  3. problem with opkg update & opkg upgrade
4 Posts 3 Posters 1.2k Views 2 Watching
  • M Offline
    M Offline
    mbahrami
    wrote on last edited by mbahrami
    Apparently the default directory http://voxl-packages.modalai.com/stable on the VOXL platforms with a system-image 3.6.0 and voxl-suite 0.5.0. is no longer available for updating the packages.
    I updated the directory in /etc/opkg/opkg.conf to http://voxl-packages.modalai.com/dists/apq8096/stable/binary-arm64/ and after running update && opkg upgrade I get the following package conflicts:
    voxl:/$ opkg upgrade
    Upgrading voxl-tflite-server from 0.1.8 to 0.3.1 on root.
    Installing apq8096-tflite (2.8.3-1) on root.
    Upgrading voxl-camera-server from 0.8.1 to 1.3.5 on root.
    Upgrading voxl-utils from 0.8.5 to 1.2.2 on root.
    Installing apq8096-system-tweaks (0.1.3) on root.
    Not downgrading package libgphoto2 on root from 2.5.26 to 0.0.4.
    Upgrading voxl-suite from 0.5.0 to 0.9.5 on root.
    Collected errors:
     * check_conflicts_for: The following packages conflict with apq8096-tflite:
     * check_conflicts_for: 	voxl-tflite *
     * check_conflicts_for: The following packages conflict with voxl-camera-server:
     * check_conflicts_for: 	voxl-utils *
     * check_conflicts_for: The following packages conflict with apq8096-system-tweaks:
     * satisfy_dependencies_for: Cannot satisfy the following dependencies for voxl-suite:
     * 	cci-direct-support *
    I wonder if flashing the system image and upgrading to the most recent one is the only way to fix the conflicts.
    Thanks.
    / # voxl-version
    cat: /etc/modalai/voxl-software-bundle-version.txt: No such file or directory
    system-image:    ModalAI 3.6.0 BUILDER: ekatzfey BUILD_TIME: 2022-02-28_23:47
    kernel:          #1 SMP PREEMPT Mon Feb 28 23:55:47 UTC 2022 3.18.71-perf
    factory-bundle:  1.0.1 (Yocto installation)
    architecture:    aarch64
    processor:       apq8096
    os:              GNU/Linux
    voxl-suite:
    Package: voxl-suite
    Version: 0.5.0
    Depends: libjpeg_turbo (>= 9.0.4), libmodal_exposure (>= 0.0.2), libmodal_json (>= 0.3.6), libmodal_pipe (>= 2.1.1), librc_math (>= 1.1.5), libvoxl_cutils (>= 0.0.2), libvoxl_io (>= 0.5.4), mavlink-camera-manager (>= 0.0.2), mongoose (>= 7.3.0), opencv (>= 4.5.2-2), openmp (>= 10.0.2), voxl-camera-calibration (>= 0.1.1), voxl-camera-server (>= 0.8.1), voxl-cpu-monitor (>= 0.2.0), voxl-dfs-server (>= 0.2.2), voxl-docker-support (>= 1.1.3), voxl-gphoto2 (>= 0.0.5), voxl-imu-server (>= 0.9.1), voxl-mavlink (>= 0.0.2), voxl-modem (>= 0.12.0), voxl-mpa-tools (>= 0.3.6), voxl-nodes (>= 0.2.0), voxl-portal (>= 0.1.2), voxl-qvio-server (>= 0.3.4), voxl-streamer (>= 0.2.6), voxl-tag-detector (>= 0.0.2), voxl-tflite (>= 2.2.3), voxl-tflite-server (>= 0.1.5), voxl-utils (>= 0.8.4), voxl-vision-px4 (>= 0.9.5), voxl-vpn (>= 0.0.3)
    Architecture: all
    Installed-Time: 236
      @mbahrami said in problem with opkg update & opkg upgrade:
      404 Not Found
      favicon
      (voxl-packages.modalai.com)
      You can see the list of available software here: http://voxl-packages.modalai.com/dists/apq8096/
        @mbahrami Your system image is quite old, I'd recommend upgrading to VOXL Platform Release 0.9.5
        • M Offline
          M Offline
          mbahrami
          Thank you both @Chad-Sweet and @tom for being super responsive on this technical forum.
