    [ERROR] Please update to a system image newer than May 14 2023
    • A
      afdrus
      Hi everyone,
      I am using a voxl2 that I received with voxl-suite 0.9.5. Since I wanted to switch voxl-vision-hub I picked the staging pkg manager with the command voxl-configure-pkg-manager and ran apt update.
      What I ended up having is the following voxl-version.
      voxl2:/$ voxl-version
      kernel:       #1 SMP PREEMPT Thu Oct 13 17:48:16 UTC 2022 4.19.125
      hw version:   M0054
      voxl-suite:
      Packages:
      Repo:  http://voxl-packages.modalai.com/ qrb5165 staging
      Last Updated: 2023-05-30 15:13:45
      List:
         libmodal-cv            0.3.1
         libmodal-exposure      0.0.8
         libmodal-journal       0.2.2
         libmodal-json          0.4.3
         libmodal-pipe          2.8.4
         libqrb5165-io          0.2.0
         libvoxl-cci-direct     0.1.5
         libvoxl-cutils         0.1.1
         mv-voxl                0.1-r0
         qrb5165-bind           0.1-r0
         qrb5165-dfs-server     0.1.0
         qrb5165-imu-server     0.6.0
         qrb5165-slpi-test-sig  01-r0
         qrb5165-system-tweaks  0.1.7
         qrb5165-tflite         2.8.0-2
         voxl-camera-server     1.5.4
         voxl-ceres-solver      1.14.0-9
         voxl-cpu-monitor       0.4.5
         voxl-eigen3            3.4.0
         voxl-jpeg-turbo        2.1.3-4
         voxl-mapper            0.1.9
         voxl-mavlink-server    1.0.5
         voxl-modem             1.0.4
         voxl-mongoose          7.7.0-1
         voxl-mpa-to-ros        0.3.6
         voxl-mpa-tools         1.0.1
         voxl-nlopt             2.5.0-4
         voxl-opencv            4.5.5-1
         voxl-portal            0.5.8
         voxl-qvio-server       0.9.2
         voxl-streamer          0.6.1
         voxl-tag-detector      0.0.4
         voxl-tflite-server     0.3.1
         voxl-utils             1.3.0
         voxl-vision-hub        1.6.5
         voxl-voxblox           1.1.3
         voxl2-system-image     1.4.1-r0
         voxl2-wlan             1.0-r0
      At this point, I wanted to switch camera config therefore I ran voxl-configure-cameras 6 (i.e. TOF+Hires+Tracking) but the following error came out:
      [ERROR] Your system image is too old to support the new camera driver structure
      [ERROR] Plese update to a system image newer than May 14 2023
      The weird thing is that this happen with all the other config IDs. However if I unplug the TOF camera sensor I am able to use Hires+Tracking but I still can't switch to any other config ID.
      • Abdullah01A
        Abdullah01
        same issue here, If you fixed this problem and solved it please let me know how
          tom admin
          @afdrus The staging repo requires an un-released system image (coming soon)
          A 1 Reply Last reply Reply Quote 1
          • A
            afdrus @tom
            @tom Thanks for the reply! Is it possible to know roughly when will it be published?
              tom admin @afdrus
              @afdrus My best guess is 2-4 weeks
