Kashish GargK
Kashish Garg
@Kashish Garg
  • MAVROS: `waiting for offboard mode` still loading
    Kashish GargK Kashish Garg
    @Denver-Bennett were you able to find a solution to this? same issue on our end
    VOXL SDK and Software ros
  • MAVRS: offboard mode issues, ./run_mavros_test.sh
    @Denver-Bennett Were you able to find a solution to this? same issue on my end
  • Mavros/local_position/odom Z-Axis drift
    @Riccardo-Franceschini We were not able to resolve this issue. However because our control stack is sending TRPY commands to mavros, this didn't come into play at all. The concern for us originated when the drone was taking off significantly higher than commanded. It turned out the propeller coefficients we received from ModalAI were insufficient.
    @Kashish-Garg Just bumping to get a hand with this. i have tried disabling Baro sensors and playing with enabling/disabling other sensors. Its clear the mavros/vision/pose is accurate, but on the z-axis in local_position is drifting/showing significant error. Any help is greatly appreciated!
    Hello, we are running into an issue where the qvio-server doesn't match with the odometry msgs published on /mavros/local_position/odom on the Starling platform.
    I have run plotted the qvio and mavros/local_position odometries over time and there is an extensive divergence with the platform completely still
  • .bashrc and .bash_profile for Starling2
    We accidentally deleted the bashrc and bash profile for the starling 2 and wanted to see if I could be pointed to those files to place them back on the Starling2.
    Thanks,
    Kashish Garg
  • Unable to retrieve camera information
    @Riccardo-Franceschini We have the same question, were you able to receive any update on this?
  • Starling 2 qvio/odometry covariance all zeroes
    I read that the "quality" reported by the qvio process is generated from the covariance matrix of the onboard state estimation.
    After running voxl_mpa_to_ros, these covariance values are all set to zero.
    Is there any work around/configuration for the starling to report the actual covariance values it uses to generate the quality?
  • Questions for VOXL2 and Sentinel
    @modaltb Hello, I was curious if there were any new plans to support Ubuntu20 in an upcoming System Image release. I apologize if this question gets asked to death, I am new to these forums.
    Thanks
