<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Voxl2 Mini i2c]]></title><description><![CDATA[<p dir="auto">Hi,<br />
Im testing the command i2cdetect with the magnetometer attached on J19 as swhon <a href="https://docs.modalai.com/voxl2-mini-offboard-sensors/" rel="nofollow ugc">here</a><br />
but I get a weird output:</p>
<pre><code>voxl2-mini:/$ i2cdetect 0
Warning: Can't use SMBus Quick Write command, will skip some addresses
WARNING! This program can confuse your I2C bus, cause data loss and worse!
I will probe file /dev/i2c-0.
I will probe address range 0x03-0x77.
Continue? [Y/n] y
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:
10:
20:
30: -- -- -- -- -- -- -- --
40:
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60:
70:
<p dir="auto">I tried to look it up on the web but I do not seem to find any solution for properly probe the bus. Any help?</p>
<p dir="auto">system details:</p>
<pre><code>system-image: 1.7.1-M0104-14.1a-perf-nightly-20231025
kernel:       #1 SMP PREEMPT Thu Oct 26 04:23:26 UTC 2023 4.19.125
hw version:   M0104
voxl-suite:   1.1.1
]]></description><link>https://forum.modalai.com/topic/2953/voxl2-mini-i2c</link><generator>RSS for Node</generator><lastBuildDate>Sun, 09 Aug 2026 16:39:15 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/2953.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 15 Dec 2023 09:02:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Voxl2 Mini i2c on Thu, 07 Mar 2024 18:29:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tiralonghipol" aria-label="Profile: tiralonghipol">@<bdi>tiralonghipol</bdi></a> No, only within px4</p>
]]></description><link>https://forum.modalai.com/post/15125</link><guid isPermaLink="true">https://forum.modalai.com/post/15125</guid><dc:creator><![CDATA[Eric Katzfey]]></dc:creator><pubDate>Thu, 07 Mar 2024 18:29:54 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl2 Mini i2c on Wed, 06 Mar 2024 10:53:00 GMT]]></title><description><![CDATA[<p dir="auto">Hei <a class="plugin-mentions-user plugin-mentions-a" href="/user/eric-katzfey" aria-label="Profile: Eric-Katzfey">@<bdi>Eric-Katzfey</bdi></a></p>
<p dir="auto">is there any code example to read the J19 i2c port 'outside' px4 ?</p>
]]></description><link>https://forum.modalai.com/post/15080</link><guid isPermaLink="true">https://forum.modalai.com/post/15080</guid><dc:creator><![CDATA[tiralonghipol]]></dc:creator><pubDate>Wed, 06 Mar 2024 10:53:00 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl2 Mini i2c on Mon, 18 Dec 2023 17:10:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eric-katzfey" aria-label="Profile: Eric-Katzfey">@<bdi>Eric-Katzfey</bdi></a> amazing, thank you!</p>
]]></description><link>https://forum.modalai.com/post/13646</link><guid isPermaLink="true">https://forum.modalai.com/post/13646</guid><dc:creator><![CDATA[tiralonghipol]]></dc:creator><pubDate>Mon, 18 Dec 2023 17:10:36 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl2 Mini i2c on Sun, 17 Dec 2023 15:52:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tiralonghipol" aria-label="Profile: tiralonghipol">@<bdi>tiralonghipol</bdi></a> For PX4? Then yes, take a look at some magnetometer driver code: <a href="https://github.com/modalai/px4-firmware/tree/main/src/drivers/magnetometer/isentek/ist8310" rel="nofollow ugc">https://github.com/modalai/px4-firmware/tree/main/src/drivers/magnetometer/isentek/ist8310</a></p>
]]></description><link>https://forum.modalai.com/post/13632</link><guid isPermaLink="true">https://forum.modalai.com/post/13632</guid><dc:creator><![CDATA[Eric Katzfey]]></dc:creator><pubDate>Sun, 17 Dec 2023 15:52:57 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl2 Mini i2c on Sun, 17 Dec 2023 07:36:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eric-katzfey" aria-label="Profile: Eric-Katzfey">@<bdi>Eric-Katzfey</bdi></a>  what I am trying to do is writing a driver for an external i2c imu<br />
is there any code example where you have already implemented an i2c interface on the dsp on voxl2 mini?</p>
]]></description><link>https://forum.modalai.com/post/13630</link><guid isPermaLink="true">https://forum.modalai.com/post/13630</guid><dc:creator><![CDATA[tiralonghipol]]></dc:creator><pubDate>Sun, 17 Dec 2023 07:36:54 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl2 Mini i2c on Sat, 16 Dec 2023 16:35:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tiralonghipol" aria-label="Profile: tiralonghipol">@<bdi>tiralonghipol</bdi></a> If you run PX4 and have a supported magnetometer attached to J19 then you can see if the magnetometer driver is sending out magnetometer data. (e.g. <code>px4-listener sensor_mag</code>).</p>
]]></description><link>https://forum.modalai.com/post/13629</link><guid isPermaLink="true">https://forum.modalai.com/post/13629</guid><dc:creator><![CDATA[Eric Katzfey]]></dc:creator><pubDate>Sat, 16 Dec 2023 16:35:43 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl2 Mini i2c on Fri, 15 Dec 2023 15:48:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eric-katzfey" aria-label="Profile: Eric-Katzfey">@<bdi>Eric-Katzfey</bdi></a>  thanks for your answer</p>
<p dir="auto">so what could be a way to check if I correctly detect a i2c device on J19? assuming of course wiring is correct</p>
]]></description><link>https://forum.modalai.com/post/13605</link><guid isPermaLink="true">https://forum.modalai.com/post/13605</guid><dc:creator><![CDATA[tiralonghipol]]></dc:creator><pubDate>Fri, 15 Dec 2023 15:48:02 GMT</pubDate></item><item><title><![CDATA[Reply to Voxl2 Mini i2c on Fri, 15 Dec 2023 15:45:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tiralonghipol" aria-label="Profile: tiralonghipol">@<bdi>tiralonghipol</bdi></a> i2cdetect is looking on the applications processor. The i2c on J19 are routed to the DSP, not the applications processor.</p>
]]></description><link>https://forum.modalai.com/post/13604</link><guid isPermaLink="true">https://forum.modalai.com/post/13604</guid><dc:creator><![CDATA[Eric Katzfey]]></dc:creator><pubDate>Fri, 15 Dec 2023 15:45:03 GMT</pubDate></item></channel></rss>
