G
greg_s
@greg_s
  • Starling 2 not following navigation path
    G greg_s
    Hello @Cliff-Wong,
    The figure 8 no longer works. It is now crashing into the netting in the room after starting the figure 8 mode. Though, it did in the past.
    Here is the screen recording as it was happening Link
    I also notice that it seems a sensor on the bottom has come loose due to the crashes sustained while trying to test the navigation. As well as the battery retention clips has broken off. Link
    G greg_s
    Hello @Cliff-Wong,
    If there is any additional information or method I should try, just let me know.
    G greg_s
    Hello @Cliff-Wong,
    I tried reproducing your suggestion. The first time I tried, it seems to work fine. After landing and trying again (I stopped and restarted the voxl-mapper and voxl-vision-hub), I few around to update the map again as it reloaded. I planned a route that was straight ahead for the drone. Instead of following the path shown in the 3D mapper, it flew diagonally upward and hit the ceiling. I captured a video similar to yours to show the result. Also note, I ran the update to get the latest patch version of the voxl sdk. After running the update twice, it updated some packages but the patch number remained 2. So this was run with 1.6.2 sdk version, unless something else messed up with the update. I did capture a log of the update I ran if that would be helpful.
    Link to video
    G greg_s
    @Cliff-Wong. For completeness below is the output of the start of voxl-vision-hub --debug_offboard. I trimmed the entire output above until the drone started to move from the plan_to command.
    voxl2:~$ voxl-vision-hub --debug_offboard
    VOXL FLIGHT CONTROLLER (VFC)
    always_on 0
    vfc_rate 100.000000
    vfc_rc_chan_min 980
    vfc_rc_chan_max 2020
    vfc_thrust_ch 3
    vfc_roll_ch 1
    vfc_pitch_ch 2
    vfc_yaw_ch 4
    vfc_submode_ch 6
    vfc_backtrack_seconds : 60
    vfc_backtrack_rc_chan : 10
    vfc_backtrack_rc_thresh : 1500
    vfc_alt_mode_rc_min 0
    vfc_alt_mode_rc_max 0
    vfc_flow_mode_rc_min 1700
    vfc_flow_mode_rc_max 2100
    vfc_hybrid_flow_mode_rc_min 0
    vfc_hybrid_flow_mode_rc_max 0
    vfc_position_mode_rc_min 1300
    vfc_position_mode_rc_max 1700
    vfc_traj_mode_rc_min 0
    vfc_traj_mode_rc_max 0
    vfc_yaw_deadband 30
    vfc_vxy_deadband 50
    vfc_vz_deadband 150
    vfc_min_thrust 0.000000
    vfc_max_thrust 0.800000
    vfc_tilt_max 0.436000
    vfc_yaw_rate_max 3.000000
    vfc_thrust_hover 0.250000
    vfc_vz_max 1.000000
    vfc_kp_z 5.000000
    vfc_ki_z 0.500000
    vfc_ki_z_max 0.300000
    vfc_kd_z 4.000000
    vfc_vxy_max 3.000000
    vfc_kp_xy 0.640000
    vfc_kd_xy 2.560000
    vfc_kp_z_vio 5.000000
    vfc_ki_z_vio 0.700000
    vfc_kd_z_vio 5.000000
    vfc_kp_xy_vio 6.000000
    vfc_kd_xy_vio 4.000000
    vfc_w_filt_xy_vio 10.000000
    vfc_w_filt_xy_flow 3.000000
    vfc_vel_ff_factor_vio 0.500000
    vfc_xy_acc_limit_vio 3.000000
    vfc_max_z_delta 3.000000
    vfc_att_transition_time 0.500000
    vfc_stick_move_threshold 30.000000
    vfc_flow_transition_time 1.000000
    vfc_q_min 15
    vfc_points_min 0
    vfc_en_submode_announcement 1
    vfc_en_backtrack_heading_hold 0
    vfc_disable_fallback 0
    loading our own config file
    Parameters as loaded from config file:
    config_file_version: 1
    MAVROS / MAVSDK
    en_localhost_mavlink_udp 0
    localhost_udp_port_number: 14551
    VIO
    en_vio: 1
    vio_pipe: qvio
    secondary_vio_pipe: ov
    en_reset_vio_if_initialized_inverted: 1
    vio_warmup_s: 3.000000
    send_odom_while_failed: 1
    MISC FEATURES
    horizon_cal_tolerance: 0.500000
    en_hitl: 0
    OFFBOARD MODE
    offboard_mode: trajectory
    follow_tag_id: 0
    figure_eight_move_home: 1
    tracking_trigger_ch: 12
    tracking_trigger_ch_thresh_temp: 1200
    tracking_trigger_ch_thresh_new: 1800
    wps_move_home: 1
    wps_timeout: 0.000000
    wps_damp: 1.000000
    wps_vfc_mission: true
    wps_vfc_mission_loop: false
    wps_vfc_mission_to_ramp: 25.000000
    wps_vfc_mission_cruise_speed: 1.000000
    wps_vfc_mission_to_kp: 0.100000
    robot_radius: 0.300000
    collision_sampling_dt: 0.100000
    max_lookahead_distance: 1.000000
    FIXED FRAME RELOCALIZATION
    en_tag_fixed_frame: 0
    fixed_frame_filter_len: 5
    en_transform_mavlink_pos_setpoints_from_fixed_frame:0
    COLLISION PREVENTION (VOA)
    en_voa: 1
    voa_upper_bound_m: -0.150000
    voa_lower_bound_m: 0.150000
    voa_memory_s: 1.000000
    voa_max_pc_per_fusion: 100
    voa_pie_min_dist_m: 0.250000
    voa_pie_max_dist_m: 20.000000
    voa_pie_under_trim_m: 1.000000
    voa_pie_threshold: 3
    voa_pie_slices: 36
    voa_pie_bin_depth_m: 0.150000
    voa_send_rate_hz: 20.000000
    voa_input #0
    enabled: 1
    type: point_cloud
    input_pipe: dfs_point_cloud
    frame: stereo_l
    max_depth: 8.000000
    min_depth: 0.300000
    cell_size: 0.080000
    threshold: 4
    x_fov_deg: 68.000000
    y_fov_deg: 56.000000
    conf_cutoff: 0
    voa_input #1
    enabled: 1
    type: point_cloud
    input_pipe: stereo_front_pc
    frame: stereo_front_l
    max_depth: 8.000000
    min_depth: 0.300000
    cell_size: 0.080000
    threshold: 4
    conf_cutoff: 0
    voa_input #2
    enabled: 1
    type: point_cloud
    input_pipe: stereo_rear_pc
    frame: stereo_rear_l
    max_depth: 8.000000
    min_depth: 0.300000
    cell_size: 0.080000
    threshold: 4
    conf_cutoff: 0
    voa_input #3
    enabled: 1
    type: tof
    input_pipe: tof
    frame: tof
    max_depth: 6.000000
    min_depth: 0.150000
    cell_size: 0.080000
    threshold: 3
    x_fov_deg: 106.500000
    y_fov_deg: 85.099998
    conf_cutoff: 125
    voa_input #4
    enabled: 1
    type: rangefinder
    input_pipe: rangefinders
    frame: body
    max_depth: 8.000000
    min_depth: 0.300000
    cell_size: 0.080000
    threshold: 4
    conf_cutoff: 0
    loading extrinsics config file
    loading horizon cal file
    existing instance of voxl-vision-hub found, attempting to stop it
    starting geometry module
    starting autopilot monitor
    starting mavlink IO
    Waiting to connect to voxl-mavlink-server
    Connected to voxl-mavlink-server
    starting fixed pose input
    starting vio manager
    Connected to VIO pipe: ov
    Geometry module updating to use imu: imu_apps_body for VIO
    ERROR in vcc_fetch_extrinsic, failed to find desired extrinsic relation in file
    Likely you need to run voxl-configure-extrinsics to make a new file
    ERROR: /etc/modalai/extrinsics.conf missing body to imu_apps_body, sticking with identity for now
    Detected Autopilot Mavlink SYSID 1
    requesting autopilot_version
    Detected autopilot version: 1.14.0
    starting tag manager
    starting voa manager
    ERROR in pipe_client_open, channel 11 already running
    Connected to VOA input pipe: tof
    starting horizon cal module
    starting imu manager
    starting state manager
    starting offboard trajectory
    Connected to voxl-mapper
    voxl-mapper pipe size is: 65536 bytes
    Init complete
    Trajectory Monitor connected to voa pointcloud
    commanding: XYZ -1.0 -0.1 -2.3 yaw: 0.1
    WARNING in VOA manager, no attitude data from px4
    G greg_s
    Hello @Cliff-Wong,
    I collected the output from voxl-vision-hub --debug_offboard and voxl-inspect-vins -n. I place a plan_to point that was about half a meter from the drone and slightly higher in altitude from the drone. I used the arrows to position the plan_to point and rotated camera to ensure the plan_to point it was placed correctly. I reduced the rrt_min_distance and esdf_inner_sphere_radius as suggested. The drone had more than a meter clearance on all sides. The room is empty with no obstacles.
