    Failed to start Stereo Camera Nodelet
    ros camera
    1936
    • A
      abdullah.sorathi
      I get this error every other time. for the first launch it executed perfectly but subsequent lanches throw error. Basically if it run perfectly and if i interrupt it by pressing ctrl + c and than run again it starts saying could not load nodelet. And many a time it says could not open camera ID = 2. Unable to open camera.
      yocto:/# roslaunch voxl_cam_ros stereo.launch
      ... logging to /home/root/.ros/log/a0237ab4-4d5a-11eb-9155-ec5c68cd1745/roslaunch-apq8096-4987.log
      Checking log directory for disk usage. This may take awhile.
      Press Ctrl-C to interrupt
      Done checking log file disk usage. Usage is <1GB.
      started roslaunch server http://10.42.0.157:48704/
      SUMMARY
      PARAMETERS
       * /rosdistro: indigo
       * /rosversion: 1.11.21
       * /stereo/stereo_cam_nodelet/cam_id: 2
       * /stereo/stereo_cam_nodelet/cam_name: stereo
       * /stereo/stereo_cam_nodelet/format: 1
       * /stereo/stereo_cam_nodelet/frame_id: left_stereo
       * /stereo/stereo_cam_nodelet/frame_id_right: right_stereo
       * /stereo/stereo_cam_nodelet/frame_rate: 15
       * /stereo/stereo_cam_nodelet/height: 480
       * /stereo/stereo_cam_nodelet/is_cam_master: True
       * /stereo/stereo_cam_nodelet/is_stereo: True
       * /stereo/stereo_cam_nodelet/skip_n_frames: 0
       * /stereo/stereo_cam_nodelet/width: 640
      NODES
        /stereo/
          stereo_cam_nodelet (nodelet/nodelet)
          stereo_nodelet_manager (nodelet/nodelet)
      auto-starting new master
      process[master]: started with pid [5006]
      ROS_MASTER_URI=http://localhost:11311/
      setting /run_id to a0237ab4-4d5a-11eb-9155-ec5c68cd1745
      process[rosout-1]: started with pid [5020]
      started core service [/rosout]
      process[stereo/stereo_nodelet_manager-2]: started with pid [5036]
      process[stereo/stereo_cam_nodelet-3]: started with pid [5038]
      [ INFO] [1609633720.545179265]: Initializing nodelet with 4 worker threads.
      [ INFO] [1609633720.762515687]: SnapCamDriver Starting
      [ INFO] [1609633720.762910065]: Monotonic offset: 1609633473.790296944
      [FATAL] [1609633726.430193936]: Failed to load nodelet '/stereo/stereo_cam_nodelet` of type `voxl_cam_ros/stereo_driver` to manager `stereo_nodelet_manager'
      [stereo/stereo_nodelet_manager-2] process has died [pid 5036, exit code -11, cmd /opt/ros/indigo/lib/nodelet/nodelet manager __name:=stereo_nodelet_manager __log:=/home/root/.ros/log/a0237ab4-4d5a-11eb-9155-ec5c68cd1745/stereo-stereo_nodelet_manager-2.log].
      log file: /home/root/.ros/log/a0237ab4-4d5a-11eb-9155-ec5c68cd1745/stereo-stereo_nodelet_manager-2*.log
      [stereo/stereo_cam_nodelet-3] process has died [pid 5038, exit code 255, cmd /opt/ros/indigo/lib/nodelet/nodelet load voxl_cam_ros/stereo_driver stereo_nodelet_manager __name:=stereo_cam_nodelet __log:=/home/root/.ros/log/a0237ab4-4d5a-11eb-9155-ec5c68cd1745/stereo-stereo_cam_nodelet-3.log].
      log file: /home/root/.ros/log/a0237ab4-4d5a-11eb-9155-ec5c68cd1745/stereo-stereo_cam_nodelet-3*.log
      ^C[rosout-1] killing on exit
      [master] killing on exit
      shutting down processing monitor...
      ... shutting down processing monitor complete
      done
      yocto:/#
      I even tried setting it as slave and not master as recommended over here [https://docs.modalai.com/voxl-cam-ros/](link url)
      but after showing Monotonic offset it throws error
      • modaltbM
        modaltb ModalAI Team
        Hi @abdullah-sorathi,
        Can you please provide us with your hardware setup? What camera(s) do you have connected?
        Can you also run voxl-version and provide us with the output?
