  3. No GPs lock for vehicle
sentinel
25 Posts 5 Posters 7.2k Views 2 Watching
  • M. al-khatibM Offline
    M. al-khatib
    Why am I unable to find the GPS location for my VOXL2 DRON connected to my Wi-Fi and linked to QGS? I constantly see the message "No GPS lock for vehicle" on my screen. I attempted to modify the parameters, but it didn't resolve the issue. Whenever I use the outdoor parameter, QGS shows "not ready to fly," and during hovering, it indicates a GPS error. However, when I switch to the indoor parameter, it shows "GPS disabled" (although the drone functions properly indoors). What could be causing these problems?
    modaltbM 1 Reply Last reply
    • M. al-khatibM M. al-khatib
      modaltbM Offline
      modaltbM Offline
      modaltb
      Hi @M-al-khatib , unless I move my vehicle outside and it has a view of the sky does the GPS get satellites. Are you trying to do the GPS test in an environment that isn't 'shielded' like indoors?
      M. al-khatibM 1 Reply Last reply
      • modaltbM modaltb referenced this topic on
      • modaltbM modaltb
        M. al-khatib
        @modaltb said in No GPs lock for vehicle:
        Yes, I conducted an outdoor test with specific parameters, focusing on essential factors. The test revealed that there was no GPS signal for the vehicle, and the information indicated that the GPS functionality was disabled. Throughout the test, the GPS count consistently remained at zero, with no HDOP readings available.Capture1.PNG Capture.PNG
          Eric KatzfeyE Online
          @M-al-khatib Can you log into the vehicle with either adb or ssh and provide the output of the command journalctl -b -u voxl-px4?
            M. al-khatib
            this is the output
              this is the output
              @M-al-khatib Perhaps this journalctl --no-pager -b -u voxl-px4 > /tmp/test.txt and then attach the test.txt file so that all of the output is there?
              • Samer JaradatS Offline
                Samer Jaradat
                no text file created
                voxl2:/$ px4-qshell gps status
                INFO [qshell] Send cmd: 'gps status'
                INFO [qshell] qshell return value timestamp: 2376085469, local time: 2376088441
                voxl2:/$ ^C
                voxl2:/$ px4-listener sensor_gps
                never published
                never published
                voxl2:/$ journalctl --no-pager -b -u voxl-px4 > /tmp/test.txt
                -- Logs begin at Thu 2023-03-02 12:58:02 UTC, end at Fri 2023-06-23 18:06:16 UTC. --
                Jun 23 16:24:45 m0054 systemd[1]: Starting px4...
                Jun 23 16:24:50 m0054 systemd[1]: Started px4.
                Jun 23 16:24:50 m0054 bash[1691]: Found DSP signature file
                Jun 23 16:24:50 m0054 bash[1691]: Running on M0054
                Jun 23 16:24:52 m0054 bash[1691]: INFO [qshell] Send cmd: 'icm42688p start -s'
                Jun 23 16:24:52 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 11522033, local time: 11523559
                Jun 23 16:24:54 m0054 bash[1691]: Starting Holybro magnetometer
                Jun 23 16:24:54 m0054 bash[1691]: INFO [qshell] Send cmd: 'ist8310 start -R 10 -X -b 1'
                Jun 23 16:24:54 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 14344064, local time: 14345444
                Jun 23 16:24:54 m0054 bash[1691]: Starting Holybro LED driver
                Jun 23 16:24:54 m0054 bash[1691]: INFO [qshell] Send cmd: 'rgbled_ncp5623c start -X -b 1 -f 400 -a 56'
                Jun 23 16:24:54 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 14401400, local time: 14402064
                Jun 23 16:24:54 m0054 bash[1691]: INFO [px4] mlockall() enabled. PX4's virtual address space is locked into RAM.
                Jun 23 16:24:54 m0054 bash[1691]: INFO [px4] assuming working directory is rootfs, no symlinks needed.
                Jun 23 16:24:54 m0054 bash[1691]: ______ __ __ ___
                Jun 23 16:24:54 m0054 bash[1691]: | ___ \ \ \ / / / |
                Jun 23 16:24:54 m0054 bash[1691]: | |/ / \ V / / /| |
                Jun 23 16:24:54 m0054 bash[1691]: | __/ / \ / /
                Jun 23 16:24:54 m0054 bash[1691]: | | / /^\ \ ___ |
                Jun 23 16:24:54 m0054 bash[1691]: _| / / |_/
                Jun 23 16:24:54 m0054 bash[1691]: px4 starting.
