  3. Can anyone recommend a Tflite Colab Notebook for VOXL2 Training
53 Posts 4 Posters 32.2k Views 4 Watching
  • S sansoy
    @Thomas-Patton
    voxl2:/$ voxl-version
    system-image: 1.6.2-M0054-14.1a-perf
    kernel: #1 SMP PREEMPT Fri May 19 22:19:33 UTC 2023 4.19.125
    hw version: M0054
    voxl-suite: 1.0.0
    will update to 1.0.1
    Can I email you my tflite and saved model for review? I'm doing a run right now that should be completed in a couple hours.
    Sabri
    @sansoy You should upgrade to the latest SDK (1.1.2)
    S 1 Reply Last reply
      S Offline
      S Offline
      sansoy
      @tom so i downloaded the upgrade and started the upgrade but its been stuck for about an hour.
      How long does it take to flash the upgrade?
      Sabri
      Flashing the following System Image:
      Build Name: 1.7.1-M0054-14.1a-perf-nightly-20231025
      Build Date: 2023-10-25
      Platform: M0054
      System Image Version: 1.7.1
      Installing the following version of voxl-suite:
      voxl-suite Version: 1.1.2
      Would you like to continue with SDK install?
      1. Yes
      2. No
        #? yes
        [ERROR] invalid option
        #? 1
        [INFO] adb installed
        [INFO] fastboot installed
      ---- Starting System Image Flash ----
      ----./flash-system-image.sh ----
      Detected OS: Linux
      Installer Version: 0.8
      Please power off your VOXL, connect via USB,
      then power on VOXL. We will keep searching for
      an ADB or Fastboot device over USB
      [INFO] Found ADB device
      [INFO] Rebooting to fastboot
      [INFO] Found fastboot device
      [WARNING] This system image flash is intended only for the following
      platform: VOXL2 (m0054)
            Make sure that the device that will be flashed is correct.
            Flashing a device with an incorrect system image will lead
            the device to be stuck in fastboot.
      Would you like to continue with the VOXL2 (m0054) system image flash?
      1. Yes
      2. No
        #? 1
      • S sansoy
        Sabri
        Platform: M0054
        1. Yes
        2. No
          #? yes
          #? 1
        Detected OS: Linux
        1. Yes
        2. No
          #? 1
        @sansoy It should start right away, I would power cycle your voxl2 and try again
          S Offline
          S Offline
          sansoy
          @tom i did all that and still stuck. could it be whats in the warning about being stuck in fastboot?
          it is the voxl2 and not the voxl2 mini.
          • S sansoy
            @sansoy As long as you are using the voxl2 SDK and are indeed flashing voxl2 hardware then that warning can be ignored.
              S Offline
              S Offline
              sansoy
              @tom hey Tom, i'm having absolutely no luck.
              i've tried 3 times and it still just hangs at
              1. Yes
              2. No
                #? 1
              I then followed the unbrick instructions and reinstalled everything per
              https://docs.modalai.com/voxl2-unbricking/#ubuntu-host
              Got the system back up and running and tried to install the latest SDK again with no luck.
              It just hangs.
              • S sansoy
                1. Yes
                2. No
                  #? 1
                It just hangs.
                S Offline
                S Offline
                sansoy
                wrote on last edited by sansoy
                #13
                UPDATE: Got it working with "sudo" for the install. normally one would get a permission errors and thought maybe that was the issue and sure enough. recommend updating your docs to
                say sudo ./install.sh
                S tomT 2 Replies Last reply
                • S sansoy
                  S Offline
                  S Offline
                  sansoy
                  @tom so i trained on a new batch of AR15 images and got really good numbers in terms of losses and mAPs. Ran an unquantized and quantized version in voxl-tflite-server and again nothing is being recognized.
                  Here's a link to the tflites, and saved_models with inference results on never before seen images.
                  Any insight on how to make these models work in your environment would be awesomely appreciated.
                  https://drive.google.com/drive/folders/1N1pU0jMRTb3rODSfIuETPrBf66m4ody7?usp=drive_link
                  • S sansoy
                    @sansoy Interesting, sudo isn't normally required. I'm curious, what linux distro are you running?
                    • S sansoy
                      @sansoy @Thomas-Patton is the ML expert here and I'll let him comment on that front
                        S Offline
                        S Offline
                        sansoy
                        @tom Ubuntu 22.04.3 LTS
                        • S sansoy
                          @sansoy Huh, okay, that's what I run as well.
                          What groups are your default user in? For example, here is mine:
                           ~  groups                                               ok | 10:20:36 AM
                          tom adm dialout cdrom sudo dip plugdev lpadmin lxd sambashare docker
                            S Offline
                            S Offline
                            sansoy
                            @tom eve@eve:~$ groups
                            eve adm cdrom sudo dip plugdev lpadmin lxd sambashare
                            • S sansoy
                              @sansoy Can you try adding your user to the dialout group and seeing if that fixes the issue?
                              sudo usermod -a -G dialout $USER
                                S Offline
                                S Offline
                                sansoy
                                @tom did that and still no inference.
                                • S sansoy
                                  @sansoy That was for fixing the fastboot issue, unrelated
                                  ? 1 Reply Last reply
                                    @sansoy
                                    When I get some time today I'll try to download your .tflite models and see what's going on. The good news is that the server is at least running! It very well may just be an issue with how the tensor is being parsed.
                                    Thomas
                                    thomas.patton@modalai.com
                                    • ? A Former User
                                      @sansoy
                                      Thomas
                                      @sansoy
                                      Hey, they just gave me access to the Google Drive folder. Can you confirm that the edgetpu.tflite in the root directory is the file you want me to try and get working?
                                      Thomas
                                      • ? A Former User
                                        @sansoy
                                        Thomas
                                        S Offline
                                        S Offline
                                        sansoy
                                        @thomas i just checked permissions and you have access to all the files and yes to
                                        edgetpu.tflit
                                        ssd-mobilenet-v2-fpnlite-640_quant.tflite
                                        ssd-mobilenet-v2-fpnlite-640.tflite
                                        saved_models/saved_model.pb
                                        • S sansoy
                                          edgetpu.tflit
                                          @sansoy
                                          Of these 4 models which is the custom trained YOLO model you mentioned above? I can't even get the edgetpu.tflite model to load so I need a little bit more information on how each of these files was generated.
                                          Thomas
