMPERATURE: 46.97C, CURRENT: 0.872A
              [0.903] (1) RPM: 703, PWR: 0, VOLTAGE: 24.913V, TEMPERATURE: 46.97C, CURRENT: 0.872A
              [0.912] (1) RPM: 719, PWR: 0, VOLTAGE: 24.924V, TEMPERATURE: 46.98C, CURRENT: 0.952A
              [0.922] (1) RPM: 727, PWR: 0, VOLTAGE: 24.926V, TEMPERATURE: 46.98C, CURRENT: 0.864A
              [0.932] (1) RPM: 735, PWR: 0, VOLTAGE: 24.921V, TEMPERATURE: 46.94C, CURRENT: 1.096A
              [0.942] (1) RPM: 743, PWR: 0, VOLTAGE: 24.929V, TEMPERATURE: 46.94C, CURRENT: 1.016A
              [0.952] (1) RPM: 751, PWR: 0, VOLTAGE: 24.925V, TEMPERATURE: 46.94C, CURRENT: 0.936A
              [0.962] (1) RPM: 759, PWR: 0, VOLTAGE: 24.929V, TEMPERATURE: 46.95C, CURRENT: 0.864A
              [0.972] (1) RPM: 767, PWR: 0, VOLTAGE: 24.925V, TEMPERATURE: 46.93C, CURRENT: 0.864A
              [0.982] (1) RPM: 775, PWR: 0, VOLTAGE: 24.917V, TEMPERATURE: 46.96C, CURRENT: 0.936A
              [0.992] (1) RPM: 784, PWR: 0, VOLTAGE: 24.926V, TEMPERATURE: 46.97C, CURRENT: 0.888A
              [1.003] (1) RPM: 784, PWR: 0, VOLTAGE: 24.926V, TEMPERATURE: 46.97C, CURRENT: 0.888A
              [1.012] (1) RPM: 799, PWR: 0, VOLTAGE: 24.931V, TEMPERATURE: 46.96C, CURRENT: 1.128A
              [1.022] (1) RPM: 799, PWR: 0, VOLTAGE: 24.932V, TEMPERATURE: 46.94C, CURRENT: 0.064A
              [1.032] (1) RPM: 993, PWR: 10, VOLTAGE: 24.939V, TEMPERATURE: 46.92C, CURRENT: 0.112A
              [1.042] (1) RPM: 848, PWR: 10, VOLTAGE: 24.939V, TEMPERATURE: 46.92C, CURRENT: 0.088A
              [1.052] (1) RPM: 933, PWR: 10, VOLTAGE: 24.941V, TEMPERATURE: 46.93C, CURRENT: 0.096A
              [1.062] (1) RPM: 949, PWR: 10, VOLTAGE: 24.935V, TEMPERATURE: 46.96C, CURRENT: 0.032A
              [1.072] (1) RPM: 980, PWR: 10, VOLTAGE: 24.932V, TEMPERATURE: 46.96C, CURRENT: 0.032A
              [1.082] (1) RPM: 1144, PWR: 40, VOLTAGE: 24.881V, TEMPERATURE: 47.00C, CURRENT: 6.288A
              [1.092] (1) RPM: 1016, PWR: 40, VOLTAGE: 24.846V, TEMPERATURE: 46.97C, CURRENT: 7.072A
              [1.102] (1) RPM: 1016, PWR: 40, VOLTAGE: 24.846V, TEMPERATURE: 46.97C, CURRENT: 7.072A
              [1.112] (1) RPM: 946, PWR: 40, VOLTAGE: 24.824V, TEMPERATURE: 47.01C, CURRENT: 7.552A
              [1.122] (1) RPM: 911, PWR: 40, VOLTAGE: 24.844V, TEMPERATURE: 47.09C, CURRENT: 7.384A
              [1.132] (1) RPM: 863, PWR: 40, VOLTAGE: 24.823V, TEMPERATURE: 47.10C, CURRENT: 7.032A
              [1.142] (1) RPM: 808, PWR: 40, VOLTAGE: 24.825V, TEMPERATURE: 47.05C, CURRENT: 6.848A
              [1.152] (1) RPM: 741, PWR: 40, VOLTAGE: 24.799V, TEMPERATURE: 47.08C, CURRENT: 6.824A
              [1.162] (1) RPM: 655, PWR: 40, VOLTAGE: 24.811V, TEMPERATURE: 47.21C, CURRENT: 7.344A
              [1.172] (1) RPM: 563, PWR: 40, VOLTAGE: 24.812V, TEMPERATURE: 47.24C, CURRENT: 7.704A
              [1.182] (1) RPM: 449, PWR: 40, VOLTAGE: 24.795V, TEMPERATURE: 47.17C, CURRENT: 7.696A
              [1.192] (1) RPM: 382, PWR: 40, VOLTAGE: 24.774V, TEMPERATURE: 47.13C, CURRENT: 8.416A
              [1.202] (1) RPM: 382, PWR: 40, VOLTAGE: 24.774V, TEMPERATURE: 47.13C, CURRENT: 8.416A
              [1.212] (1) RPM: 398, PWR: 40, VOLTAGE: 24.779V, TEMPERATURE: 47.29C, CURRENT: 8.528A
              [1.222] (1) RPM: 439, PWR: 40, VOLTAGE: 24.768V, TEMPERATURE: 47.29C, CURRENT: 8.480A
              [1.232] (1) RPM: 467, PWR: 40, VOLTAGE: 24.776V, TEMPERATURE: 47.29C, CURRENT: 8.304A
              [1.242] (1) RPM: 484, PWR: 40, VOLTAGE: 24.800V, TEMPERATURE: 47.34C, CURRENT: 9.032A
              [1.252] (1) RPM: 504, PWR: 40, VOLTAGE: 24.793V, TEMPERATURE: 47.36C, CURRENT: 8.576A
              [1.262] (1) RPM: 519, PWR: 40, VOLTAGE: 24.805V, TEMPERATURE: 47.36C, CURRENT: 9.160A