    The output from voxl-vision-hub --debug_offboard:
    commanding: XYZ -1.0 -0.1 -2.4 yaw: 2.6
    Setpoint position: XYZ -1.0 -0.1 -0.8 yaw: 0.4
    Received trajectory has duration 3.309723 seconds
    Received load and start command.
    commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.0 A: 0.0 0.0 -0.0
    commanding: XYZ -1.0 -0.1 0.1 yaw: 0.5 V: 0.0 0.0 -0.0 A: 0.0 0.0 -0.0
    commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.0 A: 0.0 0.0 -0.1
    commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.0 A: 0.1 0.0 -0.2
    commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.0 A: 0.1 0.0 -0.3
    commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.0 A: 0.1 0.1 -0.3
    commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.0 A: 0.2 0.1 -0.4
    commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.1 A: 0.2 0.1 -0.4
    commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.1 A: 0.2 0.1 -0.5
    commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.1 A: 0.3 0.1 -0.5
    commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.0 0.0 -0.1 A: 0.3 0.1 -0.6
    commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.1 0.0 -0.1 A: 0.4 0.1 -0.6
    commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.1 0.0 -0.2 A: 0.4 0.2 -0.6
    commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.1 0.0 -0.2 A: 0.5 0.2 -0.6
    Received trajectory has duration 2.234033 seconds
    Received insert command.
    commanding: XYZ -1.0 -0.1 0.1 yaw: 0.4 V: 0.1 0.1 -0.2 A: 0.5 0.2 -0.6
    commanding: XYZ -1.0 -0.1 0.0 yaw: 0.4 V: 0.2 0.1 -0.3 A: 0.5 0.2 -0.6
    commanding: XYZ -1.0 -0.1 0.0 yaw: 0.4 V: 0.2 0.1 -0.3 A: 0.6 0.2 -0.6
    commanding: XYZ -1.0 -0.1 0.0 yaw: 0.4 V: 0.2 0.1 -0.3 A: 0.6 0.2 -0.5
    commanding: XYZ -0.9 -0.1 -0.0 yaw: 0.4 V: 0.2 0.1 -0.3 A: 0.6 0.2 -0.5
    commanding: XYZ -0.9 -0.1 -0.0 yaw: 0.4 V: 0.3 0.1 -0.4 A: 0.6 0.2 -0.5
    commanding: XYZ -0.9 -0.1 -0.0 yaw: 0.4 V: 0.3 0.1 -0.4 A: 0.6 0.2 -0.4
    commanding: XYZ -0.9 -0.1 -0.1 yaw: 0.4 V: 0.3 0.1 -0.4 A: 0.6 0.2 -0.4
    commanding: XYZ -0.9 -0.1 -0.1 yaw: 0.4 V: 0.3 0.1 -0.4 A: 0.6 0.3 -0.4
    commanding: XYZ -0.9 -0.1 -0.1 yaw: 0.4 V: 0.4 0.1 -0.4 A: 0.6 0.3 -0.4
    commanding: XYZ -0.9 -0.1 -0.1 yaw: 0.4 V: 0.4 0.2 -0.4 A: 0.6 0.3 -0.4
    commanding: XYZ -0.9 -0.1 -0.1 yaw: 0.4 V: 0.4 0.2 -0.4 A: 0.6 0.2 -0.4
    commanding: XYZ -0.8 -0.1 -0.1 yaw: 0.4 V: 0.4 0.2 -0.5 A: 0.6 0.2 -0.4
    commanding: XYZ -0.8 -0.1 -0.1 yaw: 0.4 V: 0.4 0.2 -0.5 A: 0.6 0.3 -0.4
    commanding: XYZ -0.8 -0.1 -0.2 yaw: 0.4 V: 0.4 0.2 -0.5 A: 0.6 0.3 -0.4
    commanding: XYZ -0.8 -0.1 -0.2 yaw: 0.4 V: 0.5 0.2 -0.5 A: 0.6 0.3 -0.4
    commanding: XYZ -0.8 -0.0 -0.2 yaw: 0.4 V: 0.5 0.2 -0.5 A: 0.6 0.3 -0.3
    commanding: XYZ -0.8 -0.0 -0.2 yaw: 0.4 V: 0.5 0.2 -0.5 A: 0.6 0.2 -0.3
    commanding: XYZ -0.7 -0.0 -0.2 yaw: 0.4 V: 0.6 0.2 -0.5 A: 0.6 0.2 -0.3
    commanding: XYZ -0.7 -0.0 -0.3 yaw: 0.4 V: 0.6 0.2 -0.5 A: 0.6 0.2 -0.3
    commanding: XYZ -0.7 -0.0 -0.3 yaw: 0.4 V: 0.6 0.2 -0.6 A: 0.6 0.2 -0.2
    commanding: XYZ -0.7 0.0 -0.3 yaw: 0.4 V: 0.6 0.3 -0.6 A: 0.5 0.2 -0.2
    Received trajectory has duration 1.689594 seconds
    commanding: XYZ -0.6 0.0 -0.3 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.5 0.2 -0.2
    commanding: XYZ -0.6 0.0 -0.4 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.5 0.2 -0.1
    commanding: XYZ -0.6 0.0 -0.4 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.4 0.2 -0.1
    commanding: XYZ -0.6 0.0 -0.4 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.4 0.1 -0.1
    commanding: XYZ -0.5 0.1 -0.4 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.4 0.1 -0.1
    commanding: XYZ -0.5 0.1 -0.4 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.3 0.1 -0.0
    commanding: XYZ -0.5 0.1 -0.5 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.3 0.1 -0.0
    commanding: XYZ -0.5 0.1 -0.5 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.3 0.1 0.0
    Received trajectory has duration 1.165000 seconds
    commanding: XYZ -0.4 0.1 -0.5 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.2 0.1 0.1
    Received trajectory has duration 1.342931 seconds
    commanding: XYZ -0.4 0.1 -0.5 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.1 0.0 0.1
    commanding: XYZ -0.4 0.1 -0.5 yaw: 0.4 V: 0.7 0.3 -0.6 A: 0.0 -0.0 0.2
    commanding: XYZ -0.3 0.1 -0.6 yaw: 0.4 V: 0.7 0.3 -0.6 A: -0.0 -0.0 0.2
    commanding: XYZ -0.3 0.1 -0.6 yaw: 0.4 V: 0.7 0.3 -0.6 A: -0.1 -0.0 0.2
    commanding: XYZ -0.3 0.1 -0.6 yaw: 0.4 V: 0.7 0.3 -0.5 A: -0.1 -0.1 0.3
    commanding: XYZ -0.3 0.2 -0.6 yaw: 0.4 V: 0.7 0.3 -0.5 A: -0.2 -0.1 0.3
    commanding: XYZ -0.2 0.2 -0.6 yaw: 0.4 V: 0.7 0.3 -0.5 A: -0.2 -0.1 0.3
    commanding: XYZ -0.2 0.2 -0.7 yaw: 0.4 V: 0.7 0.3 -0.5 A: -0.3 -0.1 0.3
    commanding: XYZ -0.2 0.2 -0.7 yaw: 0.4 V: 0.7 0.3 -0.5 A: -0.3 -0.1 0.4
