  3. Can anyone recommend a Tflite Colab Notebook for VOXL2 Training
53 Posts 4 Posters 32.2k Views 4 Watching
    @sansoy As long as you are using the voxl2 SDK and are indeed flashing voxl2 hardware then that warning can be ignored.
    S Offline
    S Offline
    sansoy
    @tom hey Tom, i'm having absolutely no luck.
    i've tried 3 times and it still just hangs at
    Would you like to continue with the VOXL2 (m0054) system image flash?
    1. Yes
    2. No
      #? 1
    I then followed the unbrick instructions and reinstalled everything per
    https://docs.modalai.com/voxl2-unbricking/#ubuntu-host
    Got the system back up and running and tried to install the latest SDK again with no luck.
    It just hangs.
    S 1 Reply Last reply
    • S sansoy
      1. Yes
      2. No
        #? 1
      It just hangs.
      S Offline
      S Offline
      sansoy
      wrote on last edited by sansoy
      #13
      UPDATE: Got it working with "sudo" for the install. normally one would get a permission errors and thought maybe that was the issue and sure enough. recommend updating your docs to
      say sudo ./install.sh
      S tomT 2 Replies Last reply
      • S sansoy
        S Offline
        S Offline
        sansoy
        @tom so i trained on a new batch of AR15 images and got really good numbers in terms of losses and mAPs. Ran an unquantized and quantized version in voxl-tflite-server and again nothing is being recognized.
        Here's a link to the tflites, and saved_models with inference results on never before seen images.
        Any insight on how to make these models work in your environment would be awesomely appreciated.
        https://drive.google.com/drive/folders/1N1pU0jMRTb3rODSfIuETPrBf66m4ody7?usp=drive_link
        • S sansoy
          @sansoy Interesting, sudo isn't normally required. I'm curious, what linux distro are you running?
          • S sansoy
            @sansoy @Thomas-Patton is the ML expert here and I'll let him comment on that front
              S Offline
              S Offline
              sansoy
              @tom Ubuntu 22.04.3 LTS
              • S sansoy
                @sansoy Huh, okay, that's what I run as well.
                What groups are your default user in? For example, here is mine:
                 ~  groups                                               ok | 10:20:36 AM
                tom adm dialout cdrom sudo dip plugdev lpadmin lxd sambashare docker
                  S Offline
                  S Offline
                  sansoy
                  @tom eve@eve:~$ groups
                  eve adm cdrom sudo dip plugdev lpadmin lxd sambashare
                  • S sansoy
                    @sansoy Can you try adding your user to the dialout group and seeing if that fixes the issue?
                    sudo usermod -a -G dialout $USER
                      S Offline
                      S Offline
                      sansoy
                      @tom did that and still no inference.
                      • S sansoy
                        @sansoy That was for fixing the fastboot issue, unrelated
                        ? 1 Reply Last reply
                          @sansoy
                          When I get some time today I'll try to download your .tflite models and see what's going on. The good news is that the server is at least running! It very well may just be an issue with how the tensor is being parsed.
                          Thomas
                          thomas.patton@modalai.com
                          • ? A Former User
                            @sansoy
                            Thomas
                            @sansoy
                            Hey, they just gave me access to the Google Drive folder. Can you confirm that the edgetpu.tflite in the root directory is the file you want me to try and get working?
                            Thomas
                            • ? A Former User
                              @sansoy
                              Thomas
                              S Offline
                              S Offline
                              sansoy
                              @thomas i just checked permissions and you have access to all the files and yes to
                              edgetpu.tflit
                              ssd-mobilenet-v2-fpnlite-640_quant.tflite
                              ssd-mobilenet-v2-fpnlite-640.tflite
                              saved_models/saved_model.pb
                              • S sansoy
                                edgetpu.tflit
                                @sansoy
                                Of these 4 models which is the custom trained YOLO model you mentioned above? I can't even get the edgetpu.tflite model to load so I need a little bit more information on how each of these files was generated.
                                Thomas
                                • ? A Former User
                                  @sansoy
                                  Thomas
                                  S Offline
                                  S Offline
                                  sansoy
                                  @thomas here's a yolov5 trained model.
                                  https://drive.google.com/file/d/1wRbIXdylgx-EOGDLnuWnsytGd2DcTNeY/view?usp=drive_link
                                  I used this instruction set to train a yolov5 model which works well on my mac, rPI4, linux box and nvidia jetson.
                                  https://docs.ultralytics.com/yolov5/tutorials/train_custom_data/#23-organize-directories
                                  • S sansoy
                                    S Offline
                                    S Offline
                                    sansoy
                                    @thomas here's the colab notebook i used to create the tflites and quantized tflites
                                    https://colab.research.google.com/drive/1QdgpSl63OSQdLTnFwOyP8dxLQ7W0HtmW?usp=sharing
                                    • S sansoy
                                      @sansoy
                                      I found the bug in our code that's causing the issue. You can see on this line that a for YOLO models a former employee hardcoded the number of classes to be 80 leading to a segfault when we only have a single class like in your case. Here's what your model looks like on our server with the fix:
                                      What I'm going to do is write a patch for voxl-tflite-server that more intelligently reads the number from the labels file. This will be available in our SDK Nightlies and so you'll be able to use the fix tomorrow morning. If you'd like the fix sooner, what I can do is package the new voxl-tflite-server into a .deb so you can deploy it manually to your VOXL. I can help you out with this process if you're not familiar.
                                      Thomas Patton
                                      ? S 2 Replies Last reply
                                      • ? A Former User
                                        @sansoy
                                        Thomas Patton
                                        @thomas
                                        https://gitlab.com/voxl-public/voxl-sdk/services/voxl-tflite-server/-/merge_requests/22
                                        Here's the merge request with the fix, this will be published both in tonight's nightly and new SDK releases.
                                        Thomas
                                        • ? A Former User
                                          @sansoy
                                          Thomas Patton
                                          S Offline
                                          S Offline
                                          sansoy
                                          @thomas you rock! awesome! thanks for troubleshooting.