              [1.272] (1) RPM: 548, PWR: 40, VOLTAGE: 24.788V, TEMPERATURE: 47.24C, CURRENT: 8.640A
              [1.282] (1) RPM: 589, PWR: 40, VOLTAGE: 24.804V, TEMPERATURE: 47.28C, CURRENT: 6.840A
              [1.293] (1) RPM: 628, PWR: 40, VOLTAGE: 24.811V, TEMPERATURE: 47.33C, CURRENT: 6.976A
              [1.303] (1) RPM: 628, PWR: 40, VOLTAGE: 24.811V, TEMPERATURE: 47.33C, CURRENT: 6.976A
              [1.312] (1) RPM: 674, PWR: 40, VOLTAGE: 24.788V, TEMPERATURE: 47.24C, CURRENT: 7.192A
              [1.322] (1) RPM: 708, PWR: 40, VOLTAGE: 24.823V, TEMPERATURE: 47.30C, CURRENT: 7.360A
              [1.332] (1) RPM: 742, PWR: 40, VOLTAGE: 24.818V, TEMPERATURE: 47.38C, CURRENT: 6.752A
              [1.342] (1) RPM: 742, PWR: 40, VOLTAGE: 24.797V, TEMPERATURE: 47.45C, CURRENT: 7.304A
              [1.352] (1) RPM: 785, PWR: 40, VOLTAGE: 24.792V, TEMPERATURE: 47.36C, CURRENT: 6.816A
              [1.362] (1) RPM: 802, PWR: 40, VOLTAGE: 24.806V, TEMPERATURE: 47.35C, CURRENT: 6.280A
              [1.372] (1) RPM: 810, PWR: 40, VOLTAGE: 24.823V, TEMPERATURE: 47.32C, CURRENT: 6.424A
              [1.382] (1) RPM: 1110, PWR: 40, VOLTAGE: 24.805V, TEMPERATURE: 47.33C, CURRENT: 5.832A
              [1.393] (1) RPM: 858, PWR: 40, VOLTAGE: 24.823V, TEMPERATURE: 47.33C, CURRENT: 6.808A
              [1.403] (1) RPM: 858, PWR: 40, VOLTAGE: 24.823V, TEMPERATURE: 47.33C, CURRENT: 6.808A
              [1.412] (1) RPM: 899, PWR: 40, VOLTAGE: 24.830V, TEMPERATURE: 47.40C, CURRENT: 6.456A
              [1.422] (1) RPM: 926, PWR: 40, VOLTAGE: 24.813V, TEMPERATURE: 47.39C, CURRENT: 6.008A
              [1.432] (1) RPM: 925, PWR: 40, VOLTAGE: 24.795V, TEMPERATURE: 47.32C, CURRENT: 6.232A
              [1.442] (1) RPM: 969, PWR: 40, VOLTAGE: 24.841V, TEMPERATURE: 47.31C, CURRENT: 6.120A
              [1.452] (1) RPM: 970, PWR: 40, VOLTAGE: 24.812V, TEMPERATURE: 47.37C, CURRENT: 5.704A
              [1.462] (1) RPM: 980, PWR: 40, VOLTAGE: 24.823V, TEMPERATURE: 47.43C, CURRENT: 6.352A
              [1.472] (1) RPM: 1004, PWR: 40, VOLTAGE: 24.830V, TEMPERATURE: 47.36C, CURRENT: 6.392A
              [1.482] (1) RPM: 1003, PWR: 40, VOLTAGE: 24.814V, TEMPERATURE: 47.36C, CURRENT: 6.384A
              [1.493] (1) RPM: 1030, PWR: 40, VOLTAGE: 24.826V, TEMPERATURE: 47.28C, CURRENT: 6.376A
              [1.503] (1) RPM: 1030, PWR: 40, VOLTAGE: 24.826V, TEMPERATURE: 47.28C, CURRENT: 6.376A
              [1.512] (1) RPM: 10024, PWR: 40, VOLTAGE: 24.878V, TEMPERATURE: 47.28C, CURRENT: 1.096A
              [1.522] (1) RPM: 9988, PWR: 40, VOLTAGE: 24.904V, TEMPERATURE: 47.30C, CURRENT: 1.480A
              [1.532] (1) RPM: 9480, PWR: 40, VOLTAGE: 24.909V, TEMPERATURE: 47.32C, CURRENT: 1.824A
              [1.542] (1) RPM: 9350, PWR: 40, VOLTAGE: 24.868V, TEMPERATURE: 47.37C, CURRENT: 1.496A
              [1.552] (1) RPM: 8336, PWR: 40, VOLTAGE: 24.886V, TEMPERATURE: 47.32C, CURRENT: 2.832A
              [1.562] (1) RPM: 3674, PWR: 40, VOLTAGE: 24.857V, TEMPERATURE: 47.40C, CURRENT: 4.008A
              [1.572] (1) RPM: 2932, PWR: 40, VOLTAGE: 24.848V, TEMPERATURE: 47.38C, CURRENT: 4.096A
              [1.582] (1) RPM: 2825, PWR: 40, VOLTAGE: 24.842V, TEMPERATURE: 47.52C, CURRENT: 4.416A
              [1.592] (1) RPM: 2825, PWR: 40, VOLTAGE: 24.842V, TEMPERATURE: 47.52C, CURRENT: 4.416A
              [1.602] (1) RPM: 2734, PWR: 40, VOLTAGE: 24.865V, TEMPERATURE: 47.52C, CURRENT: 5.152A
              [1.612] (1) RPM: 2627, PWR: 40, VOLTAGE: 24.865V, TEMPERATURE: 47.59C, CURRENT: 5.080A
              [1.622] (1) RPM: 2619, PWR: 40, VOLTAGE: 24.853V, TEMPERATURE: 47.52C, CURRENT: 4.560A
              [1.632] (1) RPM: 2586, PWR: 40, VOLTAGE: 24.849V, TEMPERATURE: 47.52C, CURRENT: 4.048A
              [1.642] (1) RPM: 2532, PWR: 40, VOLTAGE: 24.845V, TEMPERATURE: 47.57C, CURRENT: 4.008A