    commanding: XYZ -0.2 0.2 -0.7 yaw: 0.4 V: 0.7 0.3 -0.5 A: -0.4 -0.2 0.4
    Received trajectory has duration 1.508897 seconds
    commanding: XYZ -0.1 0.2 -0.7 yaw: 0.4 V: 0.7 0.3 -0.5 A: -0.5 -0.2 0.4
    commanding: XYZ -0.1 0.2 -0.8 yaw: 0.4 V: 0.6 0.2 -0.4 A: -0.5 -0.2 0.4
    commanding: XYZ -0.0 0.2 -0.8 yaw: 0.4 V: 0.6 0.2 -0.4 A: -0.5 -0.2 0.4
    commanding: XYZ -0.0 0.3 -0.8 yaw: 0.4 V: 0.5 0.2 -0.4 A: -0.6 -0.2 0.4
    commanding: XYZ -0.0 0.3 -0.8 yaw: 0.4 V: 0.5 0.2 -0.3 A: -0.6 -0.2 0.5
    commanding: XYZ 0.0 0.3 -0.8 yaw: 0.4 V: 0.5 0.2 -0.3 A: -0.6 -0.2 0.5
    commanding: XYZ 0.0 0.3 -0.8 yaw: 0.4 V: 0.5 0.2 -0.3 A: -0.7 -0.3 0.5
    commanding: XYZ 0.1 0.3 -0.8 yaw: 0.4 V: 0.4 0.2 -0.3 A: -0.7 -0.3 0.5
    commanding: XYZ 0.1 0.3 -0.9 yaw: 0.4 V: 0.4 0.2 -0.3 A: -0.7 -0.3 0.5
    commanding: XYZ 0.1 0.3 -0.9 yaw: 0.4 V: 0.4 0.1 -0.2 A: -0.7 -0.3 0.5
    commanding: XYZ 0.1 0.3 -0.9 yaw: 0.4 V: 0.3 0.1 -0.2 A: -0.5 -0.2 0.4
    commanding: XYZ 0.1 0.3 -0.9 yaw: 0.4 V: 0.2 0.1 -0.2 A: -0.5 -0.2 0.3
    commanding: XYZ 0.1 0.3 -0.9 yaw: 0.4 V: 0.2 0.1 -0.1 A: -0.5 -0.2 0.3
    commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.2 0.1 -0.1 A: -0.5 -0.2 0.3
    commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.2 0.1 -0.1 A: -0.4 -0.2 0.3
    commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.1 0.1 -0.1 A: -0.4 -0.2 0.3
    commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.1 0.0 -0.1 A: -0.4 -0.1 0.3
    commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.1 0.0 -0.1 A: -0.4 -0.1 0.2
    commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.1 0.0 -0.1 A: -0.3 -0.1 0.2
    commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.1 0.0 -0.0 A: -0.3 -0.1 0.2
    commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.0 0.0 -0.0 A: -0.2 -0.1 0.1
    commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.0 0.0 -0.0 A: -0.1 -0.1 0.1
    commanding: XYZ 0.2 0.3 -0.9 yaw: 0.4 V: 0.0 0.0 -0.0 A: -0.1 -0.0 0.1
    commanding: XYZ 0.2 0.3 -0.9 yaw: 0.3 V: 0.0 0.0 -0.0 A: -0.1 -0.0 0.1
    commanding: XYZ 0.2 0.3 -0.9 yaw: 0.3 V: 0.0 0.0 -0.0 A: -0.1 -0.0 0.0
    commanding: XYZ 0.2 0.3 -0.9 yaw: 0.2 V: 0.0 0.0 -0.0 A: -0.1 -0.0 0.0
    commanding: XYZ 0.2 0.3 -0.9 yaw: -2.8 V: -0.0 -0.0 0.0 A: -0.0 -0.0 0.0
    Received stop command.
    Stopped following trajectory.
    commanding: XYZ -1.0 -0.1 -1.5 yaw: 0.5
    The output from voxl-inspect-vins -n:
    dt(ms) | T_imu_wrt_vio (m) |Roll Pitch Yaw (deg)|features|quality| state| error_codes
    33.1 | -1.01 -0.14 -0.79| 1.6 -0.5 148.0| 22 | 78% | OKAY |
    33.6 | -1.01 -0.14 -0.79| 1.6 -0.4 148.0| 22 | 78% | OKAY |
    33.3 | -1.01 -0.14 -0.79| 1.6 -0.4 148.0| 22 | 78% | OKAY |
    33.1 | -1.01 -0.14 -0.79| 1.6 -0.4 148.0| 22 | 78% | OKAY |
    33.3 | -1.01 -0.14 -0.79| 1.6 -0.4 147.9| 22 | 78% | OKAY |
    33.6 | -1.01 -0.14 -0.79| 1.5 -0.4 147.9| 22 | 78% | OKAY |
    33.1 | -1.01 -0.14 -0.79| 1.4 -0.4 147.9| 22 | 78% | OKAY |
    33.3 | -1.01 -0.14 -0.79| 1.4 -0.4 147.8| 22 | 78% | OKAY |
    33.3 | -1.01 -0.14 -0.79| 1.5 -0.5 147.8| 22 | 78% | OKAY |
    33.3 | -1.01 -0.14 -0.79| 1.5 -0.5 147.7| 22 | 78% | OKAY |
    33.6 | -1.01 -0.14 -0.79| 1.4 -0.5 147.7| 22 | 78% | OKAY |
    33.1 | -1.01 -0.14 -0.79| 1.4 -0.5 147.6| 22 | 78% | OKAY |
    33.3 | -1.01 -0.15 -0.79| 1.4 -0.4 147.6| 22 | 78% | OKAY |
    33.3 | -1.01 -0.15 -0.79| 1.4 -0.5 147.3| 22 | 74% | OKAY |
    33.6 | -1.01 -0.15 -0.78| 1.1 -0.6 145.1| 21 | 70% | OKAY |
    33.1 | -1.01 -0.14 -0.77| 1.0 -0.6 141.2| 20 | 70% | OKAY |
    33.5 | -1.01 -0.14 -0.75| 0.8 -0.7 137.8| 19 | 65% | OKAY |
    33.1 | -1.01 -0.14 -0.73| 0.6 -0.7 134.0| 25 | 75% | OKAY |
    33.3 | -1.00 -0.14 -0.70| 0.5 -0.6 129.9| 26 | 83% | OKAY |
    33.3 | -1.00 -0.14 -0.68| 0.6 -0.5 125.6| 24 | 82% | OKAY |
    33.3 | -1.00 -0.14 -0.65| 0.7 -0.4 121.1| 26 | 100% | OKAY |
    33.3 | -1.00 -0.13 -0.62| 0.8 -0.2 116.4| 27 | 100% | OKAY |
    33.3 | -1.00 -0.13 -0.60| 1.0 -0.1 111.5| 27 | 99% | OKAY |
    33.3 | -0.99 -0.13 -0.57| 1.2 0.0 106.5| 23 | 100% | OKAY |
    33.3 | -0.99 -0.13 -0.54| 1.3 0.2 101.4| 18 | 73% | OKAY |
    33.3 | -0.99 -0.13 -0.52| 1.3 0.3 96.3| 17 | 73% | OKAY |
    33.3 | -0.99 -0.13 -0.49| 1.4 0.5 91.1| 17 | 65% | OKAY |
    33.4 | -0.98 -0.13 -0.46| 1.4 0.8 85.8| 17 | 69% | OKAY |
    33.3 | -0.98 -0.13 -0.43| 1.5 1.0 80.6| 18 | 77% | OKAY |
    33.3 | -0.98 -0.13 -0.40| 1.5 1.3 75.2| 17 | 60% | OKAY |
    33.3 | -0.98 -0.13 -0.37| 1.5 1.5 70.0| 16 | 52% | OKAY |
    33.3 | -0.97 -0.13 -0.34| 1.6 1.6 65.0| 16 | 68% | OKAY |
    33.3 | -0.97 -0.13 -0.32| 1.7 1.7 60.3| 13 | 51% | OKAY |
    33.3 | -0.97 -0.13 -0.29| 1.8 1.7 56.0| 12 | 68% | OKAY |
    33.3 | -0.97 -0.13 -0.26| 2.0 1.7 52.1| 14 | 56% | OKAY |
    33.3 | -0.97 -0.13 -0.23| 2.2 1.7 48.5| 18 | 77% | OKAY |