                Jun 23 16:24:54 m0054 bash[1691]: INFO [px4] Calling startup script: /bin/sh /etc/modalai/voxl-px4.config 0
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread hpwork
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_hpwork with tid 83
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread lpwork
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_lpwork with tid 82
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wkr_hrt
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wkr_hrt with tid 81
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread client_sync_thread
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_client_sync_thread with tid 80
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wq_manager
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wq_manager with tid 79
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread qshell
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 78
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: icm42688p start -s
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wq_SPI1
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wq_SPI1 with tid 76
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: *** SPI Device ID 0x26000a 2490378
                Jun 23 16:24:54 m0054 bash[1691]: INFO [uorb] Advertising remote topic sensor_accel
                Jun 23 16:24:54 m0054 bash[1691]: INFO [uorb] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_topic
                Jun 23 16:24:54 m0054 bash[1691]: INFO [uorb] Advertising remote topic sensor_gyro
                Jun 23 16:24:54 m0054 bash[1691]: INFO [uorb] Advertising remote topic imu_server
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: on SPI bus 1
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: icm42688p #0 on SPI bus 1 (devid=0x0)
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: icm42688p start -s
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 11522033, current timestamp 11522034
                Jun 23 16:24:54 m0054 bash[1691]: INFO [uorb] Advertising remote topic qshell_retval
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
                Jun 23 16:24:54 m0054 bash[1691]: ERROR [muorb] SLPI: Cannot reset all parameters on client side
                Jun 23 16:24:54 m0054 bash[1691]: INFO [uorb] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic parameter_update
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_topic
                Jun 23 16:24:54 m0054 bash[1691]: INFO [uorb] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic
                Jun 23 16:24:54 m0054 bash[1691]: INFO [logger] logger started (mode=all)
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: ist8310 start -R 10 -X -b 1
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wq_I2C1
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wq_I2C1 with tid 75
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: *** I2C Device ID 0x60e09 396809
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: ist8310 #0 on I2C bus 1 (external)
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: ist8310 start -R 10 -X -b 1
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 14344064, current timestamp 14344065
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: *** I2C Device ID 0x7b3809 8075273
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: rgbled_ncp5623c #0 on I2C bus 1 (external)
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 14401400, current timestamp 14401401
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: icp10100 start -I -b 5
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wq_I2C5
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wq_I2C5 with tid 74
                Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: *** I2C Device ID 0x9c6329 1024INFO [qshell] Send cmd: 'icp10100 start -I -b 5'
                Jun 23 16:24:54 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 14434955, local time: 14435823
                Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] Send cmd: 'modalai_esc start'
                Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 14487155, local time: 14487822
                Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] Send cmd: 'mixer load /dev/uart_esc quad_x.main.mix'
                Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 14542181, local time: 14543199
                Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] Send cmd: 'voxlpm start -X -b 2'
                Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 14585276, local time: 14586089
                Jun 23 16:24:55 m0054 bash[1691]: Starting Holybro GPS
                Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] Send cmd: 'gps start -d 7 -b 115200'
                Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 14617107, local time: 14618038
                Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] Send cmd: 'px4io detect'
                Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] cmd returned with: -17
                Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 14668509, local time: 14669837
                Jun 23 16:24:55 m0054 bash[1691]: ERROR [qshell] Command failed
                Jun 23 16:24:55 m0054 bash[1691]: M0065 not detected, starting Spektrum RC driver
                Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] Send cmd: 'spektrum_rc start -d 8'
                Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 14706420, local time: 14708458
                Jun 23 16:24:56 m0054 bash[1691]: 9001
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: probe probe succeeded. data = 0x1 0x48
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: icp10100 #0 on I2C bus 5
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: icp10100 start -I -b 5
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 14434955, current timestamp 14434956
                Jun 23 16:24:56 m0054 bash[1691]: INFO [uorb] Advertising remote topic sensor_mag
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: modalai_esc start
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wq_hp_default
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wq_hp_default with tid 73
                Jun 23 16:24:56 m0054 bash[1691]: INFO [uorb] Advertising remote topic test_motor
                Jun 23 16:24:56 m0054 bash[1691]: INFO [uorb] Advertising remote topic sensor_baro
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: modalai_esc start
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 14487155, current timestamp 14487156
