  3. Failed to start Stereo Camera Nodelet
roscamera
12 Posts 4 Posters 3.0k Views 3 Watching
  • A Offline
    abdullah.sorathi
    I get this error every other time. for the first launch it executed perfectly but subsequent lanches throw error. Basically if it run perfectly and if i interrupt it by pressing ctrl + c and than run again it starts saying could not load nodelet. And many a time it says could not open camera ID = 2. Unable to open camera.
    yocto:/# roslaunch voxl_cam_ros stereo.launch
    ... logging to /home/root/.ros/log/a0237ab4-4d5a-11eb-9155-ec5c68cd1745/roslaunch-apq8096-4987.log
    Checking log directory for disk usage. This may take awhile.
    Press Ctrl-C to interrupt
    Done checking log file disk usage. Usage is <1GB.
    started roslaunch server http://10.42.0.157:48704/
    SUMMARY
    PARAMETERS
     * /rosdistro: indigo
     * /rosversion: 1.11.21
     * /stereo/stereo_cam_nodelet/cam_id: 2
     * /stereo/stereo_cam_nodelet/cam_name: stereo
     * /stereo/stereo_cam_nodelet/format: 1
     * /stereo/stereo_cam_nodelet/frame_id: left_stereo
     * /stereo/stereo_cam_nodelet/frame_id_right: right_stereo
     * /stereo/stereo_cam_nodelet/frame_rate: 15
     * /stereo/stereo_cam_nodelet/height: 480
     * /stereo/stereo_cam_nodelet/is_cam_master: True
     * /stereo/stereo_cam_nodelet/is_stereo: True
     * /stereo/stereo_cam_nodelet/skip_n_frames: 0
     * /stereo/stereo_cam_nodelet/width: 640
    NODES
      /stereo/
        stereo_cam_nodelet (nodelet/nodelet)
        stereo_nodelet_manager (nodelet/nodelet)
    auto-starting new master
    process[master]: started with pid [5006]
    ROS_MASTER_URI=http://localhost:11311/
    setting /run_id to a0237ab4-4d5a-11eb-9155-ec5c68cd1745
    process[rosout-1]: started with pid [5020]
    started core service [/rosout]
    process[stereo/stereo_nodelet_manager-2]: started with pid [5036]
    process[stereo/stereo_cam_nodelet-3]: started with pid [5038]
    [ INFO] [1609633720.545179265]: Initializing nodelet with 4 worker threads.
    [ INFO] [1609633720.762515687]: SnapCamDriver Starting
    [ INFO] [1609633720.762910065]: Monotonic offset: 1609633473.790296944
    [FATAL] [1609633726.430193936]: Failed to load nodelet '/stereo/stereo_cam_nodelet` of type `voxl_cam_ros/stereo_driver` to manager `stereo_nodelet_manager'
    [stereo/stereo_nodelet_manager-2] process has died [pid 5036, exit code -11, cmd /opt/ros/indigo/lib/nodelet/nodelet manager __name:=stereo_nodelet_manager __log:=/home/root/.ros/log/a0237ab4-4d5a-11eb-9155-ec5c68cd1745/stereo-stereo_nodelet_manager-2.log].
    log file: /home/root/.ros/log/a0237ab4-4d5a-11eb-9155-ec5c68cd1745/stereo-stereo_nodelet_manager-2*.log
    [stereo/stereo_cam_nodelet-3] process has died [pid 5038, exit code 255, cmd /opt/ros/indigo/lib/nodelet/nodelet load voxl_cam_ros/stereo_driver stereo_nodelet_manager __name:=stereo_cam_nodelet __log:=/home/root/.ros/log/a0237ab4-4d5a-11eb-9155-ec5c68cd1745/stereo-stereo_cam_nodelet-3.log].
    log file: /home/root/.ros/log/a0237ab4-4d5a-11eb-9155-ec5c68cd1745/stereo-stereo_cam_nodelet-3*.log
    ^C[rosout-1] killing on exit
    [master] killing on exit
    shutting down processing monitor...
    ... shutting down processing monitor complete
    done
    yocto:/#
    I even tried setting it as slave and not master as recommended over here [https://docs.modalai.com/voxl-cam-ros/](link url)
    but after showing Monotonic offset it throws error
    • modaltbM Offline
      modaltbM Offline
      modaltb
      Hi @abdullah-sorathi,
      Can you please provide us with your hardware setup? What camera(s) do you have connected?
      Can you also run voxl-version and provide us with the output?
