Can anyone recommend a Tflite Colab Notebook for VOXL2 Training
UPDATE: Got it working with "sudo" for the install. normally one would get a permission errors and thought maybe that was the issue and sure enough. recommend updating your docs to
say sudo ./install.sh -
@tom so i trained on a new batch of AR15 images and got really good numbers in terms of losses and mAPs. Ran an unquantized and quantized version in voxl-tflite-server and again nothing is being recognized.
Here's a link to the tflites, and saved_models with inference results on never before seen images.
Any insight on how to make these models work in your environment would be awesomely appreciated.https://drive.google.com/drive/folders/1N1pU0jMRTb3rODSfIuETPrBf66m4ody7?usp=drive_link
@sansoy Interesting, sudo isn't normally required. I'm curious, what linux distro are you running?
@sansoy Huh, okay, that's what I run as well.
What groups are your default user in? For example, here is mine:
~ groups ok | 10:20:36 AM tom adm dialout cdrom sudo dip plugdev lpadmin lxd sambashare docker -
@sansoy Can you try adding your user to the dialout group and seeing if that fixes the issue?
sudo usermod -a -G dialout $USER -
When I get some time today I'll try to download your .tflite models and see what's going on. The good news is that the server is at least running! It very well may just be an issue with how the tensor is being parsed.
Thomas
thomas.patton@modalai.com -
Thomas
thomas.patton@modalai.comHey, they just gave me access to the Google Drive folder. Can you confirm that the
edgetpu.tflitein the root directory is the file you want me to try and get working?Thomas
@thomas i just checked permissions and you have access to all the files and yes to
edgetpu.tflit
ssd-mobilenet-v2-fpnlite-640_quant.tflite
ssd-mobilenet-v2-fpnlite-640.tflite
saved_models/saved_model.pb -
edgetpu.tflit
saved_models/saved_model.pbOf these 4 models which is the custom trained YOLO model you mentioned above? I can't even get the
edgetpu.tflitemodel to load so I need a little bit more information on how each of these files was generated.Thomas
@thomas here's a yolov5 trained model.
https://drive.google.com/file/d/1wRbIXdylgx-EOGDLnuWnsytGd2DcTNeY/view?usp=drive_linkI used this instruction set to train a yolov5 model which works well on my mac, rPI4, linux box and nvidia jetson.
https://docs.ultralytics.com/yolov5/tutorials/train_custom_data/#23-organize-directories -
https://docs.ultralytics.com/yolov5/tutorials/train_custom_data/#23-organize-directories@thomas here's the colab notebook i used to create the tflites and quantized tflites
https://colab.research.google.com/drive/1QdgpSl63OSQdLTnFwOyP8dxLQ7W0HtmW?usp=sharing -
https://colab.research.google.com/drive/1QdgpSl63OSQdLTnFwOyP8dxLQ7W0HtmW?usp=sharingI found the bug in our code that's causing the issue. You can see on this line that a for YOLO models a former employee hardcoded the number of classes to be 80 leading to a segfault when we only have a single class like in your case. Here's what your model looks like on our server with the fix:
What I'm going to do is write a patch for
voxl-tflite-serverthat more intelligently reads the number from the labels file. This will be available in our SDK Nightlies and so you'll be able to use the fix tomorrow morning. If you'd like the fix sooner, what I can do is package the new voxl-tflite-server into a .deb so you can deploy it manually to your VOXL. I can help you out with this process if you're not familiar.Thanks,
Thomas Patton
Thomas Patton
thomas.patton@modalai.com@thomas
https://gitlab.com/voxl-public/voxl-sdk/services/voxl-tflite-server/-/merge_requests/22
Here's the merge request with the fix, this will be published both in tonight's nightly and new SDK releases.
Thomas
Thomas Patton
thomas.patton@modalai.com@thomas you rock! awesome! thanks for troubleshooting.
@thomas
Thomas
@thomas thanks thomas. will download tomorrow and test either in evening or next day. Really appreciate your help with this.
Great job! Sabri -
Great job! SabriYeah of course, glad I could be of assistance! Be sure to let me know if you need any more help with this.
Two things I was thinking about on my drive home that you should know - First, when you're on that page I linked above for the software nightlies make sure you sort the files by date descending so that you get the most recent one. I always make the mistake of getting the wrong one. Secondly, when you flash that nightly SDK it will overwrite anything not in the
/data/directory and so you will need to put your model file and labels txt back into/usr/bin/dnn/.Thomas
@thomas Morning Thomas, just getting back to this. I couldnt find any SDK that had a 2024 stamp. Was this uploaded somewhere else?
Sabri