              [1.652] (1) RPM: 2431, PWR: 40, VOLTAGE: 24.812V, TEMPERATURE: 47.55C, CURRENT: 5.528A
              [1.663] (1) RPM: 2411, PWR: 40, VOLTAGE: 24.830V, TEMPERATURE: 47.63C, CURRENT: 4.760A
              [1.672] (1) RPM: 2505, PWR: 40, VOLTAGE: 24.843V, TEMPERATURE: 47.47C, CURRENT: 5.264A
              [1.683] (1) RPM: 2485, PWR: 40, VOLTAGE: 24.827V, TEMPERATURE: 47.53C, CURRENT: 4.856A
              [1.693] (1) RPM: 2485, PWR: 40, VOLTAGE: 24.827V, TEMPERATURE: 47.53C, CURRENT: 4.856A
              [1.702] (1) RPM: 1949, PWR: 40, VOLTAGE: 24.843V, TEMPERATURE: 47.51C, CURRENT: 4.344A
              [1.712] (1) RPM: 2392, PWR: 40, VOLTAGE: 24.828V, TEMPERATURE: 47.63C, CURRENT: 4.640A
              [1.722] (1) RPM: 2457, PWR: 40, VOLTAGE: 24.850V, TEMPERATURE: 47.60C, CURRENT: 5.160A
              [1.732] (1) RPM: 2359, PWR: 40, VOLTAGE: 24.839V, TEMPERATURE: 47.56C, CURRENT: 6.328A
              [1.742] (1) RPM: 1800, PWR: 40, VOLTAGE: 24.821V, TEMPERATURE: 47.55C, CURRENT: 5.336A
              [1.752] (1) RPM: 2452, PWR: 40, VOLTAGE: 24.846V, TEMPERATURE: 47.54C, CURRENT: 4.216A
              [1.762] (1) RPM: 2370, PWR: 40, VOLTAGE: 24.840V, TEMPERATURE: 47.58C, CURRENT: 5.360A
              [1.772] (1) RPM: 2420, PWR: 40, VOLTAGE: 24.861V, TEMPERATURE: 47.59C, CURRENT: 4.320A
              [1.783] (1) RPM: 2365, PWR: 40, VOLTAGE: 24.846V, TEMPERATURE: 47.61C, CURRENT: 4.824A
              [1.793] (1) RPM: 2365, PWR: 40, VOLTAGE: 24.846V, TEMPERATURE: 47.61C, CURRENT: 4.824A
              [1.802] (1) RPM: 2361, PWR: 40, VOLTAGE: 24.837V, TEMPERATURE: 47.63C, CURRENT: 4.472A
              [1.812] (1) RPM: 2338, PWR: 40, VOLTAGE: 24.853V, TEMPERATURE: 47.65C, CURRENT: 4.920A
              [1.822] (1) RPM: 2360, PWR: 40, VOLTAGE: 24.852V, TEMPERATURE: 47.68C, CURRENT: 4.824A
              [1.832] (1) RPM: 2326, PWR: 40, VOLTAGE: 24.829V, TEMPERATURE: 47.73C, CURRENT: 4.696A
              [1.842] (1) RPM: 2276, PWR: 40, VOLTAGE: 24.818V, TEMPERATURE: 47.78C, CURRENT: 4.968A
              [1.852] (1) RPM: 2367, PWR: 40, VOLTAGE: 24.829V, TEMPERATURE: 47.75C, CURRENT: 4.016A
              [1.862] (1) RPM: 2333, PWR: 40, VOLTAGE: 24.864V, TEMPERATURE: 47.74C, CURRENT: 5.440A
              [1.872] (1) RPM: 2284, PWR: 40, VOLTAGE: 24.842V, TEMPERATURE: 47.77C, CURRENT: 5.088A
              [1.882] (1) RPM: 2373, PWR: 40, VOLTAGE: 24.850V, TEMPERATURE: 47.81C, CURRENT: 5.640A
              [1.892] (1) RPM: 2373, PWR: 40, VOLTAGE: 24.850V, TEMPERATURE: 47.81C, CURRENT: 5.640A
              [1.902] (1) RPM: 2299, PWR: 40, VOLTAGE: 24.839V, TEMPERATURE: 47.77C, CURRENT: 5.344A
              [1.912] (1) RPM: 2316, PWR: 40, VOLTAGE: 24.847V, TEMPERATURE: 47.75C, CURRENT: 4.304A
              [1.922] (1) RPM: 2352, PWR: 40, VOLTAGE: 24.847V, TEMPERATURE: 47.79C, CURRENT: 5.160A
              [1.932] (1) RPM: 2271, PWR: 40, VOLTAGE: 24.832V, TEMPERATURE: 47.83C, CURRENT: 4.984A
              [1.942] (1) RPM: 2346, PWR: 40, VOLTAGE: 24.856V, TEMPERATURE: 47.92C, CURRENT: 4.248A
              [1.952] (1) RPM: 2354, PWR: 40, VOLTAGE: 24.833V, TEMPERATURE: 47.94C, CURRENT: 4.904A
              [1.962] (1) RPM: 2262, PWR: 40, VOLTAGE: 24.843V, TEMPERATURE: 47.88C, CURRENT: 5.928A
              [1.972] (1) RPM: 2355, PWR: 40, VOLTAGE: 24.844V, TEMPERATURE: 47.94C, CURRENT: 4.584A
              [1.983] (1) RPM: 2241, PWR: 40, VOLTAGE: 24.820V, TEMPERATURE: 47.89C, CURRENT: 4.936A
              [1.992] (1) RPM: 2241, PWR: 40, VOLTAGE: 24.820V, TEMPERATURE: 47.89C, CURRENT: 4.936A
              [2.002] (1) RPM: 2316, PWR: 40, VOLTAGE: 24.834V, TEMPERATURE: 47.85C, CURRENT: 4.360A
              [2.012] (1) RPM: 2369, PWR: 40, VOLTAGE: 24.878V, TEMPERATURE: 47.86C, CURRENT: 5.240A
