Caio Licínio Vasconcelos PantarottoC
@Caio Licínio Vasconcelos Pantarotto
  • Hires_snapshot snapshot-no-save is saving ?
    Caio Licínio Vasconcelos PantarottoC Caio Licínio Vasconcelos Pantarotto
    @Moderator said in Hires_snapshot snapshot-no-save is saving ?:
    voxl-camera-server
    What is the easiest way to update it ? I looks like apt update is not doing the job right.
    VOXL SDK and Software mpa
    Okay. I found the problem... its snapshot_no_save (instead of snapshot-no-save)... I believe the website docs and the internal terminal info have to be updated.. Thanks... Im just leaving the topic for people who might have similar issue.
    Im using a Starling drone... and recently updated.
    I believe there is a bug with the command voxl-send-command hires_snapshot snapshot-no-save... when I use it it still saves to the folder :/data/snapshots.. is this the expected behaviour ?
  • Voxl-mapper VIO
    In my current project I need a very accurate position estimation.. I wonder if the voxl-mapper service provides a better accurate position estimation than the VIO, since it probably uses a SLAM on top of the VIO. If so how can I acquire this data ? Thank You
  • TOF and High Res Intrinsics
    @Darshit-Desai Then I believe you cannot do anything.. .the TOF is limited to certain surfaces and texture...
    Development Drones starling
    @Darshit-Desai If you have the 3D point cloud and you need to project it to a camera you need the intrinsics of the camera and the extrinsic... That's where I used the instrisic pf the RGB, on the image I sent you each point is a XYZ point projected to the RGB.. so with that you have the location in 3D space of the objects the camera is seeing.
    @Caio-Licínio-Vasconcelos-Pantarotto The point cloud has less resolution than the depth view given by the TOF ? I didn't really explored it..
    What do you mean by "running an object detector on a different resolution image and matching it with a sparse point cloud for getting 3d coordinates is inaccurate" ? You wanna use object detection on the RGB right ? Why you say that using the space point cloud is inaccurate ? Sorry I don't know much about this..
    @Caio-Licínio-Vasconcelos-Pantarotto You also need to permute (1,0,2) the coordinates as they come from the sensor.. to be the way opencv expects
  • A question about VIO reference system.
    There is one thing on the VIO reference system that made me confused... We have T_imu_wrt_vio which is "Translation of the IMU with respect to VIO frame in meters", and we have T_cam_wrt_imu which is "Location of the optical center of the camera with respect to the IMU." I just want to clarify...
    1. I would think that T_cam_wrt_imu (Also the rotation) is a fixed number (since the vector between the camera and the imu should be constant in the fixed frame of the drone).. and when I measured it on the Starling indeed is something like (0.026 0.007 0.024) most of the time.. but the T and R (0 45 90) changes slightly during movement.. is this because the IMU itself moves internally a bit ?
    2. is the T_imu_wrt_vio the XYZ global position of the IMU that is given by the VIO algorithm ? So it should be interpreted as the position in space of the drone... Sorry the sentence "with respect to VIO frame" confused me a bit...
    @Darshit-Desai I'm using the point cloud data of the TOF and projecting it to the RGB frame.. I calculated the RGB intrinsics using OpenCV. You need to use a rotation matrix diag[-1,1,1] and the translation you have to manually adjust because the TOF sensor is located (on the Starling) with a XYZ translation with respect to the RGB.. Its working more or less ok.. I believe this way is better because with the 3D point cloud you don't have to play with 2 cameras intrinsics..
  • TOF_IR
    @Moderator On the Starling.. is the TOF point cloud with relation to the high res camera ? or to the center of the body ? Because I believe to project from the point cloud to the high res frame I would need only the intrinsics of the high res and also the position with relation the where the (0,0,0) of the point cloud really is, no ?
  • High Res Snapshot Corrupted
    @Moderator I'm using a straight out of the box Starling.. with updated software..
    @James-Strawson thank you for the response
  • TOF_IR
    On the Portal we can see an Image Tof_LR, TOF_Depth and TOF_conf.. TOF_LR looks like its projecting the tof point cloud into the camera... Is that what is happening ? I would like to know how can I do that.. I believe I would need precisely the Extrinsics of the TOF and the High REs Camera.. is there any source code that shows how this is done ? I need to superimpose the TOF depth data into the camera frame.
    Unrelated to this... also noticed a dark ring border effect on the bottom of the image.. is this a common effect for this camera ?
    I believe the high resolution snapshot is delivering a corrupted image...
    I run voxl-send-command hires_snapshot snapshot and after pull the snapshot will adb pull... My MacOS native photo viewer can open the picture with no problem, but when opening on VScode I could see in the end of the picture 2 lines of black and white pixels... when trying to open using a python library I noticed that PIL cannot open, MatPlotLib cannot open, only opencv can open it, but it send a message Premature end of JPEG file. Is this a know problem with the snapshot service ? or is this corruption happening on adb pull ?
    Are the intrinsics matrices of the TOF and High Resolution cameras available anywhere ?
