    VOXL MPA_to_ROS rostopics not subscribing to anything
    Starling & Starling 2
    2715
    • Darshit DesaiD
      Darshit Desai
      Hi I went through the voxl2 custom ros documentation for the starling drone. I started up the voxl mpa to ros script successfully as shown below:
      I than go to my local computer and set the ros master uri and ros IP. I am able to see the rostopic list but when I try to listen the topics by typing rostopic hz /tof_depth it says no data packets present as seen in the image below:
      • ModeratorM
        Moderator ModalAI Team @Darshit Desai
        @Darshit-Desai that service is setup so that it does not publish anything without a subscriber. maybe try to record a rosbag to see if you're getting data?
        ben grocholskyB 1 Reply Last reply Reply Quote 0
        • ben grocholskyB
          ben grocholsky @Moderator
          rostopic hz /tracking should subscribe to the topic and work as you expected.
          e.g. for me:
          I've seen two things that might be happening:
          1. The voxl-camera-service has stopped running. Check with voxl-inspect-services , voxl-inspect-qvio, systemctl status voxl-camera-service.
          2. Your environment variables might not be set right for ROS1 remote message transport. Setting ROS_MASTER_URI on your laptop to point to the master running on the voxl is enough to discover ROS1 topic names. Two more variables are needed to be set to get message transport working ROS_IP and ROS_HOSTNAME
          Here's an example that works for me. Adjust it to match the IP addresses for your voxl2, laptop, and the ROS1 version you're running on your laptop. Select the image you want to view in the rqt_image_view GUI.
          Script on voxl2: start_mpa_to_ros1.sh
          #!/bin/bash
          source /opt/ros/melodic/setup.bash
          voxlIP=`hostname -I | awk '{print $1}'`
          echo "VOXL IP is: " $voxlIP
          export ROS_IP=$voxlIP
          echo "ROS_IP is: " $ROS_IP
          export ROS_HOSTNAME=$voxlIP
          echo "ROS_HOSTNAME is: " $ROS_HOSTNAME
          echo "ROS_MASTER_URI is: " $ROS_MASTER_URI
          roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch
          Script on laptop: start_rqt_imageview.sh
          #!/bin/bash
          # change these to match the computer connecting to VOXL ROS1
          MasterIP=192.168.1.100
          MyIP=192.168.1.101
          ROS_DIST=noetic
          # set environment variables and start rqt_image_view
          source /opt/ros/$ROS_DIST/setup.bash
          export ROS_IP=$MyIP
          export ROS_HOSTNAME=$MyIP
          export ROS_MASTER_URI=http://$MasterIP:11311
          rosrun rqt_image_view rqt_image_view
          Darshit DesaiD 1 Reply Last reply Reply Quote 0
          • Darshit DesaiD
            Darshit Desai @ben grocholsky
            @ben-grocholsky Thanks that helped me do it.
            My tof_ir, tof_conf image feed is rotated 90 degrees counter clockwise when the drone is in a normal position, is there way to change that rotation
            • Darshit DesaiD
              Darshit Desai @Darshit Desai
              @Darshit-Desai @Moderator Can anyone reply on this post?
                @Darshit-Desai Can anyone help with this? @tom
                • ben grocholskyB
                  ben grocholsky @Darshit Desai
                  @Darshit-Desai this is a more generic ROS tf transform network question than anything specific to ModalAI devices. You can get any result you'd like by adding appropriate frames to map or vehicle in the tf tree. For example, since rviz is hard coded to expect z axis upwards and everything is easier with z axis down, I'll attach an ENU frame to every fixed map NED frame and vehicle carried body FRD frame. That allows for all algorithms to be implemented in NED/FRD and still use ROS visualization by selecting ENU frames as fixed and view.
                  Check out the tf documentation http://wiki.ros.org/tf2
                  The static transform publisher is a quick way to test changes. Then you'll want to explore using http://wiki.ros.org/urdf
                    @ben-grocholsky It shows up the same in VOXL PORTAL too.
                    Is there a way to get camera intrinsic Matrix of the ToF camera. Also, if I want to align the depth image with the RGB image how do I do that?
                    Darshit DesaiD 2 Replies Last reply Reply Quote 0
                      @Darshit-Desai I wanted to ask one more follow up to this question? The datasheet in voxl-documentation says the PMD TOF runs at 45 fps for ranging distances less then 1 metres. Is there a way to set that?
                        @Darshit-Desai @ben-grocholsky @Moderator
                        • ModeratorM
                          @Darshit-Desai No, there is no current way to set that
                            @Darshit-Desai said in VOXL MPA_to_ROS rostopics not subscribing to anything:
                            @Moderator
                            ben grocholskyB Darshit DesaiD 2 Replies Last reply Reply Quote 0
                            • ben grocholskyB
                              @Darshit-Desai the recommendation to learn about tf, urdf, and xacro in ROS was because that's a way to achieve what you're asking for. If you get the launch and config files right then ROS tools such as rviz will do what ever you want without writing any code.
                                Hi sorry, I wanted to ask about the intrinsics that was highlighted by mistake. @ben-grocholsky