              [2.022] (1) RPM: 2254, PWR: 40, VOLTAGE: 24.840V, TEMPERATURE: 47.93C, CURRENT: 5.232A
              [2.032] (1) RPM: 2327, PWR: 40, VOLTAGE: 24.844V, TEMPERATURE: 47.97C, CURRENT: 4.176A
              [2.042] (1) RPM: 2331, PWR: 40, VOLTAGE: 24.835V, TEMPERATURE: 47.97C, CURRENT: 4.464A
              [2.052] (1) RPM: 2270, PWR: 40, VOLTAGE: 24.855V, TEMPERATURE: 47.97C, CURRENT: 4.712A
              [2.062] (1) RPM: 2360, PWR: 40, VOLTAGE: 24.853V, TEMPERATURE: 48.00C, CURRENT: 5.256A
              [2.072] (1) RPM: 2375, PWR: 40, VOLTAGE: 24.839V, TEMPERATURE: 47.98C, CURRENT: 4.512A
              [2.082] (1) RPM: 2274, PWR: 40, VOLTAGE: 24.833V, TEMPERATURE: 47.92C, CURRENT: 5.352A
              [2.093] (1) RPM: 2274, PWR: 40, VOLTAGE: 24.833V, TEMPERATURE: 47.92C, CURRENT: 5.352A
              [2.102] (1) RPM: 2320, PWR: 40, VOLTAGE: 24.816V, TEMPERATURE: 47.98C, CURRENT: 5.000A
              [2.112] (1) RPM: 2318, PWR: 40, VOLTAGE: 24.823V, TEMPERATURE: 48.03C, CURRENT: 4.096A
              [2.122] (1) RPM: 2385, PWR: 40, VOLTAGE: 24.832V, TEMPERATURE: 48.09C, CURRENT: 4.136A
              [2.132] (1) RPM: 2279, PWR: 40, VOLTAGE: 24.852V, TEMPERATURE: 48.11C, CURRENT: 5.520A
              [2.142] (1) RPM: 2315, PWR: 40, VOLTAGE: 24.830V, TEMPERATURE: 48.18C, CURRENT: 4.816A
              [2.152] (1) RPM: 2398, PWR: 40, VOLTAGE: 24.852V, TEMPERATURE: 48.13C, CURRENT: 4.944A
              [2.162] (1) RPM: 2284, PWR: 40, VOLTAGE: 24.823V, TEMPERATURE: 48.11C, CURRENT: 5.312A
              [2.172] (1) RPM: 2302, PWR: 40, VOLTAGE: 24.839V, TEMPERATURE: 48.16C, CURRENT: 5.216A
              [2.183] (1) RPM: 2276, PWR: 40, VOLTAGE: 24.839V, TEMPERATURE: 48.13C, CURRENT: 5.200A
              [2.192] (1) RPM: 2276, PWR: 40, VOLTAGE: 24.839V, TEMPERATURE: 48.13C, CURRENT: 5.200A
              [2.202] (1) RPM: 2328, PWR: 40, VOLTAGE: 24.842V, TEMPERATURE: 48.19C, CURRENT: 4.208A
              [2.212] (1) RPM: 2388, PWR: 40, VOLTAGE: 24.863V, TEMPERATURE: 48.15C, CURRENT: 5.048A
              [2.222] (1) RPM: 2259, PWR: 40, VOLTAGE: 24.806V, TEMPERATURE: 48.16C, CURRENT: 5.048A
              [2.232] (1) RPM: 2328, PWR: 40, VOLTAGE: 24.833V, TEMPERATURE: 48.19C, CURRENT: 4.544A
              [2.242] (1) RPM: 2348, PWR: 40, VOLTAGE: 24.834V, TEMPERATURE: 48.23C, CURRENT: 4.984A
              [2.252] (1) RPM: 2277, PWR: 40, VOLTAGE: 24.830V, TEMPERATURE: 48.21C, CURRENT: 4.984A
              [2.262] (1) RPM: 2332, PWR: 40, VOLTAGE: 24.831V, TEMPERATURE: 48.18C, CURRENT: 5.144A
              [2.272] (1) RPM: 2315, PWR: 40, VOLTAGE: 24.833V, TEMPERATURE: 48.20C, CURRENT: 5.000A
              [2.283] (1) RPM: 2354, PWR: 40, VOLTAGE: 24.838V, TEMPERATURE: 48.23C, CURRENT: 5.448A
              [2.292] (1) RPM: 2354, PWR: 40, VOLTAGE: 24.838V, TEMPERATURE: 48.23C, CURRENT: 5.448A
              [2.302] (1) RPM: 2279, PWR: 40, VOLTAGE: 24.832V, TEMPERATURE: 48.25C, CURRENT: 5.000A
              [2.312] (1) RPM: 2307, PWR: 40, VOLTAGE: 24.831V, TEMPERATURE: 48.33C, CURRENT: 5.096A
              [2.322] (1) RPM: 5555, PWR: 40, VOLTAGE: 24.847V, TEMPERATURE: 48.38C, CURRENT: 3.064A
              [2.332] (1) RPM: 5683, PWR: 40, VOLTAGE: 24.848V, TEMPERATURE: 48.40C, CURRENT: 3.456A
              [2.342] (1) RPM: 2258, PWR: 40, VOLTAGE: 24.841V, TEMPERATURE: 48.44C, CURRENT: 5.168A
              [2.352] (1) RPM: 2254, PWR: 40, VOLTAGE: 24.820V, TEMPERATURE: 48.43C, CURRENT: 4.016A
              [2.362] (1) RPM: 2282, PWR: 40, VOLTAGE: 24.847V, TEMPERATURE: 48.47C, CURRENT: 5.288A
              [2.372] (1) RPM: 2286, PWR: 40, VOLTAGE: 24.826V, TEMPERATURE: 48.44C, CURRENT: 5.368A
              [2.382] (1) RPM: 2203, PWR: 40, VOLTAGE: 24.871V, TEMPERATURE: 48.48C, CURRENT: 4.912A