    33.5 | -0.97 -0.13 -0.20| 2.3 1.7 45.4| 25 | 99% | OKAY |
    33.1 | -0.97 -0.13 -0.17| 2.4 1.9 42.6| 24 | 87% | OKAY |
    33.6 | -0.97 -0.13 -0.14| 2.4 1.8 40.1| 27 | 100% | OKAY |
    33.1 | -0.97 -0.13 -0.11| 2.4 1.7 37.9| 29 | 100% | OKAY |
    33.3 | -0.98 -0.13 -0.08| 2.4 1.4 36.1| 28 | 96% | OKAY |
    33.3 | -0.98 -0.13 -0.05| 2.2 1.1 34.4| 26 | 100% | OKAY |
    33.3 | -0.98 -0.13 -0.02| 2.1 0.9 33.1| 24 | 91% | OKAY |
    33.3 | -0.98 -0.13 0.01| 1.9 0.4 31.9| 28 | 100% | OKAY |
    33.3 | -0.99 -0.13 0.04| 1.6 0.0 30.9| 22 | 99% | OKAY |
    33.3 | -0.99 -0.12 0.07| 1.4 -0.0 30.1| 23 | 98% | OKAY |
    33.3 | -0.99 -0.12 0.10| 1.1 0.1 29.4| 20 | 86% | OKAY |
    33.3 | -1.00 -0.12 0.13| 0.6 -0.1 28.9| 16 | 80% | OKAY |
    33.3 | -1.00 -0.12 0.13| 2.0 -1.4 28.8| 13 | 60% | OKAY |
    33.3 | -1.00 -0.13 0.12| 6.1 -3.1 28.5| 11 | 59% | OKAY |
    33.3 | -1.00 -0.13 0.13| 9.5 -2.7 28.3| 15 | 52% | OKAY |
    33.3 | -1.00 -0.13 0.13| 8.4 1.1 28.4| 15 | 52% | OKAY |
    33.3 | -1.00 -0.14 0.14| 1.3 -0.1 27.9| 16 | 52% | OKAY |
    33.3 | -1.00 -0.14 0.14| 0.1 0.6 27.3| 17 | 57% | OKAY |
    33.3 | -1.00 -0.14 0.14| 0.7 0.6 27.3| 17 | 57% | OKAY |
    33.3 | -1.00 -0.14 0.14| 0.0 0.5 27.2| 16 | 52% | OKAY |
    33.3 | -1.00 -0.14 0.14| 0.0 0.7 26.9| 16 | 52% | OKAY |
    33.5 | -1.00 -0.13 0.13| 0.1 0.6 27.0| 16 | 52% | OKAY |
    33.1 | -1.00 -0.13 0.13| 0.1 0.5 26.9| 16 | 52% | OKAY |
    33.3 | -1.00 -0.13 0.13| 0.2 0.5 26.9| 20 | 65% | OKAY |
    33.3 | -1.00 -0.13 0.13| 0.0 0.6 26.9| 20 | 65% | OKAY |
    33.6 | -1.00 -0.13 0.13| 0.0 0.5 26.9| 20 | 65% | OKAY |
    33.1 | -1.00 -0.13 0.13| 0.0 0.6 26.9| 20 | 65% | OKAY |
    I am not sure if the Portal is creating/sending the correct point shown on the map. Is there a way to send a point via the command line? I couldn't find anything specific for this.
    G greg_s
    Hello @ApoorvThapliyal,
    Is there anything that looks wrong or off about the configuration? Should I look at any other file in particular?
    G greg_s
    Hey @ApoorvThapliyal,
    Here is the output of the extrinsics:
    voxl2:~$ voxl-inspect-extrinsics --all
    #0:
    parent: imu_apps
    child: tracking_front
    T_child_wrt_parent: 0.037 0.000 0.001
    RPY_parent_to_child: 0.0 90.0 90.0
    R_child_to_parent: 0.000 -0.000 1.000
    1.000 0.000 -0.000
    -0.000 1.000 0.000
    #1:
    parent: imu_apps
    child: tracking_down
    T_child_wrt_parent: -0.088 -0.004 0.027
    RPY_parent_to_child: 0.0 0.0 180.0
    R_child_to_parent: -1.000 -0.000 0.000
    0.000 -1.000 -0.000
    0.000 0.000 1.000
    #2:
    parent: imu_apps
    child: tracking_rear
    T_child_wrt_parent: -0.092 0.016 0.004
    RPY_parent_to_child: 0.0 -90.0 -90.0
    R_child_to_parent: 0.000 0.000 -1.000
    -1.000 0.000 -0.000
    0.000 1.000 0.000
    #3:
    parent: imu_apps
    child: hires
    T_child_wrt_parent: 0.039 0.000 0.019
    1.000 0.000 -0.000
    -0.000 1.000 0.000
    #4:
    parent: body
    child: imu_apps
    T_child_wrt_parent: 0.029 -0.006 -0.016
    RPY_parent_to_child: 0.0 0.0 0.0
    R_child_to_parent: 1.000 -0.000 0.000
    0.000 1.000 -0.000
    0.000 0.000 1.000
    #5:
    parent: body
    child: imu_px4
    T_child_wrt_parent: 0.004 0.007 -0.016
    0.000 1.000 -0.000
    0.000 0.000 1.000
    #6:
    parent: imu_apps
    child: lepton0_raw
    T_child_wrt_parent: -0.085 0.013 0.024
    RPY_parent_to_child: 0.0 0.0 90.0
    R_child_to_parent: 0.000 -1.000 0.000
    1.000 0.000 -0.000
    0.000 0.000 1.000
    #7:
    parent: body
    child: tof
    T_child_wrt_parent: 0.066 0.009 -0.012
    RPY_parent_to_child: 0.0 90.0 180.0
    R_child_to_parent: -0.000 -0.000 1.000
    0.000 -1.000 -0.000
    1.000 0.000 0.000
    #8:
    parent: body
    child: ground
    T_child_wrt_parent: 0.000 0.000 0.033
    0.000 1.000 -0.000
    0.000 0.000 1.000
    G greg_s
    Is there anything more your teams need to investigate/troubleshoot the issue? Thanks.
  • Setup ModalAI as a vendor
    G greg_s
    Hello ModalAI Team,
    My team are interested in purchasing an additional Starling 2 drone. My company, Hitachi America Ltd., has a policy in place that requires that we setup a merchant as a vendor before we can make large purchases. We can't directly purchase from online stores before we finish this process. I have attempted to email contact@modalai.com a few times over a week without any answer. Is there a better way to contact someone to get this setup?
    Development Drones
    G greg_s
    Yes, I am dragging the point up and panning the camera around to ensure it is roughly the same height as the drone. The line drawn for the path is pretty straight and at the correctly level. The drone just ends up flying down below the point after I have move it.
    G greg_s
    @ApoorvThapliyal, if you/your team needs anymore information or data, do let me know. Thank you.
