  2. VOXL Compute & Autopilot
  3. VOXL 2
  4. High Res Snapshot Corrupted
6 Posts 3 Posters 1.3k Views
  • Caio Licínio Vasconcelos PantarottoC Offline
    I believe the high resolution snapshot is delivering a corrupted image...
    I run voxl-send-command hires_snapshot snapshot and after pull the snapshot will adb pull... My MacOS native photo viewer can open the picture with no problem, but when opening on VScode I could see in the end of the picture 2 lines of black and white pixels... when trying to open using a python library I noticed that PIL cannot open, MatPlotLib cannot open, only opencv can open it, but it send a message Premature end of JPEG file. Is this a know problem with the snapshot service ? or is this corruption happening on adb pull ?
    Caio Licínio Vasconcelos PantarottoC 1 Reply Last reply
    • Caio Licínio Vasconcelos PantarottoC Caio Licínio Vasconcelos Pantarotto
      @Caio-Licínio-Vasconcelos-Pantarotto
      Unrelated to this... also noticed a dark ring border effect on the bottom of the image.. is this a common effect for this camera ?
      ModeratorM 1 Reply Last reply
        @Caio-Licínio-Vasconcelos-Pantarotto Can you please help with more details, similar to the details found here?
        • James StrawsonJ Offline
          James Strawson
          @Caio-Licínio-Vasconcelos-Pantarotto said in High Res Snapshot Corrupted:
          We are aware of the issue and are working on it.
            @James-Strawson thank you for the response
            • ModeratorM Moderator
              @Moderator I'm using a straight out of the box Starling.. with updated software..