              [2.392] (1) RPM: 2203, PWR: 40, VOLTAGE: 24.871V, TEMPERATURE: 48.48C, CURRENT: 4.912A
              [2.402] (1) RPM: 2179, PWR: 40, VOLTAGE: 24.835V, TEMPERATURE: 48.53C, CURRENT: 5.352A
              [2.412] (1) RPM: 2267, PWR: 40, VOLTAGE: 24.834V, TEMPERATURE: 48.54C, CURRENT: 4.256A
              [2.422] (1) RPM: 2353, PWR: 40, VOLTAGE: 24.833V, TEMPERATURE: 48.51C, CURRENT: 4.728A
              [2.432] (1) RPM: 2308, PWR: 40, VOLTAGE: 24.834V, TEMPERATURE: 48.53C, CURRENT: 4.592A
              [2.443] (1) RPM: 2206, PWR: 40, VOLTAGE: 24.829V, TEMPERATURE: 48.54C, CURRENT: 4.744A
              [2.452] (1) RPM: 2302, PWR: 40, VOLTAGE: 24.823V, TEMPERATURE: 48.57C, CURRENT: 4.256A
              [2.462] (1) RPM: 2349, PWR: 40, VOLTAGE: 24.831V, TEMPERATURE: 48.62C, CURRENT: 5.248A
              [2.472] (1) RPM: 2297, PWR: 40, VOLTAGE: 24.843V, TEMPERATURE: 48.60C, CURRENT: 5.008A
              [2.482] (1) RPM: 2368, PWR: 40, VOLTAGE: 24.827V, TEMPERATURE: 48.58C, CURRENT: 4.328A
              [2.493] (1) RPM: 2368, PWR: 40, VOLTAGE: 24.827V, TEMPERATURE: 48.58C, CURRENT: 4.328A
              [2.502] (1) RPM: 2734, PWR: 40, VOLTAGE: 24.846V, TEMPERATURE: 48.63C, CURRENT: 5.496A
              [2.512] (1) RPM: 2251, PWR: 40, VOLTAGE: 24.813V, TEMPERATURE: 48.62C, CURRENT: 4.440A
              [2.522] (1) RPM: 2268, PWR: 40, VOLTAGE: 24.813V, TEMPERATURE: 48.59C, CURRENT: 4.640A
              [2.532] (1) RPM: 2235, PWR: 40, VOLTAGE: 24.845V, TEMPERATURE: 48.56C, CURRENT: 4.376A
              [2.542] (1) RPM: 2224, PWR: 40, VOLTAGE: 24.839V, TEMPERATURE: 48.56C, CURRENT: 4.960A
              [2.552] (1) RPM: 2187, PWR: 40, VOLTAGE: 24.796V, TEMPERATURE: 48.65C, CURRENT: 6.192A
              [2.562] (1) RPM: 2275, PWR: 40, VOLTAGE: 24.828V, TEMPERATURE: 48.75C, CURRENT: 4.008A
              [2.572] (1) RPM: 2318, PWR: 40, VOLTAGE: 24.820V, TEMPERATURE: 48.76C, CURRENT: 4.240A
              [2.583] (1) RPM: 2323, PWR: 40, VOLTAGE: 24.836V, TEMPERATURE: 48.75C, CURRENT: 4.600A
              [2.593] (1) RPM: 2323, PWR: 40, VOLTAGE: 24.836V, TEMPERATURE: 48.75C, CURRENT: 4.600A
              [2.602] (1) RPM: 2375, PWR: 40, VOLTAGE: 24.834V, TEMPERATURE: 48.82C, CURRENT: 5.176A
              [2.612] (1) RPM: 2367, PWR: 40, VOLTAGE: 24.866V, TEMPERATURE: 48.79C, CURRENT: 4.864A
              [2.622] (1) RPM: 2278, PWR: 40, VOLTAGE: 24.834V, TEMPERATURE: 48.83C, CURRENT: 4.376A
              [2.632] (1) RPM: 2369, PWR: 40, VOLTAGE: 24.837V, TEMPERATURE: 48.80C, CURRENT: 4.312A
              [2.642] (1) RPM: 2292, PWR: 40, VOLTAGE: 24.835V, TEMPERATURE: 48.94C, CURRENT: 5.296A
              [2.652] (1) RPM: 2318, PWR: 40, VOLTAGE: 24.815V, TEMPERATURE: 48.92C, CURRENT: 4.992A
              [2.662] (1) RPM: 2388, PWR: 40, VOLTAGE: 24.844V, TEMPERATURE: 48.96C, CURRENT: 4.488A
              [2.672] (1) RPM: 2276, PWR: 40, VOLTAGE: 24.834V, TEMPERATURE: 48.92C, CURRENT: 4.672A
              [2.682] (1) RPM: 2399, PWR: 40, VOLTAGE: 24.824V, TEMPERATURE: 48.91C, CURRENT: 3.904A
              [2.693] (1) RPM: 2341, PWR: 40, VOLTAGE: 24.831V, TEMPERATURE: 48.89C, CURRENT: 3.880A
              [2.703] (1) RPM: 2341, PWR: 40, VOLTAGE: 24.831V, TEMPERATURE: 48.89C, CURRENT: 3.880A
              [2.712] (1) RPM: 2322, PWR: 40, VOLTAGE: 24.829V, TEMPERATURE: 49.01C, CURRENT: 4.560A
              [2.722] (1) RPM: 2255, PWR: 40, VOLTAGE: 24.810V, TEMPERATURE: 49.03C, CURRENT: 5.424A
              [2.732] (1) RPM: 2299, PWR: 40, VOLTAGE: 24.828V, TEMPERATURE: 49.07C, CURRENT: 5.160A
              [2.742] (1) RPM: 2401, PWR: 40, VOLTAGE: 24.827V, TEMPERATURE: 49.02C, CURRENT: 5.952A
              [2.752] (1) RPM: 2311, PWR: 40, VOLTAGE: 24.832V, TEMPERATURE: 49.00C, CURRENT: 5.176A