    G greg_s
    For convenience I took out the section that has the trajectory from the voxl-vision-hub logs:
    commanding: XYZ -0.4 -0.2 -1.8 yaw: 0.3
    commanding: XYZ -0.4 -0.2 -1.7 yaw: 0.3
    Received trajectory has duration 1.953539 seconds
    commanding: XYZ -0.4 -0.2 -1.0 yaw: 0.7 V: 0.0 0.0 -0.0 A: 0.1 0.0 -0.0
    commanding: XYZ -0.4 -0.2 -1.0 yaw: 0.7 V: 0.0 0.0 -0.0 A: 0.2 0.2 -0.0
    commanding: XYZ -0.4 -0.2 -1.0 yaw: 0.7 V: 0.0 0.0 -0.0 A: 0.3 0.3 -0.0
    commanding: XYZ -0.4 -0.2 -1.0 yaw: 0.7 V: 0.0 0.0 -0.0 A: 0.5 0.5 -0.0
    commanding: XYZ -0.4 -0.2 -1.0 yaw: 0.7 V: 0.0 0.0 -0.0 A: 0.7 0.6 0.0
    commanding: XYZ -0.4 -0.2 -1.0 yaw: 0.7 V: 0.1 0.1 -0.0 A: 0.9 0.7 0.0
    commanding: XYZ -0.3 -0.2 -1.0 yaw: 0.7 V: 0.1 0.1 0.0 A: 1.0 0.9 0.0
    commanding: XYZ -0.3 -0.2 -1.0 yaw: 0.7 V: 0.1 0.1 0.0 A: 1.1 0.9 0.0
    commanding: XYZ -0.3 -0.2 -1.0 yaw: 0.7 V: 0.2 0.2 0.0 A: 1.1 1.0 0.0
    commanding: XYZ -0.3 -0.2 -1.0 yaw: 0.7 V: 0.2 0.2 0.0 A: 1.2 1.0 0.0
    commanding: XYZ -0.3 -0.2 -1.0 yaw: 0.7 V: 0.3 0.2 0.0 A: 1.2 1.0 0.0
    commanding: XYZ -0.3 -0.2 -1.0 yaw: 0.7 V: 0.3 0.3 0.0 A: 1.2 1.0 0.0
    commanding: XYZ -0.3 -0.1 -1.0 yaw: 0.7 V: 0.3 0.3 0.0 A: 1.2 1.0 0.0
    commanding: XYZ -0.3 -0.1 -1.0 yaw: 0.7 V: 0.4 0.3 0.0 A: 1.1 1.0 0.0
    commanding: XYZ -0.3 -0.1 -1.0 yaw: 0.7 V: 0.4 0.4 0.0 A: 1.1 1.0 0.0
    Received trajectory has duration 1.452853 seconds
    commanding: XYZ -0.3 -0.1 -1.0 yaw: 0.7 V: 0.5 0.4 0.0 A: 1.1 0.9 0.0
    commanding: XYZ -0.2 -0.1 -1.0 yaw: 0.7 V: 0.5 0.4 0.0 A: 1.0 0.9 0.0
    commanding: XYZ -0.2 -0.1 -1.0 yaw: 0.7 V: 0.5 0.5 0.0 A: 1.0 0.9 0.0
    commanding: XYZ -0.2 -0.1 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: 0.9 0.8 0.0
    commanding: XYZ -0.2 -0.0 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: 0.8 0.7 0.1
    commanding: XYZ -0.2 -0.0 -1.0 yaw: 0.7 V: 0.6 0.6 0.0 A: 0.8 0.6 0.1
    commanding: XYZ -0.1 0.0 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: 0.7 0.5 0.1
    commanding: XYZ -0.1 0.0 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: 0.6 0.5 0.1
    commanding: XYZ -0.1 0.0 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: 0.5 0.4 0.1
    commanding: XYZ -0.1 0.1 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: 0.4 0.3 0.0
    commanding: XYZ -0.0 0.1 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: 0.3 0.2 0.0
    commanding: XYZ -0.0 0.1 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: 0.2 0.1 0.0
    commanding: XYZ 0.0 0.1 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: 0.0 0.0 0.0
    Received trajectory has duration 0.510237 seconds
    commanding: XYZ 0.0 0.1 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: -0.1 -0.1 0.0
    commanding: XYZ 0.1 0.2 -1.0 yaw: 0.7 V: 0.7 0.6 0.0 A: -0.2 -0.2 0.0
    commanding: XYZ 0.1 0.2 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: -0.2 -0.2 0.0
    commanding: XYZ 0.1 0.2 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: -0.3 -0.2 0.0
    commanding: XYZ 0.1 0.2 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: -0.4 -0.3 -0.0
    commanding: XYZ 0.1 0.2 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: -0.5 -0.4 -0.0
    commanding: XYZ 0.2 0.3 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: -0.6 -0.5 -0.0
    commanding: XYZ 0.2 0.3 -1.0 yaw: 0.7 V: 0.6 0.5 0.0 A: -0.7 -0.6 -0.0
    commanding: XYZ 0.2 0.3 -1.0 yaw: 0.7 V: 0.5 0.5 0.0 A: -0.7 -0.6 -0.0
    commanding: XYZ 0.2 0.3 -1.0 yaw: 0.7 V: 0.5 0.4 0.0 A: -0.7 -0.6 -0.0
    commanding: XYZ 0.2 0.3 -1.0 yaw: 0.7 V: 0.5 0.4 0.0 A: -0.8 -0.7 -0.0
    commanding: XYZ 0.3 0.3 -1.0 yaw: 0.7 V: 0.4 0.4 0.0 A: -0.8 -0.7 -0.0
    commanding: XYZ 0.3 0.4 -1.0 yaw: 0.7 V: 0.4 0.3 0.0 A: -0.8 -0.7 -0.0
    commanding: XYZ 0.3 0.4 -1.0 yaw: 0.7 V: 0.4 0.3 0.0 A: -0.7 -0.6 -0.0
    commanding: XYZ 0.3 0.4 -1.0 yaw: 0.7 V: 0.3 0.3 0.0 A: -0.5 -0.5 -0.0
    commanding: XYZ 0.3 0.4 -1.0 yaw: 0.7 V: 0.3 0.3 0.0 A: -0.4 -0.3 0.0
    commanding: XYZ 0.3 0.4 -1.0 yaw: 0.7 V: 0.3 0.3 0.0 A: -0.3 -0.3 0.0
    commanding: XYZ 0.3 0.4 -1.0 yaw: 0.7 V: 0.3 0.2 0.0 A: -0.4 -0.4 0.0
    commanding: XYZ 0.3 0.4 -1.0 yaw: 0.7 V: 0.3 0.2 0.0 A: -0.6 -0.5 -0.0
    commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.2 0.2 0.0 A: -0.8 -0.7 -0.0
    commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.2 0.2 0.0 A: -1.1 -0.9 -0.1
    commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.2 0.1 0.0 A: -1.3 -1.1 -0.1
    commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.1 0.1 0.0 A: -1.4 -1.1 -0.1
    commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.1 0.1 0.0 A: -1.3 -1.1 -0.1
    commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.0 0.0 0.0 A: -1.0 -0.9 -0.1
    commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.0 0.0 0.0 A: -0.7 -0.6 -0.1
    commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.0 0.0 0.0 A: -0.3 -0.2 -0.0
    commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: 0.0 0.0 0.0 A: -0.0 -0.0 -0.0
    commanding: XYZ 0.4 0.4 -1.0 yaw: 0.7 V: -0.0 -0.0 0.0 A: -0.0 -0.0 0.0
    FINISHED TRAJECTORY
    commanding: XYZ 0.4 0.5 -1.0 yaw: 0.7
    G greg_s
    I put the log file here: log100.ulg on Filebin.net
    I also put the the output from voxl-vision-hub --debug_offboard suggested by @Cliff-Wong in another post in another upload here voxl-vision-hub-log.txt on Filebin.net.
    When I attempted the flight, the drone appeared to fly to the correct X and Z coordinates, but it was close to the floor and well below the correct Y coordinate.
    Here are a couple of picture of the map and projected route:
    And a couple of the map after the drone tried to navigate and ended up below the point:
    G greg_s
    Hello ModalAI Team,
    Please let me know if there is any further information needed. So far, I haven't had the drone successfully navigate in trajectory in any version of the VOXL SDK I've tried (1.4/1.5/1.6).
    G greg_s
    Hello ModalAI Team,
    I am still trying to get the navigation working with my team's Starling 2.
    system-image: 1.8.06-M0054-14.1a-perf
    kernel: #1 SMP PREEMPT Wed Oct 22 04:13:18 UTC 2025 4.19.125
    hw platform: M0054
    mach.var: 1.0.1
    SKU: MRB-D0014-4-V1-C27-T8-M22-X0
    voxl-suite: 1.6.2
    I have updated the drone to the latest voxl version 1.6.2. I am able to fly the drone in position mode and figure 8 mode.
