  3. [ERROR] Please update to a system image newer than May 14 2023
voxl-2
5 Posts 3 Posters 908 Views 1 Watching
  • A Offline
    afdrus
    Hi everyone,
    I am using a voxl2 that I received with voxl-suite 0.9.5. Since I wanted to switch voxl-vision-hub I picked the staging pkg manager with the command voxl-configure-pkg-manager and ran apt update.
    What I ended up having is the following voxl-version.
    voxl2:/$ voxl-version
    kernel:       #1 SMP PREEMPT Thu Oct 13 17:48:16 UTC 2022 4.19.125
    hw version:   M0054
    voxl-suite:
    Packages:
    Repo:  http://voxl-packages.modalai.com/ qrb5165 staging
    Last Updated: 2023-05-30 15:13:45
    List:
       libmodal-cv            0.3.1
       libmodal-exposure      0.0.8
       libmodal-journal       0.2.2
       libmodal-json          0.4.3
       libmodal-pipe          2.8.4
       libqrb5165-io          0.2.0
       libvoxl-cci-direct     0.1.5
       libvoxl-cutils         0.1.1
       mv-voxl                0.1-r0
       qrb5165-bind           0.1-r0
       qrb5165-dfs-server     0.1.0
       qrb5165-imu-server     0.6.0
       qrb5165-slpi-test-sig  01-r0
       qrb5165-system-tweaks  0.1.7
       qrb5165-tflite         2.8.0-2
       voxl-camera-server     1.5.4
       voxl-ceres-solver      1.14.0-9
       voxl-cpu-monitor       0.4.5
       voxl-eigen3            3.4.0
       voxl-jpeg-turbo        2.1.3-4
       voxl-mapper            0.1.9
       voxl-mavlink-server    1.0.5
       voxl-modem             1.0.4
       voxl-mongoose          7.7.0-1
       voxl-mpa-to-ros        0.3.6
       voxl-mpa-tools         1.0.1
       voxl-nlopt             2.5.0-4
       voxl-opencv            4.5.5-1
       voxl-portal            0.5.8
       voxl-qvio-server       0.9.2
       voxl-streamer          0.6.1
       voxl-tag-detector      0.0.4
       voxl-tflite-server     0.3.1
       voxl-utils             1.3.0
       voxl-vision-hub        1.6.5
       voxl-voxblox           1.1.3
       voxl2-system-image     1.4.1-r0
       voxl2-wlan             1.0-r0
    At this point, I wanted to switch camera config therefore I ran voxl-configure-cameras 6 (i.e. TOF+Hires+Tracking) but the following error came out:
    [ERROR] Your system image is too old to support the new camera driver structure
    [ERROR] Plese update to a system image newer than May 14 2023
    The weird thing is that this happen with all the other config IDs. However if I unplug the TOF camera sensor I am able to use Hires+Tracking but I still can't switch to any other config ID.
    • Abdullah01A Offline
      Abdullah01A Offline
      Abdullah01
      same issue here, If you fixed this problem and solved it please let me know how
        @afdrus The staging repo requires an un-released system image (coming soon)
        A 1 Reply Last reply
          afdrus
          @tom Thanks for the reply! Is it possible to know roughly when will it be published?
          • A afdrus
            @afdrus My best guess is 2-4 weeks