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Opened UART ESC device
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: mixer load /dev/uart_esc quad_x.main.mix
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wq_rate_ctrl
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wq_rate_ctrl with tid 71
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: mixer load /dev/uart_esc quad_x.main.mix
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 14542181, current timestamp 14542182
                Jun 23 16:24:56 m0054 bash[1691]: INFO [uorb] Advertising remote topic actuator_outputs
                Jun 23 16:24:56 m0054 bash[1691]: INFO [uorb] Advertising remote topic multirotor_motor_limits
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wq_I2C2
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wq_I2C2 with tid 4169
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: *** I2C Device ID 0x784411 7881745
                Jun 23 16:24:56 m0054 bash[1691]: INFO [uorb] Advertising remote topic battery_status
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: voxlpm #0 on I2C bus 2 (external)
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: voxlpm start -X -b 2
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 14585276, current timestamp 14585277
                Jun 23 16:24:56 m0054 bash[1691]: INFO [uorb] Advertising remote topic power_monitor
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: gps start -d 7 -b 115200
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread gps
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_gps with tid 70
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: gps start -d 7 -b 115200
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 14617107, current timestamp 14617107
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: px4io detect
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: serial port fd 2
                Jun 23 16:24:56 m0054 bash[1691]: ERROR [muorb] SLPI: px4io read failed
                Jun 23 16:24:56 m0054 bash[1691]: ERROR [muorb] SLPI: px4io io_reg_get(0,0,1): data error -5
                Jun 23 16:24:56 m0054 bash[1691]: ERROR [muorb] SLPI: IO not installed
                Jun 23 16:24:56 m0054 bash[1691]: ERROR [muorb] SLPI: Detection attempt 2 failed
                Jun 23 16:24:56 m0054 bash[1691]: ERROR [muorb] SLPI: Detection attempt 1 failed
                Jun 23 16:24:56 m0054 bash[1691]: ERROR [muorb] SLPI: Detection attempt 0 failed
                Jun 23 16:24:56 m0054 bash[1691]: ERROR [muorb] SLPI: Failed to execute command: px4io detect
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 14668509, current timestamp 14668510
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: spektrum_rc start -d 8
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread spektrum_rc_main
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_spektrum_rc_main with tid 67
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: spektrum_rc start -d 8
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 14706420, current timestamp 14706421
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: sensors start
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wq_nav_and_controllers
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wq_nav_and_controllers with tid 66
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: sensors start
                Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 15763186, current timestamp 15763187
                Jun 23 16:24:56 m0054 bash[1691]: INFO [uorb] Advertising remote topic vehicle_angINFO [qshell] Send cmd: 'sensors start'
                Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 15763186, local time: 15766524
                Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] Send cmd: 'ekf2 start'
                Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 15924808, local time: 15926148
                Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] Send cmd: 'mc_pos_control start'
                Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 15977526, local time: 15978641
                Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] Send cmd: 'mc_att_control start'
                Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 16020779, local time: 16021799
                Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] Send cmd: 'mc_rate_control start'
                Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 16076014, local time: 16077458
                Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] Send cmd: 'mc_hover_thrust_estimator start'
                Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 16115582, local time: 16117055
                Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] Send cmd: 'land_detector start multicopter'
                Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 16150880, local time: 16151957
                Jun 23 16:24:57 m0054 bash[1691]: ular_acceleration
                Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic vehicle_angular_velocity
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wq_INS0
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wq_INS0 with tid 65
                Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic vehicle_imu
                Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic vehicle_imu_status
                Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic sensors_status_imu
                Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic vehicle_acceleration
                Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic vehicle_air_data
                Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic sensor_selection
                Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic sensor_combined
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: ekf2 start
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: ekf2 start
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 15924808, current timestamp 15924809
                Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic ekf2_timestamps
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: mc_pos_control start
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: mc_pos_control start
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 15977526, current timestamp 15977527
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: mc_att_control start
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: mc_att_control start
