  3. Can anyone recommend a Tflite Colab Notebook for VOXL2 Training
53 Posts 4 Posters 31.0k Views 4 Watching
  • S sansoy
    @tom Ubuntu 22.04.3 LTS
    @sansoy Huh, okay, that's what I run as well.
    What groups are your default user in? For example, here is mine:
     ~  groups                                               ok | 10:20:36 AM
    tom adm dialout cdrom sudo dip plugdev lpadmin lxd sambashare docker
    S 1 Reply Last reply
      S Offline
      S Offline
      sansoy
      @tom eve@eve:~$ groups
      eve adm cdrom sudo dip plugdev lpadmin lxd sambashare
      • S sansoy
        @sansoy Can you try adding your user to the dialout group and seeing if that fixes the issue?
        sudo usermod -a -G dialout $USER
          S Offline
          S Offline
          sansoy
          @tom did that and still no inference.
          • S sansoy
            @sansoy That was for fixing the fastboot issue, unrelated
            ? 1 Reply Last reply
              @sansoy
              When I get some time today I'll try to download your .tflite models and see what's going on. The good news is that the server is at least running! It very well may just be an issue with how the tensor is being parsed.
              Thomas
              thomas.patton@modalai.com
              • ? A Former User
                @sansoy
                Thomas
                @sansoy
                Hey, they just gave me access to the Google Drive folder. Can you confirm that the edgetpu.tflite in the root directory is the file you want me to try and get working?
                Thomas
                • ? A Former User
                  @sansoy
                  Thomas
                  S Offline
                  S Offline
                  sansoy
                  @thomas i just checked permissions and you have access to all the files and yes to
                  edgetpu.tflit
                  ssd-mobilenet-v2-fpnlite-640_quant.tflite
                  ssd-mobilenet-v2-fpnlite-640.tflite
                  saved_models/saved_model.pb
                  • S sansoy
                    edgetpu.tflit
                    @sansoy
                    Of these 4 models which is the custom trained YOLO model you mentioned above? I can't even get the edgetpu.tflite model to load so I need a little bit more information on how each of these files was generated.
                    Thomas
                    • ? A Former User
                      @sansoy
                      Thomas
                      S Offline
                      S Offline
                      sansoy
                      @thomas here's a yolov5 trained model.
                      https://drive.google.com/file/d/1wRbIXdylgx-EOGDLnuWnsytGd2DcTNeY/view?usp=drive_link
                      I used this instruction set to train a yolov5 model which works well on my mac, rPI4, linux box and nvidia jetson.
                      https://docs.ultralytics.com/yolov5/tutorials/train_custom_data/#23-organize-directories
                      • S sansoy
                        S Offline
                        S Offline
                        sansoy
                        @thomas here's the colab notebook i used to create the tflites and quantized tflites
                        https://colab.research.google.com/drive/1QdgpSl63OSQdLTnFwOyP8dxLQ7W0HtmW?usp=sharing
                        • S sansoy
                          @sansoy
                          I found the bug in our code that's causing the issue. You can see on this line that a for YOLO models a former employee hardcoded the number of classes to be 80 leading to a segfault when we only have a single class like in your case. Here's what your model looks like on our server with the fix:
                          What I'm going to do is write a patch for voxl-tflite-server that more intelligently reads the number from the labels file. This will be available in our SDK Nightlies and so you'll be able to use the fix tomorrow morning. If you'd like the fix sooner, what I can do is package the new voxl-tflite-server into a .deb so you can deploy it manually to your VOXL. I can help you out with this process if you're not familiar.
                          Thomas Patton
                          ? S 2 Replies Last reply
                          • ? A Former User
                            @sansoy
                            Thomas Patton
                            @thomas
                            https://gitlab.com/voxl-public/voxl-sdk/services/voxl-tflite-server/-/merge_requests/22
                            Here's the merge request with the fix, this will be published both in tonight's nightly and new SDK releases.
                            Thomas
                            • ? A Former User
                              @sansoy
                              Thomas Patton
                              S Offline
                              S Offline
                              sansoy
                              @thomas you rock! awesome! thanks for troubleshooting.
                              • ? A Former User
                                @thomas
                                Thomas
                                S Offline
                                S Offline
                                sansoy
                                @thomas thanks thomas. will download tomorrow and test either in evening or next day. Really appreciate your help with this.
                                Great job! Sabri
                                • S sansoy
                                  Great job! Sabri
                                  @sansoy
                                  Yeah of course, glad I could be of assistance! Be sure to let me know if you need any more help with this.
                                  Two things I was thinking about on my drive home that you should know - First, when you're on that page I linked above for the software nightlies make sure you sort the files by date descending so that you get the most recent one. I always make the mistake of getting the wrong one. Secondly, when you flash that nightly SDK it will overwrite anything not in the /data/ directory and so you will need to put your model file and labels txt back into /usr/bin/dnn/.
                                  Thomas
                                  • ? A Former User
                                    @sansoy
                                    Thomas
                                    S Offline
                                    S Offline
                                    sansoy
                                    @thomas Morning Thomas, just getting back to this. I couldnt find any SDK that had a 2024 stamp. Was this uploaded somewhere else?
                                    Sabri
                                    • S sansoy
                                      Sabri
                                      @sansoy
                                      Here's the one from last night:
                                      https://console.cloud.google.com/storage/browser/_details/platform-nightlies/voxl2/voxl2_SDK_nightly_20240117.tar.gz?pageState=("StorageObjectListTable":("s":[("i":"objectListDisplayFields%2FtimeLastModified","s":"1"),("i":"displayName","s":"0")]))&organizationId=517175400245&project=modalai-core-services
                                      You just have to make sure when you're on this page that you sort date modified by descending.
                                      Thomas
                                      • ? A Former User
                                        @sansoy
                                        Thomas
                                        S Offline
                                        S Offline
                                        sansoy
                                        @thomas
                                        installed voxl2_SDK_nightly_20240117.tar.gz
                                        per https://docs.modalai.com/flash-system-image/
                                        still not getting any detection even with your default yolov5. ive tried with hires large color, small color and grey.
                                        • S sansoy
                                          @thomas
                                          @sansoy
                                          Checking this out right now, will let you know when I have something.
                                          Thomas
