  3. M0169 integration with VOXL 2 Mini?
Scheduled Pinned Locked Moved ESCs, Sensors and Accessories
image-sensor
2 Posts 2 Posters 709 Views 1 Watching
  • ModeratorM Offline
    Is there a recommended way to supply the external 5V power required on M0169 with VOXL 2 Mini?
    VinnyV 1 Reply Last reply
    • ModeratorM Moderator
      VinnyV Offline
      VinnyV Offline
      Vinny
      We do not have a clean solution for this combination of parts since VOXL 2 Mini does not have a 5V power module. The approach will be "clunky" at best at the moment by using an additional 5V power source somewhere in your system.
      When our Voxl2 dedicated version of the new ToF adapter is ready (M0171) we should have better integration to support at least 1 ToF module using our on-board 5V regulator, but it will be limited to only 1 ToF, and may prevent high-current USB use cases.
      Once we have the working solution(s), we can explain better.
      Please stay tuned.