    I few the drone around for a couple of minutes in our testing room gathering map data. I then switched the drone into offboard_mode: trajectory. I planned a point and saw the projected path drawing a simple straight line. There are not obstacles in the way to navigate around/avoid. The drone just flew directly at the grown instead of following the path. Is there anything I should try software/settings-wise to try and get navigation working? Is there anything about the layout/appearance of a room that could cause this? Please see the attached image.
  • Starling 2 flying into ceiling
    G greg_s
    @Cliff-Wong Thanks! I will try this as soon as possible and report how it works out.
    G greg_s
    Hello @Cliff-Wong,
    Yes, I flew the drone around the room in position mode until the map was generated. I then flipped the remote to offboard with 'trajectory' set. Here are the files below:
    • VOXL Vision PX4 Configuration File
    • version: don't touch this, used to keep track of changing config file formats
    • MAVROS MAVSDK
    • en_localhost_mavlink_udp:
    •     If you are running MAVROS/MAVSDK onboard VOXL and wish to open access to
    •     PX4 through a localhost UDP port simply ensure the follow feature is
    •     enabled. This is set to true by default. This will allow one local process
    •     to communicate with PX4 via port 14551 by default, NOT 14550 which is
    •     reserved for connections outside the board. These separation prevents
    •     conflicts between the two sockets. Both MAVROS and MAVSDK can be
    •     configured to use this port.
    • localhost_udp_port_number:
    •     Port number for localhost UDP socket, default 14551
    • VIO
    • en_vio:
    •     Enable processing of VIO data from MPA to be sent to PX4 as mavlink
    •     odometry messages. Enabled by default.
    • vio_pipe:
    •     Primary pipe to subscribe to for VIO data. Must be a standard libmodal-pipe
    •     vio_data_t type. Default is qvio. If no data is available on this pipe
    •     then voxl-vision-hub will subscribe to secondary_vio_pipe instead.
    • secondary_vio_pipe:
    •     Secondary pipe to subscribe to for VIO data. Must be a standard libmodal-pipe
    •     vio_data_t type. Default is ov for openvins. If no data is available on this
    •     pipe then voxl-vision-hub will subscribe to the primary vio_pipe instead.
    •     Set to an empty string to disable. Default: ov
    • en_reset_vio_if_initialized_inverted:
    •     For VIO algorithms like qVIO that can initialize in any orientation
    •     and output their estimate of the gravity vector, we suggest leaving
    •     this enabled to allow vvpx4 to automatically send the reset signal
    •     back to the VIO pipe if VIO was initialized upside-down or sufficiently
    •     off-level. Helpful if the user powers on a drone while carrying it to
    •     the flight area and VIO starts too early.
    • vio_warmup_s:
    •     Wait this for this amount of time of having good VIO data before
    •     actually starting to send to PX4. This helps stop EKF2 getting
    •     confused if VIO flickers in and out while struggling to init.
    •     Set to 0 to disable the feature.
    • send_odom_while_failed:
    •     On by default. Send Odometry messages to PX4 with a quality of -1 when
    •     VIO indicates a failure so EKF2 can start dead reckoning.
    •     This MAY need to be turned off with PX4 versions older than 1.14
    •     since the quality metric was no implemented prior to PX4 1.14
    • APQ8096-only Features
    • en_set_clock_from_gps:
    •     Enable setting the VOXL system time to GPS time if no NTP server can be
    •     reached via network to set the time.
    • en_force_onboard_mav1_mode:
    •     Force PX4 to use onboard mode for mavlink 1 channel which is the channel
    •     apq8096 (VOXL1) uses to communicate UART Mavlink with PX4. Not applicable
    •     to qrb5165-based platforms. Sets the MAV1_MODE PX4 param.
    • en_reset_px4_on_error:
    •     Trigger a reboot of PX4 one some of PX4's unrecoverable errors,
    •     Not applicable to qrb5165
    •     Yaw estimate error & High Accelerometer Bias and both detected
    • Misc Features
    • horizon_cal_tolerance:
    •     Allowable standard deviation in roll/pitch values to consider the drone
    •     stable enough in flight to do a PX4 horizon calibration. Default is 0.45,
    •     you can increase this slightly if flying in a small indoor area or with
    •     a drone that does not hold still very well.
    •     See https://docs.modalai.com/calibrate-px4-horizon/
    • en_hitl:
    •     Enable Hardware In The Loop (HITL) testing extensions. Disabled by default.
    • offboard mode config
    • offboard_mode: The following are valid strings
    • off: VVPX4 will not send any offboard commands to PX4
    • figure_eight: Default value, VVPX4 commands PX4 to fly a figure 8 path
    • follow_tag: Drone will follow an apriltag around. Very dangerous, not
    •             recommended for customer use, for ModalAI R&D only.
    • trajectory: VVPX4 receives polynomial trajectories by pipe and commands
    •             PX4 to follow the trajectory path. Still in development.
    • backtrack:  Drone will replay, in reverse order, the last few seconds of it's
    •             position including yaw. This is useful when the drone loses
    •             the communication link and needs to get back to a place where
    •             it is able to regain the link. This mode will notice when the
    •             RC link goes away and sends a command to px4 to enter offboard mode.
    • wps:        read waypoints in local coordinate system
    • follow_tag_id:
    •     Apriltag ID to follow in follow_tag mode
    • figure_eight_move_home:
    •     Enable by default, resets the center of the figure 8 path to wherever
    •     the drone is when flipped into offboard mode. When disabled, the drone
    •     will quickly fly back to the XYZ point 0,0,-1.5 in VIO frame before
    •     starting the figure 8. Disabling this feature can be dangerous if VIO
    •     has drifted significantly.
    • wps_move_home:
    •     Enable by default, resets the center of the wps path to wherever
    • robot_radius:
    •     Robot radius to use when checking collisions within the trajectory monitor.
    •     The trajectory monitor is only active when in trajectory mode
    • collision_sampling_dt:
    •     The time step to sample along the polynomials by when checking for collisions
    •     in the collision monitor.
    • max_lookahead_distance:
    •     Maximum distance to look along the trajectory. Sensor data further out can be
    •     unrealiable so keeping this value small reduces false positives
    • backtrack_seconds:
    •     Number of seconds worth of position data to store for replay in backtrack mode.
    • backtrack_rc_chan:
    •     RC channel to monitor for transitions into and out of backtrack mode.
    • backtrack_rc_thresh:
    •     Value above which backtrack is considered enabled on the configured RC channel.
    • Fixed Frame Tag Relocalization
    • en_tag_fixed_frame:
    •     Enable fixed frame relocalization via voa_inputs.
    •     See: https://docs.modalai.com/voxl-vision-px4-apriltag-relocalization/
    • fixed_frame_filter_len:
    •     Length of the moving average filter to use for smooth relocalization
    •     when a tag is detected. Default is 5, a longer filter will result in
    •     smoother behavior when a new tag comes into view. Set to 1 to do no
    •     filtering at all and assume every tag detection is accurate.
    • en_transform_mavlink_pos_setpoints_from_fixed_frame:
    •     When enabled, mavlink position_target_local_ned_t commands received on
    •     via UDP will be assumed to be in fixed frame and are then transformed
    •     to local frame before being sent to PX4. This allows offboard mode
    •     position commands from MAVROS/MAVSDK to be in fixed frame relative to
    •     voa_inputs even though PX4/EKF2 operates in local frame relative to where
    •     VIO initialized.
    • Collision Prevention (VOA)
    • Settings for configuring Mavlink data sent to Autopilot for VOA
    • en_voa:
    •     Enable processing of DFS and TOF data to be sent to PX4 as mavlink
    •     obstacle_distance messages for collision prevention in position mode.
    • voa_lower_bound_m & voa_upper_bound_m:
    •     VOA ignores obstacles above and below the upper and lower bounds.
