Manoj KashyapM
Manoj Kashyap
@Manoj Kashyap
  • Frame Dropping with PMD TOF LIOW2 (M0169) on VOXL2 Flight Deck - Royale SDK Warnings Persist After Troubleshooting
    Manoj KashyapM Manoj Kashyap
    Subject: Frame Dropping with PMD TOF LIOW2 (M0169) on VOXL2 Flight Deck - Royale SDK Warnings Persist After Troubleshooting
    Hi ModalAI Community/Support,
    I'm working with a VOXL2 Flight Deck and trying to integrate the PMD TOF LIOW2 sensor (part number M0169). Originally, I removed the hi-res camera from J7 Upper and connected the TOF there, but after advice, I switched it to J6 Lower and disabled all other cameras. Unfortunately, I'm still seeing severe frame dropping via Royale SDK warnings in the voxl-camera-server logs.
    Setup Details:
    Hardware: VOXL2 Flight Deck + PMD TOF LIOW2 on J6 Lower (flex cable checked and reseated). I'm using the dual cable which was previously used by the tracking and hi-res cameras.
    Software: voxl-sdk is 1.5
    No other cameras connected/enabled.
    Power: Stable bench supply (5V/3A+).
    What I've Tried:
    Connected TOF to J7U initially (camId:3), saw drops.
    Moved to J6L (camId:0), disabled all other cams—same issue.
    Updated config to minimal TOF-only (tried FPS 15/20/5, decimator 1/2, pre_height 172/180/1629, exposure max 2000-3000).
    Ran voxl-configure-cameras and selected a TOF preset (e.g., C-26 or similar).
    Checked for overheating: Monitored temps via VOXL Portal/voxl-inspect-cam -a—[add your temp readings here, e.g., ~50-60°C with heatsink?].
    Debug mode: voxl-camera-server -d 0 to list modes.
    Updated SDK via apk update && apk upgrade (if applicable).
    Tested in low-light to avoid saturation.
    Logs from Camera Server are:
    configuration for 1 cameras: [TOF config as above]
    connected to mavlink pipe
    Connected to cpu-monitor
    Starting Camera: tof (id #0)
    ------ voxl-camera-server: Started 1 of 1 cameras
    WARNING: [ROYALE_WARNING] {ROYALE_FRAME_DROP}: Dropped 20834 frame(s).
    WARNING: [ROYALE_WARNING] {ROYALE_RAW_FRAME_STATS}: Raw frame drop stats: Bridge 20834 frames dropped, FC 0 frames dropped, 9 frames delivered.
    WARNING: [ROYALE_WARNING] {ROYALE_FRAME_DROP}: Dropped 9 frame(s).
    WARNING: [ROYALE_WARNING] {ROYALE_RAW_FRAME_STATS}: Raw frame drop stats: Bridge 9 frames dropped, FC 0 frames dropped, 171 frames delivered
    The initial massive drop (20k+ frames) happens on startup, then smaller ongoing drops. No frames are usable in apps like VOXL Portal or downstream pipes.
    Has anyone encountered similar Royale bridge/FC drops with this TOF module? Could it be related to using the dual cable from the tracking/hi-res setup? Maybe a cable mismatch, firmware issue, power ripple, or faulty hardware? Any specific config tweaks or SDK versions that fixed this? Appreciate any insights!
    Thanks,
    VOXL SDK and Software camera
  • M0169 integration with VOXL2 flight deck
    Re: M0169 integration with VOXL 2 Mini?
    I am trying to connect M0169 with VOXL2 using J7U(i e removing the Hires camera) id3 .Do I need an external 5V supply or Please let me know how to connect it and make it work.
  • Calibraation files not saving and camera intrinsics failing
    @Moderator Even I am facing the same issue. Did everything as per the instructions on the official website. But unable to calibrate the stereo front. I was able to calibrate stereo back though. I have attached the error along for your reference.
  • How to do Perfect Mapping only using Stereocameras
    @tom can anyone help me with this
    @Alex-Kushleyev @Moderator
    What should be the best Voxel size and Esdf Max distance as our drone radius is 0.25
    ERROR in pipe_server_write_point_cloud, received NULL data pointer
    this is also showcasing
    Hey,
    I want to make a 3D map using the voxl-mapper using stereocams only and getting VIO by tracking cam and imu .
    i have VOXL2 flight deck
    what parameters should i use to get the perfect Map Screenshot from 2025-05-16 15-35-25.png
    go through my photo
