No GPs lock for vehicle
@M-al-khatib If you are comfortable editing text files in Linux then you can try the same instructions that I provided him on that thread: https://forum.modalai.com/topic/2317/sentinel-px4-no-gps-lock-and-firmware-problem/21
This post is deleted! -
"I can't find the command 'qshell gps start -d 7 -b 115200' or 'qshell gps start' in the file '/etc/modalai/voxl-px4.config'." -
I have now arrived at this stage, yet my GPS count remains at zero.
@M-al-khatib
While presently utilizing the exact same parameter, the QGS occasionally presents a GPS error, whereas at other instances, it indicates normal GPS functionality.
@M-al-khatib
@M-al-khatib @Eric-Katzfey @modaltb ??
@M-al-khatib What release of software are you using? Can you find the file /etc/modalai/voxl-px4.config?
@M-al-khatib What do you get with the command
px4-versions? -
px4-versions?@Eric-Katzfey said in No GPs lock for vehicle:
px4-versions
modalai-slpi/now 1.0-7 arm64 [installed,local]
px4-rb5-flight/now 1.4-11 arm64 [installed,local]
px4-support/now 1.0-5 arm64 [installed,local]
python3-px4sitl/bionic 0.0.2-100 all
ros-melodic-px4-msgs/bionic 1.0.0-1bionic.20210505.094529 arm64
voxl-px4-imu-server/unknown,now 0.1.1 arm64 [installed,automatic]
voxl-vision-px4/unknown,now 1.0.5 arm64 [installed,automatic]
libfc-sensor/now 1.0-2 arm64 [installed,local]
1.2.1-M0054-14.1a-perf -
px4-versions
1.2.1-M0054-14.1a-perf@M-al-khatib What drone do you have? A Sentinel? If so, can you please update your software to SDK 1.0.0?
Okay, I'm done, and the drone got GPS this is video link.
https://drive.google.com/file/d/1XfcMhyPKbJYDFnPwljM3zM7MbZWcx4op/view?usp=sharing
However, I mistakenly used the power adapter instead of the battery when I unplugged it to switch to flight on battery mode, so there was no GPS signal.
my sdk now is 1.0.0
and my firmware Version 1.14.0dev -
my sdk now is 1.0.0
and my firmware Version 1.14.0dev@M-al-khatib Great, glad to hear it is working now!
[[topic:post-is-deleted]]This post is deleted!