    •     Remember, Z points downwards in body and NED frames, so the lower bound
    •     is a positive number, and the upper bound is a negative number.
    •     Defaults are lower: 0.15  upper: -0.15 Units are in meters.
    • voa_memory_s:
    •     number of seconds to keep track of sensor readings for VOA
    •     default: 1.0
    • voa_max_pc_per_fusion:
    •     maximum number of sensor samples (points clouds) to fuse for every
    •     mavlink transmision. Default is 100 so that voa_memory_s determines
    •     when to discard old data instead. set this to 1 if you only want to use
    •     the most recent sensor sample for example. If you start severly limiting
    •     the number of point clouds used per fusion, you will also need to lower
    •     voa_pie_threshold.
    • voa_pie_min_dist_m:
    •     minimum distance from the drone's center of mass to consider a sensor
    •     sample a valid point for mavlink transmission.
    • voa_pie_max_dist_m:
    •     sample a valid point for mavlink transmission. Note this is and can be
    •     different from the individual sensor limits.
    • voa_pie_under_trim_m:
    •     VOA discards points in a bubble under the drone with this radius.
    •     default 1.0. This helps the drone approach an obstacle, stop
    •     ascend, and continue forward smoothly over the top.
    • voa_pie_threshold:
    •     Minimum number of points that must appear in and adjacent to a pie
    •     segment to consider it populated. Default 3
    • voa_send_rate_hz:
    •     Rate to send VOA mavlink data to autopilot. Independent from the
    •     sensor input rates. Default 20
    • voa_pie_slices:
    •     number of slices to divide the 360 degree span around the drone into.
    •     default 36 (10 degree slices)
    • voa_pie_bin_depth_m:
    •     Radial depth of each bin during the pie binning step. Default 0.15
    • Collision Prevention (VOA) Input Configuration
    • Settings for configuring pipe data sources for VOA
    • voa_inputs:
    •     Array of pipes to subscribe to for use with VOA, up to 10 supported
    •     Each entry has 4 fields:
    • Fields:
    • enabled: true or false, it's safe to leave this enabled when the pipe is missing
    • type: can be point_cloud, tof, or rangefinder
    • input_pipe: pipe name, e.g. stereo_front_pc, rangefinders, tof, etc
    • frame: frame of reference, should be listed in /etc/modalai/extrinsics/conf
    • max_depth: trim away points with z greater than this
    • min_depth: trim away points with z less than this
    • cell_size: size of 3d voxel grid cells, increase for more downsampling
    • threshold: num points that must exist in or adjacent to a cell to consider it
    •                  populated, set to 1 to disable threasholding
    • x_fov_deg: FOV of the sensor in the x direction, typically width
    • y_fov_deg: FOV of the sensor in the y direction, typically height
    • conf_cutoff: discard points below this confidence, only applicable to TOF
    "config_file_version": 1,
    "en_localhost_mavlink_udp": false,
    "localhost_udp_port_number": 14551,
    "en_vio": true,
    "vio_pipe": "qvio",
    "secondary_vio_pipe": "ov",
    "vfc_vio_pipe": "ov",
    "vio_warmup_s": 3,
    "send_odom_while_failed": true,
    "horizon_cal_tolerance": 0.5,
    "en_hitl": false,
    "offboard_mode": "trajectory",
    "follow_tag_id": 0,
    "figure_eight_move_home": true,
    "collision_sampling_dt": 0.1,
    "max_lookahead_distance": 1,
    "backtrack_seconds": 60,
    "backtrack_rc_chan": 8,
    "backtrack_rc_thresh": 1500,
    "wps_move_home": true,
    "wps_stride": 0,
    "wps_timeout": 0,
    "wps_damp": 1,
    "wps_vfc_mission": true,
    "wps_vfc_mission_loop": false,
    "wps_vfc_mission_to_ramp": 25,
    "wps_vfc_mission_to_kp": 0.10000000149011612,
    "wps_vfc_mission_cruise_speed": 1,
    "en_tag_fixed_frame": false,
    "fixed_frame_filter_len": 5,
    "en_transform_mavlink_pos_setpoints_from_fixed_frame": false,
    "vfc_rate": 100,
    "vfc_rc_chan_min": 980,
    "vfc_rc_chan_max": 2020,
    "vfc_thrust_ch": 3,
    "vfc_roll_ch": 1,
    "vfc_pitch_ch": 2,
    "vfc_yaw_ch": 4,
    "vfc_submode_ch": 6,
    "vfc_alt_mode_rc_min": 0,
    "vfc_alt_mode_rc_max": 0,
    "vfc_flow_mode_rc_min": 0,
    "vfc_flow_mode_rc_max": 0,
    "vfc_hybrid_flow_mode_rc_min": 0,
    "vfc_hybrid_flow_mode_rc_max": 0,
    "vfc_position_mode_rc_min": 0,
    "vfc_position_mode_rc_max": 2100,
    "vfc_traj_mode_rc_min": 0,
    "vfc_traj_mode_rc_max": 0,
    "vfc_yaw_deadband": 30,
    "vfc_vxy_deadband": 50,
    "vfc_vz_deadband": 150,
    "vfc_min_thrust": 0,
    "vfc_max_thrust": 0.800000011920929,
    "vfc_tilt_max": 0.43599998950958252,
    "vfc_yaw_rate_max": 3,
    "vfc_thrust_hover": 0.5,
    "vfc_vz_max": 1,
    "vfc_kp_z": 5.2899999618530273,
    "vfc_kd_z": 5.9800000190734863,
    "vfc_vxy_max": 3,
    "vfc_kp_xy": 0.63999998569488525,
    "vfc_kd_xy": 2.559999942779541,
    "vfc_kp_z_vio": 5.2899999618530273,
    "vfc_kd_z_vio": 5.9800000190734863,
    "vfc_kp_xy_vio": 3.2400000095367432,
    "vfc_kd_xy_vio": 3.9600000381469727,
    "vfc_w_filt_xy_vio": 10,
    "vfc_w_filt_xy_flow": 3,
    "vfc_vel_ff_factor_vio": 0.899999976158142,
    "vfc_xy_acc_limit_vio": 2.5,
    "vfc_max_z_delta": 3,
    "vfc_att_transition_time": 0.5,
    "vfc_stick_move_threshold": 30,
    "vfc_flow_transition_time": 1,
    "vfc_q_min": 10,
    "vfc_points_min": 7,
    "vfc_en_submode_announcement": 1,
    "vfc_disable_fallback": false,
    "vfc_traj_csv": "/data/voxl-vision-hub/traj.csv",
    "en_voa": true,
    "voa_upper_bound_m": -0.15000000596046448,
    "voa_lower_bound_m": 0.15000000596046448,
    "voa_voa_memory_s": 1,
    "voa_max_pc_per_fusion": 100,
    "voa_pie_max_dist_m": 20,
    "voa_pie_min_dist_m": 0.25,
    "voa_pie_under_trim_m": 1,
    "voa_pie_threshold": 3,
    "voa_send_rate_hz": 20,
    "voa_pie_slices": 36,
    "voa_pie_bin_depth_m": 0.15000000596046448,
    "voa_inputs": [{
    "enabled": true,
    "type": "point_cloud",
    "input_pipe": "dfs_point_cloud",
    "frame": "stereo_l",
    "max_depth": 8,
    "min_depth": 0.300000011920929,
    "cell_size": 0.079999998211860657,
    "threshold": 4,
    "x_fov_deg": 68,
    "y_fov_deg": 56,
    "conf_cutoff": 0
    "enabled": true,
    "input_pipe": "stereo_front_pc",
    "frame": "stereo_front_l",
    "max_depth": 8,
    "threshold": 4,
    "x_fov_deg": 68,
    "y_fov_deg": 56,
    "conf_cutoff": 0
    "enabled": true,
    "input_pipe": "stereo_rear_pc",
    "frame": "stereo_rear_l",
    "max_depth": 8,
    "threshold": 4,
    "x_fov_deg": 68,
    "y_fov_deg": 56,
    "conf_cutoff": 0
    "enabled": true,
    "type": "tof",
    "input_pipe": "tof",
    "frame": "tof",
    "max_depth": 6,
    "min_depth": 0.15000000596046448,
    "threshold": 3,
    "x_fov_deg": 106.5,
    "y_fov_deg": 85.0999984741211,
    "conf_cutoff": 125
    "enabled": true,
    "type": "rangefinder",
    "input_pipe": "rangefinders",
    "frame": "body",
    "max_depth": 8,
    "threshold": 4,
    "x_fov_deg": 68,
    "y_fov_deg": 56,
    "conf_cutoff": 0
    • This file contains configuration that's specific to voxl-open-vins-server.
