M. al-khatibM
M. al-khatib
@M. al-khatib
  • 5G modem
    M. al-khatibM M. al-khatib
    @tom
    My video link has a weak signal. How can I improve the signal to achieve a 4K video stream for Q Ground Control? Additionally, I have another question: I'm using a 5G SIM card, but when I connect it to the modem, my PC doesn't receive internet.
    Development Drones sentinel
  • 5G modem
    @tom
    How can I determine the type of network (3G, 4G, 5G) that I'm currently connected to, and shouldn't the modem grant me an internet connection when I'm in the process of connecting to it?
  • 5G modem
    @tom
    Can you provide me the steps to connect it to VPN ?
  • 5G modem
    After using this commands and connect my PC to Tailscale what can i do ?
  • 5G modem
    @Eric-Katzfey
    Can you provide me the operating steps?
  • 5G modem
    Do I need a 5G network to utilize the Voxal Sentinel 5G modem?
  • No GPs lock for vehicle
    @Eric-Katzfey
    Okay, I'm done, and the drone got GPS this is video link.
    https://drive.google.com/file/d/1XfcMhyPKbJYDFnPwljM3zM7MbZWcx4op/view?usp=sharing
    However, I mistakenly used the power adapter instead of the battery when I unplugged it to switch to flight on battery mode, so there was no GPS signal.
    my sdk now is 1.0.0
    and my firmware Version 1.14.0dev
    @Eric-Katzfey said in No GPs lock for vehicle:
    px4-versions
    modalai-slpi/now 1.0-7 arm64 [installed,local]
    px4-rb5-flight/now 1.4-11 arm64 [installed,local]
    px4-support/now 1.0-5 arm64 [installed,local]
    python3-px4sitl/bionic 0.0.2-100 all
    ros-melodic-px4-msgs/bionic 1.0.0-1bionic.20210505.094529 arm64
    voxl-px4-imu-server/unknown,now 0.1.1 arm64 [installed,automatic]
    voxl-vision-px4/unknown,now 1.0.5 arm64 [installed,automatic]
    libfc-sensor/now 1.0-2 arm64 [installed,local]
    1.2.1-M0054-14.1a-perf
    /etc/modalai/voxl-px4.config
    empty file
    @M-al-khatib @Eric-Katzfey @modaltb ??
    @M-al-khatib
    While presently utilizing the exact same parameter, the QGS occasionally presents a GPS error, whereas at other instances, it indicates normal GPS functionality.
    @Eric-Katzfey
    I have now arrived at this stage, yet my GPS count remains at zero.
    @Eric-Katzfey
    "I can't find the command 'qshell gps start -d 7 -b 115200' or 'qshell gps start' in the file '/etc/modalai/voxl-px4.config'."
    @Eric-Katzfey
    my test.txt file same as the Samer Jaradat file.
    @Eric-Katzfey
    this is the output
    @modaltb said in No GPs lock for vehicle:
    Hi @M-al-khatib , unless I move my vehicle outside and it has a view of the sky does the GPS get satellites. Are you trying to do the GPS test in an environment that isn't 'shielded' like indoors?
    Yes, I conducted an outdoor test with specific parameters, focusing on essential factors. The test revealed that there was no GPS signal for the vehicle, and the information indicated that the GPS functionality was disabled. Throughout the test, the GPS count consistently remained at zero, with no HDOP readings available.Capture1.PNG Capture.PNG