        Travis
        • Chad SweetC
          Chad Sweet ModalAI Team
          Also, only one camera can be master in the libcamera architecture. If voxl-vision-px4 has VOA enabled, and is using the stereo cameras, is_cam_master needs to be set to false. In the log above is_cam_master is set to true
          • A
            abdullah.sorathi @modaltb
            @modaltb
            I am using voxl-flight deck
            cameras are same that comes with flight deck-> stereo camera, hires and optical flow camera
            This is the voxl version currently in use in my setup
            yocto:/# voxl-version
            system-image:    ModalAI 2.5.2 BUILDER: ekatzfey BUILD_TIME: 2020-08-24_00:08
            kernel:          #1 SMP PREEMPT Wed Sep 9 22:28:09 UTC 2020 3.18.71-perf
            factory-bundle:  1.0.1
            architecture:    aarch64
            processor:       apq8096
            os:              GNU/Linux
            voxl-suite:
            Package: voxl-suite
            Version: 0.2.0
            Depends: docker, imu_app (= 0.0.6), libvoxl_io (= 0.5.2), voxl-cam-manager (= 0.2.2), voxl-docker-support (= 1.1.1), voxl-hal3-tof-cam-ros (= 0.0.2), voxl-modem (= 0.10.0), voxl-nodes (= 0.0.8), voxl-rtsp (= 1.0.2), voxl-utils (= 0.5.2), voxl-vision-px4 (= 0.6.8), voxl_imu (= 0.0.4), voxl-time-sync (= 0.0.1), voxl-vpn (= 0.0.2), librc_math (= 1.1.2), libmodal_pipe (= 1.2.2), modalai-vl (= 0.1.3)
            Section: base
            Architecture: armv7a
            Maintainer: james@modalai.com
            MD5Sum: af706cd3c1ea59f274f2ed9b93141f1d
            Filename: voxl-suite_0.2.0.ipk
            Description: meta-package to install all of the voxl-suite
            Installed-Time: 4024
            yocto:/#
            I am currently working with SNAV and followed this [https://docs.modalai.com/snapdragon-navigator/]
            • A
              abdullah.sorathi @Chad Sweet
              @Chad-Sweet
              Yes I tried both setting it to true and false. But once you start launch camera and the terminated and try to launch again it does not launch.
              • K
                kiprock
                @abdullah-sorathi said in Failed to start Stereo Camera Nodelet:
                I have the same problem:
                yocto:~# roslaunch voxl_cam_ros stereo.launch is_cam_master:=false
                ... logging to /home/root/.ros/log/357f3634-ac60-11eb-a8f6-ec5c68cd21c7/roslaunch-apq8096-4646.log
                started roslaunch server http://10.0.0.2:34910/
                SUMMARY
                PARAMETERS
                 * /stereo/stereo_cam_nodelet/is_cam_master: False
                NODES
                  /stereo/
                process[master]: started with pid [4665]
                setting /run_id to 357f3634-ac60-11eb-a8f6-ec5c68cd21c7
                process[rosout-1]: started with pid [4678]
                process[stereo/stereo_nodelet_manager-2]: started with pid [4691]
                process[stereo/stereo_cam_nodelet-3]: started with pid [4696]
                [ INFO] [1620081479.191290494]: Initializing nodelet with 4 worker threads.
                [ INFO] [1620081479.450798205]: SnapCamDriver Starting
                [ INFO] [1620081479.451256697]: Monotonic offset: 1620078140.011942802
                libcam.enable.publish  1
                libcam.enable.publish.dump 0
                libcam.publish.buffer.policy max
                libcam.publish.buffer.max 3
                libcam.debug.level info
                libcam.dump.dir /data/misc/camera/dumps
                ERROR: could not open camera subscriber for cam id 2
                [ERROR] [1620081496.766822127]: CameraManager::Initialize() failed
                [ERROR] [1620081496.767214629]: Unable to open camera.
                Any suggestion on debugging?
                • Chad SweetC
                  The two likely reasons for this error:
                  • incorrect camera ID
                  • is_cam_master not set properly.
                  If you are not running anything that uses the stereo camera, is_cam_master should be true
                  You can check the configured camera IDs by:
                  cat /etc/modalai/camera_env.sh
                  • K
                    kiprock
                    If I set to true, it does launch but I cannot see any frame data coming out. I can for the other cameras though.
                    Here is the output of cat /etc/modalai/camera_env.sh
                    export CAM_CONFIG_ID=3
                    export HIRES_CAM_ID=0
                    export TRACKING_CAM_ID=1
                    export STEREO_CAM_ID=2
                    export TOF_CAM_ID=-1
                    I replaced the stereo camera kit (ordered from you guys). Cannot get the RTSP stream to show anything on VLC either, 0 and 1 works but not 2:
                    yocto:/etc/snav# voxl-rtsp -c 2
                    Camera number: 2
                    Simple RTSP starting
                    Connected
                    Started camera 2
                    Created session
                    Video track created
                    Updated camera parameters
                    AE Mode: 1, Exposure: 19425, Gain: 100, AWB Mode: 1
                    rtsp://10.0.0.2:8900/live
                    Started session
                    Ctrl-c or 'kill 4287' to end
                    • Chad SweetC
                      Are you sure they are all plugged in correctly? Does pin 1 on the stereo flex align for both connecting to the PCB and each sensor to the flex?
                      K 1 Reply Last reply Reply Quote 0
                      • K
                        kiprock @Chad Sweet
                        @Chad-Sweet Pretty sure everything is connected properly. Earlier today I started RTSP on the stereo cams and it was working, however I noticed that the left side was super blurry though, so I connected an old cam in it's place, which looked better, then I connected the orig back to double check that it wasn't just a blurry lens. At that point, I could not get anything.
                        If I disconnect the cameras, I cannot run the RTSP server in mode 2, if I connect the cameras, RTSP server runs but nothing shows up in VLC. I could use some help tracking down what is happening.
                        • Chad SweetC
                          Hopefully you are removing power from the board before changing the camera modules?
                          The board is not designed to handle hot-swapping of MIPI components. The connectors also are only designed for a few dozen insertions, so they are pretty delicate.
                          In short, it seems like you had it working and then changed some components? Did anything else change?
                          • K
                            kiprock
                            nothing else has changed.