      Travis
      A 1 Reply Last reply
        Also, only one camera can be master in the libcamera architecture. If voxl-vision-px4 has VOA enabled, and is using the stereo cameras, is_cam_master needs to be set to false. In the log above is_cam_master is set to true
        • modaltbM modaltb
          Travis
          abdullah.sorathi
          wrote on last edited by abdullah.sorathi
          @modaltb
          I am using voxl-flight deck
          cameras are same that comes with flight deck-> stereo camera, hires and optical flow camera
          This is the voxl version currently in use in my setup
          yocto:/# voxl-version
          system-image:    ModalAI 2.5.2 BUILDER: ekatzfey BUILD_TIME: 2020-08-24_00:08
          kernel:          #1 SMP PREEMPT Wed Sep 9 22:28:09 UTC 2020 3.18.71-perf
          factory-bundle:  1.0.1
          architecture:    aarch64
          processor:       apq8096
          os:              GNU/Linux
          voxl-suite:
          Package: voxl-suite
          Version: 0.2.0
          Depends: docker, imu_app (= 0.0.6), libvoxl_io (= 0.5.2), voxl-cam-manager (= 0.2.2), voxl-docker-support (= 1.1.1), voxl-hal3-tof-cam-ros (= 0.0.2), voxl-modem (= 0.10.0), voxl-nodes (= 0.0.8), voxl-rtsp (= 1.0.2), voxl-utils (= 0.5.2), voxl-vision-px4 (= 0.6.8), voxl_imu (= 0.0.4), voxl-time-sync (= 0.0.1), voxl-vpn (= 0.0.2), librc_math (= 1.1.2), libmodal_pipe (= 1.2.2), modalai-vl (= 0.1.3)
          Section: base
          Architecture: armv7a
          Maintainer: james@modalai.com
          MD5Sum: af706cd3c1ea59f274f2ed9b93141f1d
          Filename: voxl-suite_0.2.0.ipk
          Description: meta-package to install all of the voxl-suite
          Installed-Time: 4024
          yocto:/#
          I am currently working with SNAV and followed this [https://docs.modalai.com/snapdragon-navigator/]
          • Chad SweetC Chad Sweet
            abdullah.sorathi
            @Chad-Sweet
            Yes I tried both setting it to true and false. But once you start launch camera and the terminated and try to launch again it does not launch.
            • K Offline
              K Offline
              kiprock
              @abdullah-sorathi said in Failed to start Stereo Camera Nodelet:
              I have the same problem:
              yocto:~# roslaunch voxl_cam_ros stereo.launch is_cam_master:=false
              ... logging to /home/root/.ros/log/357f3634-ac60-11eb-a8f6-ec5c68cd21c7/roslaunch-apq8096-4646.log
              started roslaunch server http://10.0.0.2:34910/
              SUMMARY
              PARAMETERS
               * /stereo/stereo_cam_nodelet/is_cam_master: False
              NODES
                /stereo/
              process[master]: started with pid [4665]
              setting /run_id to 357f3634-ac60-11eb-a8f6-ec5c68cd21c7
              process[rosout-1]: started with pid [4678]
              process[stereo/stereo_nodelet_manager-2]: started with pid [4691]
              process[stereo/stereo_cam_nodelet-3]: started with pid [4696]
              [ INFO] [1620081479.191290494]: Initializing nodelet with 4 worker threads.
              [ INFO] [1620081479.450798205]: SnapCamDriver Starting
              [ INFO] [1620081479.451256697]: Monotonic offset: 1620078140.011942802
              libcam.enable.publish  1
              libcam.enable.publish.dump 0
              libcam.publish.buffer.policy max
              libcam.publish.buffer.max 3
              libcam.debug.level info
              libcam.dump.dir /data/misc/camera/dumps
              ERROR: could not open camera subscriber for cam id 2
              [ERROR] [1620081496.766822127]: CameraManager::Initialize() failed
              [ERROR] [1620081496.767214629]: Unable to open camera.
              Any suggestion on debugging?
                The two likely reasons for this error:
                • incorrect camera ID
                • is_cam_master not set properly.
                If you are not running anything that uses the stereo camera, is_cam_master should be true
                You can check the configured camera IDs by:
                cat /etc/modalai/camera_env.sh
                • K Offline
                  K Offline
                  kiprock
                  wrote on last edited by kiprock
                  If I set to true, it does launch but I cannot see any frame data coming out. I can for the other cameras though.
                  Here is the output of cat /etc/modalai/camera_env.sh
                  export CAM_CONFIG_ID=3
                  export HIRES_CAM_ID=0
                  export TRACKING_CAM_ID=1
                  export STEREO_CAM_ID=2
                  export TOF_CAM_ID=-1
                  I replaced the stereo camera kit (ordered from you guys). Cannot get the RTSP stream to show anything on VLC either, 0 and 1 works but not 2:
                  yocto:/etc/snav# voxl-rtsp -c 2
                  Camera number: 2
                  Simple RTSP starting
                  Connected
                  Started camera 2
                  Created session
                  Video track created
                  Updated camera parameters
                  AE Mode: 1, Exposure: 19425, Gain: 100, AWB Mode: 1
                  rtsp://10.0.0.2:8900/live
                  Started session
                  Ctrl-c or 'kill 4287' to end
                    Are you sure they are all plugged in correctly? Does pin 1 on the stereo flex align for both connecting to the PCB and each sensor to the flex?
                    K 1 Reply Last reply
                      K Offline
                      K Offline
                      kiprock
                      @Chad-Sweet Pretty sure everything is connected properly. Earlier today I started RTSP on the stereo cams and it was working, however I noticed that the left side was super blurry though, so I connected an old cam in it's place, which looked better, then I connected the orig back to double check that it wasn't just a blurry lens. At that point, I could not get anything.
                      If I disconnect the cameras, I cannot run the RTSP server in mode 2, if I connect the cameras, RTSP server runs but nothing shows up in VLC. I could use some help tracking down what is happening.
                        Hopefully you are removing power from the board before changing the camera modules?
                        The board is not designed to handle hot-swapping of MIPI components. The connectors also are only designed for a few dozen insertions, so they are pretty delicate.
                        In short, it seems like you had it working and then changed some components? Did anything else change?
                        • K Offline
                          K Offline
                          kiprock
                          nothing else has changed.
