  3. Voxl2 Mini i2c
Voxl2 Mini i2c
9 Posts 2 Posters 1.8k Views 2 Watching
  • tiralonghipolT Offline
    tiralonghipol
    Im testing the command i2cdetect with the magnetometer attached on J19 as swhon here
    but I get a weird output:
    voxl2-mini:/$ i2cdetect 0
    Warning: Can't use SMBus Quick Write command, will skip some addresses
    WARNING! This program can confuse your I2C bus, cause data loss and worse!
    I will probe file /dev/i2c-0.
    I will probe address range 0x03-0x77.
    Continue? [Y/n] y
         0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
    00:
    10:
    20:
    30: -- -- -- -- -- -- -- --
    40:
    50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    60:
    70:
    I tried to look it up on the web but I do not seem to find any solution for properly probe the bus. Any help?
    system details:
    system-image: 1.7.1-M0104-14.1a-perf-nightly-20231025
    kernel:       #1 SMP PREEMPT Thu Oct 26 04:23:26 UTC 2023 4.19.125
    hw version:   M0104
    voxl-suite:   1.1.1
    • tiralonghipolT tiralonghipol
      Continue? [Y/n] y
      00:
      10:
      20:
      40:
      60:
      70:
      system details:
      hw version:   M0104
      voxl-suite:   1.1.1
      @tiralonghipol i2cdetect is looking on the applications processor. The i2c on J19 are routed to the DSP, not the applications processor.
      tiralonghipolT 1 Reply Last reply
        tiralonghipol
        @Eric-Katzfey thanks for your answer
        so what could be a way to check if I correctly detect a i2c device on J19? assuming of course wiring is correct
          @tiralonghipol If you run PX4 and have a supported magnetometer attached to J19 then you can see if the magnetometer driver is sending out magnetometer data. (e.g. px4-listener sensor_mag).
            tiralonghipol
            @Eric-Katzfey what I am trying to do is writing a driver for an external i2c imu
            is there any code example where you have already implemented an i2c interface on the dsp on voxl2 mini?
              @tiralonghipol For PX4? Then yes, take a look at some magnetometer driver code: https://github.com/modalai/px4-firmware/tree/main/src/drivers/magnetometer/isentek/ist8310
              tiralonghipolT 2 Replies Last reply
                tiralonghipol
                @Eric-Katzfey amazing, thank you!
                  tiralonghipol
                  Hei @Eric-Katzfey
                  is there any code example to read the J19 i2c port 'outside' px4 ?
                    Hei @Eric-Katzfey
                    @tiralonghipol No, only within px4
                    • Morten NissovM Morten Nissov referenced this topic on