              [2.762] (1) RPM: 2343, PWR: 40, VOLTAGE: 24.859V, TEMPERATURE: 49.06C, CURRENT: 4.632A
              [2.772] (1) RPM: 2409, PWR: 40, VOLTAGE: 24.841V, TEMPERATURE: 49.07C, CURRENT: 5.408A
              [2.782] (1) RPM: 2265, PWR: 40, VOLTAGE: 24.819V, TEMPERATURE: 48.99C, CURRENT: 4.896A
              [2.792] (1) RPM: 2265, PWR: 40, VOLTAGE: 24.819V, TEMPERATURE: 48.99C, CURRENT: 4.896A
              [2.804] (1) RPM: 2296, PWR: 40, VOLTAGE: 24.830V, TEMPERATURE: 49.09C, CURRENT: 4.616A
              [2.812] (1) RPM: 2274, PWR: 40, VOLTAGE: 24.806V, TEMPERATURE: 49.21C, CURRENT: 4.464A
              [2.822] (1) RPM: 2376, PWR: 40, VOLTAGE: 24.819V, TEMPERATURE: 49.24C, CURRENT: 3.952A
              [2.832] (1) RPM: 2269, PWR: 40, VOLTAGE: 24.824V, TEMPERATURE: 49.24C, CURRENT: 4.376A
              [2.842] (1) RPM: 2337, PWR: 40, VOLTAGE: 24.827V, TEMPERATURE: 49.23C, CURRENT: 3.944A
              [2.852] (1) RPM: 2392, PWR: 40, VOLTAGE: 24.846V, TEMPERATURE: 49.16C, CURRENT: 4.016A
              [2.862] (1) RPM: 2253, PWR: 40, VOLTAGE: 24.832V, TEMPERATURE: 49.12C, CURRENT: 4.880A
              [2.872] (1) RPM: 2383, PWR: 40, VOLTAGE: 24.844V, TEMPERATURE: 49.17C, CURRENT: 4.488A
              [2.882] (1) RPM: 2265, PWR: 40, VOLTAGE: 24.826V, TEMPERATURE: 49.20C, CURRENT: 4.824A
              [2.893] (1) RPM: 2265, PWR: 40, VOLTAGE: 24.826V, TEMPERATURE: 49.20C, CURRENT: 4.824A
              [2.902] (1) RPM: 2400, PWR: 40, VOLTAGE: 24.841V, TEMPERATURE: 49.27C, CURRENT: 4.264A
              [2.912] (1) RPM: 2325, PWR: 40, VOLTAGE: 24.836V, TEMPERATURE: 49.28C, CURRENT: 5.072A
              [2.922] (1) RPM: 2352, PWR: 40, VOLTAGE: 24.810V, TEMPERATURE: 49.31C, CURRENT: 3.928A
              [2.932] (1) RPM: 2393, PWR: 40, VOLTAGE: 24.838V, TEMPERATURE: 49.35C, CURRENT: 4.328A
              [2.942] (1) RPM: 2289, PWR: 40, VOLTAGE: 24.822V, TEMPERATURE: 49.40C, CURRENT: 4.432A
              [2.952] (1) RPM: 2345, PWR: 40, VOLTAGE: 24.832V, TEMPERATURE: 49.43C, CURRENT: 3.824A
              [2.962] (1) RPM: 2346, PWR: 40, VOLTAGE: 24.858V, TEMPERATURE: 49.43C, CURRENT: 3.944A
              [2.972] (1) RPM: 2259, PWR: 40, VOLTAGE: 24.833V, TEMPERATURE: 49.39C, CURRENT: 4.800A
              [2.983] (1) RPM: 2262, PWR: 40, VOLTAGE: 24.828V, TEMPERATURE: 49.49C, CURRENT: 4.328A
              [2.993] (1) RPM: 2262, PWR: 40, VOLTAGE: 24.828V, TEMPERATURE: 49.49C, CURRENT: 4.328A
              [3.002] (1) RPM: 2314, PWR: 40, VOLTAGE: 24.805V, TEMPERATURE: 49.49C, CURRENT: 4.456A
              [3.013] (1) RPM: 2325, PWR: 40, VOLTAGE: 24.822V, TEMPERATURE: 49.51C, CURRENT: 4.176A
              [3.022] (1) RPM: 2295, PWR: 40, VOLTAGE: 24.828V, TEMPERATURE: 49.52C, CURRENT: 5.632A
              [3.032] (1) RPM: 2343, PWR: 40, VOLTAGE: 24.829V, TEMPERATURE: 49.49C, CURRENT: 4.016A
              [3.042] (1) RPM: 2303, PWR: 40, VOLTAGE: 24.830V, TEMPERATURE: 49.49C, CURRENT: 5.184A
              [3.052] (1) RPM: 2287, PWR: 40, VOLTAGE: 24.826V, TEMPERATURE: 49.48C, CURRENT: 4.776A
              [3.062] (1) RPM: 5707, PWR: 40, VOLTAGE: 24.841V, TEMPERATURE: 49.49C, CURRENT: 3.056A
              [3.072] (1) RPM: 5671, PWR: 40, VOLTAGE: 24.847V, TEMPERATURE: 49.54C, CURRENT: 2.984A
              [3.082] (1) RPM: 2334, PWR: 40, VOLTAGE: 24.829V, TEMPERATURE: 49.49C, CURRENT: 4.792A
              [3.092] (1) RPM: 2334, PWR: 40, VOLTAGE: 24.829V, TEMPERATURE: 49.49C, CURRENT: 4.792A
              [3.102] (1) RPM: 2230, PWR: 40, VOLTAGE: 24.821V, TEMPERATURE: 49.55C, CURRENT: 4.880A
              [3.112] (1) RPM: 2282, PWR: 40, VOLTAGE: 24.823V, TEMPERATURE: 49.62C, CURRENT: 4.608A
              [3.122] (1) RPM: 2297, PWR: 40, VOLTAGE: 24.837V, TEMPERATURE: 49.58C, CURRENT: 5.192A
