    Calibraation files not saving and camera intrinsics failing
    GPS-denied Navigation (VIO)
    • Idan FikselI
      Idan Fiksel
      Hi everyone,
      Im using the Starling V2 board on a VOXL2 which is integrated on a custom drone. Currently I'm trying to set up VIO on the drone. I configured the camera extrinsics, calibrated the IMU. I went through the process of calibrating the gyro, accel, mag, baro, and level horizon on px4 through QGC. When I check for the files they are not saved:
      voxl2 (M0054):~$ voxl-check-calibration
      Calibration File Status:
      Present /data/modalai/voxl-imu-server.cal
      Present /data/px4/param/parameters_gyro.cal
      Missing /data/px4/param/parameters_acc.cal
      Missing /data/px4/param/parameters_level.cal
      Missing /data/px4/param/parameters_baro_tc.cal
      Missing /data/px4/param/parameters_mag.cal
      Detected Missing Calibration Files
      please run the required cals
      https://docs.modalai.com/calibration/
      when I try to run qVIO server it failes because it is missing the opencv_tracking_front_intrinsics.yml. I've bee going throught the process of calibrating the tracking cameras with the 9x6 checker boards but its constantly failing. it says it most likely due to motion blur. the tracking cam im using is the AR0144 forward and down.
      I've been running this line "sudo voxl-calibrate-camera tracking_front -s 9x6 0.023". I tried it also with fisheye but that didn't work as well.
      Can someone provide a possible reasoning for this or share some tips to complete these steps?
      @QSL
      • ModeratorM
        Moderator ModalAI Team @Idan Fiksel
        @Idan-Fiksel Is the calibration card mounted to a hard backing piece so there are no warps or wrinkles in the checkerboard?
        Did you print with a PDF so that the checkerboard measurements are accurate?
        Idan FikselI Q Manoj KashyapM 3 Replies Last reply Reply Quote 0
        • Idan FikselI
          Idan Fiksel @Moderator
          @Moderator The checker board was glued to cardboard as a backing. I printed the 9x6 as a PDF. The size of the squares are ~23mm is the the correct size?
          • Q
            QSL @Moderator
            @Moderator any additional assistance? What would cause these calibration files to fail to save?
            • Manoj KashyapM
              Manoj Kashyap @Moderator
              @Moderator Even I am facing the same issue. Did everything as per the instructions on the official website. But unable to calibrate the stereo front. I was able to calibrate stereo back though. I have attached the error along for your reference.