    • NOTE: all time variables are measured in seconds
    • OpenVins param breakdown:
    • do_fej: whether or not to do first estimate Jacobians
    • imu_avg: whether or not use imu message averaging
    • use_rk4_integration: if we should use Rk4 imu integration.
    • cam_to_imu_refinement: whether or not to refine the imu-to-camera pose
    • cam_intrins_refinement: whether or not to refine camera intrinsics
    • cam_imu_ts_refinement: whether or not to calibrate cam to IMU time offset
    • max_clone_size: max clone size of sliding window
    • max_slam_features: max number of estimated SLAM features
    • max_slam_in_update: max number of SLAM features in a single EKF update
    • max_msckf_in_update: max number of MSCKF features used at an image timestep
    • Feature Reps can be any of the following:
    • 0 - GLOBAL_3D
    • 1 - GLOBAL_FULL_INVERSE_DEPTH
    • 2 - ANCHORED_3D
    • 3 - ANCHORED_FULL_INVERSE_DEPTH
    • 4 - ANCHORED_MSCKF_INVERSE_DEPTH
    • 5 - ANCHORED_INVERSE_DEPTH_SINGLE
    • feat_rep_msckf: (int) what representation our msckf features are in
    • feat_rep_slam: (int) what representation our slam features are in
    • cam_imu_time_offset: time offset between camera and IMU
    • slam_delay: delay that we should wait from init before estimating SLAM features
    • gravity_mag: gravity magnitude in the global frame
    • init_window_time: amount of time to initialize over
    • init_imu_thresh: variance threshold on our accel to be classified as moving
    • imu_sigma_w: gyroscope white noise (rad/s/sqrt(hz))
    • imu_sigma_wb: gyroscope random walk (rad/s^2/sqrt(hz))
    • imu_sigma_a: accelerometer white noise (m/s^2/sqrt(hz))
    • imu_sigma_ab: accelerometer random walk (m/s^3/sqrt(hz))
    • imu_sigma_w_2: gyroscope white noise covariance
    • imu_sigma_wb_2: gyroscope random walk covariance
    • imu_sigma_a_2: accelerometer white noise covariance
    • imu_sigma_ab_2: accelerometer random walk covariance
    • ****_chi2_multiplier: what chi-squared multipler we should apply
    • ****_sigma_px: noise sigma for our raw pixel measurements
    • ****_sigma_px_sq: covariance for our raw pixel measurements
    • use_stereo: if feed_measurement_camera is called with more than one
    • image, this determines behavior. if true, they are treated as a stereo
    • pair, otherwise treated as binocular system
    • if you enable a camera with stereo in the name, this will be set to true
    • automatically
    • try_zupt: if we should try to use zero velocity update
    • zupt_max_velocity: max velocity we will consider to try to do a zupt
    • zupt_only_at_beginning: if we should only use the zupt at the very beginning
    • zupt_noise_multiplier: multiplier of our zupt measurement IMU noise matrix
    • zupt_max_disparity: max disparity we will consider to try to do a zupt
    • NOTE: set zupt_max_disparity to 0 for only imu based zupt, and
    • zupt_chi2_multipler to 0 for only display based zupt
    • num_pts: number of points we should extract and track in each image frame
    • fast_threshold: fast extraction threshold
    • grid_x: number of column-wise grids to do feature extraction in
    • grid_y: number of row-wise grids to do feature extraction in
    • min_px_dist: after doing KLT track will remove any features closer than this
    • knn_ratio: KNN ration between top two descriptor matchers for good match
    • downsample_cams: will half image resolution
    • use_nultithreading: if we should use multi-threading for stereo matching
    • use_mask: if we should load a mask and use it to reject invalid features
      "en_auto_reset": true,
      "auto_reset_max_velocity": 20,
      "auto_reset_max_v_cov_instant": 0.10000000149011612,
      "auto_reset_max_v_cov": 0.10000000149011612,
      "auto_reset_max_v_cov_timeout_s": 0.5,
      "auto_reset_min_features": 1,
      "auto_reset_min_feature_timeout_s": 3,
      "auto_fallback_timeout_s": 3,
      "auto_fallback_min_v": 0.600000023841858,
      "en_cont_yaw_checks": false,
      "fast_yaw_thresh": 5,
      "fast_yaw_timeout_s": 1.75,
      "do_fej": true,
      "imu_avg": true,
      "use_rk4_integration": true,
      "cam_to_imu_refinement": true,
      "cam_intrins_refinement": true,
      "cam_imu_ts_refinement": true,
      "max_clone_size": 8,
      "max_slam_features": 35,
      "max_slam_in_update": 10,
      "max_msckf_in_update": 10,
      "feat_rep_msckf": 4,
      "feat_rep_slam": 4,
      "cam_imu_time_offset": 0,
      "slam_delay": 1,
      "gravity_mag": 9.80665,
      "init_window_time": 1,
      "init_imu_thresh": 1,
      "imu_sigma_w": 0.00013990944749616306,
      "imu_sigma_wb": 4.1189724174615527e-07,
      "imu_sigma_a": 0.0038947538150776763,
      "imu_sigma_ab": 5.538346201712153e-05,
      "msckf_chi2_multiplier": 1,
      "slam_chi2_multiplier": 40,
      "zupt_chi2_multiplier": 1,
      "refine_features": true,
      "pyr_levels": 6,
      "grid_x": 5,
      "grid_y": 5,
      "msckf_sigma_px": 1,
      "slam_sigma_px": 1.8,
      "zupt_sigma_px": 1,
      "try_zupt": true,
      "zupt_max_velocity": 0.03,
      "zupt_only_at_beginning": true,
      "zupt_noise_multiplier": 1,
      "zupt_max_disparity": 8,
      "init_dyn_use": false,
      "triangulate_1d": false,
      "max_runs": 5,
      "init_lamda": 0.001,
      "max_lamda": 10000000000,
      "min_dx": 1e-06,
      "min_dcost": 1e-06,
      "lam_mult": 10,
      "min_dist": 0.1,
      "max_dist": 60,
      "max_baseline": 40,
      "max_cond_number": 600000,
      "use_mask": false,
      "use_stereo": false,
      "use_baro": false,
      "num_opencv_threads": 4,
      "fast_threshold": 15,
      "histogram_method": 1,
      "knn_ratio": 0.7,
      "takeoff_accel_threshold": 0.5,
      "takeoff_threshold": -0.1,
      "use_stats": false,
      "max_allowable_cep": 1,
      "en_force_init": false,
      "en_force_ned_2_flu": false,
      "en_imu_frame_output": false,
      "track_frequency": 15,
      "publish_frequency": 5,
      "en_vio_always_on": true,
      "en_ext_feature_tracker": false,
      "en_gpu_for_tracking": true,
      "num_features_to_track": 20,
      "raansac_gn": false,
      "raansac_tri": true,
      "en_thermal_enhance": false,
      "en_overlay_landscape": false,
      "thermal_brightness": 1,
      "thermal_brightness_bos": 1
    G greg_s
    Hello. Checking in again if assistance can be provided and/or if more information is needed.
    G greg_s
    Hello. Just checking to see if there is any more data I can provide to help determine the issue. Is there some configuration that allows the drone to fly in the figure-8 without issue but not navigate within the map that has been generated?
    G greg_s
    @tom Thank you for the assistance on the previous topic. Is there a best way to diagnosis the navigation? The path appears fine, but the drone few straight upward into the ceiling before falling and breaking one of main battery clips next to the LED board.