              [3.132] (1) RPM: 2213, PWR: 40, VOLTAGE: 24.814V, TEMPERATURE: 49.64C, CURRENT: 5.616A
              [3.142] (1) RPM: 2203, PWR: 40, VOLTAGE: 24.830V, TEMPERATURE: 49.56C, CURRENT: 5.056A
              [3.152] (1) RPM: 2228, PWR: 40, VOLTAGE: 24.815V, TEMPERATURE: 49.63C, CURRENT: 3.672A
              [3.162] (1) RPM: 2338, PWR: 40, VOLTAGE: 24.815V, TEMPERATURE: 49.58C, CURRENT: 4.312A
              [3.172] (1) RPM: 2361, PWR: 40, VOLTAGE: 24.843V, TEMPERATURE: 49.61C, CURRENT: 5.288A
              [3.182] (1) RPM: 2294, PWR: 40, VOLTAGE: 24.829V, TEMPERATURE: 49.68C, CURRENT: 5.320A
              [3.192] (1) RPM: 2294, PWR: 40, VOLTAGE: 24.829V, TEMPERATURE: 49.68C, CURRENT: 5.320A
              [3.202] (1) RPM: 2310, PWR: 40, VOLTAGE: 24.821V, TEMPERATURE: 49.73C, CURRENT: 4.792A
              [3.212] (1) RPM: 2279, PWR: 40, VOLTAGE: 24.823V, TEMPERATURE: 49.74C, CURRENT: 4.432A
              [3.222] (1) RPM: 2418, PWR: 40, VOLTAGE: 24.830V, TEMPERATURE: 49.74C, CURRENT: 4.600A
              [3.232] (1) RPM: 2275, PWR: 40, VOLTAGE: 24.815V, TEMPERATURE: 49.86C, CURRENT: 4.640A
              [3.242] (1) RPM: 2356, PWR: 40, VOLTAGE: 24.830V, TEMPERATURE: 49.83C, CURRENT: 4.224A
              [3.252] (1) RPM: 2325, PWR: 40, VOLTAGE: 24.831V, TEMPERATURE: 49.82C, CURRENT: 4.280A
              [3.262] (1) RPM: 2300, PWR: 40, VOLTAGE: 24.823V, TEMPERATURE: 49.78C, CURRENT: 4.496A
              [3.272] (1) RPM: 2418, PWR: 40, VOLTAGE: 24.817V, TEMPERATURE: 49.80C, CURRENT: 5.352A
              [3.282] (1) RPM: 2370, PWR: 40, VOLTAGE: 24.828V, TEMPERATURE: 49.94C, CURRENT: 4.088A
              [3.293] (1) RPM: 2370, PWR: 40, VOLTAGE: 24.828V, TEMPERATURE: 49.94C, CURRENT: 4.088A
              [3.302] (1) RPM: 2316, PWR: 40, VOLTAGE: 24.828V, TEMPERATURE: 49.87C, CURRENT: 4.072A
              [3.312] (1) RPM: 2344, PWR: 40, VOLTAGE: 24.839V, TEMPERATURE: 49.86C, CURRENT: 4.424A
              [3.322] (1) RPM: 2428, PWR: 40, VOLTAGE: 24.824V, TEMPERATURE: 49.89C, CURRENT: 4.872A
              [3.332] (1) RPM: 2271, PWR: 40, VOLTAGE: 24.847V, TEMPERATURE: 49.91C, CURRENT: 4.408A
              [3.342] (1) RPM: 2391, PWR: 40, VOLTAGE: 24.828V, TEMPERATURE: 50.00C, CURRENT: 4.392A
              [3.352] (1) RPM: 2283, PWR: 40, VOLTAGE: 24.829V, TEMPERATURE: 49.93C, CURRENT: 5.312A
              [3.362] (1) RPM: 2343, PWR: 40, VOLTAGE: 24.833V, TEMPERATURE: 50.05C, CURRENT: 4.128A
              [3.372] (1) RPM: 2295, PWR: 40, VOLTAGE: 24.820V, TEMPERATURE: 50.06C, CURRENT: 4.304A
              [3.383] (1) RPM: 2382, PWR: 40, VOLTAGE: 24.828V, TEMPERATURE: 50.03C, CURRENT: 4.128A
              [3.392] (1) RPM: 2382, PWR: 40, VOLTAGE: 24.828V, TEMPERATURE: 50.03C, CURRENT: 4.128A
              [3.402] (1) RPM: 2280, PWR: 40, VOLTAGE: 24.834V, TEMPERATURE: 49.98C, CURRENT: 4.080A
              [3.412] (1) RPM: 2393, PWR: 40, VOLTAGE: 24.822V, TEMPERATURE: 49.97C, CURRENT: 4.432A
              [3.422] (1) RPM: 2318, PWR: 40, VOLTAGE: 24.831V, TEMPERATURE: 50.00C, CURRENT: 5.880A
              [3.432] (1) RPM: 2337, PWR: 40, VOLTAGE: 24.839V, TEMPERATURE: 50.04C, CURRENT: 4.000A
              [3.442] (1) RPM: 2371, PWR: 40, VOLTAGE: 24.816V, TEMPERATURE: 50.11C, CURRENT: 4.560A
              [3.452] (1) RPM: 2323, PWR: 40, VOLTAGE: 24.835V, TEMPERATURE: 50.15C, CURRENT: 4.992A
              [3.462] (1) RPM: 2356, PWR: 40, VOLTAGE: 24.846V, TEMPERATURE: 50.05C, CURRENT: 4.456A
              [3.472] (1) RPM: 2286, PWR: 40, VOLTAGE: 24.837V, TEMPERATURE: 50.06C, CURRENT: 5.256A
              [3.482] (1) RPM: 2420, PWR: 40, VOLTAGE: 24.856V, TEMPERATURE: 50.08C, CURRENT: 5.208A
              [3.492] (1) RPM: 2420, PWR: 40, VOLTAGE: 24.856V, TEMPERATURE: 50.08C, CURRENT: 5.208A
              Finished!