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 16020779, current timestamp 16020780
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: mc_rate_control start
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: mc_rate_control start
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 16076014, current timestamp 16076015
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: mc_hover_thrust_estimator start
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: mc_hover_thrust_estimator start
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 16115582, current timestamp 16115583
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: land_detector start multicopter
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: land_detector start multicopter
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 16150880, current timestamp 16150881
                Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic vehicle_land_detected
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: 16481861: reset position to last known position
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: 16481861: reset velocity to zero
                Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic vehicle_local_position
                Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic vehicle_odometry
                Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic estimator_states
                Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic estimator_status
                Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic estimator_status_flags
                Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic estimator_innovations
                Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic estimator_innovation_test_ratios
                Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic estimator_innovation_variances
                Jun 23 16:24:57 m0054 bash[1691]: INFO [dataman] Unknown restart, data manager file '/data/px4/dataman' size is 11798680 bytes
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic position_setpoint_triplet
                Jun 23 16:24:57 m0054 bash[1691]: INFO [commander] LED: open /dev/led0 failed (22)
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic led_control
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic tune_control
                Jun 23 16:24:57 m0054 bash[1691]: INFO [PreFlightCheck] Failed EKF health preflight check while waiting for filter to settle
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic vehicle_control_mode
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic vehicle_status
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic actuator_armed
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic commander_state
                Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic rate_ctrl_status
                Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic actuator_controls_0
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic vehicle_status_flags
                Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic vehicle_command
                voxl2:/$ /tmp/test.txt
                bash: /tmp/test.txt: Permission denied
                voxl2:/$
                • Adeeb AbbasA Offline
                  Adeeb Abbas
                  I can second the same issue. Getting the following for the GPS message check command -
                  voxl2:~$ px4-listener sensor_gps
                  never published
                  Recently received a brand new sentinel drone and wanted to try out indoor flight however QGroundControl prevents arming due to no GPS lock error. Quite similar to what's mentioned by the OP. Hoping to get a response soon. Thanks!
                  Please let me know if there's anything else you'd need.
                    M. al-khatib
                    my test.txt file same as the Samer Jaradat file.
                      @M-al-khatib If you are comfortable editing text files in Linux then you can try the same instructions that I provided him on that thread: https://forum.modalai.com/topic/2317/sentinel-px4-no-gps-lock-and-firmware-problem/21
                      Samer JaradatS M. al-khatibM 3 Replies Last reply
                        Samer Jaradat
                          M. al-khatib
                          "I can't find the command 'qshell gps start -d 7 -b 115200' or 'qshell gps start' in the file '/etc/modalai/voxl-px4.config'."
                            M. al-khatib
                            I have now arrived at this stage, yet my GPS count remains at zero.
                              M. al-khatib
                              @M-al-khatib
                              While presently utilizing the exact same parameter, the QGS occasionally presents a GPS error, whereas at other instances, it indicates normal GPS functionality.
                                @M-al-khatib
                                M. al-khatib
                                @M-al-khatib @Eric-Katzfey @modaltb ??
                                  @M-al-khatib What release of software are you using? Can you find the file /etc/modalai/voxl-px4.config?
                                    M. al-khatib
                                    @Eric-Katzfey said in No GPs lock for vehicle:
                                    empty file
                                      empty file
                                      @M-al-khatib What do you get with the command px4-versions?
                                        M. al-khatib
                                        px4-versions
                                        modalai-slpi/now 1.0-7 arm64 [installed,local]
                                        px4-rb5-flight/now 1.4-11 arm64 [installed,local]
                                        px4-support/now 1.0-5 arm64 [installed,local]
                                        python3-px4sitl/bionic 0.0.2-100 all
                                        ros-melodic-px4-msgs/bionic 1.0.0-1bionic.20210505.094529 arm64
                                        voxl-px4-imu-server/unknown,now 0.1.1 arm64 [installed,automatic]
                                        voxl-vision-px4/unknown,now 1.0.5 arm64 [installed,automatic]
                                        libfc-sensor/now 1.0-2 arm64 [installed,local]
                                        1.2.1-M0054-14.1a-perf
                                          px4-versions
                                          @M-al-khatib What drone do you have? A Sentinel? If so, can you please update your software to SDK 1.0.0?
