    High Res Snapshot Corrupted
    • Caio Licínio Vasconcelos PantarottoC
      I believe the high resolution snapshot is delivering a corrupted image...
      I run voxl-send-command hires_snapshot snapshot and after pull the snapshot will adb pull... My MacOS native photo viewer can open the picture with no problem, but when opening on VScode I could see in the end of the picture 2 lines of black and white pixels... when trying to open using a python library I noticed that PIL cannot open, MatPlotLib cannot open, only opencv can open it, but it send a message Premature end of JPEG file. Is this a know problem with the snapshot service ? or is this corruption happening on adb pull ?
      Caio Licínio Vasconcelos PantarottoC 1 Reply Last reply Reply Quote 0
        Caio Licínio Vasconcelos Pantarotto @Caio Licínio Vasconcelos Pantarotto
        @Caio-Licínio-Vasconcelos-Pantarotto
        Unrelated to this... also noticed a dark ring border effect on the bottom of the image.. is this a common effect for this camera ?
        • ModeratorM
          Moderator ModalAI Team @Caio Licínio Vasconcelos Pantarotto
          @Caio-Licínio-Vasconcelos-Pantarotto Can you please help with more details, similar to the details found here?
          • James StrawsonJ
            James Strawson ModalAI Team
            @Caio-Licínio-Vasconcelos-Pantarotto said in High Res Snapshot Corrupted:
            We are aware of the issue and are working on it.
              Caio Licínio Vasconcelos Pantarotto @James Strawson
              @James-Strawson thank you for the response
                Caio Licínio Vasconcelos Pantarotto @Moderator
                @Moderator I'm using a straight out of the box Starling.. with updated software..