              [1705518380.137016] TX=358, RX=356 packets, RX CRC ERRORS=0
              Average RPMs: 0.00 2378.00 0.00 0.00
              Average RPM deviation between ESCs : 2378.00
              False
              WARNING: In order to plot the results, install the Python "plotly" module: pip3 install plotly --upgrade
              • Alex KushleyevA Offline
                Yes, potentially. You should follow the steps to update your firmware and params specifically for low kv motors as I suggested and documented
                  Matthew Wellner
                  Just to confirm - I updated the params file (mn4006 low kv) according to the instructions and I am on this ESC firmware: version 39, hash d4fe8e3d. The firmware you list is 39 RC11, is the firmware I'm running good, or do I need to use the RC11 version? Everything else is the same as in your instructions.
                  Matthew WellnerM Alex KushleyevA 2 Replies Last reply
                    Matthew Wellner
                    @Alex-Kushleyev - Nevermind. I see you checked it in 2 days ago. I am updating the firmware now. Sorry!!
                      @Matthew-Wellner you need the firmware modalai_esc_firmware_m0134_6_v0_39_RC11_17d64675.bin - there is an update specifically to address the de-sync issue. as well as the params i mentioned, most importantly timing_advance, sense_advance and demag_timing
                        also please review params that i used for a similar motor : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/dev/voxl-esc-params/low_kv/mn4006_m0134_6_low_kv.xml
                          Matthew Wellner
                          The firmware update worked! Sorry again for not paying better attention 🤦
                            Matthew Wellner
                            @Matthew-Wellner said in Can you power VOXL2 from the ModalAI 6s ESC?:
                            Ugh - I spoke too soon... 50%+ is still having issues, but I am going to re-run through everything again to make sure I didn't miss anything else.
                            Thanks again!
                              @Matthew-Wellner - good! not de-syncing now? Are you looking at the plots that are being saved after the test? visual inspection of the data is always good, once you look at a few plots and become familiar with what to expect you can easily spot if there are any issues.
                              By the way, the test you are doing by commanding --power 40 etc, will essentially step from initial power of around 10 to 40. This is fine. I have been doing my step testing starting at 20%, which is a more realistic condition (stop from 20 to 50, 20 to 70, 20 to 90, 20 to 100 -- gradually increasing to build confidence). Stepping from 10 should be ok, but will experience even more aggressive transition.. let me know if you run into any issues with that.
                              If you did not actually want an instant step when you are using voxl-esc-spin.py command, you can provide --ramp-time 2.0 argument (which will gradually ramp up)
                                can you try the ramp test
                                https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/dev/voxl-esc-tools/doc/low_kv_motor_tuning.md?ref_type=heads#power-ramp-test
                                and the step tests
                                https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/dev/voxl-esc-tools/doc/low_kv_motor_tuning.md?ref_type=heads#power-step-tests
                                Alex KushleyevA Matthew WellnerM 3 Replies Last reply
                                  and the step tests
                                  i think the issue may be happening because you are punching a lot of power right after spin-up.
                                  You can try increasing the following parameter to make sure the motor is fully spun up :
                                  https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/dev/voxl-esc-params/low_kv/mn4006_m0134_6_low_kv.xml?ref_type=heads#L77 increase to 500
                                  I may need to add some protection against applying high power from very low rpm, as it is a really tough case
                                    and the step tests
                                    Matthew Wellner
                                    I was trying to avoid those tests before I had a proper setup to clamp the drone down, but I'll work on getting that together now and I'll give the ramp test a try.
                                      @Matthew-Wellner , yes.. safety first!
                                        #44
                                        I tried your test on my set up (mn4006 380kv, 15" prop), i cannot reproduce the issue. Please make sure that the following params are set correctly:
                                        <param name="timing_advance"        value="60"/>
                                        <param name="sense_advance"         value="20"/>
                                        <param name="demag_timing"          value="1"/>
                                        If i set timing advance to something much lower, i can reproduce an issue, the motor makes a high pitch sound.
                                        Also please check the spin-up params. you could increase the spin-up rpm target to make sure the motor spins a bit faster after spin-up.
                                        Here is a plot of the following test (don't run at such high power until you make sure the lower power works fine 🙂 :
                                        ./voxl-esc-spin.py --id 3 --power 100 --timeout 1.5 --enable-plot 1
                                        You can see three phases of the motor spin-up
                                        • smooth sinusoidal spinup (t=0..1s)
                                        • short transition to 6-step commutation control (t=1.0..1.05s)
                                        • apply desired power with a slight slew rate limit (rate limit happens internally to firmware). Motor accelerates to maximum RPM. t=1.05.. 1.5s
                                          Matthew Wellner
                                          The ramp tests seems to have worked. I think that I was jumping the power up too quickly like you suggested. I'll get into trying to calibrate now. Thanks!!
